Go Back   IH8MUD.com > tech.ih8mud.com > Trucks > GM/Chevrolet/Hummer
Old 06-20-09, 05:37 AM   #1 (permalink)
Degnol's Avatar
TLCA# 14529
96-00 Vortec Problem
135,000 miles, well maintained as in I've owned it since new. Started bucking on startup, intermittent at first, now more consistently. Put on a new starter, same thing. I suspected head gasket but pulled plugs and there is no coolant in the cylinders at all. Small coolant leak at the back of the intake, but no coolant in the oil at all. I'm beginning to think it is one of the "sensors" but have no idea where to look. BTW, it throws no codes But if the knock sensor was whacked, could the ECU be advancing the timing to the point where it would buck?
Once it starts, it runs just fine, makes good power and generally acts normally.
Am I condemned to take it to the GM dealer?????
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 06-20-09, 09:08 AM   #2 (permalink)
lingo's Avatar
Check the timing to make sure that it is correct. The base timing should be set at 0 degrees.
mike c.
'76 fj40
'71 fj40
(516): is 1am too late, or too early to make bacon?
lingo is offline   Reply With Quote
Old 06-20-09, 09:11 AM   #3 (permalink)
Degnol's Avatar
TLCA# 14529
Thanks Mike. I talked to a GM tech and he said it may be the CKP (crankshaft position sensor). That would affect timing. It bucks just like when you install a new tach and get the timing too advanced.
Ed
Old 06-20-09, 11:03 AM   #4 (permalink)
Degnol's Avatar
TLCA# 14529
I replaced the CKP and had a little problem....the last step in the installation is to "Perform the CKP Variation Learn Proceedure" which requires a "Dealer-level" scanner However there is no harm in starting and running without performing that as the engine has to be running and warm when it is done. So, I started it and no bucking! 'Course the problem was intermittent, so
Old 06-20-09, 03:41 PM   #5 (permalink)
FineWynsFJ55
FineWynsFJ40's Avatar
TLCA# 19730
Some trouble codes won't light up the Check Engine Light, so you have to check it regardless of whether the light is on or not. The computer system teaches itself as it drives, so it should be good. The computer can figure out for itself what to do, and doesn't need you to adjust the distributor cap for it
Good luck!
Brian
~ Two paths diverged in the woods, and I, I engaged my front axle and took the path less travelled ~
1974 FJ40: Pandora's Box
1970 FJ55: Iron Pig
FineWynsFJ40 is offline   Reply With Quote
Old 06-20-09, 04:30 PM   #6 (permalink)
Degnol's Avatar
TLCA# 14529
So, are you thinking I don't need to go to the dealer and have the "Learning" proceedure done....that is if this fixes it? That would be cool
I gave the distributor cap three coats of Carnuba wax so I should be good there.
Thanks,
Ed
Old 06-22-09, 05:00 PM   #7 (permalink)
Degnol's Avatar
TLCA# 14529
On the advice of a mechanic buddy I replaced the distributor cap and rotor and VOILA! Starts(repeatedly) and runs fine. My buddy said to use only AC Delco or Borg Warner. I had it replaced at 98,000 miles, but I do not know what mfr they used. I think those flat caps have a tendency to short out inside. Anyway.....fixed.
Thanks!
Ed
Old 07-05-09, 12:15 AM   #8 (permalink)
Elbert's Avatar
TLCA# 17526
FYI... you don't have to go to the dealer for the "learn process" most new scanners have the ablity to check the camshaft offset angle...
On the new engines you don't set the timing per say... The ECM controls the entire process, you do have to get the camshafte offset angle correct or close _+2 degrees. which you do my having the engine running as I recall at 1K RPM and monitor the offset angle with a scan tool , you move the distributor left or right to get it set right...which I think is 0 degrees. By the way its a challenget to get the dist set correct as almost any movement will change it by 5 or 8 degrees too much.
1986 FJ60
5.7 Vortec
Elbert is offline   Reply With Quote
