Old 10-13-09, 10:25 PM   #301 (permalink)
John,
that sucks about the fittings leaking. your description sounds right on. I havent had any leak, other than one that the female part of a line was designed for a male fitting that had a non threaded shank on the end where it would pinch the flare. Turns out when I used a fully threaded nut on the tube,it wouldnt thread in properly and galled up the female part when tightened enough to seat the flare. obviously it didnt fully compress the flare and it leaked.
Brett
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." -Thomas Jefferson
cruiserbrett is offline   Reply With Quote
cruiserbrett
This message has been deleted by cruiserbrett.
Old 10-14-09, 02:47 PM   #302 (permalink)
Great description and hopefully I'll be able to figure out my screwup.
In the attached picture, the fitting on the left is a stock vacuum fitting. As noticed, it isn't threaded fully. I have no idea what the one on the right is but it is fully threaded.
Are brake masters set up for fully threaded tube fitting like the right side?
I haven't had a chance to check all my fittings yet(this weekend maybe) but would I be better off having all my fittings being the non fully threaded version like on the left? Is there any downside to having them all non fully threaded?
Is there any reason why the non fully threaded version wouldn't work in all cases?
-1971 FJ55: 6.0L-NV4500-doubler, SOA, D60s, ARB'd... and cupholders
-1972 extra cab FJ45... 10 year project with a BB cady... DOA 08
-1999 Tacoma for Sale: Sac, CA $6k (clicky link)
Lil'John is offline   Reply With Quote
Old 10-14-09, 02:58 PM   #303 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
I have a decent flare tool if you want to use it. I've never had one leak, so I think it works OK. Let me know if you would like to use it.
Andrew
Old 10-14-09, 03:18 PM   #304 (permalink)
Thanks for the offer Drew.
I've got this bad boy:
- Fun Deals 4 U
Mastercool Universal Hydraulic Flaring Tool
It is the cats meow if I'm using it right My big doubt now is that I may have been using the wrong fittings on my tube
Old 10-14-09, 03:19 PM   #305 (permalink)
TLCA# 11734
- Fun Deals 4 U
Nice! That's the one I wanted and could not justify. Now I know where to borrow one!
Andrew
Old 10-15-09, 12:07 AM   #306 (permalink)
I have been using brakequip bq4511 with good luck lately, and 25' rolls of tube from summit racing.
brakequip tube fittings
I will say that getting the usage of the tool down to a science does take some patience! That and the auto store tubing has a pronounced seam that seemed to either split or cause the flare to be off center. the summit tube is much better!
dont compress the handle more than about what you can do with two fingers when using the 45 cone finishing the flare. I think that thing has enough power to pinch the tube so much that there is not any give in the flare seat area which impedes sealing...
Needless to say, it is SO much better than twisting a damn handle and trying to hold the clamp dealio on a manual flare tool...
Brett
Old 10-15-09, 12:18 AM   #307 (permalink)
Is the tube with the flare without the nut in you picture just some scrap tube? It has a bubble flare, and the tube nuts for bubble flare dont work with inverted flare well at all. a correct inverted flare nut will have a bevel inside the end of the nut, and generally the bubble flare nuts will have a squared off end of the fitting... The bq4511 nuts I mentioned earlier have the bevel.
Brett
Old 10-15-09, 08:25 AM   #308 (permalink)
IH8MUD VOYEUR
hicruise55's Avatar
TLCA# 17618
I just read all 11 pages! Very nice project and work!
On the current brake issue... where is the fluid? If your losing all that fluid- it's going somewhere, at least lead you to a specific connection/union? Just a thought? Aaron
-'76 FJ55-ARB's/4x4labs/Longs/60ps/60axles/36's/SOA/H55/Custom Awesome Driver!
-Matching FJ55 Trailer-ARB RTT/ARB Fridge/Same 36's/ trailer-being setup for long range travel/Basecamp
-'89 FJ62-350/700R4/reversal/33's/18"Mojave's/blacked out
-'69 FJ40-Now on 40's/SOA/60 axles w-ARB's/60ps/ 60 springs/4x4Labs... installed soon
See my Land Cruisers Myspace @ http://www.myspace.com/hicruisefiftyfive
hicruise55 is offline   Reply With Quote
Old 10-15-09, 10:37 AM   #309 (permalink)
Yes, the right hand tube/ flare nut are scrap from a bubble flare Just what I had on hand to show a fully threaded vs partial threaded flare nut
Wish I could claim the very nice work was mine I'll settle for the very functional portion of the work
It is leaking out of multiple connections So I know where it is leaking just not exactly why. It is leaking from at least one of the master cylinder connections and both the proportioning valve connections. I MAY have fixed another three leaks last week
LinkBack to this Thread: http://forum.ih8mud.com/fj55-iron-pig-preservation-society/211723-daily-drive-71-55-build-up.html
Posted By For Type Date
Info.com - where do the roller bearings go in a np203? - www.Info.com This thread Refback 06-18-09 12:57 PM
Untitled document This thread Refback 05-15-08 11:42 AM
