07-19-09, 02:58 PM
#31 (permalink)
well -
i picked up a coil, and i have to find the clutch slave rod, i should be able to crank this thing next week.
and maybe by the end of the week have it "oklahoma" road legal.
71 FJ55 - Project
52 Farmal Model 100
The Duty Is Ours, The Results Are God's.
- John Adams
07-21-09, 02:14 PM
#32 (permalink)
check it -
found this on here, huge beautiful schematic
edit: sorry i probably should give credit where credit is due
http://www.globalsoftware-inc.com/co...J55/73JF55.jpg
by coolerman
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-21-09, 08:50 PM
#33 (permalink)
i was digging through parts, and i don't know if this belongs to an old mower, or the pig.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-21-09, 09:41 PM
#34 (permalink)
not an addict
Attachment 341581
looks like old mower
"to learn is to teach someone else"
only four cruisers left
07-22-09, 07:05 AM
#35 (permalink)
thanks it is the only one i could find, i quess i need to get a new one.
i now have a working clutch, working brakes, coil is mounted.
i also need to find the throttle cable, i thought that would be a no brainer, but i have two cables that do nothing, they may be rusted up and one of them is the throttle.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-22-09, 10:24 AM
#36 (permalink)
I would recommend a new throttle cable, SOR.com has them for cheap.
Brett
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." -Thomas Jefferson
07-22-09, 11:41 AM
#37 (permalink)
thanks
and i have what i think is an electric choke? there is a black wire with yellow stripe, looks like the perfect size to bolt to coil with the black/yellow wire there?
any idea?
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-22-09, 11:59 AM
#38 (permalink)
thanks
any idea?
Probably fuel cut-off solenoid.
I don't remember what year your Pig and engine are, but they were manual choke for quite a while...
07-22-09, 01:44 PM
#39 (permalink)
thanks pablo
i have went through the fsm, for chasis and engine and i can not figure out a hand full of items.
first
does the hose that leaves the side of the block by the distributor attach here?
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-22-09, 01:48 PM
#40 (permalink)
also i don't think i have a brake booster check valve.
if i can pick one up where does the other end of that hose go?
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-22-09, 04:08 PM
#41 (permalink)
When it comes to vacuum lines, your best bet is to have a vacuum schematic handy.
I know some years had a decal on the air cleaner. If you do not have this, use the F engine manual or emissions manual.
HTH!
07-22-09, 09:03 PM
#42 (permalink)
that does help
i did not know there was an emissions manual.
Duuhhh. that would explain why i couldn't find it in the engine or chasis fsm.
thanks again i'll check the air breather and hood for a diagram.
wish i could get another weber, i know folks don't like them. but i desmogged my 40 and went from 13 mpg to 18 mpg in a snap.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-22-09, 09:35 PM
#43 (permalink)
not an addict
that does help
there wasn't a whole lot of emissions on the early models, so there may not be a book, but for the mid70s on, there were separate approximately 60 page books for all the emissions crap.
07-23-09, 03:58 PM
#44 (permalink)
so i go buy a solenoid for the pig, this is what i got. i can not find on the schematic where it goes.
and i can't find on the fender well where it goes either?
do we use these kinds of solenoids or is the only one the one on the starter?
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 04:38 PM
#45 (permalink)
arrggg i think i was using the wrong schematic
i think i found the right schematic, but i can not find the BW wire or the W wire labled on the schematic on the pig, i guess i need to grab a circuit tester and start tracing wires.
i think this is the schematic i need, so can i take the two post fender mounted solenoid back?
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 09:56 PM
#46 (permalink)
ok here is the starter
i did have the black white wire to attach
the schematic shows that there should also be a white wire, the only wire that i think could go to the solenoid is red (but it might be an aftermarket patch by the po) i am guessing the white wire should go to the screw in the yellow circle
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 10:00 PM
JackA
This message has been deleted by JackA.
07-23-09, 10:00 PM
#47 (permalink)
and where should this hose go on the other end.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 10:03 PM
#48 (permalink)
That's the PCV hose and goes to the spacer under the carb...........like in your pic above.
07-23-09, 10:07 PM
#49 (permalink)
Originally Posted by JackA
Are you looking for the carb solenoid like mentioned above? Not sure what you are doing with that starter solenoid?
sorry
everything i ever worked on (short list) had a two pole solenoid. i can not find one in the schematic, or anywhere to mount one under the hood.
the barrel of parts that came with this puzzle had the battery cable running straight to the starter.
so i am trying to figure the rest of the puzzle out.
shematic shows one battery cable, one "BW" wire (black with white stripe) and one "W" wire (white)
i think my white wire was replaced with a red wire by the previous owner.
so the main question is, am i on the right track or is there suppose to be a two pole solenoid inserted into the puzzle somewhere?
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 10:10 PM
#50 (permalink)
thanks
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 10:14 PM
#51 (permalink)
so i guess i got the vacuum lines straight now.
the accelerator cable is hooked up and working.
clutch and brakes are working.
good battery, new coil, good points.
if i can get a few wires straightened out i'll be ready to try and crank this thing.
thanks mud
 better go get some gas.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-23-09, 10:19 PM
#52 (permalink)
and i really do appreciate all the help and comments.
i am flying in the dark here, so anything from "you're too stupid to own a cruiser " to " you're the rain man of fj-55" is fine with me.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-24-09, 07:54 AM
#53 (permalink)
There's no remote solenoid on these. The wires go directly to the starter. It's all good..............you'll get it.
07-24-09, 07:36 PM
#54 (permalink)
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-24-09, 07:49 PM
#55 (permalink)
not an addict
07-24-09, 08:02 PM
#56 (permalink)
i am not twelve feet tall, i am sitting on an old kitchen chair.
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-24-09, 08:40 PM
#57 (permalink)
Wondered about that for a moment........thought it was Andre the Giant driving there  Congrats on a running pig!!
___________________________
69 Fj55
I been warped by the rain, driven by the snow...
07-24-09, 08:49 PM
#58 (permalink)
not an addict
i was figuring five gallon bucket. milk crates work good.
07-24-09, 08:53 PM
#59 (permalink)
ha yeah i could have bucket seats...
thanks again for the help lemon. i can not get the lights, horn, signal lights, to work.
that is going to wait till next week.
got to go take a test in the morning in okc and catch some cows for a neighbor when i get home in the afternoon
edit: oh i found my brake booster check valve too
71 FJ55 - Project
52 Farmal Model 100
- John Adams
07-24-09, 10:44 PM
#60 (permalink)
I thought you just messed up  on the metric to SAE conversion  somewhere CONGRATS on gettin it going!
85 Toyota mini truck  for chase/support!
CSC #41
