06-07-09, 04:33 PM
#931 (permalink)
Red alert! Red alert! Its my mom's b-day tues and my step-daughter's 8th graduation Wed. Monday or thurs work for ya?
06-08-09, 09:09 AM
#932 (permalink)
Monday would be best. I'll get Dora on the ground today and work on the line lock tomorrow. See you at 6pm today. Thanks again.
build-up: Family Haulin' FJ60
06-08-09, 09:57 AM
#933 (permalink)
Cool, see ya tonight...
06-09-09, 09:14 PM
#934 (permalink)
KOOL AAROW
LOOKIN good I love my polys .. I wish I was closer to you guys I'd come over and play
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
06-09-09, 09:41 PM
#935 (permalink)
they got 4wheelparts out here... why dont cha transfer out here then?
06-11-09, 03:04 PM
#936 (permalink)
weekly update
Whew! It's been a long couple of days and I feel like I got a lot done even though I didn't get everything done that I wanted.
I clearanced the front hoop braces a little more for the 7100s since they are a little larger diameter.
Passenger
Driver
Since I didn't put washers behind the studs on the rear I also needed take a little off the heads so the rim would be flush up against the spacer.
This is the model number for my 7100s. The 99 at the end is their code for custom valving and they printed the valving on the label.
Looks like I'm missing a couple pics from my upload last night. I'll post what I got. Anyways here one of the pics with the shocks mounted.
My wimpy lower return heater hose wasn't cutting it so I got some gates green stripe that has a much thicker wall and it holds it's shape much better. I tried to replace that 90 fitting preiviously but I couldn't get it to budge so the next time I do a coolant flush I'll have to give it another shoot.
That got Dora drivable and a trip out to Brokenpart's allowed me to test the new shocks and the rear locker. The shocks work great and the dampening feels really good; firm but not stiff. I went to Zack's for some more bending and to borrow his front bumper. In deciding how to mount it we ran into a problem since it's made to mount inside the frame and I put a cross member there. Out came the plasma! This works out anyways because the cross member has been pinched (missing pic) due to a couple good pulls and I want to incorporate a receiver into the new front bumper anyways.
I had to clearance a few things to get the bumper to side into the frame horns but Zack will tell you it's the grease that made the difference. We played with depth since the original mounting holes would place the bumper too close to my tires. We used the mounts I made for the original bumper to extend the frame horns. They already had the holes cut into them so it worked out great.
Bumper mounted
06-11-09, 03:33 PM
#937 (permalink)
KOOL AAROW
I PUT IN FOR THAT STORE BEFORE IT OPENED
GIT-R-DONE!!!!
TLCA #15374
www.jkcustoms.com
06-11-09, 04:13 PM
#938 (permalink)
weekly update cont.
Once the bumper was mounted we bent some tube for the rear quarter protection. By then we had lost our daylight so I grabbed the pieces to work on them the next day. Zack started asking if I had this or that to take with me on the trail and I ended up going home with a bunch more recovery gear to sweeten the deal! Thanks again and much appreciation!
I decided to cover the back-up lights since those aren't working right now anyways. I tacked them all together to get what I wanted, removed the bumper and welded it up. I slapped on a 20ft paint job and put the bumper back on. With my  gone I had to go bug my neighbors to give me a hand sliding it back in the frame. I'll have to get pics of it completed but I like how the protection turned out.
With the rear bumper complete I turned my attention to the line lock. I went to Portland Oil Filter Service and asked them about adapting 1/4" line to 3/16" line. I walked away with a couple adapters and some brake line. I borrowed a bender and flaring tool from the local auto parts place and started getting things ready. They didn't have a small pipe cutter but my other neighbor did and that makes cutting lines 100 times better for flaring.
These ends were cut off to use compression fittings for the line lock valve.
Compression fittings are easy and effective. There are three pieces to it and that's the valve I'm using. I lucked out and got these for free which is why I went to the hassle of adapting to 1/4" line.
This is where I put my line lock and how I mounted it.
For plumbing I got an adapter to 1/4" for my master and ran the line to the line lock and then back to tie into the factory line. I bought an adapter for 3/16" line to 1/4" thread and used a union to connect the two. I needed to cut off the 10mm fitting on the factory line, put on the new fitting and flare the tube.
Flaring the line
The inverted flare turned out fine.
This is the 1/4" union to connect the 1/4" line I ran to and from the line lock to the factory line.
I again bugged the neighbor to help bleed the rear brakes so I could test for leakage and see if it actually worked. Works like a dream!
I picked up some 2"x1.5" tube to make some cross members for my skid plate. I didn't get started on this until yesterday evening so I was running out of time quickly. I cut, shaped, and repatched a couple ideas and decided on this.
I then literally just cut some 1/4" plate out and slapped it on. Don't know if it will hold and I'll definitely have to redo this later but at least I was able to get something underneath there.
I've been looking for some 16" rims on the cheap for a spare and a posting showed up yesterday so I grabbed them. It was listed as 16". Broke the beads and pulled out the old rim from one of the boggers and when I slipped in the rim I realized it was a 15 incher.  So now I have to try and find a rim before next wednesday. I work until saturday, leave sunday, and report to the trail on wednesday. I'm hoping I can find something on Monday that will work.
So I didn't get the antiwrap bar put on, didn't get the CB installed (didn't find the antenna at the local truck stop anyways), didn't get a sleeping plateform made so we'll be bringing a tent, didn't get my ready welder wired up but I think I'll sacrafice some jumper cables for that because I'm definitely taking that with me, and I still need a rim for my spare.
I'll be packing up the next two days and am excited to wheel the rubicon.
06-11-09, 04:27 PM
#939 (permalink)
Turbo Diesel Lover
Wou Mike.. you can open an off road shop anyday !
Le me underestand something .. did you intercept your brake line ( to the rears ) with the line lock ?
Maybe I miss something but seems you take the line from the MC ?
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
06-11-09, 04:55 PM
#940 (permalink)
I was going to splice into the rear brakes line along the frame but decided to go out of the master (rear port) to the line lock and then from the line lock to the factory line. This way the 1/4" line is all first and I'm not stepping up in line size in the middle of the 3/16" run. This also only introduces only two more connection points than I had before. The fewer connections the better I figure.
06-11-09, 09:04 PM
#941 (permalink)
lookin good man... make sure to take lots of pics!!!!
06-11-09, 09:41 PM
#942 (permalink)
Rum Runnin'
Sweet! Like Zach said, take more than enough pics
The 4BT weighs less than the 2F, right? Would you recommend the same valving you have for a 2F 60? How wide is the top shock bushing?
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
06-12-09, 09:45 AM
#943 (permalink)
Turbo Diesel Lover
Thanks Mike .. I got it .. can you share where do you got your lock valve .. ? there was not 3/16 option ?
06-12-09, 10:34 AM
#944 (permalink)
I'll try to get some pics of the top mount and some numbers, I'll be focusing on packing tonight and tomorrow before I leave so I might not get that to you right away. ~1 1/2" seems to feel about right.
The 4bt is pretty close to the same weight but all the other stuff I have adds more weight namely the tranny and doubler plus the protection I've been adding. I'll report once I get some seat time on the trail but I'd lean towards a stiffer valving. I think their stiffest standard is 360/80 and is probably a good starting ground. If you are really picky you can change the valving yourself by getting different shims that'll change the rates. Again I'll have a better feel after my 630 mile trip on sunday and then my week at rubicon. So let me get some more impressions before I commit to anything.
06-12-09, 10:41 AM
#945 (permalink)
Turbo Diesel Lover
Mike .. i didn't remember if you are running a PS oil cooler .. ?
How it's working your PS with those tires .. ?
06-12-09, 10:41 AM
#946 (permalink)
I got my valve from a friend at work. I really didn't search that hard before I talked to him so there might be valves that go down to 3/16. The SwageLok site seems to show they are available in that size. I'm using a 40 series valve.
06-12-09, 10:47 AM
#947 (permalink)
I'm not running a cooler. I do have a separate reservoir so that helps a tiny bit but a cooler would be a good idea. I'd like to get a little more flow out of the pump by drilling out the valve one step but it works fine for now. The rig just never seems to get finished.
06-12-09, 11:05 AM
#948 (permalink)
Rum Runnin'
Thanks for the info! I was asking the top eye width to see if it would fit in the Ford towers I just bought.
Good luck on your trip!
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
06-12-09, 03:53 PM
#949 (permalink)
Here are the missing pics from the weekly update.
7100 bilsteins. I'd like to move the reservoir but for now it works.
Front crossmember that I added before the plasma was fired up. It was just c-channel and you can see where it got pinched from wraping a strap.
Other pic of Zack's front bumper.
Other angle of the rear quarter protection during fitting.
Cutting the factory line to put on the new 1/4" adapter.
I just picked up a bigger storage container during lunch for fluids/parts/tools to go in the back of the cruiser. Hope to get it packed up tonight.
06-12-09, 04:46 PM
#950 (permalink)
Turbo Diesel Lover
Finish .. are you serious .. ?
After 12 years with Tencha I can barely let it without work a month .. there is always something to do ( a leak a nut .. a fix .. etc )
I believe looking in a yunk yard will be pretty easy and cheap source a good tranny ( from a auto tranny ) cooler .. if you see one, pic another to me
06-12-09, 05:03 PM
#951 (permalink)
Turbo Diesel Lover
I miss your answer .. thanks .. I was looking at the website .. thought the 40G series are the best option . ?
06-14-09, 10:25 AM
#952 (permalink)
Awsome!
Yello! just read your whole garage, the rig is crazy... I really like your way of solving things, and the fab skills are just gettin better and better! Also going to do the rear ass chop, and the sliders, think i'm gonna copy your way of doin it, as it looks clean and functional!
And for the engine and mechanical...wild! looks like you got a nice setup of friends and helpful network, thats extremly important, for me the whole car-thing is not just show-off, but also the whole social thing, wrenching, wheeling, trailing and fabbing! Keep it up!  The best from norway!
06-21-09, 02:41 PM
#953 (permalink)
Thanks for checking it out. The LC community is full of great people.
The family and I are driving back to Portland tomorrow and I'm just starting to work on videos and pics of the rubicon trip. Almost 120 mins of video and we filled up our camera card with over 450 pics so there is a lot to look through. It was perfect weather for a incredible trail and Dora wheeled amazing. Everything just worked.
06-21-09, 04:57 PM
#954 (permalink)
Rum Runnin'
Let us know how well those shocks worked!!
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
06-21-09, 07:50 PM
#955 (permalink)
did you manage to sell the bumper?
Glad everything worked my friend. NOW GET TO POSTING PICS AND VID!
06-21-09, 08:04 PM
#956 (permalink)
Mike, great to meet you dude! You and the diesel spanked the Rubicon!!
Dylan
'85 FJ60 | SOA | ARB | M8274-50 | Sliders | Aussie'd | H55F | 4.7 Toybox | 4.88s | Custom Crap
06-22-09, 06:03 AM
#957 (permalink)
Right on!!!!!
Jealous yet smiling in Indiana!!!!!
john
06-22-09, 02:20 PM
#958 (permalink)
Turbo Diesel Lover
Turbo Diesel show in the Rubicon trail .. I wanna see it .. !
06-22-09, 07:55 PM
#959 (permalink)
KOOL AAROW
lookin good cant wait for wheelin pics
GIT-R-DONE!!!!
TLCA #15374
www.jkcustoms.com
06-23-09, 08:26 AM
#960 (permalink)
Wow! You've put in many hours and I like what I see
HJ60 2H Diesel Donkey
Pretoria, South Africa
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
