Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 12-01-07, 06:22 PM   #271 (permalink)
dieselcruiserhead's Avatar
TLCA# 9439
Boots awesome progress and work.. Your front axle also looks awesome, seriously you are bordering on real-expert type caliber work and understanding of all of these systems, things that I think it took years and many times doing to understand... Most excellent!
- Cummins 4BTswaps.com Forums
- Hazard Assembly Dirtbag Adventuring Community
- Diesel Conversion Website
TLCA# 9439 Since 1999, Wasatch Cruisers
'89 Toyota Pickup V6, OME, 33x10.5's
'69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300
dieselcruiserhead is offline   Reply With Quote
Old 12-01-07, 09:52 PM   #272 (permalink)
2nd gen mounts much more forgiving, how they fit in this
setup dont know for sure.
h1c is less efficient then a hx or hy stuff.
hydroboost you can just pull the firewall side plunger
out and shorten it and stick it back in. offset a bit when
mounting it to run it single shear style. OR mark it, pull it
out run the die on it, then just put it back in or hold it like you
did. LOL lines should be a plug and play, all but the return from
the box, that fitting.
easiest is just cut put metric on and reflare, MAKE sure you put
your adjustable prop in the rear first then do it after. Run regular
lines from master to prop regular master cyl adapters will get
you down to 3/16ths line then go.
hydro to toy master, well Kind of a pain and really doesnt make sense
adapter booster then another adapter, would require plate adapter then modifying the
output plunger from the booster. playing with these plunger lengths is a pain, and then
doing both sides of the booster is just nuts regular gm master will work just fine, and
there is 8-10 different masters that can work on hydroboost booster, so you can change
bore, look of, line sizes, etc... by just changing to different master.
EMAIL ME
click on my name, Send email to HI^C
TONS FOR SALE <<<CLICK ME
"everyone has different experiences and different opinions"
My posts "greatly based on my observations and opinions" and "TO EACH HIS OWN"
Sig edited to help futher eliminate those who have or get twisted panities.
HI^C is offline   Reply With Quote
Old 12-02-07, 01:14 AM   #273 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by HI^C View Post
2
The high pressure side from my hydroboost uses a different fitting than the high side to the toyota steering box. My HB is an o-ring fitting and the toyota box is an inverted flare. This Hydroboost is metric so the toyota line does screw in but it won't seal properly. This is the case with my box. I'm sure there are HB boxes out there with flared connections, mine isn't. I will either have to get a line made or convert to AN fittings and run my own hose (still leaning toward the second). There are o-ring to AN fittings commonly titled "power steering adapters." Thats what my research last week turned up.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 12-02-07, 01:17 AM   #274 (permalink)
boots4's Avatar
TLCA# 19547
I consider that a huge compliment, thanks.
I did do quite a bit of reading to try and understand it all and I generally like to have a plan before I get into a project, especially one this big (for me anyways).
Old 12-02-07, 01:24 AM   #275 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by brokenparts View Post
boots you're my hero.... fantastic build up! I wish you would have this thing together for the snow run on the 8th...
That would be fun. I was talking to Kevin about wiring (he'll be out next week to give me a hand) and he said he might fire up the 40 for that run. If I get the things done that I want next week maybe I'll show up. I'd like to see your smurf in action.
Have you posted pics of your ram assist yet? I'd like to see how you put it on the axle.
Old 12-02-07, 01:28 AM   #276 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by redcorn View Post
I smell a tagteam wrap up @ for the Cascade Cruisers.
C'mon fellas, a keg of Mirror Pond, some Hollow Point energy drink.
Elk sausage and a day of wrenching to boots gameplan.
You're making me hungry. Hopefully by next weekend there won't be much more major stuff to do .
Old 12-03-07, 11:14 AM   #277 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
I just didn't have enough time on my days off so I started putting in hours after work. This helped and I just might get it running for the christmas trip to visit family. I talked to a local FJ60 4bt and he will be out this week to help wire. In fact the plan is to have him drive his over and we'll just look from one engine bay to the other. Should take less than 2hrs if we get to chatting.
My wheel spacers showed up, the triple boot showed up, and the axle shims showed up all last monday.
These are 1.25 width with a 6 x 5.5 pattern. I wanted them just wide enough to clear the studs. If I bought some again I'd probably just get 1.5's since they were the same price. Since I don't have brakes yet I figured out another way to keep it from spinning while I torqued down the nuts. Because my discs are vented I just slipped a screw driver in a vent hole and had it rest against the caliper in the direction I was tightening. It worked out great.
I decided to spend a little more to get metal shims instead of aluminum ones. They are 5 degrees and are 2.5" wide. The mounting hole is knotched to make it flat for the spring bolt. I added another leaf to the bottom of the pack and put on the shims.
One of my new u-bolts got mangled when I took it off for the shims so I'll get another one but I couldn't resist seeing the adjusted pinion angle so I put it on with three u-bolts. It looks like it will work well, see more pics below.
Put my Aussie locker in the front 3rd member. There are some good write-ups on here. I didn't do the first clearance test, just the last one and it was perfect anyways.
Did some more exhaust work. Got the down pipe around the back side over the trans. Just stepvan parts.
You can see the dents that were already in it. Since I wanted to get this thing running soon I just used the parts. I'll look into replacing it all at a later time but for now it will do.
Got the rear on the ground. I will need some longer lugnuts so I just put on three per wheel.
Before I put it on the ground I dropped the axle and put the overloads back in the spring pack. I will make an anit-wrap bar for it later so the overloads will help for now.
I didn't like the plastic t-fitting that came with my boost gauge so I bought a brass one. It's in a part of the hose that bends and when I took out the plastic one (which was a little to small for the hose anyways) it was slightly flexing already. This will be more durable.
I relocated the axle breather. Grabbed a 10mmx1.0 tap, drilled a hole and put it in. I had to move it because the axle brace covered the old hole that I closed up.
Old 12-03-07, 12:19 PM   #278 (permalink)
boots4's Avatar
TLCA# 19547
more pics
I did some running around on saturday morning for parts. NAPA didn't have anything I wanted so I just ordered it from them so I could get back to the cruiser. I ordered rubber lines to the calipers, the lines to the axles, driver side 4runner caliper since my junkyard one had a frozen piston (still cheaper to go that route due to the core charge). I was refered to a screw and fastener place which wasn't open on saturday but I looked them up online and I wish I had found them sooner. Sounds like it will be a candy store. It's called Tacoma Screw.
I got home and got ready for some front axle fun. I got out all my parts and the rebuild kit that I'd been storing since before the beginning of the build. I looked over the FSM a little, read some here, wrote down some torque specs and got to it.
I couldn't get to the bottom side of the ball to drive in the trunion races so I decided to put the bad u-bolt on with one bolt and lift the rig to put jacks under the axle. This gave me more room. The races went in without much drama.
Cleaned up and painted my knuckles, put in my ARP knuckle studs using the double nut method (real easy), grabbed my Marlin high steer arms, and put the knuckle on. I fastened the seal and felt wiper on the backside after it was on and started filling with moly grease. Marlin's new axle seals are in there too.
Driver
Passenger
Fished out my Longfields and 30 spline inners from bedside storage (it'll be nice to have some room on my side of the bed now ), popped them together, and stuffed them in. The long side was a little difficult to get in but with some more wiggling (being careful of the seal) I got them in with a little more force. Short side was a piece of cake.
Driver
Passenger
If you have to take the spindle off a lot I could see how changing to studs on the knuckle would be helpful but the gasket hole it just a little smaller than the bolt so it actually holds the bolt for you. I put the combo together with my cut dust shields and put those on. I took a look at my longs one last time since I hope not to see them until the next knuckle packing.
My bearing washers were toast so I ordered some previously. No wonder why the cruiser's handling was a little loose.
If I'd had my other caliper I could have put it on the ground, so instead I put the front tire in place to get an idea. My goal for the week was to get it on the ground so I'm pretty much there. The front will come up about 2" to get the tire on.
Hooked up the high steer and got a sight alignment. I'll do the measurements once the tires are on. The weight of the rig is on the axles.
Passenger
Got carried away with the grey primer and sprayed the front. I even thought about painting other walls in the engine bay but I stopped and worked on other things. I bolted the radiator down and fastened on the AC condensor.
Driver
Old 12-03-07, 12:24 PM   #279 (permalink)
boots4's Avatar
TLCA# 19547
more more pics
The pitman arm set up for FJ80 joints.
From back to front of how the tires stick out. That's the kind of look I like, sticks out a little but not too much. These are just 35s and I'll change to the 38's when I can get some time in for a little body work.
Hooked up the steering box to the steering wheel. I had to pull the zerk fitting to release some grease so that I could get the joint far enough back so it'd fit on the box shaft.
Oil pan and pinion clearance
I've still got plumbing to do for the engine and the brakes but I was hoping to turn the engine over by the end of next weekend. Keep your fingers crossed, I just might make it.
Old 12-03-07, 01:46 PM   #280 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Nice nice .. I hope some day I could do some work as you do .. Hi quality !
Just wondering if you thought your rear spring pack setup it's enought heavy to support the weight of all family stuff on it and your family with enought shackle clearance from the frame to the spring eye ..
HJ-60 2H-T Intercooled Tencha
Old 12-03-07, 02:16 PM   #281 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
That looks so good, Mike... I hope to see it at the Cascade Cruiser Christmas Party!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 12-03-07, 02:26 PM   #282 (permalink)
boots4's Avatar
TLCA# 19547
Thanks again Tapage, I actually wanted to see how the rear pack did without the overloads but since I put them back on I am confident it will carry whatever weight I put back there.
When I was deciding on shackle length I used this thinking. A leaf spring is at it's longest point when it is flat. When the spring has arch in it whether postive or negative it will shrink in size. A shackle allows the eye to swing in an arc motion. I decided on a length for the shackle (considering mounting points) that allows the spring to get flat and not contact the frame. If I were to over load the springs and cause negative arch then the shackle would actually push the eye away from the frame because the spring would shrink.
Old 12-03-07, 04:22 PM   #283 (permalink)
1974FJ's Avatar
hey Matt,
It looks like the front driveshaft might be pretty close to the oil sump. Do the 4bts come with rear sump? or is that an aftermarket sump? I couldnt remember which way it went, ive seen both.
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
1974FJ is offline   Reply With Quote
Old 12-03-07, 05:37 PM   #284 (permalink)
boots4's Avatar
TLCA# 19547
O.k. looks like I need a simple correction. My name is actually Mike, not Matt. No worries.
There have been 4bt's with front, rear, and the marine version which is flatter overall. The pan on my 4bt is a rear sump. There is clearance for the pinion and driveshaft. That was the best angle I could get to try and demonstrate that. Looks like it didn't work.
Old 12-03-07, 05:44 PM   #285 (permalink)
OHV Trail Patrol
TLCA# 15577
That's what I said...
KE7VSA - MetalTech
Old 12-03-07, 05:52 PM   #286 (permalink)
1974FJ's Avatar
Sorry "Mike" haha
So did you buy that sump?
Martin Hovis
Old 12-03-07, 06:20 PM   #287 (permalink)
TLCA# 9439
In the home stretch. Looking excellent
Old 12-03-07, 06:25 PM   #288 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by 1974FJ View Post
Sorry "Mike" haha
Nope, it was on my engine. It came from a stepvan that had the chevy adapter and the turbo400.
Old 12-10-07, 12:33 PM   #289 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
It's getting cold again but I'm loving the jumpsuit my wife found at an estate sale a couple months ago. I put that thing on and stay warm. In fact it was in the 50's on one day and I had to take it off because it was too hot! I definitely recommend a lined jumpsuit if you have to build your project outside like me.
A local 4bt FJ60 came by last week and gave me a hand. We mostly chatted but talked through the wiring and the heater hose configuration. So I didn't get much physically done that day but I know where to hook everything up now. As a reward I asked for a ride and that kept my motivation high. From the passenger seat it felt like it's got plenty of power to get out of it's own way and I can tell that the torque is going to be addictive. He has a T400 tranny with no overdrive but the first three ratios are the same as my 4L80 so it should be similar in acceleration.
I got some key systems hooked up this weekend. After hitting a few places and having each one tell me to try out a different place I finally arrived at a place called Oil Filter Service that had what I was looking for. Here is the stuff I came home with. Top to bottom: hose for tranny cooler lines, power steering hose, old hose for reference (toyota line on top, then stepvan hose), and a handful of adapters to make it work.
I ported the steering box but will mount my ram later, probably when I have time to trim the fenders for the 38s. These are some 6 AN caps.
These are the o-ring adapters to 6 AN. I needed three of these for the pump and the HB unit: 1-18mm x 1.5 to 6AN, 2-16mm x 1.5 to 6AN.
I should have taken a pic of the other end because this shows the 6AN side but this is the one that fits in the steering box. It's for an inverted flare. This was 16mm x 1.5 to 6AN.
These are for the tranny. The guy behind the counter said the original threads are not quite 1/4 NPT for the line adapters. My tranny research said they were but he has seen these before (I brought mine in for reference). He did say that a tranny shop around the corner goops these and cranks them in. They will go in once, but not twice so if you need to take these out again you'll have to tap new threads to whatever you want. They are 1/4 NPT to 6AN.
I needed 6AN adapters on my tranny heat exchanger to match the ones on my tranny so there they are put in. They seal by o-ring so no tape. In fact those tranny side adapters are the only ones I taped because the rest seal by the seat of the adapter or the o-ring on the adapter.
When I put the adapters in the tranny they didn't feel like they were binding but I'm not going to take them out to find out if the threads were different. I am still deciding on the exact position of the heat exchanger so I haven't hooked up the lines yet. I just hope I bought enough line. I did get the push-in hose ends so if the hoses aren't long enough I guess I'll just make another run to the place and get some more.
I made this bracket to hold the power steering fluid reservoir and the overflow tank for the radiator.
It mounts on the driver side fender well using existing bolts and holes.
Overflow tank and reservoir mounted.
Old 12-10-07, 01:33 PM   #290 (permalink)
boots4's Avatar
TLCA# 19547
More
I got the brakes hooked up. I loaned a flaring tool at Autozone and started practicing. I didn't get it on the first couple of tries so I kept practicing. The flares finally started to turn out alright so I started hooking up my lines. The master cylinder had two different threads for the front and the rear so I got an adapter to make them the same. I reused one of the original fittings and got another one for the other side. I took the master with me to verify it would fit and got a fitting for 3/16 line. That and the toyota metric line are the same. It didn't take too long once I could duplicate good flares. I'm also reusing the toyota proportioning valve. I don't know if it will work but I'll try it out. If it's a no go I'll just pick up an adjustible one and plumb that into the rear line. I had this laying around so I thought I'd try it out. You can also see the power steering lines hooked up. That system is complete too.
Sneak in one of the steering box
I chatted with dieselcruiserhead about the adapter for my turbo compressor housing. My old one didn't fit. He said he had one tigged. I decided to cheat and if my cheat doesn't work I'll end up doing that. I took the housing off and ground the lip down to get the hose over it. I left a lip to act like a barb to catch the hose. There is enough flat surface on the neck that I think the hose will seal with a good compression clamp. So I'll give it a try and see.
Got my new caliper at Napa, painted it and put it on. Actually one of the threaded holes in my knuckle was stripped. I found that a 1/2"-20 (fine) would re-tap the hole so I converted from metric to grade 8 fine 1/2" bolts. I didn't even have to drill out the hole, it was the right size. The old pads looked good so I sanded them to resurface the pad and put them in.
I decided on a location for the brake line tabs and welded those back on the axle. This location allows the caliper movement without binding the rubber line. These are the shorter lines from Napa (per the part numbers on the tech section). I think I could have saved some $ if I had them made at Oil Filter Service where I got my steering hoses. Oh well, they are hooked up now.
Driver side
Passenger side
These are the long lines to connect the axle to the frame. They are plenty long and I doubt I'll use up the length. This is the front axle.
Rear axle, sorry these turned out blurry but you get the idea.
Close up of the connection between hard line to rubber on the rear.
I fixed the smashed line on the front axle with a union and two 3/8" fittings. They didn't have any 10mm unions (I had extra 10mm fittings) so I used standard thread instead. I may grab a whole new line and bend it up since this one was pretty wavy.
Heat hose routing. You will notice that I put t-fittings on two of the lines. Those are for the tranny heat exchanger. I wanted flow through the exchanger and the engine pre-thermostat or in other words for the exchanger to get flow before the thermostat opens up. On the 4bt there is a pre and post thermostat port (in my definition pre allows flow with out the thermostat having to be open) so I hooked up the front heater and exchanger to that line. I hooked up the rear heater to the post port. The cruiser already consolidates the heaters to one return so I put a T in the return line for the exchanger.
I cut down the original upper radiator hose to fit. I've had some problems mating the lower to the radiator because the 4bt has a masssive 2 1/2" port while the cruiser's is 1 1/2". I'm still playing with ideas and will show what I come up with. I just need to get some hose that fits. My first pieces were too small.
I found some bilsteins brand new on craigslist so I offered a reasonable amount and picked them up. The fronts are 5150s 14" and the rears are 5125 12". It seems like that was what most with SOA's were running. They should look good with my color scheme.
Things left before I can start it:
- finalize the lower radiator hose
- plumb the heat exchanger
- route the intercooler tubing (I had an idea last night when I couldn't sleep which might work)
- get a belt
- hook up fuel tank and lines
- hook up battery
Old 12-11-07, 09:18 AM   #291 (permalink)
89s rule's Avatar
TLCA# 14198
looking nice. its amazing how much we can get finished if we just set aside a little time!! Keep up the good work!
'93 FZJ 39K miles - 850/860, Bilies, LED tails, sliders, & 285 MTRs Lightforce 240s waiting on a bumper.
'97 4Runner SR5 - 4x4, leather, Toyo AT, TJM T15, LF 240s.
'63 Biscayne Wgn - Kandy Green & Tweed. Family Wagon 3rd row in the garage.
'89 FJ62 & '83 fj60 SOLD
Erskine College Upstate Cruisers
89s rule is offline   Reply With Quote
Old 12-11-07, 04:42 PM   #292 (permalink)
redcorn's Avatar
I've got major wood looking at this thread my man............
I know you are soooo close....
stay warm AND dry
john
No cruisers left behind, they all deserve a good home
BIG WAGONS RULE
http://forum.ih8mud.com/60-series-wa...orns-turd.html
redcorn is offline   Reply With Quote
Old 12-11-07, 07:19 PM   #293 (permalink)
boots4's Avatar
TLCA# 19547
stay warm AND dry
john
LOL, It was the extended shocks wasn't it.
My goal this weekend is to start it. I bled the brakes last night and eliminated a headache, I'm ditching the AC compressor until spring. It just simplifies the work and routing the intercooler will be much easier with the parts I already have. I was going to reuse my small-child sized air filter that came on the stepvan but after really looking at it, it's got some breaks in the pleats so I won't be using it. Fitment would have been a problem anyways. I ordered a really nice one and will show it when I get it. Also grabbed a new locking dipstick for the tranny online. I picked up some more radiator hose to adapt the bottom port and finalize the top just today so that will be done. I also have most of the exhaust pieces I think I'll need. The ducks seem to be lining up for a weekend puff of diesel!
Old 12-11-07, 07:54 PM   #294 (permalink)
1974FJ's Avatar
i cant wait! haha
I hope you can take video?
Martin Hovis
Old 12-12-07, 09:15 AM   #295 (permalink)
brokenparts's Avatar
TLCA# 16127
good to hear man!!!
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 12-12-07, 11:21 AM   #296 (permalink)
concretejungle's Avatar
TLCA# 14646
This has to be one of the best, most complete builds i have read on Mud. Great job.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is online now   Reply With Quote
Old 12-12-07, 11:42 AM   #297 (permalink)
boots4's Avatar
TLCA# 19547
Thank you.
I put in some more time last night and got the fuel lines hooked up to the first filter but ran into size problems for the lift pump. I took off the hose barb that was 3/8 and will look for a 5/16 one. It doesn't sound like much but I cannot get it to slide on far enough so I'll run around at lunch break today.
Other things I got done last night:
-cleaned, cut and hooked up the passenger side intercooler pipe once I tighten up my altenator in the original position.
-clamped down the upper radiator hose.
-worked on the lower but didn't have the just right clamp to cinch it down to see if my adapter is going to work.
-changed out the bad u-bolt on the driver side for a good one.
-repositioned my pitman arm so that I'd have more adjustability on the drag link.
-put on my belt.
Old 12-12-07, 01:41 PM   #298 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I'm pretty sure if you get any failure in yout Cruiser .. you gotta know exactly where is .. and how to solve .. the bigest benefit from a scratch build ..
Old 12-13-07, 09:02 PM   #299 (permalink)
Swedish Chef's Avatar
I love your rig! I just read this whole thread and am very impressed! Your attention to detail is great and this thread is on my watch list now!
-Cameron
The day job: iPd
Swedish Chef is offline   Reply With Quote
Old 12-17-07, 12:25 PM   #300 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
Wow, what a long week. In fact it's been a couple of long weeks. Quick summary: IT RUNS!! but........ she's not moving all that well meaning probable tranny rebuild sooner than later.
There are many ways to do this and and probably better but this is what I came up with for the lower radiator hose. I had to adapt the 2 1/2" to a 1 1/2" with a funny angle. I couldn't find any copper elbows big enough but I did find a plumbing elbow that had close to a 2 1/2" o.d. It is actually list as 1 1/2" i.d. Then I just got some 2 1/2" radiator hose from Napa.
I took in a half of my 4bt upper hose to Napa and had them find something that had a similar bend. They had something so I used that new piece as the second half of the upper hose and used this older piece to connect to the FJ60 lower. I picked up an exhaust reducer from 2 1/4" to 1 1/2". This is the lower section of the frankenstein hose.
This is how it goes together.
After I invested in some hose clamp stock I picked up some better clamps and put it on. The engine side clamp is not small enough so I'll need to get a smaller one and eliminate the second clamp from the top. Hey, sometimes more clamps are better . It makes me laugh looking at it but it works.
Friday was a very good day. Kevcj came over and put in 9 hours with me and we got a ton of little stuff done. Little stuff like circle clips, front hubs, rear lug nuts, filler neck tube to the gas tank, finished routing lines to the heat exchanger, making a mount for the heat exhanger, wiring, hooking up power, oh yeah we even got the engine RUNNING!
The tranny cooler/heat exchanger came with a mount base. We heated it up and bent some parts and now it's on the firewall.
Video was requested, here you go.
diesel first start.mov videos from rides videos on webshots
I'll admit this wasn't the very first start. We had to troubleshoot a few things before it would actually start. This is what we did: We hooked up the battery and found a switched 12v source from one of the connectors on the driver side that wasn't being used. We wanted it hot once the key was in the ignition spot. I got new fuel, took off the fuel filters and filled them up. Then we put the rest of the fuel in the tank. We primed it using the primmer on the lift pump. The arm went limp. Then we tried to start it. The starter turned over very slow. After some additional batteries and a couple of jumper cables we found that the ground was not efficient. I had put it where the last one was and that was on the fender. I scratched off the paint but the ground was inefficent. Once we went to the frame with the ground it spun the starter much faster and I now get the instant start that I got in the stepvan. We used the big, thick cables that came from the stepvan and had plenty of room to re-route the ground. I ground the engine and the battery to the passenger side diagonal brace that already had two bolt holes in it from removing that front undercover (I think this is FJ60 specific), anyways the threaded holes were already there. The engine started up and stumbled for about 20 seconds and then it settled into a rock solid idle. I didn't have to bleed the injector lines. The fun came when I tried to turn it off and it kept running when I took the key out of the ignition. There is a manual shut off on the injector pump and I used that to stop the engine. After talking it out we must have used some wire that continued to get power after the key was out. I knew the coil wire was good but it was on the other side of the engine bay. I decided to tag off of that wire to try it out but Kevcj, who already stayed later then he planned, could go home and leave me dumbfounded that things actually worked. I hooked up that wire and the engine started and stopped with the turn of the key like it should so I'll just clean up the routing of that coil wire. If you are doing a swap, label your wires, I did and it was easy to find them 7 months later when I needed them again. Also before I started the engine I put in any necessary fluids like power steering, engine oil, coolant, and ATF since I'm running an auto.
With the engine running I could see a few leaks I needed to fix. The biggest one was the block heater. The next day I took it out and found a tighter fitting o-ring at the hardware store. It wasn't as easy to get to since everything was on the engine now but with the air filter off it was accessable. HINT: When I put it back on I tightened it as far as I could get with a little allen head wrench but it didn't feel tight enough so I got some socket extentions and tapped it with a hammer. I tighten it some more. I did this a couple of times until the block heater looked almost flush with the block. Now it doesn't leak.
In order to take it around the block I needed to get the front wheels on so I did an alignment. This is how I measure for 1/8th toe-in. I found some straight angle, clamped them on, measure out equal distance on the front and back and compared. Pretty simple.
I went to my friend's shop and he helped me shorten the rear driveshaft. Finished up other stuff and went for a drive. I forgot to put the doubler and TC in gear but figured that out. Then it still wouldn't move. I increased the rpms and it finally started to move.
Vids:
leaving
first time leaving.mov videos from rides videos on webshots
coming back
first time coming back.mov videos from rides videos on webshots
Got the hood on (yes I re-routed the air cleaner, this one's just temporary until the other one comes in), hooked up the dash and tested the lights. Only one bulb worked on the dash so I turned the others around in the sockets and now the others worked. LEDS are polarity specific so it matters which way they go in. You'll only know if you get it right when they do or don't come on. I really like how the lighting turned out and they do dim if needed. I then took it on the freeway to go the a cruiser christmas party.
I got on the freeway and couldn't get overdrive. I thought earlier that I wasn't getting third gear but it was actually overdrive. So this is what I'd get: 1st good, 2nd good, nothing in the 3rd spot, 3rd in the 4th spot, and no overdrive. I was going maybe 55 mph on the freeway (had my wife chasing behind me and we used little radios to communicate). It felt like 3rd is slipping (1:1 ratio). I got off at the next exit (2 miles) and turned around to go home. It was a good first test but with unfortunate results. I have the trans manual and will look it over to see if it's something simple but I'm leaning towards a rebuild. Since I don't have a dipstick low fluid is a possibility. I think I had 10-11 quarts in it. I added 3 more for a total of 14 quarts and took it out yesterday but it was doing the same thing. I should be getting my dipstick today so I'll have to see how it reads once I get it installed. Bummer, looks like we won't be taking it to California after all for the christmas visit. I didn't have a muffler on it when I was on the freeway and it was loud. I hooked the stepvan one up yesterday before the tranny test and it helped. I was worried because I haven't hooked up shocks yet but it wasn't that bad without them and I took it easy and left myself room to stop.
Here are some pics of the engine with the hood on. I have a clearance issue with the overflow tank and will need to cut of the mount and weld it on a little lower.
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
