Old 09-26-09, 10:53 PM   #1 (permalink)
beauty school dropout?
RockDoc's Avatar
TLCA# 18148
Worth saving the bacon?
Hi all,
Came across this pig in the local classifieds, and being the sucker I am, I'll likely go take a look at it. It's described as a '67 in non-running condition, and is about an hour away from me. I'm certainly not up to speed on the 55s, but the 2F under the hood and shifter on the floor lead me to believe it is a later truck....
Is there anything in these photos that makes you knowledgable souls scream run away? Looks like there is at least a generous skim coating of body filler, the rockers seam to be gone and the rear wheel well has some rust through.... Do these trucks remain pretty solid structurally despite a rough exterior, or do they rot out underneath?
Thanks,
Curtis.
[ ][ ]=TOYOTA=[ ][ ] - 3FE and rust - Wobble Wagon
[ ][ ]=TOYOTA=[ ][ ] - 2FE and no rust, in the works
Edmonton area Cruiser Corner
Peace Canyon Toyota Swamp Donkeys
Today's lesson: You can't teach others, you can only facilitate their learning.
RockDoc is online now   Reply With Quote
Old 09-27-09, 01:18 AM   #2 (permalink)
Lee777's Avatar
Its hard to tell how the body really is until you take a grinder to it. But the front clip has the usual rust along the inner apron but has a pretty good looking front grille. Looks like you have good windshield and cargo glass which is nice. I wonder if the tailgate is working, that "toyota" emblem is always nice. Dash, and guages looks pretty good. It hard to tell how much rust there is until you start taking her apart. Usual spots are the DS, PS body front body mounts. Definitely looks like a parts truck with all that bondo and that its "non running"
I wonder what he drive drain is like. Does it stop? Earlier models had Drum brakes. So be prepared to reman those.
Dual cylender brake cylender with brake booster is nice to have if you want to convert to front disc.
Take a good look under the front floor boards and rear seating area as well as the rear quarters. As well are the body mounts in tact or dissolved? This will give you and Idea of how much fabrication your up against. How are the roof drip channels? is there a lot of roof rust? will it require a new roof, or is it minimal so that it can be patched/repaired?
Good luck, look forward to a build thread!
Lee
'84 BJ 60 ("Dad's Truck") 3" OME, 1" BL, Ubolt Flip
'73 FJ 55 ("Mom's Truck" a pig build in progress)
'76 FJ 55 Parts Truck
'73 FJ 55 Parts Truck
'79 FJ 55 Carcass
Lee777 is offline   Reply With Quote
Old 09-27-09, 04:13 AM   #3 (permalink)
Deathoncall63's Avatar
The classy thing about it has got to be the drapes across the back windows. Quality aftermarket upgrade
Deathoncall63 is offline   Reply With Quote
Old 09-27-09, 09:05 AM   #4 (permalink)
my guess is someone posted as a 67 but should be a 77, as they didn't exist in 67.
how much $$? it does look like more of a parts rig tho.
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 09-27-09, 01:35 PM   #5 (permalink)
RockDoc's Avatar
TLCA# 18148
Lee
Thanks for the tips on where to look
More than I think it would be worth, and I'll bet more than they expect to get. I think the combo of 2F and early tail lights narrows it down to 74-77.... I wonder if they just got the 6 & 7 backwards for a 76.
Thinking more about it last night, I'm starting to think I should forget about it. I'd be looking at it as a future trail truck project and I've already got another 62 in the works to keep me busy. What can be seen of rust damage (rotted out wheel well, missing rockers and wheel arch lips, is that galvanized steel patching up under the filler?) doesn't look encouraging as far as structural integrity. Drivetrain I would be happy to take on, but brake conversion, power steering conversion and a ton of body/structural reworking don't really turn my crank. I'll see if the guy responds to my request for pics, and likely drop it if there isn't anything encouraging.
Old 09-27-09, 08:10 PM   #6 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
It's a 75
Early course hubs, 2f
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Old 09-27-09, 09:04 PM   #7 (permalink)
RockDoc's Avatar
TLCA# 18148
Thanks Marshal.
I'll have to take a peak in the "best 2F" thread and see what that means for piston shape and 3FE head compatibility, as that's where I'd go with it if I got it.
edit domed pistons, no good for a quick and easy 2FE
Old 09-28-09, 12:26 PM   #8 (permalink)
PabloCruise's Avatar
TLCA# 10713
Keep us posted man - that is not too awful bad for a Pig.
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 09-29-09, 07:41 AM   #9 (permalink)
The Anti-Leafer
LC_Hamma's Avatar
TLCA# 3343
At least it's really straight & no major visible rust, but who knows what's hiding in the usual places I'd check the fame & underbody, especially around the low hanging rear sheetmetal & body mounts. You prolly know the rest of the typical problem areas. You don't want to piss him off by low-balling (like $200). See what he's asking for other vehicles you're familiar with so you can get a feel of what could be a *fair offer.
LC_Hamma is offline   Reply With Quote
