Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 10-11-08, 05:57 AM   #661 (permalink)
jvazquez53's Avatar
Originally Posted by boots4 View Post
Wow, what a long week. In fact it's been a couple of long weeks. Quick summary: IT RUNS!! but........ she's not moving all that well meaning probable tranny rebuild sooner than later.
There are many ways to do this and and probably better but this is what I came up with for the lower radiator hose. I had to adapt the 2 1/2" to a 1 1/2" with a funny angle. I couldn't find any copper elbows big enough but I did find a plumbing elbow that had close to a 2 1/2" o.d. It is actually list as 1 1/2" i.d. Then I just got some 2 1/2" radiator hose from Napa.
I took in a half of my 4bt upper hose to Napa and had them find something that had a similar bend. They had something so I used that new piece as the second half of the upper hose and used this older piece to connect to the FJ60 lower. I picked up an exhaust reducer from 2 1/4" to 1 1/2". This is the lower section of the frankenstein hose.
This is how it goes together.
After I invested in some hose clamp stock I picked up some better clamps and put it on. The engine side clamp is not small enough so I'll need to get a smaller one and eliminate the second clamp from the top. Hey, sometimes more clamps are better . It makes me laugh looking at it but it works.
Friday was a very good day. Kevcj came over and put in 9 hours with me and we got a ton of little stuff done. Little stuff like circle clips, front hubs, rear lug nuts, filler neck tube to the gas tank, finished routing lines to the heat exchanger, making a mount for the heat exhanger, wiring, hooking up power, oh yeah we even got the engine RUNNING!
The tranny cooler/heat exchanger came with a mount base. We heated it up and bent some parts and now it's on the firewall.
Video was requested, here you go.
diesel first start.mov videos from rides videos on webshots
I'll admit this wasn't the very first start. We had to troubleshoot a few things before it would actually start. This is what we did: We hooked up the battery and found a switched 12v source from one of the connectors on the driver side that wasn't being used. We wanted it hot once the key was in the ignition spot. I got new fuel, took off the fuel filters and filled them up. Then we put the rest of the fuel in the tank. We primed it using the primmer on the lift pump. The arm went limp. Then we tried to start it. The starter turned over very slow. After some additional batteries and a couple of jumper cables we found that the ground was not efficient. I had put it where the last one was and that was on the fender. I scratched off the paint but the ground was inefficent. Once we went to the frame with the ground it spun the starter much faster and I now get the instant start that I got in the stepvan. We used the big, thick cables that came from the stepvan and had plenty of room to re-route the ground. I ground the engine and the battery to the passenger side diagonal brace that already had two bolt holes in it from removing that front undercover (I think this is FJ60 specific), anyways the threaded holes were already there. The engine started up and stumbled for about 20 seconds and then it settled into a rock solid idle. I didn't have to bleed the injector lines. The fun came when I tried to turn it off and it kept running when I took the key out of the ignition. There is a manual shut off on the injector pump and I used that to stop the engine. After talking it out we must have used some wire that continued to get power after the key was out. I knew the coil wire was good but it was on the other side of the engine bay. I decided to tag off of that wire to try it out but Kevcj, who already stayed later then he planned, could go home and leave me dumbfounded that things actually worked. I hooked up that wire and the engine started and stopped with the turn of the key like it should so I'll just clean up the routing of that coil wire. If you are doing a swap, label your wires, I did and it was easy to find them 7 months later when I needed them again. Also before I started the engine I put in any necessary fluids like power steering, engine oil, coolant, and ATF since I'm running an auto.
With the engine running I could see a few leaks I needed to fix. The biggest one was the block heater. The next day I took it out and found a tighter fitting o-ring at the hardware store. It wasn't as easy to get to since everything was on the engine now but with the air filter off it was accessable. HINT: When I put it back on I tightened it as far as I could get with a little allen head wrench but it didn't feel tight enough so I got some socket extentions and tapped it with a hammer. I tighten it some more. I did this a couple of times until the block heater looked almost flush with the block. Now it doesn't leak.
In order to take it around the block I needed to get the front wheels on so I did an alignment. This is how I measure for 1/8th toe-in. I found some straight angle, clamped them on, measure out equal distance on the front and back and compared. Pretty simple.
I went to my friend's shop and he helped me shorten the rear driveshaft. Finished up other stuff and went for a drive. I forgot to put the doubler and TC in gear but figured that out. Then it still wouldn't move. I increased the rpms and it finally started to move.
Vids:
leaving
first time leaving.mov videos from rides videos on webshots
coming back
first time coming back.mov videos from rides videos on webshots
Got the hood on (yes I re-routed the air cleaner, this one's just temporary until the other one comes in), hooked up the dash and tested the lights. Only one bulb worked on the dash so I turned the others around in the sockets and now the others worked. LEDS are polarity specific so it matters which way they go in. You'll only know if you get it right when they do or don't come on. I really like how the lighting turned out and they do dim if needed. I then took it on the freeway to go the a cruiser christmas party.
I got on the freeway and couldn't get overdrive. I thought earlier that I wasn't getting third gear but it was actually overdrive. So this is what I'd get: 1st good, 2nd good, nothing in the 3rd spot, 3rd in the 4th spot, and no overdrive. I was going maybe 55 mph on the freeway (had my wife chasing behind me and we used little radios to communicate). It felt like 3rd is slipping (1:1 ratio). I got off at the next exit (2 miles) and turned around to go home. It was a good first test but with unfortunate results. I have the trans manual and will look it over to see if it's something simple but I'm leaning towards a rebuild. Since I don't have a dipstick low fluid is a possibility. I think I had 10-11 quarts in it. I added 3 more for a total of 14 quarts and took it out yesterday but it was doing the same thing. I should be getting my dipstick today so I'll have to see how it reads once I get it installed. Bummer, looks like we won't be taking it to California after all for the christmas visit. I didn't have a muffler on it when I was on the freeway and it was loud. I hooked the stepvan one up yesterday before the tranny test and it helped. I was worried because I haven't hooked up shocks yet but it wasn't that bad without them and I took it easy and left myself room to stop.
Here are some pics of the engine with the hood on. I have a clearance issue with the overflow tank and will need to cut of the mount and weld it on a little lower.
This is so well done and interesting that inspired me to follow your steps!
José
White 92 FJ80 "El Tractor Dos"
Gray 9
2 FJ80 aka "La Tractorcita" (Daughter's FJ 80)
83 FJ60 "El Tractor "(RIP) 2009
76 FJ40 - sold
74 TY250 - sold
83 IT 175 - sold
85 TY350
DT250 - sold
91 Isuzu P/UP - sold
79 Plymouth Trailduster - sold
72 Jeep Commando - RIP
jvazquez53 is offline   Reply With Quote
Old 10-11-08, 09:18 AM   #662 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by SAR_Squid79 View Post
So I just bought an FJ62...
...If I can find a step van, and drop them both off at your house - how much and how long for you to do my diesel conversion?!?!?!
Let's see, the second one usually goes faster and considering all of the things I did besides the engine swap the first one took me about 10-11 months to get it on the ground and the next 6+ to continue tuning. I bet I could get a swap and SOA with pre-bought parts done in 3 weekends... Seriously, I'm still working out stuff and expect to continue that for awhile. It's just the nature of the game and (sometimes I have to remind myself) part of the fun. It can get stressful but there should always be some fun in it. I've been taking a little breather from wrenching lately getting ready for winter which mostly means a wood supply for heat.
As far as price, the would probably make it expensive since she fills in as my therapist, cook, babysitter, house cleaner, occasional cruiser project assistant, and my friend. That can't be cheap.
What are your plans/intended use for your rig? Great color BTW!
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 10-11-08, 09:21 AM   #663 (permalink)
boots4's Avatar
TLCA# 19547
Thanks Jose, looks like you've got plenty to do with all your vehicles in your sig line! I bet you keep busy.
Old 10-11-08, 12:19 PM   #664 (permalink)
Scottb's Avatar
This a great build, if you ever want to sell it PM me.
This build has alot of great ideas also, keep up the good wood.
<>< JC rules Toyotaless right now.
95' Dodge Cummins diesel, 35'' tires, 5pd, do it all rig.
Scottb is offline   Reply With Quote
Old 10-11-08, 11:19 PM   #665 (permalink)
chicago's Avatar
TLCA# 16202
I googled "Colorado off road express, Jerry Nichols" and this thread popped up. I spent a better part of the day reading this damn thing, and going over and re reading certain parts of it!
I never come to the HC section all that often cuz....well....Im not all that hard core, but Im glad I found this!
Planning on a Vortec, 4L60E to NP203 to 19 spline and this thread helped clear up A LOT of the quesitons that I had regarding the mating of the tranny to the dual case set up!
Thanks and great job!
Just out of curosity, about how much was the 203 to the 19 spline adapter?
BITCHIN THREAD! BITCHIN WORK!
Chicago
TLCA#16202, KE7VAT
Toyota family:
88 FJ62 (Sold to a good home. Goodbye old friend!)
76 FJ40 (Blotch rig part deux)
06 4runner...wifes rig!
06 Tacoma, DD, BONE STOCK and staying that way!
PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada!
FAWKING CUBS!
chicago is offline   Reply With Quote
Old 10-12-08, 09:00 AM   #666 (permalink)
boots4's Avatar
TLCA# 19547
I think the adapter was $525 or $550 and Jerry had it shipped out the next day.
Tips for what you might be interested in:
I've been looking over how I mounted the shifters and found the mount is really flexing when I yank on the levers so that will need some bracing. I'm trying to decided if I want to completely redo the mounting base or try and salvage what I have. The levers with zerks I'll definitely be keeping.
If I did another crossmember I'd go under the front tcase output instead of over it (easier to make) and mount it to the frame differently so it's easier to take out. Probably like how the stock one is mounted. It will help protect better and make a skid plate a little simpler.
Old 10-12-08, 09:10 PM   #667 (permalink)
chicago's Avatar
TLCA# 16202
What are the zerks from...
IIRC, you said that you were strolling through the hardware store...is there a more specific application for those that you have.
Im NO WHERE near a point that I can begin much of anything, but For the x member, I was considering building something similar to FC fab's x member.
Honestly, the two things that worrie me the most, are the wiring, and the shifter linkange fab...
Ive never done anything like this, so this project is gonna be the challenge of a life time for me.
Ill be amazed if my rig will ever run again after I get started!
Chicago
TLCA#16202, KE7VAT
Toyota family:
FAWKING CUBS!
Old 10-13-08, 09:09 AM   #668 (permalink)
boots4's Avatar
TLCA# 19547
Ask for set collars. My store had them separate from the nuts and bolts. I choose a size, found a bolt they would fit snug on and found zerk fittings that fit the holes where the allen head screws were. The zerk threads weren't the same just the hole size was similar so I just cross-threaded them in. They're not holding any pressure so I didn't bother with drilling and tapping new threads.
I'm going to try bracing the base in the next day or two to see if that helps improve shift engagement. If not, I'll go back to the drawing board to make a new base to mount the shifters on. The challenge will be figuring out how to mount the base to the tranny.
This is my first complete project too and I've treated it like a bunch of little projects (a common approach I believe). It made it easier to manage.
Old 10-13-08, 12:23 PM   #669 (permalink)
chicago's Avatar
TLCA# 16202
Ask for set collars. Mine store had them separate from the nuts and bolts. I choose a size, found a bolt they would fit snug on and found zerk fittings that fit the holes where the allen head screws were. The zerk threads weren't the same just the hole size was similar so I just cross-threaded them in. They're not holding any pressure so I didn't bother with drilling and tapping new threads.
Thanks for the info man!
Again...props to you for the documentation and photos. This is an award winning thread!
Oh yeah...I did have one more question that I was thinking about...Why did you go with a 4L80 and take out the electronics, why not go with a NON computerized tranny like a 700R?
Just curious!
Chicago
TLCA#16202, KE7VAT
Toyota family:
FAWKING CUBS!
Old 10-13-08, 01:50 PM   #670 (permalink)
boots4's Avatar
TLCA# 19547
I wanted to go with an auto and it had to be GM since that was the adapter that came on my engine and I didn't want to trade out for another setup. I was concerned about the strength of even a built 700r4 behind the 4bt. The torque pulses this engine makes is different than the GM diesel v8 some of the 700r4's came behind. Some are having fine results behind the 4bt but aren't pushing big #s or big tires. I wanted to have some scalability so I decided on the 4l80. I found out I could convert it to manual shift and for me I thought that was the best of both worlds. I can keep it in whatever gear I want like a manual and have the benefits of a t.converter for finessing obstacles. It makes backing up my trailer in our backyard up an incline on wet grass easier as well. The deeper first ratio didn't matter to me because I'm running a diesel and the way it pumps out torque much quicker than a gasser. So far I like it, but I can tell the t.converter isn't quite matched to this engine. I used a heavy duty diesel t.converter that came behind the GM v8 mated to a 4l80.
Old 10-16-08, 12:00 PM   #671 (permalink)
boots4's Avatar
TLCA# 19547
biweekly update
I didn't get last week posted so I'll just post it here. I didn't get much done anyways I just painted the back of the rear seat since it had some rust and painted part of the tailgate since I had the paint out.
This was the worst of the rust. I wire wheeled it to clean it up.
This is after two coats of rustbullet. By the time I'm done with this project the whole thing will probably be coated with this stuff!
I coated part of the tailgate. The center part will eventually be cut out for tailgate storage.
In my quest for more boost and leak finding I started reading more about turbo dynamics. What I did read re-enforced the idea that bigger is not better and that a matched setup is better. My power goals are 200hp, mid to upper 20s for boost, and mid 20s for fuel economy. Right now I putting out about 140hp, 18psi max, and 18mpg consistantly.
For the boost department I reconsidered my setup. I was getting some turbo lag and so I decided to try out my original setup that came on my 4bt. I was going to replace the 54mm inducer with the 44mm inducer. This meant tearing the turbo apart to replace both the turbine shaft and compressor wheel because they are balanced together even though it would have been easier to just swap out compressor wheels. I removed it from the engine and brought it to a workbench.
The Hi-temp silicone actually held up and sealed so well that the cover took a little persuasion to separate.
I took the 54mm compressor wheel off. Still nice and clean inside.
Getting ready to remove the main body from the exhast housing. It came out using the wedge trick with little effort.
Here is the rear oil seal I had to transfer over to the other turbine shaft. There was actually some wear on it but I reused it anyways.
Other side
I haven't had my wastegate actuator hooked up to line pressure so I decided to just remove it from the turbo. To keep the wastegate shut I tapped into my redneck and used a piece of the old emergency brake cable when I had rear drums. Didn't want to go to the store and wanted it to be reversible in case I want to play with an actuator later on. My thoughts are I probably won't with this turbo setup but who knows.
Here it is mounted back on the engine. WH1C with 44mm inducer, 3" intake housing, 12cm exhaust, wastegate deactivated.
But now I had to setup a 3" intake instead of the 4" I had for the other housing. I still have parts from the stepvan to play with.
I measured and recut a bunch of times and came up with this. The good thing is that I worked in my air filter meter that measures the vacuum pull in the intake tube. This will help tell me when I need to clean/replace the air filter.
Tapped back into my redneck and made a TEMPORARY 4"-3" reducer. I'll be ordering a real one today but wanted to get it back on the road to see the difference of the turbo.
It's all hooked up and tightened down. I now have room to change the oil filter again. I'll hold on to the 4" stuff incase I move up to a different turbo needing 4" intake.
Driving impressions:
The turbo spools faster improving drivability. It takes off from a stop light a little quicker and it responds to hills quicker as well. Doesn't sound any different.
Since the inducer is smaller (44mm) the turbo doesn't have to work as hard by making smaller slices of air. According to reading, the air quality is also suppose to be better. The 54mm did come off a 6bt that needed more air to fill more displacement. Remember that this is for an H1C holset so the turbine wheel was exactly the same. If you change that turbine wheel then a bigger inducer could be a better match but that would probably mean a different turbo.
I stared at the tcase shifters and am getting closer to redesigning the mounting base with something that will be more rigid.
I also think I've narrowed the boost leak down to the intercooler. That will mean either a fix or a replacement. I'll first look into fixing it and then research for a replacement.
For fuel economy I'm going to try some injector cleaner to see if they are dirty. I don't get smoke or hard starting issues that would be associated with worn out or leaky injectors so I'm thinking they are dirty. Now matter how I drive I get 18-19mpg pretty consistently. I suspect cleaning the injectors should also quiet the IP just a little since it won't have to work as hard.
Old 10-16-08, 02:19 PM   #672 (permalink)
Turbo Diesel Lover
Tapage's Avatar
But the new 44mm inducer make any diference on boost along with no wastegate at this time .. ?
I'm with a no signal wastegate in my K26.8 from second week on Tencha ..
HJ-60 2H-T Intercooled Tencha
Old 10-16-08, 03:32 PM   #673 (permalink)
boots4's Avatar
TLCA# 19547
No, not on max boost. Still around 18psi for max. That will change once I get the leaks fixed; I had been taking a break from hunting for them until recently. Gauge still flutters.
I've been thinking about fueling and how the IP accounts for boost. Basically when the turbo starts boosting the pressure builds on the AFC diaphram in the injection pump moving it down causing more fueling to make up for more air due to boost. More exhaust is produced and in turn powers the turbo. The turbo is obviously boosting more than 18psi right now but is not max boosting since the signal the AFC diaphram is seeing is after my boost leaks so it's only fueling to the 18psi it's seeing. Just fixing my boost leaks will result in a performance increase because it'll get more fuel due to a higher boost signal; meaning it will push the AFC diaphram down further and let the fuel pin travel further. The other benefit to getting more boost is that with my current settings I could see a small reduction in ETGs. Just thinking out loud.
Old 10-16-08, 03:42 PM   #674 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
I always wondered how a mechanical IP accounted for the extra air provided by the turbo.......cool!
So your leak is at the intercooler? Are you going to test that by replacing it with a tube or hose to see if you retain more pressure?
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 10-16-08, 04:13 PM   #675 (permalink)
boots4's Avatar
TLCA# 19547
That would be one way to single out the intercooler and I've been tempted to just try that out to see what boost I would see out of the turbo.
I've thought about taking it out and closing off the ends and using compressed air to build some pressure inside and then dip it under water (an aquarium would help) or putting soapy water on the it to see where I get bubbles or filling it with water and pressurizing to see where it leaks or taking it to a repair shop and have it tested. I've toyed with the idea of using jbweld or similar product to patch the holes but haven't called any repair shops to see what a real repair would cost. Wish my brazing friend still lived here because he could patch almost anything.
Old 10-16-08, 04:33 PM   #676 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I'm just curious .. when you by pass the intercooler to see if there are much more boost inmediately .. actually in Toyota Diesel pumps you can adjust the hole rail in the IP and get more diesel throught the hole powerband .. in theory ..
Actually my Tencha IP can't suply the necessity of fuel when I'm over 14 PSI .. but I'm not really worryed about that coz If I keep my foot on the floor at 3k rpm and 14PSI my engine temp start climbing ..
There is another cooling issue that I need to solve .. maybe with a bigger rad ..
Old 10-16-08, 06:57 PM   #677 (permalink)
boots4's Avatar
TLCA# 19547
...actually in Toyota Diesel pumps you can adjust the hole rail in the IP and get more diesel throught the hole powerband .. in theory ..
The Bosch VE IPs on these cummins have adjustability like your toyota pump. With easy light wrenching:
You can adjust the full power screw which would give more fuel all over. You can adjust the AFC diaphram which can fuel more aggressively depending on boost. You can adjust the star wheel which allows the IP to start fueling at lower boost pressure (reduces the spring preload on the AFC diaphram). And of course there is timing. That's in a nutshell and when adjusting one thing you affect another.
With our mechanical IPs we're doing the same thing as a "chip" in the modern truck except that we have to turn some screws instead of press some buttons.
Old 10-17-08, 01:35 PM   #678 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
Originally Posted by brokenparts View Post
better finish before the baby comes.
Are you kidding? I'm going to need that project as an excuse to get out of the house and into the shop!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 10-17-08, 02:19 PM   #679 (permalink)
brokenparts's Avatar
TLCA# 16127
you have so much to learn young jedi.
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 10-17-08, 03:21 PM   #680 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I believe your Bosh VE type IP have much more options to adjust it and much more simple than linear Toyotas .. but at the end we can reach the same goals ..
Hey I got my pen and paper .. let me take a note, so start with those lessons ..
Old 10-17-08, 04:41 PM   #681 (permalink)
OHV Trail Patrol
TLCA# 15577
Come home, play with baby, put baby to bed, put mommy to bed, bring baby monitor into shop...
KE7VSA - MetalTech
Old 10-18-08, 02:32 PM   #682 (permalink)
FLYINGLOW's Avatar
TLCA# 9203
You left out the part about waking baby up when you go to bed, momma makes you feed baby, baby cries for 1 hour. Next day you face the wrath of an overtired momma and in the evening you are asleep on the couch before baby... Let us know how it goes.
77 FJ40 TBI 2F, Aussie rear, rear 45 springs, 36" TSLs, Warn 8274......
Made in Japan, Built in Canada
97 4 Runner Ltd
FLYINGLOW is offline   Reply With Quote
Old 10-18-08, 02:50 PM   #683 (permalink)
OHV Trail Patrol
TLCA# 15577
Yeah... I'm really excited. (Actually, I am...)
KE7VSA - MetalTech
Old 10-22-08, 12:04 PM   #684 (permalink)
boots4's Avatar
TLCA# 19547
Findings:
When I was under the rig just looking around I found that I had a clearance problem with the ram and that it had contacted the oil pan. It must have happened last wheeling trip since I got to flex out the front end on a couple of spots. It actually left a very small dent on the oil pan, nothing needing to be fixed but something needing to be addressed. I had planned to go wheeling so I spent the day before lengthening the bumpstops.
I also found that my passenger side motor mount is going to need replacing if I start wheeling it harder. I'll study it some more to see if I need to redesign/modify that mount for better weight placement.
So I wheeled it yesterday and got some more motivation to get some sliders fabed up and get a front bumper together for some better winch/tow points. Driver side rocker got dented and I have a little gutter work since I peeled it down in one spot (the hole tells me it won't seal up very well). The place we explored had some serious overgrowth so that part wasn't much fun for me. I got detained on two obstacles where being locked front and rear would have helped so I had to use the strap. My jam nut on my driverside TRE kept loosening so the ram would spin the tie rod and bind. Not a problem on the street but sawing back and forth on wet, muddy rocks with a little go pedel applied more force on the parts to loosen them up. I've got my TREs tilted opposite ways (as suggested when mounting a ram to the tie rod so it doesn't spin) so I might try swapping the tilt on them to see if that makes a difference. I wheeled it harder this time and found once I got back into town that it felt "funny" when I try to reverse, like something is rubbing or not meshing correctly. It's only in reverse and I got home just fine. I didn't drive it today to work because I didn't get a chance to further troubleshooting it. Ujoints were fine and nothing looked like it was rubbing the tires so I plan to pull the diff cover and have a look inside. If it's spider gears I've got some to replace them, if it's a tooth on the R&P I'll be working on that 14bolt sooner than I thought. I'll have to go up the line from there if I don't find anything: tcase, doubler, tranny. Any of those will make me sad.
Old 10-23-08, 08:36 AM   #685 (permalink)
boots4's Avatar
TLCA# 19547
Findings:
...it felt "funny" when I try to reverse, like something is rubbing or not meshing correctly. It's only in reverse and I got home just fine...
I got underneath it last night after dinner and popped off the diff cover. No problems and no metal chunks/chips in the lube or at the bottom of the housing. I looked around some more and noticed that there was a scratch mark on the inside of the passenger rear rim like a rock had gotten wedged between the caliper and rim. There was a scrape line on the inner diameter. I didn't see any thing left that could be wedged and then I found it. The top bolt on my caliper was missing so when I was going forward and braking the bottom bolt acted like a pivot point and would suck the caliper down on the rotor. When I traveled in reverse the opposite would happen and the caliper would pivot off the rotor and rub against the inside of the rim. I used locktight on those bolts but I never went back and retighten them down after a few miles on the road. I took the other bolt out and will go find a match during my lunch break today. I do feel relieved that it'll only be a $1.50 repair. I'll try and get some pics tonight of the issues I've had this week.
Old 10-23-08, 01:08 PM   #686 (permalink)
regarding boost leaks... I've had good luck tracking down leaks but using a bicycle innertube. Cut it in half, use pipe-clamps to attach each end to the intercooler openings... then pressurize system via the schrader-valve. Only need 10PSI or so... then listen for leaks. Or let it sit and see if it looses PSI.
gifu is online now   Reply With Quote
Old 10-23-08, 01:37 PM   #687 (permalink)
boots4's Avatar
TLCA# 19547
That's a great idea, thanks for sharing! I'll try this out soon.
Old 10-24-08, 08:46 AM   #688 (permalink)
boots4's Avatar
TLCA# 19547
My 4" to 3" reducer came in so I slipped out my temporary one and put the real one in.
I decided to keep the 4" air filter and just reduce it since it's still new plus this way if I step up to a turbo with a 4" intake I'll have the parts already.
This was the scratch in the rim from the caliper rubbing due to a missing bolt. No real damage to the rim or the caliper just some scrapes. I got a replacement bolt yesterday and put it on last night so I drove it today.
This is where I peeled the gutter down. I took a crecent wrench and bent it up a little but I'll need to reseal and repaint that section once I finish straightening it out.
Here is my driver side rocker damage.
Front extended bumpstop
Rear extended bumpstop. I offset the rears so that it would contact the flat part of the spring plate. I had to offset because I moved the axle back and reused the original holes for the bump stops.
Old 10-24-08, 10:26 AM   #689 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
I have that same type of rocker damage. Gonna cut them out and weld in some sliders??
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 10-24-08, 11:32 AM   #690 (permalink)
boots4's Avatar
TLCA# 19547
It does seem pointless to protect that rocker now but I wasn't planning on cutting them out, just adding sliders anchored off the frame. I'll have to see what kind of slider material I find in the scrap metal area at the local steel yard. If I need to tuck them up higher then I might cut them out and do some body work (the body work is what I'm not looking forward to).
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
