06-13-08, 10:07 AM
#511 (permalink)
Originally Posted by 4alarm
Wow, all that work in 1 year! I've only been working on mine for 4 years now, and I still haven't driven it.
I love the work that you do. Did Dora mention how clean the intercooler is now?
LoL, the turbo does build boost quicker now when I've got the t.converter locked up then it did before with Dora hanging out. You know, this episode just may have named my cruiser. Maybe I need to call it Dora the explorer. No worries, I won't be sporting any Dora stickers.
You've had a bigger non-cruiser related challenge than I so you have the right to take a little longer. I think it's great that you keep pluging away on that 40, plus you are so close now. I know for me having the project keeps my mine a little sharper and something to look forward to.
build-up: Family Haulin' FJ60
06-13-08, 02:07 PM
#512 (permalink)
no doubt about it... your cruiser is now Dora.
06-13-08, 05:27 PM
#513 (permalink)
"I won't be sporting any Dora stickers. "
don't be too sure of that.... see you soon
clint
06-13-08, 05:32 PM
#514 (permalink)
Uh-oh... maybe I'll be driving the car to the cruiser meeting next week instead of taking the 60 just in case someone decides to sticker it for me.
This guys looks like he might do something.
06-16-08, 12:49 PM
#515 (permalink)
OHV Trail Patrol
Werd...
Sticker is being made as we speak...
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
06-16-08, 04:41 PM
#516 (permalink)
OHV Trail Patrol
Creepy...
Nevermind... Cancelled sticker order after seeing this...
KE7VSA - MetalTech
06-17-08, 12:45 AM
#517 (permalink)
  That's some great stuff. That dancing Dora sure was freaky.
06-19-08, 11:17 AM
#518 (permalink)
weekly update
I did some more ordering last week and one of the parts that came in was my downturn. Didn't need it to be chrome but that's all I found. I moved the baffle so that it spans between the downturn and the exhaust. I just quickly put it on but plan on finalizing it later.
I had a hard time getting the male spline to slide in and out of the female so I smoothed the first set of splines and removed the second set of splines. It slid in and out fine after that. The left mark is where I wanted ride height to be and the right mark was right before the shaft would hit the cap on the yoke. That cap did pop out eariler so I tacked it back on to help keep the muck out. I determined travel by ramping it and decided I wanted more slip when extending the driveshaft due to the shackle angles I was seeing (it is going to allow the axle to travel forward more than backwards). It will give me about 8-9" of total slip travel with about 6" of it for extention.
Called NAPA like the toyota trails article did and they didn't know anything so I called the six states distributers that was nearby and they had something. The toyota tube was 2.557 OD and they had a 2.75 tube with a .083 wall making that 2.667 ID. I measured that I needed 12" and it cost me $8. If the shaft holds that makes it a $50 drive shaft since I bought an earlier fj60 shaft for the DC joint and had the regular one that came on my rig.
I cut and cleaned up the tubes on the two pieces.
Tubes slid in no problems but weren't loose.
I didn't trust some of the surfaces I had to give me a level reading so I ended up using a piece of straight angle iron to get the yokes phased.
From there I tacked it, tested it on the rig and found I needed just a little more length on the tube so I slid them out just a tad and welded it up. I used the 85' axle side yoke so the bolt pattern was the same but the tcase pattern was different.
The nice thing about the flanges is that it's hubcentric meaning it centers on lip on the yoke and hole on the flange so I rotated it, marked and drilled holes. I marked it like this and then drilled it separately.
I took time to get the holes the right size so I could use my studs again, got it all together and I couldn't find where I put the nuts. After looking for a while with no luck I ran to the hardware store and grabbed some fine grade 8s. I drove out the studs and put the shaft on and used my new hardware. Drove up the  ramp to test extention and 4wd. Locker works good and I got another foot up my ramp. I still have plenty of travel on the slip.
This is stuff on my shock travel. The tire is being limited by the fender right now so I will drop the bumpstops to this point and trim the fenders.
I have 1/8" clearance between the leaf pack and the tie rod. I was thinking about adding one more leaf but after seeing this I think I'll stay with the slight slinkbug appearance. I do tow with this so my stingbug stance is useful.
I drove around the yard a little with the front engaged and left a few marks on the lawn. I told my wife that it was just like arrating it for root stimulation. I don't think she bought it. I didn't try taking the shaft up to speed so I don't know if or how bad it will vibrate but I'll try it out soon. Time for more fender trimming and getting my linkage on my shifters dialed in.
06-19-08, 11:29 AM
#519 (permalink)
Nice excuse........core arration(sic)...
I'll have to remember that one.
I just buried my 60 @ the river while swimming my dogs.
Time to rebuild my front axle and get back to 4 wheel drive....
glad you are making progress!!
john
06-19-08, 05:23 PM
#520 (permalink)
Turbo Diesel Lover
I maybe be more carefull with the compresion travel of the fron DS with shackle reversal due to the leng of your shackles and the softness of your springs ..
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
06-25-08, 03:37 PM
#521 (permalink)
does your tr rub when you turn left to right vise versa, i know you got some clearance but make sue thats turned both ways
looks good
06-26-08, 10:05 AM
#522 (permalink)
looks good
At ride height I get no rubbing turning left or right and that's without the steering stops back on the axle yet. Now when stuffing the tire that's a different story. That will require more trimming, something I planned on anyways.
06-26-08, 11:39 AM
#523 (permalink)
weekly update
Just worked on a few little things last break. I lost a day replacing all the hard metal lines on an older toyota Camry from Ohio. Her brake lines had rusted through and was pissing on the ground every time she stepped on the brakes. My hat is off to you guys who have to work on "rust-belt" vehicles, it was no fun.
I ordered a newer water temp sender to work with my spal controller. This was pretty cheap and I like the screw-on wire connection instead of the slip-on that comes on these 4bts. I didn't get a chance to re-set my controller yet but the cruiser temp gauge is reading better. Before if it made it 1/4" up the bar part on the gauge it was over 200F. Now it's just shy of the middle at 190F. With a couple of hot days it will be easy to get the controller set up since on cold days it's harder to get the engine hot.
I did some research and decided that the intelligent solenoid from National Luna was what I wanted to charge and isolate my dual batteries. It's mostly aimed toward the expedition crowd who need their stuff dependable when out in the middle of no where for long periods of time. The wiring challenge I have is that I need to run 12v for the vehicle system and then want to be able to hook up hook up in series (24v) for the ready welder for trail repairs. From a couple people I briefly chatted with it seems the best way will be system of disconnecting. I've got some ideas and need to get to a welding store to grab some wire and see what kind of connectors they have.
I worked on my shifter linkages. A group of wheelers will be at the local stomping grounds and I'm planning on meeting them out there to do a little wheeling this weekend. This is the 2-4wd linkage. I made it out of thicker material since I needed to put a bend in it for clearance and out of my three levers, this one shifts the easiest. I played with the shifters and it will get me by for now.
I painted both drive shafts (you can see part of the front in the pic above) and a few other parts while I was underneath. I must admit, having a ramp to flex on in the work area is helpful. I checked for clearance and found my rear tires do rub on the body mounts.
So I cut out a piece for additional clearance. I found that there is a point of diminishing returns in trying to get my rear tires to stuff much more. The leaves contact the frame in two places and the shock finally contacts the spring plate along with fender contact. I worked on bump stops but my first round was greatly underestimated so it was back to the drawing table to take another stab.
These are the way-to-short front extensions.
Here are two pics of stuff and droop from a different angle when I was looking for clearances.
More than enough travel on my extended brake hose going to the axle.
Then I had a little distraction curious in what I was doing.
I was looking in my scrap pile for something to extend the bump stops with and got the urge to clean up so I started getting ready for a metal run. My wife was happy about that one.
I conveniently ran out of wire and steam while working on the rear stops at the same time so that ended my break.
I'm going to try and get the temp sender programmed, finish my bump stops, and finish sealing up the rear quarters before the wheeling trip. Hoping to have a few wheeling pics next week.
06-26-08, 12:52 PM
#524 (permalink)
wish I could join you guys this weekend but I'll be at my daughter's soccer tourny this weekend. Have fun and bring your camera!
06-26-08, 03:33 PM
#525 (permalink)
Bummer, I'll be there the 29th.
06-28-08, 02:03 PM
#526 (permalink)
Filled up today and got 18.6mpg on half a tank. It's a little easier to stomach filling half a tank instead of a full tank. I did drive a little more judiciously this tank. The goal is mid 20s so I've got more tuning to do. Still, not bad for fat tires. Hate to see what the 2F would be getting with my current setup.
07-01-08, 06:21 PM
#527 (permalink)
OHV Trail Patrol
Wheeling pics!
KE7VSA - MetalTech
07-01-08, 10:31 PM
#528 (permalink)
You just reminded me that I still need to make bump stops!
Looking good.
-Josh
'70 FJ40 (work in progress)
'85 FJ60
'02 Sequoia
'08 G35 Sedan (Wifey's)
TLCA Member #14566
My Build Up
My Pictures
07-02-08, 10:15 AM
#529 (permalink)
weekly update
07-02-08, 10:38 AM
#530 (permalink)
Great job, Boots. Your truck is beyond badass!
Look for some of those pics in my gallery soon!
85' FJ60 - 2F, desmog, 4-spd, 4.88's, Aussie rear, SOA, 37's on 2" bs ***FOR SALE***
95' FZJ80 - new to me, some mods, details to come...
Copper State Cruisers #71
KavikOffRoad.com
60 Series porn
07-02-08, 12:01 PM
#531 (permalink)
So sweet and all that in 365 days!!
Hats off to you!!!!
I could care less about stereo in my rig, but I gave in about a year ago.
I am running a Scion XB head unit for the sounds in my 60.
Nice unit, Ipod and satellite compatible and it was only $50.00 on Ebay.
Coupled with some Infinity speakers in the doors, I can jam out as I wheel.
Happy Fourth of July to you and yours!!!
john
07-02-08, 12:13 PM
#532 (permalink)
Where's all the pics of you going up lil'rube, can opener, and waterfall? Just kiddin... looking good boots. I'm going to head out there hopefully on Sat. if I can find some peeps to go with me.
07-02-08, 12:23 PM
#533 (permalink)
Turbo Diesel Lover
Dude .. your Cruiser looks incredible with those tires .. the hole pic it's sick !
07-02-08, 03:10 PM
#534 (permalink)
OHV Trail Patrol
I sure like the way the pic turned out shooting into Dani's side veiw mirror... The 60 did great! Keep ironning out the bugs and lets get that thing up Lil Rubi!
KE7VSA - MetalTech
07-02-08, 07:34 PM
#535 (permalink)
Hats off to you!!!!
john
Yeah, I'm wanting more sound again and I didn't mind sniffing wood dust compared to metal dust for a change. I didn't buy great stuff in case it gets stolen or ruined from wheeling but stuff that sounds decent. It's stuff I already had in there before the build, just putting it in a different spot now since I want to do something else with the rear panels. I'm still debating about the sub design I was planning on. It'll be bigger than I wanted.
Me too, another favorite.
07-03-08, 02:12 AM
#536 (permalink)
Your rig on the road  , nice pics mate,
07-03-08, 01:32 PM
#537 (permalink)
Looks awesome! Congrats on finally getting her on the trail!
...SLIDERS!!!
~Jamie
1990 FJ62 Daily Driver
2000 TRD 4WD PreRunner
Supercharged, Locked, Armored.
Mountain - she can crawl it.
Ass - She can haul it.
07-06-08, 07:09 PM
#538 (permalink)
Killer truck! My 100 is going bye bye soon and I will have a 60/62. Yours will be one of the builds I am going to follow for motivation/ideas!
2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers, Misc scratches, etc...Sold...What is next???
M101 Trailer - Sold & sadly missed...
07-10-08, 11:38 AM
#539 (permalink)
weekly update
Family was in town so I spent time with them but I did get a little done.
I found the air filter I wanted. It was the powercore by Donaldson that Volant sold in a universal application. I put in my first order 6 months ago. After three months and a couple of emails saying the manufacture didn't have any dates on when they'd ship it out I cancelled my order and tried another store. After another three months the store I ordered it from cancelled my order and refunded my money. I was bummed because I really liked the features of this powercore filter. I hopped on the internet to search for something else and decided on an Amsoil Ea air filter (ironically also made by donaldson) and put in an order. I also got some fittings from Intake Hoses, IntakeTubing, and Intake Clamps to hook things up.
Everything showed up on tuesday and I got some time yesterday to throw it on. The air filter is the EaAF04090 and I decided to stick with a 4" since that's what the turbo inlet is.
I got the cobra head fitting thinking it would help out on the space constraints. It is deceptively small looking on the website pics and I was amazed to see how big it actually is when I got it.
If I ever need an elbow brace on the trail I now have one I can scavenge from my rig.
Here's my inside-of-the-filter artsy shot.
Old Macgyvered setup.
4" is big and I had to trim down the lip on the cobra head to get it to move over enough to get the oil filter back on. A light coat on the filter case allowed it to slip on the rubber fitting but it touches and perhaps an oil filter relocation kit is going to be needed after all.
Trimming the lip on the cobra head also made it touch the housing by the outlet. There were a couple of touching spots but none that I think will cause a problem. I'll say it again, 4" is big! I ended up rotating the compressor housing to get the inlet to point up some more for fender well clearance.
I got some 4" aluminum tubing to go inside the joints. This is how it turned out. I do plan on fabbing up a heat shield/air filter box and cut out a few more holes for more cool air flow.
I feel better now about dusty conditions since my BHAF had what looked like tears in the pleets. In my quest to get more boost I looked at my modified intake tube going from the intercooler to the intake manifold and saw just a little oil.
I took it off and put a couple of spot welds on it and found more holes. I patched what I could find and I put it back on. I pushed it this morning to get on the freeway but didn't see an increase in boost so I'll be using some soapy water to track down any other leaks I might have.
My new master cylinder showed up yesterday and I hope to get it on next break and get a better feel and response out of my braking system.
07-10-08, 04:59 PM
#540 (permalink)
Turbo Diesel Lover
outstanding job as always dude ..
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
