Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
HardCore Corner Hybrid, Buggy and Fab-from-Scratch creations...for those "out of the box" projects.
Old 04-04-07, 10:56 AM   #1 (permalink)
projektdotnet's Avatar
Questions about SM420 w/spaceghost plate
Ok so I purchased an SM420 that is using a Spaceghost adapter and is almost ready to drop in except for one little problem...what clutch setup should I get? I probably need a new T.O. bearing and Pilot IIRC. Also I have the stock Toyota 4spd behind a 74 F motor currently if that makes a difference. So what clutch parts would I need to get?
Pressure Plate:
T.O. Bearing:
Pilot Bearing:
Disc:
Thanks in advance
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 04-04-07, 11:31 AM   #2 (permalink)
what he said
Mace's Avatar
pressure plate Stock,
Clutch plate, 11" chevy (although, I still think the toy plate will wor, but I have not tried it myself)
TO bearing, stock
Pilot bearing (I use a GM bushing in a adapter..)
I am kinda gay.......
I've set the bar, don't trip over it....
Old 04-04-07, 11:32 AM   #3 (permalink)
TO bearing, stock
Where would I source the GM adapted bushing? I am guessing stock will not work in this case?
Old 04-04-07, 01:08 PM   #4 (permalink)
what he said
Mace's Avatar
I think I got mine from Advance adapters.
Old 04-04-07, 01:56 PM   #5 (permalink)
thanks
Old 04-04-07, 03:20 PM   #6 (permalink)
bustanutley's Avatar
You need a 3 speed bellhousing, and the nose cone adapter ring thingy
the 3speed disc did not fit the splines on my 420, GM 10spline 11" is the way to go.
Pilot bearing A&W Bearing Supply 800-535-9638
A piece of exhaust pipe cut to 7cm has the correct inner and outer diameter 1 3/8” ID & 1 1/2” OD Part #548530 for stock TO bearing
I'm using a 3 speed clutch and flywheel.
FJ-40 on FO-DEEs
just a lil guy
bustanutley is offline   Reply With Quote
Old 04-04-07, 07:04 PM   #7 (permalink)
hlb3's Avatar
I picked up the throw out bearing adapter, indexing ring, and bushing from Classic Cruisers.
I picked up my 11" Chevy clutch disc from partsamerica.com, they have them for $25, by far the best price I found.
'68 FJ40, F/SM420/3spd case, SOA, 36x12.50 TSL's
hlb3 is offline   Reply With Quote
Old 04-04-07, 08:28 PM   #8 (permalink)
Thanks guys
