Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 09-17-08, 12:02 PM   #631 (permalink)
boots4's Avatar
TLCA# 19547
Gifu as you know advancing the timing will bring down your EGTs a little. Perhaps the way you routed your exhaust is somewhat restrictive (more stuff you already know) and that shows up as more heat. Something I haven't started looking at yet since I still got psi leaks are the injectors. Maybe they are worn out and not atomizing fuel well enough. What kinds of thing have yout tried already to increase boost? It's not uncommon for the stepvan engines to be timing retarded and power screw deficient. Do you have an intercooler?
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 09-17-08, 01:59 PM   #632 (permalink)
Turbo Diesel Lover
Tapage's Avatar
But if you have enought fuel, no matter what if you advance of retard your IP timing, you would get the same boost as always ( at lease in Toyota Factory turbo engines ) .. more fuel at low rpm ( low boost condicions ) of decreased top speed but the same level of boost ..
HJ-60 2H-T Intercooled Tencha
Old 09-17-08, 05:32 PM   #633 (permalink)
I haven't done... a thing. Haven't checked timing, injectors, pump, etc. Soon. I wonder, if the injectors are drippy/pissers, would it cause excessive smoke? I mean, could you have poor atomization, causing poor burn, causing high EGT... but still have very little/no smoke?
gifu is offline   Reply With Quote
Old 09-17-08, 06:47 PM   #634 (permalink)
boots4's Avatar
TLCA# 19547
True, I was suggesting timing to bring his EGTs down. That way he could add more fuel and see if he gets more boost.
Old 09-17-08, 07:01 PM   #635 (permalink)
boots4's Avatar
TLCA# 19547
I'll have to study up on injectors to see what symptoms are caused by what conditions, just haven't looked into those yet.
Old 09-18-08, 09:34 AM   #636 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
After my warning for flares and mud flaps I wanted to at least get something on there and had planned to put mud flaps on it anyways. I looked online at kits and quickly decided I'd make my own. I found some trucker flaps at the local Flying J truck stop. They were only $12.99 per flap, way cheaper than what I found online. They are massive (and these were the smaller ones).
I went to the hardware store to see about square tubing and again quickly decided I was going to find scrap at home that I can get to work. I found some pipe that would work so I could make them removeable.
The law as explained to me states that mud flaps must extend down to the center of the axle. I don't need all the length that I have but might leave these until they become a problem. They were pretty simple to make.
Here's a close-up of the disconnects. The larger pipe had a seam on the inside that I needed to file off to get the smaller tube to slide in. The only other thing I'll probably do it to retain the flap so it doesn't catch a lug and get pulled over the tire. I've taken them on the freeway and they flap some but haven't been pulled over the tire yet.
Thanks to Zach (brokenparts), I got another front shaft to play with. After looking and measuring I decided to cut off my CV and weld it on his old shaft. This is cutting the single joint yoke off the new shaft. Then I just took a hammer and punch to tap out the yoke.
I've got more parts to play with now.
I put the tube in the vice to hold it and put the slip in the tube to get some measurments. I leveled the yoke so I had something to match.
I inserted the CV on the other end and aligned it so the joints would be in phase. I matched the level and then welded it up. I used two passes to make sure all was well.
Here it is complete. I might end up retubing it later since it was three inches shorter than my ideal length; however, with 10" of slip I still have plenty of engagement. I put it on and called it a day.
I've been having some dash light issues. The left combo gauge was acting like a strobe and blinking quickly and my tranny temp gauge light went out. I pulled the dash to investigate and retraced my wiring. I then pulled and tested the bulbs. The bulb I used in the combo gauge was a 5-led and only three were working and for some reason blinking. I swapped it with my non-functioning tack gauge and had no problems so I think that bulb was on it's way out. I figure the tranny temp bulb burned out so I didn't get to it since I have to take the gauge out of the pod to get to it. I'll get some on order and get a few spares now that I found that I like that white color I was using.
I reindexed my throttle arm on my injection pump to the 2-3 marks instead of the 1-4 marks it was lined up with. This made the idle screw useful again and readjusted the idle. I did this because when I turned up the power screw the idle wouldn't return to the setting I had, not a run-away condition just not idling low enough.
I then started to detail the front end with a compound and final polish. The paint has oxidization and is dirty. This has really improved the shine and finish. It takes time to get it all done but it will be easier to maintain once I finish the process. I'm sure this hasn't been done to the vehicle for years if ever.
Old 09-18-08, 10:12 AM   #637 (permalink)
brokenparts's Avatar
TLCA# 16127
dang you're quick... looks good man!
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 09-18-08, 10:54 AM   #638 (permalink)
boots4's Avatar
TLCA# 19547
It ended up being real simple with what I had so I threw it together. Hopefully I'll get a chance to test it out at Cruise the Woods when I'm done with the check point.
Old 09-18-08, 11:44 AM   #639 (permalink)
Captain23's Avatar
Yep it was intercooled.
Boots, props on one of the best diesel build up threads ever!
PORTLANDERS + NW CRUISERS::
$@#!! L A N D C R U I S E R S P E C I A L T I E S !!!
H O R R I B L E W O R K , W O R S E A C C O U N T A B I L I T Y!!!
Captain23 is offline   Reply With Quote
Old 09-19-08, 12:05 PM   #640 (permalink)
Turbo Diesel Lover
Tapage's Avatar
actually I have my rotoy pump advanced 4 degrees ( from totally of 8 that you can advance it ) and my EGT fly really fast .. also I have plenty of diesel available under my skiny pedal anycase ..
Old 09-19-08, 01:42 PM   #641 (permalink)
boots4's Avatar
TLCA# 19547
Tapage I just want to make sure we're on the same page and that I'm not mis-interpreting you. I know you've been tweaking your diesel and you know this stuff well.
This timing page I found before when I started learning (still learning) more about tweaking my engine helped clarify what timing does to a diesel . Diesel Timing
What else have you done to your pump?
Old 09-19-08, 04:47 PM   #642 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I'm not sure if we share the same tipe of pump .. but In my experience ..advance the timing of my IP don't lower the EGT .. but I do it at the same time as I increase the fuel settings.
Now I can blew my pyro if I want .. sure I have plenty of care each time that i push the skiny to the metal .. don't go over 1250 ..
But the mayor advantage that I get from advancing the timing it's the low end torque at hard start .. and that why I do .. due to my stock gearing and my auto tranny ..
Old 09-23-08, 12:43 PM   #643 (permalink)
jeffsclan's Avatar
TLCA# 16057
Boots, Thanks again for the great thread. I've learned a ton just reading along.
" I'm still pissed about the Lincoln Lamp ! " 1983 FJ60 Weber carb, Aussie locker, H55F, Homemade bumpers and rock rails, winch, headers, OME Dakar springs, Saginaw ps, smog pump AWOL, 33/12.5s, 4.56s, York OBA, Camo,
1993 FZJ80 "Backbone" (wifes)
jeffsclan is offline   Reply With Quote
Old 09-24-08, 09:29 AM   #644 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
Glad you like it Jeff.
The vibs from the tires were getting worst so I decided to research some more balancing options. I'm still really drawn to the dynamic balancing idea so I looked at other media to put inside the tires that was still cheap. Unfortunately the options are limited and I decided to try out Zinc plated BBs. So in order to get the airsoft out and put in the bbs I needed to break down the tires. Being cheap and wanting to do it myself anyways I ended up buying some tire spoons and made a bead breaker. I didn't come up with the idea, just copied it from something I found online that mounts on the bottom of a hilift jack. It uses the holes on the jack base to line up and not slip off. I made the curved plated 3 inches tall and just traced the plate for the base size. I heated it up, bent it a little and then welded it together. It was 1/4" scrap I had laying around.
I first tried it out on the rear bumper on an old trailer tire I have laying around but it needed more weight so I moved to the front. Since I've got plenty of weight up front it worked well and popped the bead on a rusted steel trailer tire. I moved up to my 38s and I only had resistance with one, the other three let the bead pop right off. On the one I had resistance I used a rubber mallet to help persuade it off while under the weight of the bead breaker. This is how I placed it on the tire.
This is after a couple of cranks on the handle watching for any slipping or shifting.
I got out my new tire spoons and started playing on my rims. I tested them out on a steel rim to try and get the feel of them. On my first aluminum rim I bent the lip in two spots getting a feel for how to use them but by the second rim I started getting a better feel and on the third and fourth rim I had it down. I was trying to pull too much over the rim and found taking smaller bites worked much better.
I looked inside expecting to see the airsoft pellets broken up or damaged but I didn't. They held up just fine so that made me curious to if bbs were even going to work.
Well, I was this far so I might as well try them out and see if I get any change. I vacuumed the airsoft out and put in the bbs. I just poured the whole container into each tire ~20+ oz.
The other reason I wanted to get inside was to fix the leaky valve stems. Here's what one looked like.
The rubber on the old ones was cracking and in pour shape. I couldn't get replacement groments at the place I bought the tire spoons at so I ended up getting 4 new ones. The new is on the left and the others are the old ones.
I used the starter fluid bead reseating method of flammable fun. No matter how many I did I still flinched every time the "controlled" ignition popped that bead back on the rim. On my second rim it would pop the bead back off the rim due to the vacuum created inside the tire. I did that a couple times with the same results. I then got my blow nozzle on my compressor, bumped the regulator to 100psi and got ready to play with fire again. Once the bead popped back on I grabbed my blow gun, put the nozzle in the valve stem hole and started to blow (no valves were inserted while reseating the bead). This put some pressure inside the tire basically equalizing the pressure and kept it from unseating the bead. The first time I had to tell my daughter to go sit on the step away from what I was doing before I lite it up. The second time she never came close.
I've only driven it this morning to work and the results are mixed. The bbs seem to help balance better while at speed but I still get some decend vibs around 40mph (part of my DW problem) and they don't do so well at those speeds around curves. I know I won't be satisfied with this so my initial thoughts are to take out the bbs and get the tires balanced traditionally. I think that because the tires are so wide dynamic balancing might not be the best choice. My choice of media could also be the problem and I've at least eliminated two materials. There are lots of other materials out there but not lots of funding to try them out.
The guy at the tire supply shop gave me some samples. These are Equal samples and problems they see.
This is counterbalance. They are glass balls.
I've tried out dynabeads on my last rig. I was getting vibs but my rims were a little bent and I could have had a bad rear pinion angle so I'm not sure the beads weren't working.
I got some tie-down tracks for a present last christmas and thought I'd throw them in.
I put some right by the rear seat, on the sides like above, and one at the back. It was originally two tracks but I cut one up to give me a few more mounting choices.
I'll be helping out the Cruise the Woods this coming weekend so it'll be nice to be in the dirt.
Old 09-24-08, 10:32 AM   #645 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Two questions with these tie down tracks. If you don't mind, where did you get them? Secondly, it looks like they are attached with self tapping screws of some type instead of bolts with fender washers on the back. How do they attach, and how secure do you feel they are? I use a ratchet strap to secure my junk in the back while off-roading, which can obviously produce a ton of tension.
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 09-24-08, 11:18 AM   #646 (permalink)
boots4's Avatar
TLCA# 19547
My intended use is the same as yours.
The kit came with both counter-sunk metal screws and counter-sunk fine threads with nylocks and fender washers. The screws are spaced every 6 inches apart and I used the fine threads on the sides and the close-to-seat mounts because I could get to the backside in those locations. I couldn't get to the backsides of the rear most bar and used the metal screws for it. I only put 4 in the rear bar because I wasn't sure if I wanted to cut that one and put a couple of bars in other places.
They have a website on one of the labels so I'll go out at lunch time and get that. I imagine it will have ratings on the website. I will test out the configuration this weekend as all I have is that spare tire racheted down. That seemed solid so far.
Old 09-24-08, 01:44 PM   #647 (permalink)
FLYINGLOW's Avatar
TLCA# 9203
those tracks look like the tracks used in helicopters and airplanes for mounting seats and tie down rings. In our helicopters they are mounted with 10-32 screws but I don't know the load rating... Very handy and versatile.
77 FJ40 TBI 2F, Aussie rear, rear 45 springs, 36" TSLs, Warn 8274......
Made in Japan, Built in Canada
97 4 Runner Ltd
FLYINGLOW is offline   Reply With Quote
Old 09-24-08, 03:30 PM   #648 (permalink)
boots4's Avatar
TLCA# 19547
The tracks are called Core-trax and here's the website: Core - Products
It's doesn't talk about weight limits on the tracks but does talk about 500 lbs per load lock (accessories page).
I'll see if I can find any info on the instruction sheet that came with it.
Old 10-02-08, 11:23 AM   #649 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
Took saturday off and drove out to TSF on friday night for the Cruise the Woods '08 event. I was assisting with a checkpoint. Planned on meeting up with DirtyGipsy to caravan to the camp ground. On the way out of Portland I put it in 3rd, locked the converter and gave it a little juice to get up the hill (traffic was too slow to go into overdrive) and really started getting some vibs from the rear tires. It was the worst I've ever felt and it wasn't going away. I exited a couple miles later because the vibs weren't going away and I couldn't find a speed/load that would reduce it. I thought maybe I had a ujoint going but I check the ujoints, lugnuts, ubolts, leaf bolts, steering even though it was definitely coming from the back. After confirming there was nothing loose I got back on the road and just kept it easy and got this weird cyclical vib coming in and out. Just as I reached the exit road to meet up with DirtyGipsy he pulled up to the stop sign so I kept going straight and he pulled in behind me and we made it into camp. We went back out and got some firewood, made a fire and chatted for awhile. The next day we woke up early and got our instructions for the event and I followed another member to our checkpoint. We wheeled up the trail that the group would be coming down.
I didn't end up fitting under the tree.
While we waited I changed out my burned out headlight. We didn't have much to do and ended up closing down our checkpoint due to time constraints so we wheeled a trail on the way back to camp.
Fellow member's FJ80
The event went well and I stayed another night in the hopes to do a little wheeling the next day. The group got up, got a few things taken care of and those left went on a couple trails. Dora's not a virgin anymore, she's been mounted.
Came up to the mini rock garden and had CreeperSleeper spot me. The throw for my doubler is off so I couldn't get it in stupid low but Dora did just fine. Here's a couple of shots on the garden. I'm going do a little picture whoring.
Up top on SaddleBack mountain (I think)
If you are interested in other pics from the trip you can see them here starting with post 39: Cruisn' The Woods 2008
On the way home I got the same vibs so I resolved to yank the tires and pull those BBs out of the tires that I just put in last week. After I got all that done I was curious and took it for a drive. Vibs gone! I took it on the freeway this morning up to 70mph and very little vib! So I'll be driving around without any balance. Don't get me wrong, they aren't glass smooth but have no where near the vibs I was getting before, it just feels like the vibs from the big lugs hitting the road with no thumper (Bambi reference) syndrome.
Let me say that the diesel performed GREAT! I filled up before the trip and came back home with 1/2 tank left. I never had to give it full thottle although mud will be different. So far I really enjoy this combo and look forward to getting out more often. Wheeling an auto is great, especially one that stays where you put it.
Old 10-02-08, 01:50 PM   #650 (permalink)
TLCA# 16127
Glad to hear the trip went well Mike... I wish I could have been there. Told you wheelin with an auto is like cheating.
Old 10-02-08, 01:51 PM   #651 (permalink)
TLCA# 16127
oh yeah, you have a headlight out.
Old 10-05-08, 11:11 AM   #652 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
whats this for?
It's a Jeep thing I didn't understand. So I bought an FJ60 and now I get it.
Just bump it.
SOA in progress!
ROTW: http://forum.ih8mud.com/60-series-wa...lver-60-a.html
Dirtgypsy is offline   Reply With Quote
Old 10-05-08, 08:06 PM   #653 (permalink)
boots4's Avatar
TLCA# 19547
Yeah I know it's a little small but it's better than nothing. The boggers I have are on 8 lug rims and if I decide to swap in the 14bolt those will be ready as spares. I'll just have to get 4 other tires and rims
Old 10-06-08, 08:10 AM   #654 (permalink)
1974FJ's Avatar
Hey, that 14bolt is a C&C 14 bolt (measures ~63" WMS to WMS) I assume you plan to run a D60 front? Youll need to shorten the front 60 if you do. Have you given this much thought? Im doing this on my 40 now and it seems that maybe 62" up front will fit right with the stock perches. idk, i like the idea but its gonna be more money and alot more work. Whats your plan for this?
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
1974FJ is offline   Reply With Quote
Old 10-06-08, 04:52 PM   #655 (permalink)
boots4's Avatar
TLCA# 19547
I'd narrow the 14 bolt and get adapters for the front to run 8 lug stuff. I need to double check what ratio the 14bolt is (I believe it's 4.10), do some actual measurements to see if I can make it offset (something about just shortening the long side and running two short shafts) and to see what width I'd need to get close to the front with the adapters. Since there are two hub options for the 14bolt that gives me more options for narrowing. Definitely would need to convert to disc brakes and do a little shaving. I would also plan to run a Detroit in it. If I swap out the rear axle I'd only do it for an upgrade to something stronger and full floating.
The idea is to set it up (locker doesn't count cause I have to buy one for my rear now) for a similar price as buying polys. Still debating whether I really need it or not. I could sell my current axle and recover some of the cost. For now I'm just going to run the cruiser axle and get to know Dora off road.
Old 10-06-08, 04:59 PM   #656 (permalink)
1974FJ's Avatar
Oh ok,
dont know if you are aware or not, but you can run 15" wheels with the 14bolt drums with no shaving.
Martin Hovis
Old 10-07-08, 08:37 AM   #657 (permalink)
boots4's Avatar
TLCA# 19547
If I go 8 lug I'll most likely step up to 17" rims since there is decent tire selection for them.
As for shaving I meant the diff for a little more clearance.
Old 10-09-08, 01:50 PM   #658 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
If ya go Chevy axles, I may be interested in your stock ones... I have a 4Runner build I should get started on!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 10-09-08, 03:15 PM   #659 (permalink)
TLCA# 16127
better finish before the baby comes.
Old 10-11-08, 12:24 AM   #660 (permalink)
SAR_Squid79's Avatar
TLCA# 17716
So I just bought an FJ62...
...If I can find a step van, and drop them both off at your house - how much and how long for you to do my diesel conversion?!?!?!
~Jamie
1990 FJ62 Daily Driver
2000 TRD 4WD PreRunner
Supercharged, Locked, Armored.
Mountain - she can crawl it.
Ass - She can haul it.
SAR_Squid79 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
