Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 07-03-07, 02:11 PM   #61 (permalink)
boots4's Avatar
TLCA# 19547
I thought I needed the input for mock up but I guess I don't. The case is apart with the bearing retainer removed. Since you have set one up Mace I think you know what you are talking about, thanks for the heads up.
I did order a 32 spline input to match my tranny output and was planning on leaving the 203 chunk apart until I got that. It's suppose to be here by the week's end.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 07-03-07, 04:19 PM   #62 (permalink)
what he said
Mace's Avatar
TLCA# Something
Having a input to make sure the bearing retainer is centered is idea. BUt it does not have to be spline specific..
Make sure that the adapter and the Bearing retainer aer the same size. I have noticed a slight difference between some of the ones I have played with (genreally ferd vs chevy)
You will also want to work on plugging all of the unnecessary holes and making a stop for the lower gear shaft..
I am kinda gay.......
My Myspace
Old 07-03-07, 05:27 PM   #63 (permalink)
boots4's Avatar
TLCA# 19547
I did notice that the threaded holes went all the way through and I was thinking of using some of those holes to mount a plate with the notch cut out that will retain the lower gear shaft. Do I need to worry about sealing the shaft?
Old 07-03-07, 09:25 PM   #64 (permalink)
what he said
Mace's Avatar
TLCA# Something
not the shaft, it has an O ring. but you do need to anchor it.
My Myspace
Old 07-04-07, 07:39 AM   #65 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Dude .. if you plan run 33" - 35" I though tyou have no issues with 3.70 .. actually with 4.11 you gonna be in the Hi rpm range .. over 2500 - 3000 rpm .. and you dn't really need it ..
HJ-60 2H-T Intercooled Tencha
Old 07-04-07, 08:23 AM   #66 (permalink)
boots4's Avatar
TLCA# 19547
I don't think I could justify throwing this thread in the hardcore section if I were going to run 33s. I do have a set of 38s that I'm going to shoe-horn under it. I ran the rpm calculator and with my overdrive and 4.11 ratio I'll be spinning about 1800 rpm at 65mph which is a sweet spot for the 4bt. Yeah, 33s would be too small and if I go down in tire size it will only be to a 37. I think 37s fit a SOA just right on an FJ60.
Funny side note: My mom is visiting us and she is not into the whole lifted truck thing and when we passed a F350 superduty with a big lift she said "I just don't like the look of that, the tires are too SMALL". Right then she made me happy.
Tapage I noticed how your front fenders are trimmed and I like the line they follow. Since I'm trying to keep it from getting too high I know I'll be trimming fenders and I thought yours were done well. For the rears since I'm moving the axle back just a little bit I am thinking I will have to trim the body mount bracket attached to the frame so the tire doesn't hit it when compressing the suspension. Has anyone else running big meats on an FJ60 run into that bracket?
Old 07-04-07, 09:41 AM   #67 (permalink)
Turbo Diesel Lover
Tapage's Avatar
What it's the OD number for your auto tranny .. ?
Point taken .. you are right with 38" or at least 37" ( that really have 37 inche ) you would be in the nice spot with the 4.11
Why move the rear axle back . ?
Actually I leave my rear axle in the factory place and have no rub issues with my tires .. and don't need to do any fender cut yet ..
At front was obligatory coz with the SR I hit the fender at each flex
Old 07-04-07, 10:08 AM   #68 (permalink)
boots4's Avatar
TLCA# 19547
ratios for the 4L80e: 1st-2.48 2nd-1.48 3rd-1.00 4th-.75
I was going to move the rear axle back 1-3 inches because I'm worried the tire will hit the front of the fender when stuffing plus it would help my departure angle a little. So I figured it would be easier to cut the rear of the fender since the front is where the door is and would be harder to cut. I plan on cutting the quarter panels and that might be enough for clearance when stuffing the tire but the body mount looks like it will be real close. However, it sounds like I might not have to touch it. Just thinking ahead. I won't cut anything until I do a flex test once it's back together.
Old 07-05-07, 10:25 AM   #69 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Actually I'm always thinking in cut my rear fenders .. and as you mention was much more simple cut rear than front .. with the door to close there.
Someday I will do to keep it match with the front fenders .. and you have grear OD in the 4L80E much more than I have in my H55F ..
Old 07-11-07, 01:36 PM   #70 (permalink)
boots4's Avatar
TLCA# 19547
I am now the father of two. My boy was born last sunday and everything was good. All I have to say is that an Epidural makes the process smoother for everyone . I was able to get some stuff done before he came so I'll post that stuff.
Costco has a pallet of these for $50 so I picked one up for a future on-board air set-up.
I decided to go with a 4L80e because of the strength, the overdrive, and the fact that it will bolt straight on to the chevy adapter on the back of my 4bt. I did want an auto this time but the controllers were pretty spendy. Then I read about a trans-go kit that will allow full control of the 4L80e without a computer. I didn't find much on the web about it (drivability, shift quality, etc.) but I decided to go with it anyways (the kit). I feel I'll get the best of both worlds, stays in the gear I choose like a manual but no clutch to deal with on the technical wheeling stuff. It will cushion my drive line some and absorb some of the massive torque built low in the rpm range. I'll be wiring in the lock-up on the torque converter to lock in any gear I want which ='s engine braking and manual-like efficency.
Here is the kit
I read that instruction booklet 5 times since I've never worked on an auto before. The instructions started to make sense and once I got into it, it wasn't so bad.
Inside the box
I started to separate the valve body and kept everything in order so I knew which bolts went where.
Then I pulled the pump out since there are some internal mods you can make with the kit.
Back side of the pump
Front side of the pump
With the tranny sitting upright (like in a vehicle) this is the bottom of the top half of the valve body.
With tranny upright, top of the bottom half of the valve body
No turning back now! The kit requires some drilling to the valve body to modify the flow.
The separator plate that goes between the two halves of the valve body. Had to plug in some holes and file them smooth.
I found some the friction plates behind the pump that looked to be worn out so I changed those out. I didn't dig any deeper and while the wise choice would be to just pull out the internal chunk and rebuild it I didn't want to get into it that far. I did buy a rebuild manual and figure I'll be do a rebuild down the road after studying the manual. I'm just hoping there is life left in the tranny. This is one of the unfortunate compromises to get this thing back on the road sooner. So I cleaned up the valve bodies, got rid of the shavings and old tranny fluid still sitting in the channels and put it back together with some stiffener plates. I hooked up the unit that controls the torque converter lock-up since I'll need that. Overall it went together fine. I did have some roller bearings come out on the overdrive planetary that I had to get back in but once I figured out the trick it just took a little time.
Things back together
Picked up a 9/16 drill for the holes on the rear spring mounts, drilled them, and after aligning them on the frame I tacked them on.
Passenger side
Driver side
After double checking I burned them into the frame.
Threw some paint on them. I think I'll throw a coat of black paint over the whole frame once I'm done grinding off old bracket and welding on new ones.
That's it for now.
Old 07-12-07, 12:47 PM   #71 (permalink)
Turbo Diesel Lover
Tapage's Avatar
My respect .. I never think ( and never crss my mind ) do anythink to a auto tranny ..
Old 07-12-07, 02:01 PM   #72 (permalink)
boots4's Avatar
TLCA# 19547
thanks Tapage. I always took things apart when I was a kid and really I'm still just tinkering with my toys. It just costs more!
Old 07-12-07, 02:20 PM   #73 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I like to play with toys also .. and "wiring" it's my best but auto trannys .. mmm not at least if I do, when shift it in D and push the pedal the rig with luck run backwards
Old 07-12-07, 03:05 PM   #74 (permalink)
brokenparts's Avatar
TLCA# 16127
hey, why dont you get off your butt and get something done? hehehehehe
geez... you're gettin after it!
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 07-12-07, 04:23 PM   #75 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
You should take your own advice... Wait, your letting some else build your rig!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 07-12-07, 04:56 PM   #76 (permalink)
TLCA# 16127
touche.,cant wait to get mine home though... I think I could have got it done just as fast as they did . No complaints though they're doing a good job and I just dont have the room (or time) to take on the projects that I had done. I still got some fenders to cut, on board air to install (the york), finish my half doors, fab my rear bumper, and then send it over to Metal tech for a cage!
Old 07-12-07, 07:09 PM   #77 (permalink)
boots4's Avatar
TLCA# 19547
so what your saying is another "2-3 weeks" right?
Old 07-13-07, 12:06 AM   #78 (permalink)
TLCA# 16127
hey, arent we suppose to be talking about your rig?
Old 07-13-07, 09:23 AM   #79 (permalink)
Turbo Diesel Lover
Tapage's Avatar
damn dude .. cage on Metal Tech .. now I'm jelaous !
Old 07-13-07, 11:49 AM   #80 (permalink)
OHV Trail Patrol
TLCA# 15577
so what your saying is another "2-3 years" right?
fixed it for ya!
KE7VSA - MetalTech
Old 07-13-07, 03:10 PM   #81 (permalink)
TLCA# 16127
well... not to further hi-jack this thread but Big Blue is back home now.
Old 07-13-07, 06:31 PM   #82 (permalink)
Moby's Avatar
Congrats! Having just brought mine home I know the feeling
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 07-15-07, 03:55 PM   #83 (permalink)
boots4's Avatar
TLCA# 19547
Hey Mace,
is your 203 orientated straight up and down or does it favor a side. Basically I have the option of clocking the case a few degrees since I get to drill new holes on the 203 for mounting it to the 4L80e adapter. I am curious on how your is set up and if you would change the position any? I'm not after a flat belly so I don't mind if it hangs down some, just don't want it to be an anchor.
Old 07-16-07, 10:52 AM   #84 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
This showed up last week. I wasn't able to find a used one so I had to go with a new one from HERE.
The front side of the 32 spline input for the 203.
Back side
This is the seal No. that I pick up from Napa.
It's the single wider seal with the double lip. It's application was for a 203 behind a turbo 400. I believe my 203 came behind a turbo 350 and the parts computer said it took a different seal which they didn't have (which I think is the two seals put in back to back).
Double single seals on the left, single double-liped seal on the right
Input gear comparison. 27 spline on left, 32 spline on the right. The bearing was good so I reused it. Getting the bearing retainer clip off of the old shaft and on the new one turned into quite a job. I had to leave it alone for awhile and come back to it because I was having the urge to grab a BFH.
Just like Mace said in post NO. 60 the adapter centers on the bearing retainer.
Good fit
Decided to add a drain port to the 203. I used a "metal shavings removal device" to assist in cleanliness while drilling.
Got the input gear and shifting mechanism back in the 203. Put the adapter on the 203 and made my cardboard cutout of the intermediate shaft retainer idea.
Cleaned and painted the 4L80e 4x4 adapter
Cut this out of the stepvan frame. I made the inner circle by drilling holes around my tracing on a drill press. Then I took a dremel tool to it and fine-tuned the hole size.
The adapter can be rotated without it hitting the retainer I made. I'm using existing bolt holes to fasten the retainer and that will plug those holes up. Now I'll have to deal with the ones around the input shaft area under the adapter.
Last edited by boots4; 07-11-09 at 09:56 AM. Reason: Added where I got the new 203 input from.
Old 07-16-07, 12:35 PM   #85 (permalink)
what he said
Mace's Avatar
TLCA# Something
Nice, I could not find the double seal. So I used 2 of the other ones (very common apparently)
BTW, that is a hell of a intermediate shaft retainer. Mine is a piece of 1.5" flat stock..
My Myspace
Old 07-16-07, 01:37 PM   #86 (permalink)
boots4's Avatar
TLCA# 19547
Thanks.
Do you think JB weld will work for pluging in the other holes on the 203 or just use some gasket sealant stuff?
Old 07-16-07, 01:40 PM   #87 (permalink)
what he said
Mace's Avatar
TLCA# Something
I used "the right stuff" and allen head set screws..
My Myspace
Old 07-18-07, 12:52 AM   #88 (permalink)
andrew.fletcher's Avatar
Great build-up thread. I'm getting ready to go down the same road with my Pig and all these threads are a huge asset. Thanks
1972 BDJ55-T Resto Mod 4BD2T/4L60
http://forum.ih8mud.com/fj55-iron-pi...resto-mod.html
1989 FJ62 Daily Driver
2006 Chevy Trailblazer-Wife needed more seats than the FJ62
1976 MGB w/ 2.8L Chevy and T-5. Lots o' fun
andrew.fletcher is offline   Reply With Quote
Old 07-18-07, 07:34 AM   #89 (permalink)
Former Lifer
beaufort-fj60's Avatar
TLCA# 14545
mace.... this guy is kicking your ass.
Limit all US politicians to two terms; One in office, One in prison
beaufort-fj60 is offline   Reply With Quote
Old 07-18-07, 08:18 AM   #90 (permalink)
what he said
Mace's Avatar
TLCA# Something
You suprised?? lol
My Myspace
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
