Old 01-27-07, 01:46 PM   #1
TachedOutOffRoad's Avatar
Finishing a coiled-over idea
Truck:
1990 4runner, bobbed with p/u tailgae
3.4l, dual cases, SAS, 4.88s, full Detroits, hydrauilc assist, 3-link, coilovers
CLEAN!! never been wheeled. It was used as an advertisement truck. I flexed it out and the 35"s scrubbed BAD . Not a little "What was that noise?" more like POWPOWPOW "Oh hell, you just chunked the tires."
Ive only ever had a 22r/re in a yota and this thing balled the tires on pavement with the 4.88s . If I feel much of a loss with the 37"s Ive got some 5.29s that Ill put in.
To do:
Front end rebuild, 30 Spines, hub gears, upgrade hub studs, real high steer with beefy rods, upgrade driveshafts, rebuild one coilover, trim fenders for 37"s, move steering ram <-- fix leaks, tighten-up bumpers, add cooler for steering, full exo <--Only b/c the truck is SO clean, remove gay stickers, flush all fluids (is the radiator fluid supposed to be brown ), swaybar, and whatever I break the first trip out.
The links in the front look weak to me and are my biggest concern. Ill take some pics and post.
No too bad a list. The cage will be the most time consuming and I hope that the links will hold up to a good skinny pedal pounding
I like to build my own stuff for many reasons BUT I am on a budget and will gladly buy a ready built crewcabish tacoma thing with a 3.4l and duals in it, I did get into this money pit sport to RIDE right? Im basically looking at this like a pile of parts and expecting nothing, but hoping for the best.
What i bought
TachedOutOffRoad is offline   Reply With Quote
Old 01-27-07, 01:48 PM   #2
SWEET! more than 100hp than what Im used to and all Toyota.
Have to have
New to me
Old 01-27-07, 01:51 PM   #3
30s BEIOTCH
preventive maintenance
Had this laying around
Old 01-27-07, 02:00 PM   #4
No, I didnt take it swimming . . .
Gotta work on this
unexpected wheel spacers and IFS rotors
Old 01-27-07, 02:01 PM   #5
Upgrading these
So I can run these
Old 01-27-07, 02:02 PM   #6
before= scary and weak
after= strong and BLING
Old 01-27-07, 02:05 PM   #7
First ever halfway descent fender trimming job that Ive done. Found a little bondo, but it worked out.
Old 01-27-07, 02:05 PM   #8
I like the look of the bumpers, but the front sticks out way too far.
I can probably cut about 4"s out of it if I keep the multi-mount winch plugs.
Old 01-27-07, 02:07 PM   #9
parting shot
Thats it so far.
The steering stuff sould be here next week and I need to fab new brackets for the ram.
I found out that Im going back to Iraq in 12 weeks so we moved our trip to Hot Springs back a month so I really need to hustle on this exo-cage. Im not a huge fan of them, so Im going to try to make it as simple and with clean lines as I can. A test ride is a must before I make the 9 hour trip to Arkansas in the new family ride.
The more I sit here, the more I want to go check out my links and see how thick they are before I make any crazy plans
Old 01-27-07, 04:53 PM   #10
84yota4x4's Avatar
That looks like a great starting point for building a trail rig! Keep us posted on the progress. Looking good so far.
Covenant College
Olde North State Cruisers
1984 FJ-60 w/ 4runner brakes, Dick Cepek 31/10.5 (resting in the garage )
1994 Saturn (great on gas )
84yota4x4 is offline   Reply With Quote
Old 01-30-07, 07:19 AM   #11
Link shots
sweet giant bolts
The rears are 1.75"x .120"
The lower fronts are the same but the uppers ar only 1" OD. Im really trying to go on a test run this weekend and I may weld some angle iron on the uppers for the test ad then retube them when I get back.
The ends have what I call johnny joints in them.
The coilovers are Doetsch 15" with QA1 springs. 225/250 in the rear and 250/300 in the front.
I ordered two new 15" shafts, two rebuild kits and overnite shipping for $90 which I though was pretty reasonable.
Old 01-30-07, 07:29 AM   #12
Rear trimming
PLENTY of bondo. Whoever bobbed this would kill me if he saw what I did with that cutoff wheel
Before w/ 35s
After w/ 37s
This is way taller than ride height.
Can you see how thick it was?
Old 01-30-07, 07:34 AM   #13
Departure angle
Approach
This is with the bumper off in case you could not tell
After I trim it, it should only stick out about 5" in front of the tires.
Old 01-30-07, 07:36 AM   #14
New hub studs
Did I mention that this was my tow vehicle
Old 01-30-07, 07:40 AM   #15
Its 76" tall
24" to the frame rail
about 112" wheel base
on 37" IROCs
Old 01-30-07, 09:05 AM   #16
what he said
Mace's Avatar
those are not hub studs..
I would swap them out for studs..
I am kinda gay.......
My Myspace
Old 01-30-07, 09:41 AM   #17
You know what I meant
Why would you not use them?
Old 01-30-07, 09:46 AM   #18
Something clever
Arya Ebrahimi's Avatar
Because they are not studs. As you tighten the bolts, the cone washers compress and prevent the bolts from reaching true proper torque(you torque wrench may read the value, but the fastener is not actually achieving that torque, the reading is being affected by the friction caused by the cone washer). A true stud does not turn and is therefore not affected by the cone washer. This lets the stud act purely in tension and not in shear.
In short, use studs because that's what you're supposed to use. Use ARP studs if you want some extra beef, available from www.frontrangeoffroadfab.com
Ary
HOKIES UNITED
Arya Ebrahimi
'94 FZJ80 200k miles, locked, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
My mini-truck buildup thread...updated 9/10
Mini-truck's first trip!! With PICS! 11/10
Arya Ebrahimi is offline   Reply With Quote
Old 01-30-07, 09:54 AM   #19
I see what you are saying, but. . . .
Ive sheared off all of the factory ones twice in one day and these have to be stronger. A grade 8 bolt is like 10.2 metric and these are like 12.2.
Ill dog the shiznt out of it this weekend and report back what happens.
Old 01-30-07, 10:47 AM   #20
Something clever
Get the ARP studs from front range. The guys on PBB beat their shit like no other and I have yet to hear of an ARP stud failure. Whether it be hub studs or steering studs.
HOKIES UNITED
Arya Ebrahimi
Old 01-30-07, 02:00 PM   #21
Tapage's Avatar
Look nice ..
But the other studs from the hub cab ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 01-30-07, 02:06 PM   #22
Old 01-30-07, 04:06 PM   #23
Isotel's Avatar
TLCA# 16898
Nice Buildup! id like to build a runner to beat on soon!
Maybe those Hex Bolts will hold up! i would not hesitate to run them! the only way to find out if they work is to try.. THe ARP Studs seem to work great, and/or the Hendrix Pin Mod!
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - Safety First
CrAwLoRadO.com - Just Check it out
Old 01-30-07, 04:22 PM   #24
my upgrade was only $68.40 cheaper than the ARP ones
time will tell
Old 01-30-07, 04:46 PM   #25
what he said
Mace's Avatar
Bolts will loosen up again. Then you will shear them off..
Typically the failure of the hub studs is from them loosening up. Not a direct failure of the studs themselves.
The multi dowel approach has been proven.. It does wonders..
There cone washers under those allens? what did you torque them to?
My Myspace
