Oz TUTer
Winch challenge project
G'day, I've decided to make use of the three Daihatsu Scats that I own (F10, F20 & F55) to make a little comp truck to save my HZJ80 from getting to trashed offroad. Toyota owns Daihatsu now and I plan on using a few Toyota components as well so I thought I'd document it's build up here.
I'll be mainly using the truck for recreational trail use but also for Short Course, Winch challenges and some rock crawling. Until I work out which events I like best and which events it is better suited to I'll try to keep the rig an allrounder. My goals are to keep the rig lightweight, manouverable and reliable. I want to be able to complete each of the courses/stages rather than outright speed or ability. I will use my F55 Daihatsu as a starting point for the project as it has a 107" wheelbase standard as opposed to the others 80" wheelbase. The DG diesel motor will be removed and a VN Commodore 3.8L V6 and T700 auto will be slotted in. These will be mated to either a Hilux T/case and Hilux/Bundera diffs or a Land Rover LT 230 T/case and Range Rover diff housings fitted with Hilux centres. The Rangie/Hilux hybrid diffs are something I've seen on Outerlimits or Pirate, the Haultech boys use them on their buggies.The first stage of the build will involve getting the cab roadworthy (the rust is pretty bad around the gutters and windscreen). The comps require the vehicle to be registered so I'll keep it pretty tame to start with then as the project evolves and the funds permit the more fun mods will begin. For those of you who don't know what a F55 looks like (nothing like a FJ55 for starters ) here's a couple of pics of "Piglets" rig which will be very similar to my proposed build. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
Oz TUTer
I don't have any pics of my F55 at the moment but next Saturday I'm hiring a car trailer to transport it from my mates place out of town where it is currently stored to my house in town where I can start work on it.
The cab is very rusty around the gutters but one of the boilermakers from work said that he would cut it out for me in exchange for some mechanical work on his V6 Prado . Body work is not one of my favourite jobs so it is good to be able to offload that job to somebody else. The roof and gutters are that bad that it will probably be easier to replace the whole roof section. As the Ute cab is a bit tight on interior room I'm toying with the idea of converting it to an extra cab and using a cutdown SWB hardtop for the roof. I guess that will depend on how keen the boilermaker from work is. At least I've got a few more boilys to chose from if I scare this one off, I'm the foreman at a fabrication workshop .As I hate doing bodywork I plan on fitting an exo to try and lessen the carnage later on down the track. As the rules I'm going to have to comply with require an internal cage and I want to keep the weight down I"m going to have to be careful with my exo design. I'm thinking a four point internal cage to meet the specs with a full tube rear tray/cage. The front end will have a small tube bar to house the winch (hopefully PTO if I go with the LT230 L/R T/C) and side rails/scrub bars leading down to the rock sliders. The cab protection I'm thinking I'll make from slightly smaller tube than the rest and make it bolt on to make it removeable. The tubes will come forward from the tray headbord/front hoop along the gutters to the "A" pillar and then down to the side rails/scrub bars. Cross bars at top and bottom of the windscreen will complete the cab protection. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
Oz TUTer
Here's another quick pic of a hard core F55. This one's got a chev v6 and 60 series cruiser axles.
Don't know who owns this one though. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
Oz TUTer
Here's a list of mods I have planned for this project.
-VN V6 and T700R4 auto -LT230 T/case -Range Rover diff housings, coils, links and brakes -Hilux/80 front diff centres, airlockers, haultech CVs(birfields) -Simex Centipede 35/10.5R15 tyres -PTO winch front -Electric winch rear -York AC compressor for OBA Future mods (when I win Lotto) -MaxiDrive bolt on portal boxes -Floating tophat/hydraulic rear suspension -Hydraulic ram assist steering -Haultech traction control __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
Those things look sweet. They look about the same as a suzuki lj20. Are they about the same size?
Oz TUTer
Here's a link to the writeup on the Toyota/Rover hybrid axles on Pirate.http://www.pirate4x4.com/forum/showthread.php?t=367387
The main reason I want to go this way is a mate has just bought a Rangie to compete in as well and when he bought it he got a heap of spares with it. I also think this mod combines the best of the advantages of each of the different makers to give a good diff to suit my requirements. The Rangie diffs will also match the offset of the LT230 t/case I want to run. The LT230 has a good low range, a good trans mounted park brake, is strong, light and being constant 4wd has the ability to be unlocked to permit front or rear "burns". __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
#7 | |
Oz TUTer
Piglet's blue truck weighs about 1620kg in full Outback Challenge specs including the extra fuel, water, food and spares required for the comp. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
Oz TUTer
Here's a link for those that are interested in learning more about these tuff little trucks.
http://www.outerlimits4x4.com/PHP_Mo...forum.php?f=18 __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
Good luck on your new project, can't afford one of those yet.
__________________ 93 hzj80 Aussie spec cruiser with 9000 pound warn winch , old man emu suspension , engel fridge, ARB front & rear lockers,GME UHF 2 way and ARB compressor. |
#10 | |
Oz TUTer
My original F20 (my first 4wd) cost me $1500 years ago and the spare parts F10 cost me $1200. The F55 I'll be using for this project cost me $300 of which I got back $250 when I sold the gearbox, t/case and bonnet. My plan for the motor and auto is to buy a complete VN commodore to wreck for about $300-$500, keep the engine and gearbox,wiring loom and computer and then sell the rest. I already own a BOC 250R MIG welder (even though I suck at welding) and a tubing bender and all of the rest of the tools a person in my position (4wd Mechanic) owns. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
#11 |
Spit my last breath
i got no idea why the haultech boys do that... considering toy cv's and inners (not to mention aftermarket) are tuffer than rover as well so i don't see the point in stuffing around with hybrid shit
__________________ What can you do when you wake up and realise you sacrificed everything you ever wanted in life for the sake of progress? |
#12 |
Oz TUTer
The hybrid axles use the Toyota centres and CVs. It's just the housings, brakes, hubs and suspension that is Rover. I reckon the suspension and brakes of the Rovers are better than the Hilux/Bundera alternative. I know I'm going to get flamed for that one but the Rover rears come standard with discs, Fully Floating hubs, "A" frame suspension and a small high clearence pumpkin. I'd have to Bundera or Surf to get a similar setup and the offset would be wrong for the T/case and the hubs aren't fully floating. The other good reason I like is the Rover axles are a hell of a lot cheaper to get in the first place and most of the Toyota bits are things you would replace in a tuff axle build anyway.
#13 |
Spit my last breath
why not run cruiser FF rears? will you need discs on your truck? offsets not a huge deal
#14 |
Just wondering dude .. and only IMOP ..
I know ( maybe most of us ) about great suspension on Land R, I'm agree with this .. but I'm not sure or believer ( here in Panamá is really expensive buy one LR spare, if you can find off course .. ! ) about LR axles .. I'm pretty sure in Toyota Axles .. ! tranny and t-cases .. again .. just my .000000002 cents ..
#15 | |
Oz TUTer
I've never been a real fan of drums, just personal preferance for the discs. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
#16 | |
Oz TUTer
My mate who has just bought a Rangie to compete in only paid $800 for the complete car in roadworthy condition and got another spare parts car thrown in with it. Hopefully I'll be able to get the axles of his parts car. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
#17 | |
If you can found Hi Lux axles .. straight with those ones .. or if you found LR axles .. |
#18 |
those rigs are sweet, good luck on the project
__________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#19 | |
Oz TUTer
#20 | |
Oz TUTer
I'm going out this Saturday to pick up the ute from my mates place with a car trailer so hopefully I'll be able to get a few pics of my rig and to get a bit of a start on the project. __________________ 90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, 9500lb winch, ARB dual pivot rear bar, 39L Engel, water tank, dual batts, sliding drawers, cargo barrier, underbonnet shower, laptop, GPS, oziexplorer, etc.... 99 HZJ105R GXL, alloy bullbar, Safari snorkel, more to come.....watch this space.......... |
#21 |
your welcome, lets see some more pics
#22 |
Oz TUTer
Here's one from http://www.offroadimages.com.au/OffroadHome/index.php to tide you over until I take some photos tomorrow and get them posted up.
#23 |
That is a top looking little 4wd.
#24 | |
#25 | |
Oz TUTer
