03-17-08, 05:37 PM
#421 (permalink)
Turbo Diesel Lover
Originally Posted by boots4
Thanks tapage, that's nice to know about the pyro too. I've got the probe in pre-turbo so I figure I can get 1100-1200F before I need to back off. So at shut down you aim for 250F before turning it off?
Preturbo in both turbo cruisers and yes .. sometimes ( not really usual ) I take the chance to go close to 1250 - 1300ªF before backoff the skiny pedal ..
Usually I let it really calm down .. sure if I have the time .. if not, at least to 300 - 325 in a real hurry.
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
03-25-08, 01:26 PM
#422 (permalink)
Not much to update with family in town but I have noticed that I seemed to be getting more vibs than before so I started looking at mounts and found one of my motor mounts had a nut that slightly loosened. So I got a wrench in there and tightened it up. I checked them all but that was the only one that loosened. The vibs reduced and now my hood doesn't shake so much. I'll add this to my visual inspections as I lay underneath and just look at stuff.
Part of the problem might be that seam in the metal that the washer is resting on. The nuts are ny-locks so it didn't go very far but enough to let it vibrate more than what felt normal.
build-up: Family Haulin' FJ60
03-31-08, 12:58 PM
#423 (permalink)
weekly update
Family left and other issues popped up in life but I was able to get some time on the cruiser and conduct a distance trip test.
First I picked up a 10' stick of 3" exhaust tube to redo the exhaust. I'm ditching the muffler and going to try out the those baffles I posted on the previous page. So to prep for that I started cutting and welding. The previous downpipe I made had dents in part of it and I got some free tubing with a bend that I could use so I cut up the old one and put on the new one.
Here is what my frankenstein downpipe looks like now.
I shaped the piece that will replace the muffler section and got to the part to clear the shock and go over the axle.
I tried these mounts I found at the local hardware store but it's ended up being too soft. I'll either need to find something more ridgid or mostlikely redesign the mount.
My sweet wife decided that I needed a decent tool box for my birthday so we found some on craigslist and ended up grabbing this one. It'll be nice to have most of my tools in one spot so I cleaned it up and started organizing stuff. My distance test came when we picked up the box. It was a 2 1/2 hr round trip pulling my trailer on the freeway. It towed great but need to get the lock-up wired on my tranny and my 38s mounted. I was pulling at 70mph no problem but it was out of my efficiency range and used more fuel than I thought. I hovered around 200F on the tranny temp without lock-up so I know that will come down once wired up. I'll plan on adding a cooler in the near future because when we go the get a load of wet wood for next season it's going to be a little more weight to lug. The steering is still too loose for my tastes so I think I'll pull the steering box and check out the preloads per FSM to see if that will tighten it up. I checked for movement in the system and believe that's where the slack is coming from. I know I've changed the geometry (wider tires, wheel spacers, leafs) and the wide, bald, out-of-balance tires on it now are playing a part but I'm trying to tighted it up more before I get the 38s fit and the ram assist mounted. Maybe the ram assist will take care of some of it. As for the engine it happily pulled along running 7-10lbs of boost with the trailer empty and didn't miss a beat. Great little engine. Anyways it's an 18 drawer cabinet with ball bearing sliders.
What instigated the need for a tool cabinet was the suprise of a friend getting rid of a bunch of tools he got from a deceased diesel machanic (widowed wife passed them on). My friend thought I might be able to use them so I picked it all up. Just a lot of misc. stuff and some duplicates of what I already have but there was also a box of just taps. One of the taps (which I'm sure I'll never use) is a massive 1 1/2".  Maybe I'll mount a spare tire with one bolt.
I hope to finally go to the junkyard this weekend and get some leafs to play with and get the front pack reconfigured.
03-31-08, 04:10 PM
#424 (permalink)
Turbo Diesel Lover
Dude .. did you already go to the alignment shop and get the caster values for your Cruiser .. ?
There any play in your steering box .. ( maye can tight it a little with the top adjust )
03-31-08, 04:33 PM
#425 (permalink)
I have not gone to an alignment shop but I cut n'turned to 3 degrees with the weight of the rig on the axle and added a 5 degree shim so I should be @ 8 degrees (that was my cheater way of not having to cut off the axle perches and weld them back on to bring down the pinion angle). It does track straight at speed but the wheel feels loose and I have to "saw" away on the wheel (go back and forth) before it feels like it's engaging the wheels. I've played around with toe-in too and am currently running 1/4" toe rather than 1/8th" like normal. It tightened it up a little but will cause more tire wear; something I don't care about on these junker 35s but want dialed in before I start wearing my 38s away. I've also played with the adjusting nut on the top of the box and I get similar results of a slight increase in tightness but not satisfying. I know I'm being picky and that these normally have some play in them but mine seems like too much. Steering box internals is the only place I haven't checked yet. I simply took it apart and put it back together when I ported the box. I think the issue was pre-existing and having wider tires plus spacers is amplifying that previous issue because I do remember it being sloppy before the build. It may end up being a worn out box but I won't know that until I take it apart to measure and get some FSM comparisons. At least it's not leaking.
04-07-08, 11:57 AM
#426 (permalink)
weekly update
We had a sister come up from Medford to attend a training class last week. Upon shuffling the vehicles around to park the cruiser behind the others (I leave for work first) I bumped into the fire heidrant that is located on the corner of our lot.
It was dark and I got a little to friendly  with it and I heard large PSSSSH sound. I looked to the that corner and saw no water (thank goodness) but noticed the front right drop several inches. I got out and saw the damage and drove the cruiser up the driveway first so I could park it (I'd be taking the car to work instead). I put a jack under the axle to get the rim off the ground and here is the damage to the tire. I don't think a few tire slugs were going to fix that.
That's a pretty good sidewall rip, enough to get my arm in.
The  suggested we just get another cheap 35 and stick it on. I told her I might as well throw on the 38s instead of waste money on a 35. She said she didn't understand why I wanted to put such a big tire on since hopping into the truck in a dress for church doesn't excite her. I think I'm losing her  . So what do I do? Just like any loving husband I'll just build her a step because the 38s are goin' on! To get all the tires to the shop to swap them over I needed to tow the trailer so I put on the old original tires. If anyone still wonders if it will look alright doing a SOA and running small tires please look at the following pic.
I went to a local little tire joint and helped them mount the 38s. They were the max for their machine. It was interesting to see how they did it and it looks like reseating a bead on the trail might be challenging. For balance I used 14 oz. of heavy weight airsoft pellets in each tire. I followed the chart on Tire Chart Map and added another oz. or two to be safe. I had a few onlookers ask me some questions and what I was going to run them on. I did end up popping the hood and showing some of the conversion but once the tires were done I drove home and I parked the 60 for a test fitting.
This pic is more for a comparison
Here's the meat.
I jacked up one side and put them on. Now we're talkin'!
Yup, now we're talking clearance. Remember, I've moved the rear axle reward and the front axle forward a couple inches. This is the rear clearance with the quarter panel.
I've got 4 fingers between the tire and the body mount. I'll have to stuff it to see what I need to cut out.
Here's a look at the front.
I'll definitely be hitting on the front when stuffing. Some of that will need to come out.
I did some full turn tests and actually don't hit anything standing still. Add some road bumps or trail roots in the mix and I'll be getting contact.
That's almost full turn to the left. I'll probably need to take a couple of inches off that too since with a SR the axle will move back.
Front spring clearance almost full turn to the left. I should be fine. Full turns usually only happen at slower speeds, at least for me, don't know about some of you crazies out there.
I threw on the other front tire to get a shot of the front.
04-07-08, 12:11 PM
#427 (permalink)
looks great man... you're defiantly in the need for trimming. Too bad too cause the body is so nice. Mine was easy since the body is pretty beat.
04-07-08, 02:15 PM
#428 (permalink)
update cont.
Have fun in Moab Zach!
Let see if this will work the second time.
Here is my projected line for the quarter chop.
I got out the cutting disks, welded, and did some grinding. Again the axle is on jacks so I could put the tire in and out for visual clearance so it's not bolted to the axle. While the chop might seem high (it did to me) I will have sliders/protection running underneath it and that should give the rear end a little more plumpness.
I echo the concensous that body work sucks. I'd spot weld in little strips to attempt to keep the heat out of it but I'll probably use a health dose of sealant and bondo to smooth it out. I'm trying not to spend too much time on the chops since I'll probably get dents back there anyways. I used 1/8" plate for the bottom caps.
I used some rod for the fender lips to give me something to weld to and give it some structure. It helped absorb the heat from having too much juice on my welder.
While I had the bottom open I got a hammer in there and pounded out the dent on my rear corner. It only had surface rust so the panel is a keeper.
I didn't get as far on the passenger side.
Two more pics just for eye candy.
04-07-08, 03:07 PM
#429 (permalink)
Wow! And those rear quarters are turning out real nice.
04-07-08, 03:52 PM
#430 (permalink)
Nice work as always ... Looks like you managed to keep those body mounts in there too. How much room do you have when the tire moves up?
I finally finished up my rear bumper in time for Moab. It really improved the look of the rear with the quarter chop not to mention added some good protection. I got my aals in too... Kinda looks like its doing a wheelie now. Hope they settle out a bit.
04-07-08, 04:18 PM
#431 (permalink)
Turbo Diesel Lover
It rocks !!!!
I'm not a fan of those tires .. but they look amazing hot in your cruiser dude ..
P.S. looking forward on your step .. coz my wife scream for some help heach time that we go out in Tencha.
04-07-08, 04:32 PM
#432 (permalink)
I still need to flex it to see what I need to cut. I should be able to keep the mount, just a little less of it.
I never got to see you completed bumper but I figure there will be plenty pics of it once you're back from Utarrrrr.
Originally Posted by Tapage
P.S. looking forward on your step .. coz my wife scream for some help each time that we go out in Tencha.
Yeah I got a good deal on the tires so I couldn't pass them up.
Sorry, don't mean to get your hopes up. It'll probably just be something I can throw in the back once she's in and probably only be used when she's in a dress. On the high note, she'll get the door opened for her now.
04-07-08, 04:37 PM
#433 (permalink)
Thanks, I'm glad they look better in the pic than in real life.  Really they aren't that bad, it's just my first time doing sheet metal so I'm learning.
04-07-08, 06:03 PM
#434 (permalink)
Turbo Diesel Lover
you gotta get problems with my wife .. coz I send a message and said that a fiend in mud it's designing a step for 60 series ..
Now she will be diesapointed .. it gonna cost me other 3 hours of my sunday in the mall
04-07-08, 06:13 PM
#435 (permalink)
OHV Trail Patrol
Sexy! That is so cool... (I want 38's...)
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
04-07-08, 06:43 PM
#436 (permalink)
04-08-08, 03:54 PM
#437 (permalink)
Good job mate!, nice pics, but i dont like cut the body   , enjoy
04-08-08, 08:06 PM
#438 (permalink)
Looks like a monster truck with the little wheels they put on them to get them in the trailers.
Awesome build!
-Josh
'70 FJ40 (work in progress)
'85 FJ60
'02 Sequoia
'08 G35 Sedan (Wifey's)
TLCA Member #14566
My Build Up
My Pictures
04-08-08, 09:18 PM
#439 (permalink)
That is so freakin sweet!!! i love the rear fender cut you made, that makes it look awesome!
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
04-10-08, 05:47 PM
#440 (permalink)
Top-notch work as always, AND - your first & second official wheelin mods are done!
~Jamie
1990 FJ62 Daily Driver
2000 TRD 4WD PreRunner
Supercharged, Locked, Armored.
Mountain - she can crawl it.
Ass - She can haul it.
04-14-08, 11:49 AM
#441 (permalink)
weekly update
I found out this weekend that I suck at body work. I tried 3 layers with sanding inbetween and I gave up. So it looks like I'll need to get some texture on the quarters to hide the imperfections and mask some of the wavyness. At least now I have a better appreciation for those who can do it well. I just threw on some primer to keep rust from starting. Here are my results
Testing continues:
My first test drive with the 38s was pulling a trailer going to get a load of wood. On the way back it's probably the heaviest load I've had on the trailer and towed with the diesel so far. I really like the 38s. Smooth, not very loud, and more comfortable than those worn out 35s. It even tracked better. I did notice an increase on my pyro but the 4bt pulled great. I did get the tranny pretty hot, 240F on the gauge, and had to pull over and let it cool off (stop and go, warmer day, in hilly terrain pulling a heavy load). I am reconsidering about using that heat exchanger and thinking about ditching it for just a cooler. Before I do that I'm going to get a fan for that radiator and redesign the lower coolant hose since it's got a kink in it now from readjusting the motor mounts. I'll probably build an inlet port for the engine side that's the same size as the radiator outlet so I can use one size of hose. Should be much easier to deal with leaks although suprisingly my frankenstein hose isn't leaking a drop. I'll plan on using a tranny cooler with the exchanger and see what happens.
The next day we hooked the trailer back up and picked up a swing set for my daughter's Bday. As we pulled onto the street it was really sluggish and felt like a dog. I wasn't registering any boost on the gauge but could hear the turbo spinning, just not as much as it should. I kept thinking about what it could be as we drove there and back with our load and when I got home to start investigating I noticed the tubing for my boost gauge had come off of the t-fitting for a boost signal. I hooked it back up and we went to pick up some plants. It was boosting like normal and then as I had my foot in it the boost dropped and it became sluggish again. I pulled over and saw the tubing had popped off again so later that evening I fastened it with a hose clamp and used some glue to bond the tubing to the rubber fitting that goes on the T.
So if you notice an immediate drop in boost, it's not registering on your gauge, and your engine feels like a dog then there could be a pressure leak somewhere, mine was easy to find. This was good to find because I'll be increasing the boost pretty soon by playing with my wastegate. The tranny was running hot again so I hope to finally hit the junkyard this weekend and will add a fan to my list. I'll also do a fluid flush before a big trip to California at the end of May.
The front tires are rubbing on hard turns and I'm getting some slicing so I'll be cutting some chunks out of the fender very soon.
So the testing continues and hopefully one of these weekends I'll get some springs to reconfigure the fronts and flex it!
04-14-08, 12:14 PM
#442 (permalink)
Wannabeen
You have some guts, chopping and welding your rig like that. The new molding looks really great. Planning any rubber-like coating there?
04-14-08, 01:16 PM
#443 (permalink)
I haven't quite decided what to use yet. I like the rust bullet I've been using on everything else so that's probably in the lead but I'll still need something with texture to go underneath. I've seen some spray-on stuff that's suppost to mimick that factory look on the lower panels you see on newer cars but I don't know if that will be enough texture. I'm sure using a roller with rustbullet will also help give texture so that might be enough with the other stuff underneath. I'm not too fond of herculiner as I did it on my last truck and the UV chewed on it. Then there is that plastidip stuff I was looking into earlier. That might make a good project down in Cali since it will be warmer and drier so I've got a few weeks to decide.
04-15-08, 08:35 PM
#444 (permalink)
KOOL AAROW
 WOW AS ALWAYS WELL DONE
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
04-16-08, 01:45 AM
#445 (permalink)
Ramblin Wreck
I would consider Body Schutz or 3m Rubberized Undercoating in the Aerosol can for some light texture.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
04-16-08, 08:39 AM
#446 (permalink)
Got Rice?
04-16-08, 10:57 AM
#447 (permalink)
If you ever got into body work on your 60 I bet you'd turn out a pro! You'd have lots of practice.
04-16-08, 11:03 AM
#448 (permalink)
The undercoating I've used before on my tralier wheel wells (probably wasn't 3M) ended up with bubbles in the skin. I'm not sure how it would take paint over the top nicely but I probably put it on too thick and used the cheap stuff. Maybe better stuff would go on without forming bubble holes in the skin.
04-20-08, 11:20 AM
#449 (permalink)
Looking great!!!!
The 38's are titties
04-21-08, 02:02 PM
#450 (permalink)
Good to hear from you Redcorn, I hadn't seen you post for a little while.
I finally got out to the U-Pull It and found a couple of items. I got a pair of rear ranger springs to play with. I found a contour dual fan. There was only one in the whole yard and I don't know why it was in that particular contour because it was sporting a 4 banger and I thought the dual fan only came in the v6 option. Regardless I was happy to find it and all I had to do was cut some wires and it was mine. I also found an aftermarket tranny cooler that I should be able to use.
Contour fan
I haven't done any research yet but does anyone know what this part of the wiring does?
Tranny cooler
I think I might have some air bubbles in the system and that might be helping cause the tranny to run warmer than I want. One of my coolant hoses runs higher than the radiator so that might help trap some air. I know the bigger tires are more of a load but I wouldn't expect them to cause that much heat in the tranny.
We had a club event in a huge shop and I took the opportunity of being inside to reconfigure the front packs. We had to get a little creative on jacking up the frame to drop out the axle and springs and this is what we ended up with.
I still had to take the front tires off to get the axle to drop far enough but I needed to take them off anyways.
I took my time, pulled off the springs and decided how I wanted to stack them. You can see the way I had it in the back and the way I re-did it in the front. I originally took the other main ranger spring and heated up just part of the eye to bend it out to create a military wrap but that just didn't seat well so I ended up cutting the eyes off and putting it underneath my main. I stacked the springs so that I had about 3" of underlap (hope that makes sense). It was suggested to help make the pack work together to taper the ends of the spring a little in width and thickness. I was running out of time so I didn't do that part but I thought it's worth mentioning for anyone else trying to tune leaves.
I got them back on and did some quick cuts on the front fenders so I could at least flex it a little. I'll clean up the lines and will need to modify that core support as it will rub it I try to flex and turn.
The piggy next to me was swapping on longer alcans and we were pretty even for awhile but he got his on the ground before me.
Passenger
Driver
With and open rear and no 4wd that's as good as I could get in the gravel.
That jeep got owned that day. It was undented and this was after a couple of cruisers romped on it. Wish I got in more time watching than wrenching but next year I plan to contribute to the car crushing.
I knew 2wd wasn't going to get me very far but this was the first time flinging mud with it so I had to see if the cummins would spin those wheels. Spinning was no problem, traction was.
Felt worst in the rig and I didn't want to chance even the thought of rolling on a wheeling pre-trip.
Just a great pic. We got everything that day in the weather department and when it really started to snow around 7PM it was time to go.
Another of the front cut. I'll clean up the cut, modify the core support, and I'll take a little off of the rear.
Two more of the reconfigured packs.
I can't wait to go wheelin'!
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
