02-19-06, 06:50 PM
Removing headliner insulation
Hello,
Is there an easy solution to removing the insulation glue on the roof? Man, that is tough stuff!
Thanks,
Chuck
1989 "HJ62" 2H, H55F, OME, ARB, Roof Rack, Winch
1991 Toyota Pickup Truck
1974 Land Rover Series III SWB Diesel, RHD
1994 Land Rover Defender (slightly built)
02-19-06, 07:13 PM
I asked that a long time back as well. I am going to use a wire brush wheel if I ever fricking get to it. I thought about just lighting it on fire at one point too though. I also thought about some paint remover and a scraper.
Cruiserless for the first time in 4+ yrs
Upstate Cruisers
02-19-06, 07:33 PM
Yes, I've tried the wire cup brush on a high speed angle grinder. Nothing about that method is high speed!
02-19-06, 08:39 PM
How about a heat gun?
1975 FJ40 2H/H55
1975 FJ40 Lifted,locked,toyboxed,woods rig
1971 PIG 1HZ,H55,60 axles(in Progress)
1980 HJ47 Troopy
02-19-06, 09:38 PM
or a steamer? like wallpaper, maybe that would work?
Ravi
70 fj55 under construction:
4WDiscs- done
rust- working on it
09-20-08, 11:28 AM
Incompetent Tinkerer
Cooling the roof down with dry ice helped a little, the glue came off in larger chunks, but it still left behind the thin layer where the glue adhered to the paint. I used a plastic chisel and a hammer, with the chisel at a fairly steep angle to the metal.
IH8MUD™ Forums - View Single Post - 74 Pig Build
LC_HAMMA points out that the wire wheel will smear the glue.
I've tried using a heat gun, but that left more residue than when I chilled the roof.
Anybody come up with a better idea yet? There's always sandblasting it, but I'd rather not go there just yet.
09-20-08, 05:43 PM
As for the small bits left over...acetone works in large quantities.
Tried small amounts of goof off, wd-40, ronsonol lighter fluid, and shooter's choice solvent, they didn't seem to work well but I didn't feel like soaking a rag in any of those either.
09-20-08, 07:29 PM
I wonder if Naval Jelly will cut that stuff off. It eats rust like no tomorrow wonder if it will have any effect?
1971 FJ55 which goes by the name of "Pig Bites"
Gotta love the ones the hurt you right...
09-20-08, 07:35 PM
The Anti-Leafer
Yep, that'll throw glue pieces all over - messy. I used small amounts of heat (mapp gas tank), waving back & forth. It'll scrape off easy after that. Also used some paint remover & let that sit for a little while & wiped off the remaining residue. Your shoulders will get a workout.
09-20-08, 09:58 PM
#10 (permalink)
Ah, I didn't realize that by small amounts of heat you meant mapp gas  . I was using a heat gun.
03-15-09, 08:23 PM
#11 (permalink)
03-21-09, 10:15 PM
#12 (permalink)
i had mine soda blasted.
Clay
75 BDJ55- biopig
