Old 10-01-09, 12:42 PM   #1 (permalink)
fj55-100's Avatar
POTM October - FJ55-100
ok this will be in several parts , most of my cool pics of the build up are locked on birfield.com . but i will try to pull as many off my defunct hard drive as i can when i get off work .
Pigs name is fj55-100 as the merger of the 2 rigs suggests . also by the surname zebra pig (my kids) that eyesore (my boss) and sister wife 2 (now that i live in utah).
Paint color is artic camo put on by Robert that used to work for spector off road ,that i purchased the pig from in a attempt to fit all the camping gear needed for a weeks time in the desert for the family .my fj40 was way 2 small .
concept was formed in 97 looking at the new toyota v8 prototype thinking how cool it would be to ditch the 350 chev and build a waggon using all toyota parts .
build started in 2001 , where i gutted the pig . and inserted a lexus 4.7 v8 engine / transmission transfer case . the computer chosen to drive it was a pcm from a 2002 4x4 tundra to aviod having a key with a chip. the harness was hand built with only the nessary equipment . the trans tunnel was moved up so that there would be nothing that would hang down below the frame rails . all new floor was formed . all mounts custom made by me . with the drive train in place the stock radiator was remounted . rear heater was removed as the hump in the floor was large .
Axels are stock 55 in the front with a 80 series e-locker fit in the housing .aussie inner shaft mates the two.the birfields have changed a few times in the years since ,went from Smurfields . to longfields . to stock .and back to longfields . disc conversion from a mini truck w/vented rotors . the first of only 2 non toyota parts , marlin crawler high steer arms .
rear axel is a non usa full floater with/e-locker .rear disc brakes . . driveshafts were toyota cv shafts that i made and used adapter hubs i machined out of 2"steel . lockers arecontrolled by the factory switch and computer that pulls them in and disconnects them without overrunning the motors .
Steering is fj60 box , controlled by the 2uz pump and linked by 80 series tie rods shortened and rethreaded. stock coulmn has went to a 76 to gain the key in the column .
Suspension is stock springs.Spring over..stock shackles custom track bar .
Fuel is the second part not toyota.a 50 gal tank with a 1/2 " crash skid plate surounding it . Stock 100 series fuel pump was installed in the tank as were several baffels . all were installed in stock location so i could replace the pump through the stock acess hole if needed .
All under side protection was designed as tube so the motor could rid the heat . trans, engine,transfer skid plates all of tube . Side nerf bars are IPOR plates that i welded tube to . rear rocker bars to keep from bashing in the overhang . and seleced bars fitted into the inner panels and doors to keep out rocks .
Interior is a set of Lexus Gx470 seats/w heaters .stock rear for the kids , a SOR healiner kit . all fit over a floor coating of polymer/cermanic that they use on the space shuttle , to keep the catalysts from baking me . the rubber mat was reused for cleanup . a console box to hide the cb . all tie points in the interior welded in to keep junk from flying in a rollover .
Stock Ac from several doner years . fitted to the 4.7 compressor .
functional snorkle . even though it does not rain much in Utah .
Sent the stock alternator out to Premier power welder had it made into the welder generator . used it many time so far for trail welds ,even use it at work .
Added the supercharger later . as i found a used one . one of the best mods . keeps me out of the throttle as much . unless in the sand dunes .
70 series turnsignals . roof rack . powertank . onboard air . more crap stuck into every hole . even cut a 12 x12 hole in the pass floor and made a box in the floor . made ammo boxes fit onto the inner front fenders to store oil,gear lube , and other stuff i did not want leakin inside the cab . all new door seals window seals .rear window seals .quarter glass seals . extra additional door seal on the body side .
I can fill a book with the things i have forgotton . if you have a suggestion for pics . in perticular .
i will try to find them . most of you know my mods better than i do .
All work was done by me , from the welding , to the seat uppolstry , lathe work , mill work , tube bending , .
ALL parts were from a TOYOTA eccept the 2 listed .
Ammendments to follow
Pics to follow
FJ55-100
Evan jenkins
Saint George UTAH
fj55-100 is offline   Reply With Quote
Old 10-01-09, 07:43 PM   #2 (permalink)
fj55-100's Avatar
Pismo dunes
in the sand for the Surf-n-Turf run
Old 10-01-09, 07:45 PM   #3 (permalink)
romegadave's Avatar
Garage
Sound interesting Evan.........looking forward to some pics when you get the chance!!!
EDIT: Hey those pics weren't there a second ago!!!
EDIT II: Color scheme looks appropriate in the desert!!
___________________________
69 Fj55
I been warped by the rain, driven by the snow...
Last edited by romegadave; 10-01-09 at 07:47 PM. Reason: Magical Pig Pics Appeared
romegadave is offline   Reply With Quote
Old 10-01-09, 07:48 PM   #4 (permalink)
fj55-100's Avatar
pics
Ok i have found some pics on the old hard drive . some of moab ,Pismo , some of the mods ,
Old 10-01-09, 07:56 PM   #5 (permalink)
fj55-100's Avatar
pics
Moab in the rocks
Old 10-01-09, 08:02 PM   #6 (permalink)
fj55-100's Avatar
pics
Moab , poison spider mesa
Old 10-01-09, 08:14 PM   #7 (permalink)
fj55-100's Avatar
More pics
Kids , Emily spotting me, Erick sleeping.
8 years of all kinds of wheeling, camping , rock bashing , too many pics of mods that either made the cut , or got left on the shop floor .
As my dailey driver i have about 60k on the motor . the only issue it ever had was last summer it blew out one of the coil packs ,still drove it home !!!!
It is still a work in progress , an outlet for ideas , .I had plans to paint it but after so long now it has been a reflection of who i am , .
Old 10-02-09, 08:44 AM   #8 (permalink)
weeboo's Avatar
Love the family shots that piggie is a beautiful old truck
weeboo is offline   Reply With Quote
Old 10-02-09, 10:12 AM   #9 (permalink)
YotaJosh's Avatar
TLCA# 19299
Cool pig. A 55 or 40 with the 2UZ is a dream project of mine.
What transfer case are you running? Is your rear axle centered?
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
YotaJosh is offline   Reply With Quote
Old 10-02-09, 10:45 AM   #10 (permalink)
fj55-100's Avatar
stock fulltime case , and 70 series not centered rear
Old 10-02-09, 05:14 PM   #11 (permalink)
PabloCruise's Avatar
TLCA# 10713
Does your little guy have enough legroom when the child seat is placed in the rear seat?
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 10-02-09, 06:33 PM   #12 (permalink)
AKcruiserfreak's Avatar
Good lookin rig! Way cool engine conversion as well.
TK
1966 FJ-45lv resto. in progress
1966 FJ-45lv donor
1971 FJ-40 fun truck, resto. in progress
1974 FJ-40 donor
1985 FJ-60 donor
1985 FJ-60 creampuff
1993 FZJ-80 built to haul groceries
AKcruiserfreak is offline   Reply With Quote
Old 10-02-09, 08:15 PM   #13 (permalink)
fj55-100's Avatar
kids have plenty of room . Emily is 10 now . Erick is 5. you have the normal kid kicking of the seat back after 12 + hours driving . but i forgot to put in the build list i put dvd players in the headrests , they are hidden by covers most of the time .
I take the guys from the shop out to lunch all the time , never had a adult complain of no room .
Old 10-03-09, 10:05 PM   #14 (permalink)
Eric Ellis's Avatar
Great stuff. Hope you can get some of the Birfield stuff found.
77fj40
75fj55
JUST FOR THIS POST...YOU CAN JUST NEVER HAVE ENOUGH VISE GRIPS
Eric Ellis is offline   Reply With Quote
Old 10-04-09, 04:47 PM   #15 (permalink)
89GASHOG's Avatar
I think this one takes the prize as the coolest cruiser I've seen yet. Did you do anything to cut down on interior noise levels? Pics of the "cockpit" would be nice.
Bret
Juneau, Ak
1989 FJ62 3FE 125K
1992 Toy short cab 4x4 22RE 177K
89GASHOG is offline   Reply With Quote
Old 10-06-09, 03:46 PM   #16 (permalink)
fj55-100's Avatar
I will put up some inside pics when i get home tonight, interior noise , started with coating all the floor with a ceramic/poly/glass/ paint that they used on the space shuttle to stop the heat . as a by product it killed some of the sound . followed by a welding blanket cut sewed to fit .. under the headliner got 1 inch foam closed cell . for sun controll. double door seals . new felt sealers on all the cracks .
Old 10-06-09, 08:06 PM   #17 (permalink)
fj55-100's Avatar
interior
so far i cant find any of the headliner , but here is some of the seats
Old 11-09-09, 02:53 PM   #18 (permalink)
Evan, awesome build! I've recently aquired two '74 55's.. Both are original, one runs and drives whereas the other has no engine and is slated for a very unique build..
I'm toying around with what to do with the empty 55 I have(no engine).. 4.7 is most definately at the top of my list, and i'd love to come check yours out. I should be down in St George in January or so (I live in SLC).. Let me know if that's cool..
-Jason
SAMI188 is offline   Reply With Quote
Old 11-09-09, 03:48 PM   #19 (permalink)
Goebeler's Avatar
Nice to see some pics of this thing Evan. I love that set up. The Super charger makes all the difference in the world ay! Not to mention simply sounds great.
I wheeled mine a few weeks back and it did real well. Sure wish I was closer to your side of the world so I could wheel the thing like you do yours! Great build!
Goebs
71 fj55 "Megan" 72 fj40, 75 fj40, and woody's new red 76 fj40
Goebeler is offline   Reply With Quote
