06-14-07, 01:47 PM
#31 (permalink)
Great project! Very interested in the 4l80e to 203 adapt.
85' FJ60 - 2F, desmog, 4-spd, 4.88's, Aussie rear, SOA, 37's on 2" bs ***FOR SALE***
95' FZJ80 - new to me, some mods, details to come...
Copper State Cruisers #71
KavikOffRoad.com
60 Series porn
06-14-07, 01:58 PM
#32 (permalink)
Kavik Great project! Very interested in the 4l80e to 203 adapt.
I'm pretty sure I'll have to redrill the bolt pattern and change out the input, but what I won't know until I get them together is if I'll need to shorten the the output on the tranny.
I've emailed murdak about the 203/splitcase adapter but haven't gotten a return. Are he and that other place mentioned in the 203 doubler thread the only ones that sell this adapter? I'll try calling him, too.
build-up: Family Haulin' FJ60
06-14-07, 02:10 PM
#33 (permalink)
I got my adapter from Gary (Mudrak). I have a 700r4 w/ the AA tailshaft already installed. But, my donor 350tbi has a fresh 4l80e already bolted up.
Try the coloradok5.com forum for GM stuff...
Decisions, decisions....
KavikOffRoad.com
60 Series porn
06-14-07, 03:03 PM
#34 (permalink)
Let's try and finish the catch-up. The rest of the pics will be some misc. parts and the start of some of the little stuff.
Here is the intercooler that came from the stepvan. It was black so I sanded off the paint from the fins and painted the ends a cream color. I like the aluminum look through the grill. It almost fits between the supports, so I'll have to do some cutting and this will go first in the cooling row.
I do have a question, but let me set it up first. I plan on stacking the cooling row like this: intercooler-FJ60 AC evap (if thats the right name for it)-FJ60 radiator. I'm going to run a large tranny cooler too, so where would you put it? In the cooling row or locate it separately?
infamous rusty inner channel being yanked
other side. It's not bad but I need to box in the rear section for the shackle mount and it doesn't make sense to leave it in to rust away.
it ended up taking me 1 full day just to get these suckers out! Only have a grinder, drill, and BFH, and prybar to get those out. I was sore the next day from pounding so much. But, alas... Victory!
You can see where the water stays and the rust forms. Luckily it will be fixed by cleaning and painting and not surgery. Back to the pass. side.
The brakes worked well on the stepvan so I'm using the system. Master cylinder painted with rustbullet.
my hydroboost came with a separate resevoir. cleaned/painted.
the hydroboost unit. Since diesels don't produce enough vacuum to run a brake booster I'd have to get a vacuum pump or go to hydroboost. Yup, that was an easy decision.
brake master goes on this side
other side. it's got three ports.
measured the distance from the mounting plate to the center of the hole on the back side of this to find out how deep to mount the hydroboost unit on the firewall
and then I made this
so that it could to here. reused some more parts from the original bracketry in the stepvan
secured those studs and quickly slapped on some paint (I'll probably repaint it)
and it mounts to the back of the hydroboost unit like this.
I just cut up the bracket on it and welded the center section into a new plate. I did it that way because it has that notch in it and I didn't want to run to the store to find the perfect sized hole saw. I might not have gotten the notch in the right place meaning the tilt on the brake master might be too much. It did have some tilt on it and if it ends up being too much I'll probably just remove that notch in the circle and rotate it accordingly. The circle is a tight fit and I won't need to find something special to seal the hole on the firewall. I will reuse the cruiser gasket that was on the firewall when I took off the original unit. That should seal it up so I don't have air leaks for cabin comfort.
06-14-07, 03:19 PM
#35 (permalink)
I really like what I've read about the 4L80. If you are going to run big power and that 700r4 is just stock I would lean towards the 4L80 but I know the decision isn't as simple as that.
Stuff you might know: to operate the 4L80 you will need a controller, either aftermarket or the computer that you got that combo out of. What I've read is it's easier to set up an aftermarket controller rather than trying to get the factory stuff to work right. Then there are the sensors like the VSS that you probably don't have since the 700r4 isn't electronically controlled. Plus the 4L80 is bigger and tranny mounts might not line up. The flywheel flex plate also has a different bolt pattern than the 700r4 so if you plan to slap the new engine and the 700r4 together that will have to be dealt with. You will probably get more money out of the 4L80 if you sell it, thus funding other projects.
I choose the 4L80 over the 700r4 mostly because I'm running a diesel and wanted the extra strength. The lower first gear ratio didn't matter to me because of the torque curve of this diesel. Sounds like a good decision to wrestle with.
06-14-07, 04:22 PM
#36 (permalink)
I choose the 4L80 over the 700r4 mostly because I'm running a diesel and wanted the extra strength. The lower first gear ratio didn't matter to be because of the torque curve of this diesel. Sounds like a good decision to wrestle with.
The 700r4 has been beefed up a bit during the rebuild, and the TBI will remain mostly stock. So, I think the simpler & "beefy enough" route is the 700r4. Plus all of the adapters I have are based on this combo.
That being said, the 4l80e should be perfect for your application. I know a good running diesel can produce some evil torque, so you should be in good shape on and off-road.
By the way, I'm doing a similar SOA lift (shackle reversal w/ low profile hangers, etc).
Your build is looking good. Keep up w/ the pics.
KavikOffRoad.com
60 Series porn
06-14-07, 04:46 PM
#37 (permalink)
I've got some rust on the back lip that holds the weatherstripping on . I pried it away from the body and found minimal transfer of rust. I'll just replace it with some angle iron so that the gate will seal better.
more rust
this is the seal between the tranny and transfercase. Mine leaked so I'll replace it. Too bad Marlin doesn't make a new improved seal for this like he does for the axles. I guess I'll have to do this again in another 20 years.
blacked out the headlight bezels
cleaned up the pressure fittings that connects stuff after the turbo
comparison between front and rear stock axles. Those rear landcruiser axles look stout!
I'm just going to run the rears and if I break one I'll upgrade.
rear disc idea. I bought new front discs and plan on doing the 4runner upgrade but when I started pulling stuff apart the fronts looked pretty good. So, not to be wasteful, I'm going to use my old front stuff to set up rear disc brakes. The mounting ears for the drum assembly will need to be ground down just a little for clearance and I'll mount the discs to the backside of the axle since it won't fit over the flange. The original rear studs don't have a long enough shoulder to bite into the axle flange so I was going to check if front studs will work. If not I'll need to find some that will work. Then it's just making a bracket and lining up the caliper.
the nut on the bottom is what I pounded on to get the studs out. I'll get a new one.
the axles
Well guys, I'm finally caught up. Thanks for going through so much in such a short time. I started the project only 5 or 6 weeks ago. I am plowing on so I hope to be wheeling in a couple of months. And I've finally decided on the configuration that I want to run so now it will be about getting some time on it, and of course sharing the pics along the way. I'll generally get new pics updated at the beginning of the week after a weekend of wrenching. Post away.
06-14-07, 04:47 PM
#38 (permalink)
Thanks for all the post so far, I'll probably have questions when I really get into the building part of the build-up.
06-14-07, 09:21 PM
#39 (permalink)
lookin great man...i want to put a 4bt into something i build in the future
what's the plan for an e-brake? interested in any ideas you've got, i'm stickin w/ the rear drums on my fj62 axles for now...not a fan of the GM swap or of the t-case mounted setup.
also, how large is that intercooler in relation to the radiator?
malphrus
'these are my awards, mother, from army. the seal is for marksmanship and the gorilla is for sand racing.'
...build-up here (stalled)...
06-15-07, 09:28 AM
#40 (permalink)
have you hooked the linkage to the hydro unit yet? I cut the end off the hydroboost rod and then threaded it to accept the stock toyota clevis. Lookin' good .
1977 fj40 All Beat Up ... But Still going strong !
1993 80 series
06-15-07, 12:13 PM
#41 (permalink)
Plans for the ebrake will be line locks and/or probably a tcase unit. I haven't liked what I read about the GM stuff either and I have all this stuff already in good condition. It will be a cheap way for me to get disc brakes and control the 38s on the slow down.
I'll have to get a pic of the intercooler and radiator together so you can see what it looks like. They are close to the same size.
The good news is that I just sold the Turbo400. Yeah it was cheap but at least it's gone (less clutter, I still have a cut up stepvan that I need to haul off the yard) and that's more money for the project. I'll be picking up my 4L80 today too.
06-15-07, 12:15 PM
#42 (permalink)
Too Tall,
I haven't hooked the linkage up to the hydroboost unit and I like your suggestion. Do you have any pics of that setup?
06-15-07, 03:15 PM
#43 (permalink)
Bummer... Called the place I'm getting the tranny from and there was a "shipping" problem. My tranny is at a different location and they only have a truck coming on Monday. Looks like I'll be waiting another week to pick it up since they close before I get off of work on my work days. Guess my luck ran out.
On another note I did get the 203 separated this morning. I've got a show tonight (play keys in a local band) so unfortunately I won't get a full day in today.
06-15-07, 05:44 PM
#44 (permalink)
where ya playin at?
06-16-07, 01:08 AM
#45 (permalink)
We just played at Tiger Bar tonight. It was a good show. Sorry I didn't get back to you earlier. We are working on some public access TV thing so I'll let you know if it airs anywhere.
06-18-07, 09:14 AM
#46 (permalink)
cool... I just work up the street from there.
06-18-07, 11:03 AM
#47 (permalink)
monday morning update
Had to work on the DD some. It's going to need some attention in the near future but it's hard to divert my cruiser attention. I got some pics for 72cruiser asking about the intercooler size relation.
Started separating the 203 and ended up doing the cheater cut with a grinder on the rod that controls the backhalf. Anybody have any pics of drain and fill ports on a 203 doubler?
Backhalf
front half (gear reduction part)
203 s****
intercooler and radiator. It's about as wide but not as tall as I thought.
Other side. I might offset it slightly for radiator fill clearance. We'll see if it's that big a deal in the rig.
Front wheel stud on the right, rear wheel stud on the left. I pounded a set in with the disc on the rear axle using the front studs. Everything looked great until I tried to mount the rims and found that the lug nuts were bottoming on the stud and not the rim. Either I'll need new studs to work or put a spacer between the back of the stud and the disc. I'd rather find new studs that will work.
cleaned the back of the flanges where the discs will mount
next I started doing some painting. Front hangers
painted rear channels
painted the front calipers I'll be using on the rear
another shot
made a bracket to interface the brake pedal and the hydroboost unit. made it longer so I could adjust if needed. I haven't decided whether to drill a hole and weld it, or tap the hole and the rod on the hydroboost unit to just screw it on.
I'll have to cut that eye off to weld or tap.
got a little carried away grinding and cut into this wire. Electical tape will fix that right up, don't ya think?
some parts I've had waiting to be installed. I ordered a set of used FJ62 diffs for the 4.1 ratio. I'll throw this locker in the front and work on funding for one in the rear. The rear will be easier to do later with the access cover.
these boxes are shiney bling
my slotted bling going on the front with 4runner calipers
06-19-07, 02:16 PM
#48 (permalink)
Turbo Diesel Lover
Dude it's amazing ... Nice proyect and thanks for share all those pics, comments and story
I have one comment in your build up .. and a side note I never dealing with cummins engines.
But .. in Toy engines in 60 series, 2H and 12H-T the temp issue is important coz you haven't really much flow rate coz the 60 haven't a wide front grill to allow it ..
So if you gonna palce the intercooler in front I thought you don't gonna have enought room to grill+intercooler+AC condenser + rad .. ( forget tranny cooler )
IMOP you can run without grill intercooler + AC stuff and rad .. and place the tranny cooler in other side .. with a electric fan.
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
06-19-07, 04:33 PM
#49 (permalink)
Thanks tapage for your comment. I've followed your cruiser and I think many here including myself feel it's one of the nicest chop tops done. Do you have a site where you post your wheeling pics? That would be great to see.
I've been reading that diesels tend to run cooler than gassers and some of the guys doing these swaps (4bt's but not landcruiser specific) are having a harder time heating up during the winter months. I pulled the water pump just to check it out and it looks like it will move a decent amount of fluid.
I was thinking that with some restriction I could get it to heat up better. I was thinking of running an electric fan (ford contour-dual fans) with the DCC controller even though my 4bta came with a mech fan. I have ideas that I could wire one side or both to be on a low speed so that the intercooler gets constant air flow through it, but maybe it doesn't need it. I'll have to post that question on the 4btswaps site to see what they think and if any of you are running and intercooler perhaps you could chime in: Does an intercooler need constant air flow through it?
That's the only reason I could come up with as to why this 4bta had a mech. fan and others come with electrical fans.
Where do you guys recommend placing a tranny cooler if it's not grouped with the radiator? If it's not in front should I look into a cooler/fan combo?
06-19-07, 04:37 PM
#50 (permalink)
Also, as for placement of the intercooler-AC-Radiator I will probably have to do some custom mounting meaning the radiator probably won't bolt into the same location. That should make room for the whole stack to fit behind the grill. I love the 60's grill so I've got to keep it.
06-20-07, 10:45 AM
#51 (permalink)
Turbo Diesel Lover
I have some wheeling pics in the local forum ( here in Panamá ) and videos .. but haven't yet any with the ragtop evolution
Fact it my bad .. I'm alwais thinking you are here in Panamá where the heat it's a issue .. but fortunately for you not !
To get better performance form a intercooler, you must keep the air flow throught this .. but if it centanly afecto your performance .. maybe you don't gonna feel it at low rpm/speed ..
In fact when you need all HP and lb/p from your engine, most of the time gonna be in the HW at high rpm/speed when the aire flow thought the intercooler/AC/rad come great .. and you get the better performance from your intercoled engine.
Anycase at low ARM with a manually activated electric fan front or behind the intercooler make the job ..
06-22-07, 12:43 PM
#52 (permalink)
OHV Trail Patrol
It was good meeting you last night! Get this thing done so we can go wheelin!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
06-25-07, 11:22 AM
#53 (permalink)
more stuff
I've been waiting to find someone with a 1 inch breaker bar to get those lug nuts off of the stepvan rear so I could get to the leaves. I didn't want to wait any longer so I yanked the leaves and preped them for painting.
I tried a couple of configurations and decided on this: ranger main-stepvan 2nd-ranger 2nd-stepvan 3rd-stepvan 4th. So it's a 5 leaf pack. I thought it might be too light since the landcruiser packs have more than that and the 4bta is a few pounds heavier than the 2F, but the landcruiser leaves are thinner than these so I'll start with this and if I need more I preped 4 more leaves for add on front or rear. The center bolt is too long so I'll need to pick up a shorter one to tighten it up.
the front and rear packs for comparison
the rear pack mock up. I want to move those back just a little because cuting the well up behind the wheel will be easier than messing with the front of the well. I already plan to cut the rear quarter panels anyways.
about where the front will hit
about where the rear will hit
here is my grill finished. I thought I might be the first to try this sceme out but there was a FJ62 that posted a similar look, darn. I used that hammerite stuff.
cutting up some of the stepvan frame to make my box sections for the cruiser rear end.
made these to fit inside the cruiser frame for welding. Painted the inside side.
outside side
here's what they look like in the frame. I'll put a diamond-shaped plate over the vertical weld to tie the two together.
finally got my tranny. shipping dilema over. 4L80e passenger side.
drivers' side, it had a gear position sensor unit on the shifter but I took that off since I don't plan on using it.
bellhousing and torque converter. I'll need to get a different torque converter to better suit the torque curve of the diesel. Will definitely want to keep it lock-up too.
4L80e rear. I did get the 4x4 adapter but I took it off to see what it looks like on the 203.
painted the front hubs
4x4 4L80e adapter tranny side.
4x4 4L80e adapter transfer case side.
4x4 4L80e adapter side view
06-25-07, 11:31 AM
#54 (permalink)
Rough mock up of the 4x4 4L80e adapter on the 203. I won't be able to mark any holes for drilling until I get a 32 spline input shaft and install it to center it on the tranny output.
cut up the front disc backing plates and kept these for the spacing.
That's what I got done last weekend. I have a baby "coming" next weekend (he'll come when he really wants to but the induction will be next weekend) so I'll get outside when I can. I also received my FJ60 3rds this weekend. I wanted the 4.1 diff ratio and used ones were much cheaper than new gears.
06-26-07, 10:52 AM
#55 (permalink)
OHV Trail Patrol
Wow... you did get a lot done last weekend! (Thanks, Grandma!)
KE7VSA - MetalTech
06-26-07, 12:14 PM
#56 (permalink)
Yeah, it's always great when grandma comes. No matter how old I get she likes to fill up our freezer whenever she comes.
07-03-07, 10:24 AM
#57 (permalink)
No baby yet so I got a chance to work outside.
Finally got the rear frame boxed in. Since my ready welder is powered by batteries and I was only able to get a five inch bead before a charge was needed I knew my batteries were shot. I had my batteries tested and only needed one. Once I hooked them up together I was able to weld all I wanted. Much better.
Passenger side
driver side
I've got 4.10s and the original 3.70s to play with. I plan on running the 4.10s since I have an overdrive tranny.
made the rear hangers, just need to drill the holes on my neighbor's drill press.
started cleaning off the tranny. This is the torque converter and the filter. I talked to txchange.com since they are local and got a quote for a HD diesel converter for $230 and a billet one for $293. They will also take my TC even though it's a higher stall for the core charge. I've got a few more places to call but I thought that was alright plus they are local.
input shaft. I grabbed a seal to replace since I'm in there.
took off the pan and wiped up. I just bought the trans-go kit to convert it to full manual and will be reading the instructions 7 times before I do anything.
07-03-07, 11:53 AM
#58 (permalink)
 awesome rig so far
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
07-03-07, 12:08 PM
#59 (permalink)
OHV Trail Patrol
Lookin good!
KE7VSA - MetalTech
07-03-07, 12:37 PM
#60 (permalink)
the 203 centers on the bearing retainer, not the input shaft. So it makes no difference what spline count the input is.
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
