Go Back   IH8MUD.com > tech.ih8mud.com > Trucks > GM/Chevrolet/Hummer
Old 03-17-08, 04:39 PM   #1 (permalink)
FJ40_owner's Avatar
TLCA# 16294
Carb'd Chevy 350 Question - Carb backfire
My 40 has a 78 350 installed. I run a Rochester 2 barrel carb. There is no smog stuff on it. Recently when running at moderate rpm, say 2000, engine is warm, when I put my foot into it the engine will sneeze through the carb.
My stock 40 used to do this and the solution was a new gasket around the accelerator pump, as I recall.
The only PM I have done is fluid changes, air filter and plugs. The PM was done months ago.
I run regular CA fuel.
Should I check the timing or might something be wrong with the carb?
The choke is OK and not stuck closed.
Thanks,
BigJim
1977 FJ40 Softop
Chevy 350
Turbo 400
35 inch MTR's
Dual Band Ham
8274 with Synthetic rope
40 gallons on board fuel
FJ40_owner is offline   Reply With Quote
Old 03-17-08, 06:20 PM   #2 (permalink)
Supamod
Gumby's Avatar
TLCA# 5658
Garage
Accelerator pump sounds like the culprit.
Gumby is offline   Reply With Quote
Old 03-17-08, 11:20 PM   #3 (permalink)
baxter650's Avatar
Engine off, look down the carb throat, move throttle to w/o, look for pump shot.
1980 PU 9" lift 383 38" Swampers
1993 FZJ80 6" slee lift 37s
2008 XR650L
My 83 BJ60 bobbed, SOA, frame up, money pit, build. http://forum.ih8mud.com/60-series-wa...t=pics+tonight
baxter650 is offline   Reply With Quote
Old 03-18-08, 06:38 AM   #4 (permalink)
Supamod
Gumby's Avatar
TLCA# 5658
Garage
definitely with the engine off. You'll look goofy without eyebrows.
Old 05-12-08, 12:21 AM   #5 (permalink)
LMAO! I have seen this happen!
Does the water go all the way around the Island?
NeverSummer is offline   Reply With Quote
Old 06-04-08, 07:06 AM   #6 (permalink)
Chevinater77's Avatar
my 72 chevy 2 wheel drive long bed with a 350 with a 2 barrel carb does this with bad gas. We just picked the rig up so i plan to get a carb "rebuild" kit. and do the gaskets and new filters for it! Mine only did it around 50-60 MPH. and only when in drive. when i ran premium it stopped doing it so much but still did a little!
Its not a Passion, its an Obsession
Cruiser~95 stock 80 series, Goodyear Forterra Triple-Treds, Samco sport PHH.
Princess Ride~2008 Toyota Tundra Crewmax limited
Chevinater~ 77 Chevy 3/4 ton 350/350/203 with 44 front 14ff rear, 4.56s, 6 inchs 35x12.5x16.5 bfg m/t
Chevinater77 is offline   Reply With Quote
