05-05-09, 12:22 PM
#871 (permalink)
Nope, all they really care about here is sticking it up your tail pipe or plugging in to your computer (96 and newer) and then collecting their fee.
I do understand this isn't a legal parking brake (not a separate system). This is going to be the easiest way to pass the tech inspection for a TLCA event.
Things to get done before Rubithon include:
- upgrade to PP rear axles - ordered this week
- rear locker - ordered this week
- parking brake for tech inspection - researching line locks now
- finish rear quarter protection - tube bending on the 17th
- front bumper and fender protection -tube bending on the 17th
- skid plate - started cutting scrap
- wiring for ready welder - got the cable just need some clamps and a connector
- CB radio and antenna - researching
- build rear platform for sleeping in the rig
- 16" rims for spare tire - searching
- replace front shocks - ordered this week
- build anti wrap bar - research done and ready to build, just need to order a JJoint (ordered today), bushings ordered last week, copy brokenparts wrap brackets using his plasma
Plus of course my own maintenance inspection for the trip. I'm loosing a week (vacation) this month and have family moving to the area in two weeks so I hope to get this all done.
build-up: Family Haulin' FJ60
05-05-09, 01:57 PM
#872 (permalink)
Originally Posted by Drofen
Here in TX we have to have a working parking brake to pass safety inspection to be street legal, and line locks don't count.
Do you guys have the same issue?
nope.
05-05-09, 03:27 PM
#873 (permalink)
Turbo Diesel Lover
This brake valve means you need to route your brake line in to the cabin .. I wanna get some ideas about it.
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
05-06-09, 05:34 PM
#874 (permalink)
I've got my location for the valve picked out and it will go on the tranny hump next to my shifter on the driver side. Basically ~8" away from the ebrake handle. Probably the only trick to it will be allowing some give/flexibility between body and frame from where I tie it in. I'll splice the line going to the rear brakes close to mid frame and run those lines under the body to where I put the valve. If this doesn't make much sense it will in the next couple of weeks when I get pics during the install.
05-06-09, 06:32 PM
#875 (permalink)
Rum Runnin'
To get that necessary flex between the body and the frame, have you thought about using some old rubber brake lines or some short SS lines? The SS lines would be for bling factor of course.
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
05-06-09, 06:39 PM
#876 (permalink)
weekly update
I've been prepping my  for another round of spending on Dora so she was ready for me to place a couple orders as noted up above.
Started on the frame mounts for the skid plate. I decided how long I wanted it and cut some pieces out from the stepvan frame. Yup, I'm still nibbling on that thing. Then I shaped them to the frame and clearanced for existing frame obstructions. There is a bend in the frame that I needed to follow so I notched the pieces and got the angle. I welded on a piece to keep my angle while I filled the gap with weld.
I filled in the gap and checked my fitment. I grabbed a piece of cardboard to get bolt hole locations so I could transfer those to the pieces I shaped.
After I drilled out one side I noticed that the other side was the same so I used my drilled side to transfer holes to the other side.
Here's the driver side
And the passenger side
From here I can make crossmembers to attach the plates to. I like the access so I won't be making a soild plate from one side to the other.
05-06-09, 06:42 PM
#877 (permalink)
I was just going to put a coil in them like the body to frame junction under the hood. If I can I'd like to have just four connections, two at the valve and two at the splice.
05-06-09, 07:22 PM
#878 (permalink)
Rum Runnin'
Gotcha. Probably makes more sense that way with less places for fluid to leak.
Using a frame to make a skidplate  Definitely a great idea.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
05-07-09, 12:49 PM
#879 (permalink)
Ramblin Wreck
I'll be interested to see what you come up with for the skidplate. Are you doing a solid plate, or using tube and just plating to protect the lowest and most vulnerable parts?
I built a skid few years back for my 40 using the same style frame mounts you did. The skidplate (not the mounts) wasn't great, and I've never liked it and now it is about bent up enough that I need to redo it.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
05-07-09, 01:27 PM
#880 (permalink)
The initial plan is to plate the areas that would do damage which will definitely be the lowest parts and maybe just a little more. I plan to make the frame first and then plate that. Not sure if I'll use square or round tube.
05-07-09, 09:03 PM
#881 (permalink)
OHV Trail Patrol
I need to do that too... along with fixing my driveshafts...
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
05-07-09, 09:30 PM
#882 (permalink)
hey mike to you mind measuring how far that Hydroboost set up extends out from the firewall?
05-07-09, 10:24 PM
#883 (permalink)
nevermind...
05-07-09, 11:14 PM
#884 (permalink)
nevermind...
Glad I could help out.
05-08-09, 08:46 AM
#885 (permalink)
05-11-09, 11:56 PM
#886 (permalink)
I don't know what you've been looking at. The Unidens are nice, big or small. The 520Pro little one is cheap and has an RF gain knob that comes in handy. The big ones have an SWM built in to let you tune your antenna live (could be detrimental to your CBs health too). Finally the Cobra with the front-firing mic is nearly DIN-sized and a nice package (can find on CL with patience).
Antennas- firestick makes a very cool box to split out signals from your CB antenna to CB and FM. Also has tuner for each signal type built into the box (use after SWM calibration).
I also found a 3-channel 12V mixer at parts express to mix in CB/HAM/Ipod to my aux stereo input and allows level adjustment per channel. Nice unit but the cables are kind of rare to find (ins/outs are mono 1/4" female so you need things like dual mono 1/4" male to mini stereo kinds of cables). Hope to try it out in a couple weeks to see how the sound quality works out.
My rough draft platform is really basic, but I like it a lot. I think you've seen it before, but if not we could meet up if you wanted to get an idea of what issues exist.
aside-
I've been watching my EGTs and they drop below 350 without any waiting. I'm guessing a good push up to Roger's camp might be a different story but they seem to drop really fast after the load is gone. fwiw
05-12-09, 06:27 AM
#887 (permalink)
Rum Runnin'
Cobra 75 WX ST. This is one of the units with all of the controls in the hand microphone and a small remote mount box to be mounted somewhere discreet. They're cheap at about $80 on fleabay and can be hidden pretty well. I'm planning on mounting my remote box under the dash with my AR1A Matchmaker splitter ( the one esh was talking about ) as soon as kevinmrowland gets his antenna mounts from his laser cutter. Good reception, hidden installation and if you want more volume, you can mount a cheap remote speaker under the stock amp location on the dash ( looks like a speaker hole in the dash pad ). For the antenna, get a Firestick flexible Firefly with tunable tip. Lots of signal adjust ability with the tunable tip. For the length, they say that for best reception, the top 1/3 of the antenna should be above the roof line.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
05-12-09, 09:53 AM
#888 (permalink)
Thanks Esh and GLTHFJ60 for chiming in on CBs. Eveything you both said coincides with the research I've been doing so it's great to have that confirmed without asking yet!
For the antenna I really do like the flexible ones even if they're not as powerful as the more solid ones so I've looked at Firestik, Wilson, and KD40s. Each has a flexible antenna that I like. I plan on mounting a 3' one where my broken FM antenna was on the passenger front fender. I'll need to make a base to support the antenna but I've already got some plans for that. I did read about the vital importance of tuning. Esh do you have an SWM tuner and would you be willing to help me tune mine when I get a setup?
I will get an AM/FM/CB splitter.
As for a radio I'm just looking at basic models; however, I do like the front firing boxes and am interesting in the weather channels so I'll probably go with the next level up from basic. I've read that the difference in radios is not the power since that's regulated but the features are what you are buying. It's the antenna that plays a bigger factor on transmitting and receiving. So far I've been looking at Uniden Bearcat Pro 538W and Cobra 18 WX ST II but am open to other suggestions. I'm still sitting on the fence about the all-in-ones, can they get as loud as the boxes? With a loud diesel I'll need a little more volumn.
05-12-09, 10:06 AM
#889 (permalink)
Originally Posted by esh
aside-
That's nice, sounds like you've got good flow from your intake and exhaust. I bet cool down times will lengthen a little if you decide to give it more fuel. Mine will cool down to 400F fast but the last 50F takes longer. Since my gauge sits above 0 with no power I suspect that I'm cooling it lower than 350F before I shut it down. If it's normal driving it usually takes close to a minute to cool down but when I work it the cool down time goes up, however, I've never had to wait more than 5 minutes to shut down.
05-12-09, 10:16 AM
#890 (permalink)
Rum Runnin'
As for the mount, kevinmrowland is setting up a kit to do just that with a stainless bracket and walcottcb.com components and I'll be getting his first "production" kit shortly. That will be a slick install.
For the volume issue, why not set up a remote mount speaker?
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
05-13-09, 02:13 AM
#891 (permalink)
I have an SWM when you're ready to tune it.
For the antenna mount, just went with a standard stainless antenna bracket over the oem antenna location. I was joking with Kevin last winter in Canada telling him I setup my antenna just like his. He was disappointed when he saw I didn't quite go to the same lengths as he did.
Good to know about the 1/3 above the roof thing. Most people have commented my radio seems to get out really far, and I think it might be partly due to just that factor, and probably that it was tuned. I have a pretty stiff firestick tunable and the 520 Pro little Uniden right now. I'd like to move it forward to the bull bar and put a stiff spring on it because the bracket mounts just suck.. keeps loosening up. Might try a mount to the rear tire carrier.
05-13-09, 06:40 AM
#892 (permalink)
Rum Runnin'
Hahaha, leave it to kevin to over-engineer just about everything. That's alright though, I really like how his design mounts and he's never told me about it loosening up.
I can't remember for the life of me where I read it, but that seems to be the rule of thumb. Maybe I read it on the forum somewhere or on one of the many CB sites I've been reading lately. Either way, results tell the story.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
05-14-09, 12:24 PM
#893 (permalink)
April Video
I forgot about the footage I grabbed of wheeling after the clean-up event so I threw it together and uploaded it. Creepersleeper is in there along with other local club members. Only a small clip of myself but I thought I'd include it here.
Wheeling TSF 4-09
05-14-09, 12:28 PM
#894 (permalink)
I think you have some new pics too dont cha?
05-14-09, 12:32 PM
#895 (permalink)
Yup, I'll get those here soon. I'm also working on another video from this week's trip too, that one will have to be in 2 parts.
05-14-09, 01:25 PM
#896 (permalink)
Turbo Diesel Lover
Wheeling TSF 4-09
thanks for the Vid Mike .. we still need more .. ( well at least me .  )
05-14-09, 05:34 PM
#897 (permalink)
OHV Trail Patrol
Nice Vid, Mike! I always like seeing my 80 in action! LOL
KE7VSA - MetalTech
05-15-09, 07:20 PM
#898 (permalink)
Weekly update
05-16-09, 11:01 PM
#899 (permalink)
IH8MUD FREAKin' Addict
Nice pics! Let me know when you're ready to test the latest updates to your rig! I'm always up for another run.
05-17-09, 07:57 PM
#900 (permalink)
bumper...
getting started:
first couple Bends
nice lines:
bottom bent and mock up with top piece:
Different angle
cheater way to notch:
Dirtgypsy showed up to start his rear bumper... Mike is taking a nap:
Boots bumper tacked:
me taking a picture of mike taking a picture of his bumper:
Dirtgypsy still cursing at the rivots:
Mike decided that the vertical pieces were too long... this is the way to properly secure a bumper "in progress" while grinding:
Clint still cursing at the rivots....
Mike has more pics to come later....
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
