Go Back   IH8MUD Forums > CruiserRegistry.com > FJ55 Iron Pig Preservation Society
Old 01-06-09, 05:24 PM   #1 (permalink)
ID the problem with these pictures (aka get a rope)
Previous owners
If it is illegal to hunt them down and lynch them, it shouldn't be.
Look at the two pictures below and identify what should get one of the PO beaten to within an inch of their life
I'll give you a hint. It isn't the fact that the 55 has storage boxes in it. It also isn't the missing rubber. Nor is it the hanging headliner.
The cost is gonna be my rear bumper though
-1971 FJ55: 6.0L-NV4500-doubler, SOA, D60s, ARB'd... and cupholders
-1972 extra cab FJ45... 10 year project with a BB cady... DOA 08
-1999 Tacoma for Sale: Sac, CA $7k (clicky link)
Lil'John is offline   Reply With Quote
Old 01-06-09, 05:55 PM   #2 (permalink)
cruiser_guy's Avatar
TLCA# 16387
How about, "The tailgate doesn't close all the way."
You've also got two big holes in the rear pillars that should not be there.
www.wirrell.com
Old 01-06-09, 06:19 PM   #3 (permalink)
Supamod
Gumby's Avatar
TLCA# 5658
two holes in the rear pillar is a hanging offense?
Please don't look at either of my pigs
Cerdito and the nameless 45lv
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
GingerFab Cages and Zilch Bags
Retard Strength
Gumby is offline   Reply With Quote
Old 01-06-09, 06:52 PM   #4 (permalink)
The two VERY large holes(little under 2") are supposed to be there for the smog lines
The two smaller holes are closer to the issue
Tailgate was only partially closed due to handle not working
A good place to look is at the top of the window sill. The issue stands out REALLY well there. But it is a LARGE problem
I didn't know it was a problem just from looking at it until I tried to install some parts
Old 01-06-09, 07:06 PM   #5 (permalink)
later tailgate? It does appear that the tailgate is tweaked? seems to be open more on one side?
the round holes inside the pillar are OEM for smog hose routing on early Fj55's. They take the exact door plug on pre 74 Fj40 doors.
Brett
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." -Thomas Jefferson
cruiserbrett is offline   Reply With Quote
Old 01-06-09, 07:09 PM   #6 (permalink)
Radd Cruisers's Avatar
Maybe the ole 2x4 in one side trick while you push hard on the otherside with the board wedged in the otherside between body and tailgate.
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
Old 01-06-09, 07:14 PM   #7 (permalink)
Tailgate got cocked because I've only got one side latched.
The highly undesired mod would be the one missing metal channel that the upper tailgate rubber holds onto. Basically, right now the upper tailgate rubber only has one metal rib to hold onto instead of two
Don thinks he can fix it but
Still no idea WHY someone would cut that off
Old 01-06-09, 08:14 PM   #8 (permalink)
oh sh$t! Its so uniform I didnt even notice. WTF would someone do that for????????????????/
Brett
Old 01-06-09, 11:24 PM   #9 (permalink)
scouthead's Avatar
Been putting the gate down with the window stuck up? Sure, a whole bunch of cutting and touch up is easier than replacing a little window regulator gear... Easier to load and unoad with that giant pane of glass jutting out too!
I've chosen to ignore the pile of receipts...but I know it's growing...
scouthead is offline   Reply With Quote
Old 01-07-09, 04:14 AM   #10 (permalink)
TLCA# 16387
Not a hanging offense, it just didn't appear to be stock to me.
The missing or cut off sheet metal should be a relatively easy repair, the problem is it will blister the paint if welded.
www.wirrell.com
Old 01-07-09, 07:27 AM   #11 (permalink)
Damn camera takes pictures too good Blame the nut behind the camera for not making it more obvious
Relatively easy is relative
Actually, the solution presented to me by Don is to take some sheetmetal and make some angle iron. Then spot weld similar to factory style. Shouldn't kill the paint too bad Just takes a few hours(aka money)... but that is time that could have been spent on the bumper or cutting the rear rockers
It is frustrating to run into things like this where the PO does something completely unexplainable. It is one thing to fix bad welding or ugly bumpers... quite another to fix something like this that wasn't even needed
Things were just starting to look like they were going to run smoothly and then this happens
Old 01-07-09, 08:57 AM   #12 (permalink)
TLCA# 16387
Exactly what I would do.
www.wirrell.com
Old 01-09-09, 06:43 PM   #13 (permalink)
scouthead's Avatar
I would also weld it, but you could also rivet the new lip on (if the weather strip will alow it) and might be easier to seam seal/ touch up without damaging the existing paint.
Old 01-09-09, 06:46 PM   #14 (permalink)
TLCA# 16387
If he decides against welding then I'd suggest a panel bonding adhesive. Rivets would be a distance last choice in my book.
www.wirrell.com
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
