11-01-07, 08:18 AM
THC
November POTM Trollhole's 75
11-01-07, 08:18 AM
THC
For the most part it seemed pretty complete. It was missing a turn signal and a few otheer odds and ends but the important stuff was there. I washed it and started cleaning.
First round of cleaning.
The inside was pretty dusty was missing ther steering colum cover and the front seat was torn.
The door panels looked good and were for the most part free of rust. Which is rare.
Took the rims off and had some new tires put on. White lettering is out. I will fix that when I paint the rims. I went with a size that was as close as I could get to stock which is a 27" tire.
Funky front hubs.
Even got the wife involved in cleaning.
Cleaned for now. As you can see it has some rust but not much for a 55.
These are some of the pics of the crash damage from his drunken run.
I even found a beer can in the back.
These are the after pics after I decided to fix it all myself.
And while cleaning I found this under the seat.
I decided to see if I could save the paint. Which I now know I won't.
More cleaning
Pretty much at this point I decided to start my seach for parts that were missing. Drip rails, mirrors, turn signal, weatherstripping, lights, tools, jack handles. It has taken me a year and a half but I finally have 95% of everything that is needed. I've even bought a PTO that I'm going to install.
11-01-07, 08:19 AM
THC
I had no intention of getting it running until I had some other things done but a friend came by and said lets see if it starts. I had my doubts since it had been sitting for 20 years. New battery, cleaned the points and bypassed the gas tank that was shot. It fired right up. In facted everything worked. Blinkers, wipers, lights, gauges, everything. Just amazed me and him. The it started to overheat and we shut it down. But it ran.
So here is a list of what I have done to it to date.
Rebuilt carb
replaced vaccum hoses
new battery
new coil and points
new plugs and plug wires
new oil pan gasket
Tcase had a hole in it and was trashed so I found a 75 t-case rebuilt it and put it back in
Complete new brakes all around, from the master cylinder to the brake cylinders. Only thing original is the hard lines.
New clutch master and slave
new waterpump and thermostat
Radiator was boiled
new coolant hoses
new fuel pump
new dash cover
found a stock radio and installed
Like new front fenders
Found a few sets of drip rails
good front and rear bumpers
New Turn signals
new brake lights
New weatherstripping all around
Painted the front clip
New mirrors
New emblems
Sourced the factory A/C
Sourced a PTO
For the most part everything mechanical is done. Except to rebuild the smog pump and installe the PTO and A/C.
I'm now down to body work which has taken a lot longer than I thought. But I'm still working. The pig section is good inspiration to get me going and if that doesn't work I just go sit in the pig for a little bit. That usually fixes it.
As it sits.
11-01-07, 10:52 AM
The Anti-Leafer
Good story & teriffic job on the bodywork. I like the part about "I just go sit in the  & that usually does it". I have an old project BMW in the driveway & when the  is done, that's next. I go sit in it just to smell the old metal & that does it for me too  I guess the gas tank worked out allright for you w/o too much trouble - heard you had to have somethin welded on it (?) Lemme know if you need any odds or ends - I have some rear sheetmetal pieces that need to get gone soon. Keep up the FABulous work
11-01-07, 11:06 AM
THC
Do you have the rear corners?
Gas tank turned out great. Thank you. I ended up not having to weld a fuel return on it. I just put a T fitting on the filler vent tube. Works great. Crazy thing is I bought another tank from someone else at the same time. It just needs to be cleaned and would be good to go. So if anyone out there needs one let me know.
11-01-07, 11:14 AM
The Anti-Leafer
Sure, but both are cut off right in the middle of the reflectors, you can prolly see a pic or 2 on my build page somewhere. I have some other stuff you can have - misc underbody pieces if you want. I can give them to Heather, then you can pick 'em up from her. Lemme know if you need anything else......
11-01-07, 12:01 PM
THC
Sounds good I'll tell Heather to check with you next time she sees you. Or I might just drive down there and have a visit with ya.
11-01-07, 01:26 PM
ya the part about just sitting in it sure rang true for me. that act alone has saved my pig from the selling block a couple times. Sinnin grinnin when driving it, throwing those gears........ you bet, sure wish I knew where that feeing came from.
11-01-07, 02:31 PM
Roger that Marshall and Chuck...piggy delivery service present and accounted for!
Marshall, the 55 is looking amazing. I am so envious that you can do all that work yourself. I need to get up there for some lessons from the master!
11-02-07, 12:38 PM
#10 (permalink)
Currently Cruiser-less...
Location: Honolulu, HI (Soon to be San Diego via VA and RI)
You and me both!!!
Very cool story!!
PRESENT:
'01 Saab 9-5 SE Wagon 102k mi. (wife)
'93 Volvo 940 312k mi. (my DD)
still looking for another Cruiser...
PAST:
'72
'00 LX-UZJ100
'86 FJ60
11-02-07, 09:37 PM
#11 (permalink)
Thanks for sharing Marshall. That piggy looks great, and happy too. Have you been able to drive it yet?
11-03-07, 07:40 AM
#12 (permalink)
THC
Just around the block and to the gas station.
11-03-07, 10:28 AM
#13 (permalink)
I bet you were grinning from ear to ear! I wake up every morning and stare at my pig sitting in the driveway, for just a minute, but it makes my entire day (and then driving it to work, is also pretty cool).
11-05-07, 09:22 PM
#14 (permalink)
Great work and thanks for sharing
Harry
78 FJ55 - "Arnold"
78 FJ55 - "Chester White"
89 FJ62 - "Ming"
07 UZJ100 - "Koto"
TLCA #13476
11-14-07, 10:26 AM
#15 (permalink)
hey marshall, did you chrome or pewter the grill and light eyes? i was thinking about doing this myself with original pewter paint, but i am also wanting to find some places that coudl do the silver and black backing behind TOYOTA. let me know! thanks man
'87 freeborn red fj60 cruiser "Julie"
'73 FJ55 (soon to be original colors again) "Raleigh"
11-14-07, 10:27 AM
#16 (permalink)
it looks awesome by the way!
11-14-07, 12:44 PM
#17 (permalink)
THC
I just went to the Autozone and bought a couple cans of what I think is pewter spray paint. I will look tonight.
Sanded it down, Primed it. Painted it Pewter. Then Masked off the Toyota area and the letters and painted it Gloss black. Hind sight I should had done a semi gloss. But if will eventually fade. Looks good though.
I used the blue 3m tape and a sharp exact-o knife.
11-14-07, 06:11 PM
#18 (permalink)
The only thing I ever found under my back seat was dead mice.
Good lookin pig! I wish I could have hung on to my stocker. Kind of cool having one that's not lifted/chopped/cut/re-motored/un-pigged.
Painting the grill was one of the last things I did to my '76... should have been one of the first things.
It's amazing how much different a pig looks when it's got a clean nose.
I've chosen to ignore the pile of receipts...but I know it's growing...
11-20-07, 08:02 AM
#19 (permalink)
Pig Sittin'
Hell, I thought I was the only one to go sit in their PIG from time to time (usually with a couple of beers).Making mental notes of what needs to be done and trying to foresee the future of the thing on the road. It really keeps the fire going. This really is a sickness...and there aint no drug for it. I'm just happy to know I have company. Good job Troll on the progress you have made. I hope to see it in person one day, maybe in Tellico. Thanks for sharing your knowledge and parts findings, it really helps us "PIG SITTERS" keep the dream alive.....  Now what's the scoop on the weather stripping?
Political correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end!
11-21-07, 06:01 AM
#20 (permalink)
THC
Thanks Jeff. Well I have been a little slack on weatherstripping. I know we can find a better solution just need to find it.
I've got way to many projects going on and having the flue and then walking pnemonia has not helped it much. I have never been sick like this. I've been sick for a month now. But feeling better every day. I will work on getting some things out to vendors this weekend.
I have also been talking to my wife about going into the parts reproduction business. She gave me the go ahead. Though it won't be a full time job yet. I could see it being that. SO watch out I may have a red star soon.
