Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 09-05-08, 09:47 AM   #601 (permalink)
brokenparts's Avatar
TLCA# 16127
the flex-a-lite style ones you can pick up at napa or schucks aren't worth much...I bought one and wished I had spent a couple bucks on a decent one.
These seem to work better from talking to others:
B&M 70268 - B&M SuperCooler Oil Coolers - summitracing.com
or
Earl's Performance 42510ERL - Earl's Performance Temp-A-Cure Fluid Coolers - summitracing.com
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 09-05-08, 09:49 AM   #602 (permalink)
TLCA# 16127
Flex-a-lite 3818 - Flex-a-lite TransLife Transmission Coolers - summitracing.com = poop.
Old 09-05-08, 09:53 AM   #603 (permalink)
redcorn's Avatar
Originally Posted by brokenparts View Post
42s and some double beadlocks. 13/64 for the drill bit. Makes a big difference. Make sure to run a decent cooler or you might run into cavitation problems. Be careful when you pull the restrictor, the spring wants to pop outta there and dont loose the bushing! Ask me how I know!
Dude, you know you want a buggy...................
Save the 60 as it is, wheel it and go for a buggy!!!
I bet Mark and LT would be able to build an awesome chassis for you.
No cruisers left behind, they all deserve a good home
BIG WAGONS RULE
http://forum.ih8mud.com/60-series-wa...orns-turd.html
redcorn is offline   Reply With Quote
Old 09-05-08, 10:10 AM   #604 (permalink)
TLCA# 16127
Just like Kling-on said... gotta wheel whatcha got! If my body was nice like boots I'd consider it but my 60 body is hacked on and beat...No room for a buggy either!
Old 09-05-08, 01:48 PM   #605 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I have some 39.5s for sale.
Ohh Lord .. !
Those 42" sure math with 1 Ton axles ..
Boots ... thanks for the pics .. great, big time, yes I'm running my factory Toyota Steering box and yes .. too my Tencha is as normal ( joke for Aussies ) world driven .. LHD.
HJ-60 2H-T Intercooled Tencha
Old 09-05-08, 01:53 PM   #606 (permalink)
Turbo Diesel Lover
Tapage's Avatar
BTW I forgot .. Boots, why not disconecting the wastegate and take a test run .. just to know if you see ( blocking the port at the compresor ) more than 18 PSI .. this discard the wastergate adjusting failure.
Old 09-05-08, 03:14 PM   #607 (permalink)
boots4's Avatar
TLCA# 19547
My actuator and linkage is behind the turbo so getting to it won't be a five minute job. I do plan on holding the gate shut to test that out like you suggested.
You can see that I have a bunch of stuff in front of it now and the starter is in the way from underneath. But I'll figure something out. (Time for an oil filter relocater to make removing that 4" elbow easier)
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 09-05-08, 03:40 PM   #608 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Not easy .. maybe as dificult as I have on my both Turbo Cruisers .. I notice in Tencha that have the wastegate in the same place ( in between the Turbo and the block ) that the heat make the spring and the hole wastegate system more soft ..
What I do in Marilu ( learing in the process ) it's run a halmarks boost controler ( blocker type ) it allow me to route and block the comrpesor signal ( boost ) that goes to the wastegate, before it reach the wastegate and try to open it ..
So I place the wastega in much more comfi place ..
Old 09-06-08, 06:19 PM   #609 (permalink)
1974FJ's Avatar
Hey, I dont know that the intake plate needs 30+ lbs of torque. The factory torque spec for it is 18ft/lbs. Just a fyi. Also, on the valve side of the intake plate, you may want to consider using some form of thread locker to prevent blow-by when pressurized. Have you pressure tested all your intake plumbing? with the intercooler and all, it wouldnt be crazy to have a leak some where at a joint or hose connection. You could disconnect the hose to the top of the intake plate and plug the system and add a valve stem and check to see if you cant hear the leak....just an idea.
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
1974FJ is offline   Reply With Quote
Old 09-10-08, 09:01 AM   #610 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
I had a bit of a challenge finding long bolts for the intake plate. I finally found some at tacoma screw. The long ones were 8mm x 1.25 x 80. The only flange head they had was in the 10.9 class and the heads are actually bigger so I get a little more surface area for clamping. I wrapped them with teflon tape and tighten them up. This time none of the screws felt like they were stretching so I think it was a good idea to replace them since I had to open it up.
I also found a plug for the wastegate signal line. So with the actuator disconnected, the line plugged and the intake plate tightened up I still have a leak. Yup, the gauge even bounces more but I did see 1 psi increase. I'll just keep plugging away at it and pressurizing the system may be the best bet.
My wife and kids have been pretty good about the whole project but even I needed a quick break so we headed to the beach to have some famliy time. There are certain beaches here in oregon you can drive on so it was a good chance to see if I float or sink, on the sand of course.
We found a great place out passed Astoria called Warrington OR. It's where the columbia river opens into the pacific ocean. We drove around and found some beach access. We were the only ones on this beach and the water was shallow with a gradual decline being great for kids to splash around. I motored around in 2WD the whole time.
We spent a couple of hours there and had lunch. The wind started to pick up so we packed up and went exploring some more. We found another beach with access and drove out there. This one had more people on it with all kinds of street vehicles on it. We got a few waves from other toyota's but the one I was impressed with was a semi on the beach!
This is my favorite pic of that day.
I even put a small video together from a couple of clips.
YouTube - Wheeling in Warrington OR
Old 09-10-08, 09:41 AM   #611 (permalink)
boots4's Avatar
TLCA# 19547
testing!
The next day I had the chance to do a little wheeling so I met a friend and we headed out around Estacada OR. We planned on a light trip to test things out. We got in and found a good obstacle to try. It had a vertical face of about 3ft.
I bumped up against it and just added a little more right foot and the front end popped right up.
I lightly bumped it a couple of times to see if the back would pop up but since I have no locker out back I'd end up spinning a tire and loosing traction. This is when I heard a crunching sound come from the rear end. I'll be needing a new tail light.
I decided to give another harder bump with more throttle and I found my weak link. My homemade front driveshaft snapped. If I would have been able to keep all the splines I think it would have held up but this broke right passed the weld. Talking to my friend I think he came up with a good idea and it doesn't look like I'll need all the slip I built into this shaft so I'll keep this female and get another male to replace my broken one. I'll have to lengthen the tube again.
I took the shaft off so as not to run the risk of it binding and blowing out my Tcase. My buddy asked if I wanted to park it and wheel with him but I told him I'll just play around in 2WD. So we went exploring and I followed him around. There were a couple of spots I needed a yank if I couldn't bump over an obstacle but I still had fun. He was impressed on all the places I could get to in 2WD and I was impressed too since it's an open rear end. Those tires just kept on biting.
We just left the strap on the front after the first yank to make it easier. We found some mud pits (more like deep puddles) to play in.
And then we found a nice rocky climb to play on. I did park mine and scout/ride along with him on this section. It will be pretty challenging when it gets wet and we'll definitely be coming back to this one. So we wheeled up in his rig and got to the top and it was the top of this mountain with a fantastic view!
These are two shots looking down at different spots.
Second incline section
After that we headed back down the moutain to call it a day. So for carnage I broke a front shaft, got a few more scratches (they'll buff out ), and cracked my rear tail light. On his rig he busted a lower shock mount on his front axle. Good testing day and good to re-energize for building the last few things to pound around in it.
I was turning onto my street to my place (10 houses from mine!) and a cop two cars back and in the other lane jumped over and pulled me over. I got the ol' fender flares and mud flaps warning so it looks like that'll be my project next week. Mud flaps will be easy but flares might be a little more difficult. I might just see if I can get by with flaps for a while.
I also slapped together another little video from clips.
YouTube - Wheeling in Estacada OR 9-2009
Old 09-10-08, 10:34 AM   #612 (permalink)
TLCA# 16127
Wow, where is that in Estacada? I'd like to check that out. Looks like you guys had a good time. I might also have a solution to your front driveline problem depending on the length you need. Also looks like you'll need to come over so we can bend you up some protection for your rear.
Love that Diesel sound!!!
Old 09-10-08, 10:53 AM   #613 (permalink)
boots4's Avatar
TLCA# 19547
We're wanting to go out there and map stuff out at least once a month and I think we're wanting to go more so I'll let you know when we go next. There were a couple of posted no-motor vehicle signs on some of the trails so we stayed off of those but these were still good.
I'll really do need to start bending tube so we'll get together soon and I'm very interested in your front driveshaft . Even the rear if it becomes available and things fit up. What size dies do you have so I can pick up some tube?
Old 09-10-08, 11:15 AM   #614 (permalink)
TLCA# 16127
I'm going to be down for awhile (currently pulling my axles) so I probably wont be able to make it out on the next run you guys make out there. My current driveshafts are spoken for but I had a nice one that driveline tech made for me that I was using for a spare. I'll measure for it for you tonight extended and in all the way. It's all yours if it'll fit...
Just one die right now... 1.75.
Old 09-10-08, 11:29 AM   #615 (permalink)
boots4's Avatar
TLCA# 19547
You can always ride along and be photo behach
1.75 is the size I was hoping for. Do you have a decent place to get tube on your side? The steel yard on Columbia Blvd only carries 1.75 in .095 wall and I'd like to aim for .120 wall. The one out in clackamas didn't have any 1.75 .120 wall.
Are you taking pics of your tear down? We always like pics!
Old 09-10-08, 12:10 PM   #616 (permalink)
TLCA# 16127
Yep, I'll be taking some pics along the way... not sure I could compare to this thread but I'll do my best.
No great deals on this side either. I usually get my stuff through Forest Grove Iron but they usually dont stock much tubing either. They can have what you need within a couple days though. I got my .120 through special order with the steel yard... I dont think I'll ever use them for tubing again. Sometimes they have good deals in their "overstock" for flat bar and what not but overall I'm not impressed with them.
Old 09-10-08, 01:16 PM   #617 (permalink)
jeffsclan's Avatar
TLCA# 16057
Looks like it works good. Nice and flexy (and sexy) . Thanks for the off road porn. Your diesel is too cool.
" I'm still pissed about the Lincoln Lamp ! " 1983 FJ60 Weber carb, Aussie locker, H55F, Homemade bumpers and rock rails, winch, headers, OME Dakar springs, Saginaw ps, smog pump AWOL, 33/12.5s, 4.56s, York OBA, Camo,
1993 FZJ80 "Backbone" (wifes)
jeffsclan is offline   Reply With Quote
Old 09-10-08, 05:12 PM   #618 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Thanks for the pics .. the story but the best sure, the video ! thanks .. sound like a good baby this 4BT .. so you found your leak . ?
Old 09-10-08, 05:35 PM   #619 (permalink)
boots4's Avatar
TLCA# 19547
Nope, I'm still looking for it and I think I had a couple so while I've fixed some others are showing up. If all I need is more fuel I'll feel pretty stupid but that fluttering boost gauge seems to indicate I haven't found them all yet. So I still feel like I haven't really seen what this engine can do yet from free power although I test it out everytime I get on the freeway .
Old 09-11-08, 01:27 PM   #620 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I saw that you already disconect your wastegate .. but not if you see more boost .. and together if you adjust to more fuel if you get more boost .. ?
how are your EGT's .. ?
The 4BT use a butterfly at the intake or any other sort of blokage that can cause a turbo spike .. ?
Old 09-11-08, 03:15 PM   #621 (permalink)
boots4's Avatar
TLCA# 19547
On our trip out to the coast I hit a couple of climbs that I pulled in 3rd tconverter locked and hit close to 1100F doing 70mph. Climbing in 4th locked I could see 1200F doing 70mph. This is with 17-18psi of boost (wastegate signal plugged) and if I got more I could probably safely add more fuel. I did see higher boost in 3rd than in 4th due to more revs but I'm tach-less still so I don't know the actual rpm. If I can get the boost gauge to mellow out (find the leaks) I'll probably play with adding just a little more fuel to see what EGTs do. If I push more air in there the EGTs will come down from what I have on my current settings so I'd probably have a little more room for more fuel.
As for engine temps with one fan going I stay at 190-200F.
When I was wheeling I just left the one fan going the whole time and temps never got hotter than 190F. The tranny ran up to 190F when in tcase high and would stay around 170F when going around in tcase low running the one fan.
I need to reset my spal controller as the temp range is too close together right now and it cycles between high speed and low speed. It's harder to get the temps up to 205F for my high fan setting just idling when it's not getting as hot outside anymore. The other fan still isn't hooked up as I was troubleshooting the relay wiring and haven't gotten back to it so it's disconnected right now.
As for restictions like a butterfly valve there is no valve, it's all open.
Old 09-12-08, 10:00 AM   #622 (permalink)
Turbo Diesel Lover
Tapage's Avatar
And if you know any other similar setup like yours ( 4BT ) how much boost are capable the engine/turbo combo ?
Old 09-12-08, 11:55 AM   #623 (permalink)
boots4's Avatar
TLCA# 19547
This turbo should be able to get me in the 30s without a problem (leaks fixed and correct fueling/timing) and having a little bigger compressor will give me a little better topend. The head gasket at factory torque specs is generally safe up to the low 40s if it's in good condition. If you retorque the head following the 12v 6bt guys some are running 50-80 psi on stock head gaskets with over torqued bolts. It's amazing what some of these guys are pushing through their engines and laying down on the road! While I'm not a 6bt, only seeing 18-20psi max on my 4bt seems small when there is much more potential. In the future I can see bigger injectors and another turbo combo but since I doubt I'm close to maxing out this setup I'm going to get to know it better and get those leaks fixed. Obviously I'm convinced I have leaks and that there is more potential to be had in my current setup.
Some things just take me a while, for example, I finally realized why re-indexing the throttle lever will get the idle back down from when I added the 366 spring to the injection pump and turned up the power screw. Re-indexing the lever will add more spring tension returning it to my idle setting. Turning in the power screw more has caused a higher idle so I need more tension to overcome that and return the throttle lever to my idle setting.
Old 09-13-08, 11:21 PM   #624 (permalink)
TLCA# 16127
here ya go Mike... sorry I've been making my cruiser levitate.
about 40 extended and about 30 compressed.
Old 09-14-08, 11:29 AM   #625 (permalink)
boots4's Avatar
TLCA# 19547
PM'ed
Old 09-14-08, 03:36 PM   #626 (permalink)
TLCA# 16127
and back at cha.
Old 09-15-08, 05:48 PM   #627 (permalink)
Turbo Diesel Lover
Tapage's Avatar
damn ! Mike those are serious numbers .. up to 40 PSI factory head&gasket and bolts .. damn ! those rods, pistons and else can hold fine this king of pressure .. ?
Thought I need to move to a 4BT soon !
Old 09-15-08, 06:35 PM   #628 (permalink)
Boots, which H1C are you running? What year Dodge did it come off of? Was it an intercooled or non-intercooled? (changes the impeller size). I'm running a 52MM compressor H1C on my 4BT, with a 12CM nonWC housing. Right now, it can hit 1200 F without even a hill... and has very low boost... 12-15psi.
gifu is offline   Reply With Quote
Old 09-16-08, 10:57 AM   #629 (permalink)
boots4's Avatar
TLCA# 19547
I got the H1C from a 93 6bt a friend gave me (thought it was intercooled but not sure). I replaced its exhaust housing with my 12cm wastegated housing and currently have plugged the signal to the wastegate with no increase in boost. I measured the inducer at 54mm and the turbine sizes were the same. The full details are HERE.
My reasoning on why this combo should get more boost is because the H1C turbines looked the same and the angle on the compressor wheels looked the same, just a bigger inducer. If some guys are getting easy 20s and some with low 30s (with enough fuel) with H1C why can't we. A bigger inducer should mean it can move more air. Maybe we're not spinning our engines high enough to get that full potential (could see this if the compressor vane angles were different), we don't have enough fuel going in (although with high EGTs we're inclined not to add more fuel), or there are other issues like cylinder blowby and psi leaks. Does your gauge flutter and where are you tapped for your signal?
Old 09-17-08, 11:34 AM   #630 (permalink)
my gauge doesn't flutter. the boost gauge is tapped at the manifold. I have yet to move any fuel or timing settings since pulling the motor from the breadvan. Correction: mine is a 54MM compressor. Same-same as yours. My buddy is running the baby H1C, i think it's a 46 or 44MM compressor, and he's using a 12CM housing (assembly #3523322). His truck will boost to about 20PSI pretty, and pretty fast. But he sees some EGT... about 1100 Pre-Turbo on a long hill. That's pretty hot.
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
