04-21-08, 02:20 PM
#451 (permalink)
wish I could have made the bbp but it looks like you guys had fun. Did Chad manage to put more scratches in his dents?
04-21-08, 02:45 PM
#452 (permalink)
Not sure if I could tell the difference on Chad's rig but Cameron (Duane's son) did blow a hub on his father's 40.
build-up: Family Haulin' FJ60
04-21-08, 03:28 PM
#453 (permalink)
Turbo Diesel Lover
Pretty fast your spring packs job ..
I thought now you are in the best flex that you can get from your spring packs .. nice, really nice. But I miss the part when you post a video with your 4BT spining your rear tires in the muddy hill !
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
04-21-08, 03:33 PM
#454 (permalink)
OHV Trail Patrol
Who me?!? Never....
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
04-21-08, 03:33 PM
#455 (permalink)
No one grabbed one so I'll add that to the list. I'm still working on the sound video comparison I promised a couple pages ago
04-21-08, 04:07 PM
#456 (permalink)
oh man... that's so tempting to photochop...
04-22-08, 11:45 AM
#457 (permalink)
Wannabeen
Looks like tweaking and adjusting really takes time, especially when you're exploring that kind of terra incognita. Congrats and please keep posting pics of the beast in action!
04-28-08, 11:30 AM
#458 (permalink)
weekly update
Lets start out with troubleshooting.
I was driving up to an intersection at lunch time last week and the engine just died. No stumbling, sputtering or struggling, just turned off. It turned over fine but would not start. I fiddled some with no success and called a co-worker to give me a tow back to work (1/2 mile, I didn't get very far). I fiddled some more in the parking lot but gave up when the 40mph winds were blowing the sideways rain drops up my nose! I got it towed home and continued my troubleshooting the next day. I have two fuel filters: 1 is pre lift pump and 2 is post lift pump. 1 was full of diesel and 2 was more than half empty. The lift pump seemed to prime fine but the engine still didn't fire. I cracked a banjo bolt before filter 2 and tested the lift pump. The pressure seemed fine but at the end of the pump I got some bubbles from the line. I figured it was a hole in the diaphram on my lift pump and air was getting in. I thought about a piston style pump but due to time and funding I just replaced it with another diaphram style pump.
I also took out the fuel cut-off solenoid thinking that was why the engine just stopped without any stumbling. I should have tried a hot 12v to it first but I didn't, here's what it looks like.
If the solenoid is faulty and you need to take this out so you can get diesel to your injection pump just take the plunger and spring out and reinstall the body back in the hole.
Don't forget to put the o-ring back on the solenoid or it won't seal and you'll get air sucked in the injection pump and that will lead to air in your injection lines. I did find this out the hard way and cost me a couple hours of head scratching.
Once I figured out air was coming in and no amount of bleeding the injectors was going help I put the o-ring back in and re-bled. I went through a charge on the battery and had to wait while a battery charger gave it juice for a few more turnovers for the bleeding process. I finally got enough air out of the line that it started. It stumbled for 10-15 seconds, ran rough for 20 seconds while it purged the rest of the air out and then started purring again. I turned it off and made sure it would start back up and it did. I then re-installed the plunger on the fuel cut-off solenoid and found it was working fine.
The other culprit I didn't consider is that I actually ran out of diesel. Since the rear quarter cut I hadn't drilled a new hole for the fuel sender wire to pass through the body and connect with the harness so my fuel gauge wasn't working. I figured I was getting close but was going off of mileage. What I forgot to consider is the difference in the tire size  (from 35s to 38s) When I drilled a hole and connected it back up the gauge read empty. However, it's one of those areas where it's degrees of emptiness but apparently I was close to the last degree. I put 2 gallons in to make it to a diesel station so I wouldn't have to do this again. So I'm not absolutely sure the lift pump was shot. The air bubbles were compelling enough for me and now I've got a spare I can carry around. So it turned into an exercise to get to know my engine better and what to do if I ever run out of diesel again. Moral is, don't run out of diesel!
With that experience and success under my belt I turned to getting the lock-up wired. When I called transgo several months ago about wiring up the solenoid in the tranny I was told to step down the voltage. Well, another tried that out and it didn't work. He talked to his tranny guys and ended up running straight 12v to it and it worked fine so that's what I planned. I went to radio shack thinking they'd have the biggest selection of switches but only found toggle style switches that were rated for 12v. I ended up getting and automotive toggle rated for 12v/20amp. I also picked up LEDs with a built-in resistor so all I'd have to do it wire it in with the switch. I bought two LEDS thinking I'd put one in the dash eventually. Cost me $7
I took my shifter apart, decided on a location, drilled some holes and put them in.
Pulled a 12v source from the fuse block and wired it up.
Found some connectors that would fit the tranny pins and hooked them up. I want to finish this up better but for tryouts this will do.
Put it all back together and went for a quick test. I flick the switch and the lock-up engages. I'll do a little learning on when it should and shouldn't be engaged but sure makes it feel like a direct connection between the engine and the tires. Success.
04-28-08, 11:44 AM
#459 (permalink)
update cont.
On my last day my baffles showed up and I was excited to try them out so I started in on the exhaust.
I decided to put one in the downpipe and one at the end of the exhaust. It'll be an experiment. My downpipe wasn't long enough so I added in a section. I then marked a drilled some holes for the baffle to be bolted in.
There it is inside.
So I'm hoping that this is my final and complete downpipe.
Over-the-tranny downpipe installed.
I ran out of steam trying to figure out how I wanted to mount the rest of the exhaust so I just grabbed this piece with a little turndown and threw it on until this weekend.
I think I'm just about ready to start counting for mileage.
04-28-08, 02:59 PM
#460 (permalink)
Turbo Diesel Lover
Maybe .. and just maybe the extra fuel filter made your IP plunger do more heavy work . ? in my case with 2 filters I add a electric pump that also help to deliver more diesel to my engine ..
3" exhaust . ? niiiiceee . .
First time that I saw a baffle .? which it's the idea .. ( thought a sound in the exhaust .? )
04-28-08, 03:14 PM
#461 (permalink)
Good point about the extra filter causing more work. It probably needs to be changed soon since I've run bio through the system and filter 1 could be causing more resistance from a cleaning in the lines and tank.
Yup, 3" exhaust. That was what was on the stepvan so I just kept the size. For a better explaination of the baffles and their benefits visit here: Spiral Turbo Specialties: Spiral Turbo Baffles Overview Scroll down, there is a short article about them.
04-28-08, 05:58 PM
#462 (permalink)
Turbo Diesel Lover
Originally Posted by boots4
Nice info .. thanks .. first time that I read about it .. now you need to report the improvement and take a video for the sound
04-28-08, 07:42 PM
#463 (permalink)
those are pretty sweet mike, may have to get a set. Let us know the increase in MPGs!!!!
PORTLANDERS + NW CRUISERS::
$@#!! L A N D C R U I S E R S P E C I A L T I E S !!!
H O R R I B L E W O R K , W O R S E A C C O U N T A B I L I T Y!!!
04-29-08, 06:00 AM
#464 (permalink)
Looking forward to meeting you in the coming month and forging ahead with PNW wheeling with you and the rest of the Cascade Cruisers.
john
04-29-08, 08:22 AM
#465 (permalink)
john
That's fantastic! It's been so long since I've been wheeling that you'll have to show me around.  Let us know when your trip gets close.
05-05-08, 05:07 PM
#466 (permalink)
barely an update
To many other things needed attention this weekend so cruiser time was limited. I did rework my lower radiator hose reducer so I wouldn't have so many hose clamps. Plus I've had a kink in the lower hose ever since I adjusted the passenger side motor mount. I thought about fabbing a new inlet for the block to accept the same sized hose as the radiator but decided not to since whenever I get around to putting the A/C compressor back in I might have to build one then.
I took the two pieces I had, welded them, cleaned up the weld, and covered it with JB Weld to make sure I wouldn't get any leaks. Here's how it came out.
I also put a coat of JB Weld on the inside.
I thought my coolant was going to look dirty but it didn't so I strained it with some old jeans and filled it back up.
I helped someone move last weekend and used it to tow their stuff and it pulls really well with a load on it with the T.converter locked up. Still going to turn up the pump and play around with more boost, the 38s slowed it down a little, but the hwy rpms feel pretty good.
05-06-08, 10:33 AM
#467 (permalink)
Turbo Diesel Lover
How much boost are running right now . ?
05-06-08, 11:05 AM
#468 (permalink)
My wastegate bleeds me at only 15psi. I'd like to be in the 20's I was planning on putting together a manual boost controller that basically modifies the signal to the wastegate to get it to open later.
05-06-08, 04:21 PM
#469 (permalink)
Turbo Diesel Lover
Only .. ? ha ! I'm having some problems to run 15 PSI .. !
I'm jelaous !
Yap .. I have a manual boost controler in Marilu, coz the CT26 wategate are nos ajustable .. ( thought as same as yours )
05-07-08, 06:19 PM
#470 (permalink)
I dont even remember right now, but what turbo are you running anyway? hy35w? or the H1Cw?
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
05-07-08, 06:59 PM
#471 (permalink)
It's a hybrid WH1C I put together. It has a 12cm exhaust housing and the 54mm inducer. It's suppose to be close to an HX35.
05-07-08, 07:21 PM
#472 (permalink)
where did you get the 12cm2 housing, i see some guys have ordered them. I have a baby H1C turbo(small intake housing) sitting behind my shop thats in good shape, didn't know if it had the 12cm2 housing. Do all the 12cm2 housing have a wastegate?
I looked back at your turbo write up, and i see you had alot of trouble getting that exhaust housing to separate too, what a pain!? took me a day and a half for it to soak enough(crewcab59 showed me that spraying penetrating oil and using a torch and then more penetrating oil works great, and of coarse a BFH)
You think that modified H1C will work well with that air to air? I didnt think that it would be enough turbo, but i guess some did come intercooled, so i dont know.
Martin Hovis
05-07-08, 08:03 PM
#473 (permalink)
The 12cm housing came on my WH1C which came on my stepvan and so did the intercooler so I figure it was matched from the factory. Not all 12cm housings come wastgated since one can buy one with or without but I think they did come wastegated with the factory install like in my van but I could be wrong. With the bigger inducer on the compressor side I'll be pushing more air but with the wastegate bleeding at 15psi I don't think I'm really tapping into this turbo setup. I think there is more potential in it and now I'm ready to play with it. I like the idea of the wastegate to keep it from overrunning but I still want more boost especially when I make some adjustments on the power screw.
05-10-08, 08:02 PM
#474 (permalink)
Lookin' good Boots. I'm still scrappin' my van. Nice to see how much progress you've made. Keep it up and let us know what kind of MPG you're pulling when you get to that point.
05-12-08, 07:26 PM
#475 (permalink)
I did some maintenance last weekend in preparation for a 630 mile trip down to California for a family visit. I'll be towing the trailer down and back so I decided to get my tranny cooler on. I picked this up on my U-Pull IT run. I made some quick little brackets to mount it and sprayed on some primer.
I'm putting it here for now and will decide if I need to move it whenever I get around to fitting the AC stuff back on. It's about 11" x 11" edge to edge.
I found it was going to be easier just to remove the grill and valance. It really only takes 10 mins and I had easy access to drill holes where needed.
I figured it was a good time to flush the tranny while I was rerouting the cooler lines with new line I picked up. I hooked up all the lines except for the lower going into the tranny, that way I'd get the heat exchanger and cooler flushed out as well. I measured out 4 quart increments on a bucket (just used water and marked it before hand) so I'd know how much was coming out. I had my  start it up and then turn it off once I hit 4 quarts. I'd put 4 quarts of new fluid in the tranny and repeated until I'd flushed 14 quarts. I'll filter this and burn it through the tank during fill-ups.
I also changed out the oil and put on a new filter. I'll probably do the same and filter it and run it through the tank. I'll only add a little at a time and it will help lubricity with ULSD.
I wired the cruiser for a trailer connection and found I needed a 3-wire to 2-wire converter since my turn signals are on seperate lines than the brakes. I also added some bar to wrap the safety chain around. I was previously using my shackle point on the bumper but wanted a better spot for the chains.
Upgraded from an old rusty chain to some new ones. I took the easy route and welded them on.
The only thing I need to get hooked up for the trip will be the radio! I've been looking at local stores for a junction block to wire accessories up instead of having a bunch of wires coming off the batteries. If I don't find anything I'll just crimp on a bigger ring terminal and hook it up.
I plan on bringing a few projects with me since we'll be down there for 10 days. It's suppose to be pretty warm (at least from what I'm used to here in Portland) so I might not be motivated to work on it all day. I'd like to get the radiator fan hooked up down there and do a detail job on it to get some protection on the paint. At least if I detail it now before I start scratching it up I'll have some pics of when it used to look nice.
05-12-08, 07:28 PM
#476 (permalink)
Have fun scrapping that van. I still have the front end to pull off and take down to the recyclers! I'm going to need to clean my part of the yard pretty soon.
05-12-08, 09:20 PM
#477 (permalink)
Just take it easy on your trip. Towing with a new rig can be touchy. If you're haulin' any weight and it doesn't feel right take the time to reload it. I'm near Medford/Grants Pass and if you need a pitstop on the the way there or back give me a holler..
05-13-08, 08:14 AM
#478 (permalink)
Kief, PM'd
05-15-08, 07:34 PM
#479 (permalink)
sorry couldn't catch ya on your way through, have a good trip..
05-23-08, 06:02 AM
#480 (permalink)
Why?
cant you dump it?
Paul
'04 UZJ100- Daily driver
'91 HZJ80 - 4" lift, 36s, 8274 hi mount, EFI V8, T400, cage, lockers, soon to be custum extra cab and tray
'89 HJ60 - (selling for parts)
'85 HJ60 - (Sold) Chopped, V8, custom everything - click here ROTW - here
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
