Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 02-25-09, 12:16 PM   #781 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by GLTHFJ60 View Post
The rockers look great! Have any pictures of the undersides?
Didn't end up taking any good pics of the open rocker. I'm not done with them so I'll get some decent ones in a week or two.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 02-25-09, 01:53 PM   #782 (permalink)
pjohnson's Avatar
TLCA# 9166
Looks good.
Are you going to close up the underside of the rocker to keep rust producing crap out?
Phil
1973 FJ40, beeropener
1966 FJ45, (the 12HT has arrived.... )
1995 4Runner, AT with dual cases
President, Mountain Transit Authority, San Jose, CA
pjohnson is offline   Reply With Quote
Old 02-25-09, 02:07 PM   #783 (permalink)
brokenparts's Avatar
TLCA# 16127
Looks good Mike... you comin Sat. to bend up some tube?
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
brokenparts is online now   Reply With Quote
Old 02-25-09, 04:53 PM   #784 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by pjohnson View Post
Looks good.
Phil
I'm going to seal the seam that is under there and probably the holes for the pillars but that's about it. I will coat it and that should be fine.
Yup, I'm still planning on it and it even looks to be a dry day! What time can I swing by? I might need to use the welder a little too.
Old 02-25-09, 07:04 PM   #785 (permalink)
TLCA# 16127
no problem... the lil'welder is good for tube too. How's 10:30-11 sound?
Old 02-25-09, 08:57 PM   #786 (permalink)
boots4's Avatar
TLCA# 19547
Great. I'll leave by 10am. I'll probably just bring my trailer.
Old 02-27-09, 09:45 PM   #787 (permalink)
Whew, just finished reading--what a great thread. Seeing some of the issues you've had to work through has been a good thing. I definitely need to have stuff together before starting--lots and lots and lots of research to do yet.
Have you thought of using a water injection kit to keep your EGT's manageable when towing in the mountains?
Robert
Herman
84 FJ60 033 White
If you want to hear God laugh, tell Him your plans.
Drofen is offline   Reply With Quote
Old 02-28-09, 09:59 AM   #788 (permalink)
boots4's Avatar
TLCA# 19547
I'm glad I wrote this all down because I wouldn't be able to remember it all! It's fun to go back through and see the things I've done so far. Anyways, I have thought about water injection but for me that would be after I've finished tuning. I'm still trying out different power settings, chasing my mysterious boost leak, and playing with timing. All things that can have an effect on EGTs
EGTs got hot in the mountains towing for a couple reasons:
towing with 38s and 4.11s (4.56s would probably be better but this is part of my compromise to have one rig do all these things)
restriction in the exhaust (solution was to move that baffle from the down pipe)
I certainly could have slowed down some but I was impressed that little engine would pull that weight at 70mph with my setup.
I still have only 1 fan hooked up (it's winter so I haven't really needed even that one)
So I'm trying to say I've got a few things to finish/tune that can help with the higher EGTs while towing. Removing that baffle helped and if I could keep all that boost I'm trying to make going into the cylinders that would also help. Since I've been chasing those leaks I try out stuff and than work on other projects so that's why it seems like it's dragging on.
Currently as of FEB 2009
EGTs run about 800F on the freeway at 70-75mph. If I drop down to 55-60mph they go to ~600F. This is without towing. I haven't really towed anything heavy for a while so I'll have to see how changes I've made since then help whenever I get something heavy to tow. I'm peaking at 21psi of boost when I've got my foot to the floor which is only when I'm getting on the freeway. Gauge is still fluttering (much less now so progress is being made) and my end goal is upper 20s-30psi. That should get me about 180-200hp which will be more than enough; torque should be over 400ftlbs at those levels. It's the goal and the goal can change if it looks like that won't be reliable. Anyways, thanks for reading.
Old 03-01-09, 10:24 AM   #789 (permalink)
TLCA# 16127
I beat you to the pics Mike.... here's some progress on Mike's sliders from yesterday:
Tube being bent... the cheapo hydro actually works pretty well
Outrigger bent up:
Mike welding up the slider arms:
not too shabby for his first time with a mig:
This is how Mike looks on a regular basis:
Sorry we got caught a little short today for time but at least we'll have idea of what were doing when we start your front bumper.
Old 03-01-09, 02:30 PM   #790 (permalink)
boots4's Avatar
TLCA# 19547
Thanks Zach for posting the pics and thanks a TON for letting me bug you yesterday, it was lot of fun. That bend tech program and your bender really make putting shapes in tube fun and easy. Glad your wife saw us using it. I enjoyed playing with your MIG welder and am amazed how fast your plasma cutter rips through steel (no wonder you don't like going back to grinding!) You are a great host and I look forward to our next fab day.
Old 03-01-09, 04:08 PM   #791 (permalink)
TLCA# 16127
me too my friend.... it might be a bit harder for the next month or two because of my daughter's soccer but we'll get in another day sometime soon to work on your bumper.
Old 03-03-09, 03:29 PM   #792 (permalink)
KOOL AAROW
kling-on's Avatar
TLCA# 15374
Tube being bent... the cheapo hydro actually works pretty well .
SO DOES THIS MEAN YOURS GETS ROUND OUTRIGGERS NOW
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 03-03-09, 05:03 PM   #793 (permalink)
TLCA# 16127
Yes it does... Mike was kind enough to be my guinea pig.
Old 03-03-09, 07:03 PM   #794 (permalink)
boots4's Avatar
TLCA# 19547
Looking forward to being the bumper guinea pig too.
I got the outriggers tacked on and three supports per side done too. Hoping to get some paint on it tomorrow.
Old 03-03-09, 09:14 PM   #795 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
looking good guys!! can't wait to see the final product!
Clint
It's a Jeep thing I didn't understand. So I bought an FJ60 and now I get it.
Just bump it.
SOA in progress!
ROTW: http://forum.ih8mud.com/60-series-wa...lver-60-a.html
Dirtgypsy is offline   Reply With Quote
Old 03-03-09, 10:54 PM   #796 (permalink)
mrqtipp's Avatar
killer build
mrqtipp is offline   Reply With Quote
Old 03-05-09, 10:57 AM   #797 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
Here are my side of the pics from last saturday fabbing with Zach.
Loaded my stuff on the trailer. Put on a "flag" so people wouldn't skewer themselves on my tube. I thought the hearts were a nice touch.
Zach getting the bender set up.
While the jack may be slow if you had to bend tube for a living I thought it was a perfect speed and really allowed you to fine tune the degrees.
I have some pics of the degree dial on his bender but I guess those didn't get transferred to my hosting site last night so I'll edit this post and get those on here.
Here is the work from this week.
I borrowed this fun little tool from Zach to get my bird mouth angles transferred onto the outrigger supports.
Here's the lines being transferred. Then I just cut out a V with cut off wheels and used a grinding disk to carry out the curves.
Now the supports are also tacked in. I didn't weld it up because I didn't pick up any new batteries for my welder but here's what they look like. The outriggers have a slight upwards slope to them.
Once I get them welded up I'll paint them and then work on attaching them to the frame.
My cuts up old kids clothes she gets off of craigslist and I use those as rags. I grabbed this one to wipe the coating off the tube before I tacked on the supports and saw an interesting pic. I cannot read it but I don't think thats needed to understand what it says (hope it's not offensive writing). No wonder she cut up this shirt!
Kind of hard to get decent pics of the rockers but I hope this gives an idea of what they look like inside. I finished my cuts, cleaned them up, sealed the seam, and slapped the first coat of Rustbullet on them. I'll put another coat on it before I weld the sliders on.
Front looking back
Front fender area. Because of the rod and the welded well it actually has good support and it doesn't flop around. I might put a screw in it but probably doesn't need it.
I retimed the engine to 14.4 degrees (from 15.3) because I was eating a little too much oil and a little too loud. It did quiet down a couple dBs and we'll see about any economy improvement with a couple of tanks.
I think I'll take another look at my boost signal line to the gauge and see if I have connection/pinch issues. I wonder if the line might be too small.
Old 03-05-09, 01:57 PM   #798 (permalink)
TLCA# 16127
those look great man... good work!
Old 03-05-09, 10:14 PM   #799 (permalink)
TLCA# 16127
hey mike... what is your frame height (ground to bottom of frame)?
Old 03-05-09, 10:47 PM   #800 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
That's what the inside of the rockers look like. Nice.
Excellent sliders!
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 03-06-09, 08:32 AM   #801 (permalink)
boots4's Avatar
TLCA# 19547
Once I get done adding all the extra weight from protection it might be a tad lower but right now I'm at 25" from bottom of the frame under the driver side door to the ground. My tcase does hang down a bit lower (~5") and I haven't fabbed up a skid plate yet.
Old 03-06-09, 08:39 AM   #802 (permalink)
boots4's Avatar
TLCA# 19547
Excellent sliders!
Yeah, once I saw Zach's (brokenparts) and then cut mine off there isn't much that needs to be sealed so doing the work to cap them seemed like diminishing returns especially since it will be covered up with a slider anyways. I just sealed up that seam in the middle and will run some rubber plugs in the holes at the bottom of the pillers. The one area I need to look into further is the hole at the rear wheel well. I'd like to get a flashlight in there and see where it goes to see it's worth dealing with (maybe just a piece of rubber glued in to keep things out).
Old 03-06-09, 09:51 AM   #803 (permalink)
TLCA# 16127
Gracias.
Old 03-06-09, 04:23 PM   #804 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Gracias.
practicando Castellano ..?
HJ-60 2H-T Intercooled Tencha
Old 03-06-09, 04:36 PM   #805 (permalink)
TLCA# 16127
poco.
Old 03-06-09, 09:47 PM   #806 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
Those are bada$$ mike.
please tell me you are NOT going to put those boggers on your truck
Clint
Just bump it.
SOA in progress!
Old 03-06-09, 10:16 PM   #807 (permalink)
boots4's Avatar
TLCA# 19547
Clint
Those will be spare tires. I still need to get some 6 lug 16s to mount those. Right now they are on 8 lugs.
Old 03-12-09, 01:01 PM   #808 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
I seem to be taking my sweet time with these sliders but they'll get put on soon.
This was my battery condition for my welder. I had one boil over so I knew it was toast (charger didn't get the right signal so it kept charging) and then the other had a post that was loose so I decided to just replace both of them.
Trojans are pretty good batteries but I decided not to fork over the extra difference and just got house brand. These are group 27 deep cycle batteries. They are new and if I have any problems in the next three years I'll be bringing them back to their shop.
I cleaned off the battery tray with baking soda, plopped in my new batteries and hooked them up.
With new juice supplying my welder I burned in the outriggers, cleaned up the metal and put my first coat of Rustbullet on. With the warmer weather coming up I'm hoping it will be easier to paint since I'll need a second coat on the sliders and the rockers. I'm getting low on Rustbullet too so I'll need to get some more ordered.
I've been tracking down a coolant leak that wasn't dripping. I ended up having a couple pinholes on my return heater hose so I got some new stuff and replaced it. It was also time for an oil change so I made a mess on the driveway and got that finished. After the rubicon trip this summer I should have over 10K miles on the swap.
Old 03-12-09, 04:11 PM   #809 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
That's awesome! I can't wait to buy one of those Ready Welders!!
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 03-12-09, 06:26 PM   #810 (permalink)
boots4's Avatar
TLCA# 19547
Thanks, I do plan on making a new cart, something more vertical with a place to wrap the cabling for the gun and grounding clamp. Plus those skinny wheels don't do so well on soggy grass so probably some wheels with more "floatation". I've been eyeing this big-wheeled radio flyer cart at Harbor Freight that I could modify.
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
