LinkBack (7) Thread Tools Display Modes
Old 08-31-07, 09:54 PM   7 links from elsewhere to this Post. Click to view. #1 (permalink)
cruiser_guy's Avatar
TLCA# 16387
September POTM - Cruiser Guy, Guatemala
This FJ55 started out as a father/daughter project. My daughter wanted a 4WD and didn’t have much cash to get one. We found a note on one of the ‘Cruiser boards about a ’76 FJ55 that was suitable for restoration, free to the first one to pick it up. My daughter borrowed our ’84 BJ60, a tow bar and invited a friend who was to a mechanic apprentice and a friend to help keep everyone awake on the drive from Vancouver, B.C. to Minot, ND.
Three days later she was back and the FJ55 was waiting at the border for clearance. After waiting for the requisite 3 business days we were able to go and pick up the truck. We no doubt gave the U.S. Customs a laugh when they came to inspect the truck to ensure it was not stolen. When the customs officer came out and saw the truck she was questioning our sanity for even wanting to export it. The next laugh came from the Canadian side when they wondered why anyone wanted to import a rusty truck. After paying a few dollars in duties (the truck was assessed at $200) we headed home to look over the truck.
It didn’t take long to come to the conclusion that anyone who is not a ‘Cruiser head would not place any more value than $200 on the truck and for some that was a generous amount! The truck had rust holes in the floorboards that you could fall through, there was not much, if any rockers left, the transfer case was in bad shape and the “rebuilt” engine leaked everywhere when we tried to fill it with water to try running it. About the only thing not rusty on this truck was the roof and chassis!
At this point I had severe doubts about this rig being good for anything other than parts.
www.wirrell.com
cruiser_guy is online now   Reply With Quote
Old 08-31-07, 09:58 PM   #2 (permalink)
TLCA# 16387
Fortunately at about this time we found another “free” ’74 FJ55. This time it was a body carcass only that was in Los Angeles. After speaking with the folks that had it and determining that most of the rust was in the roof we rented a flat deck and headed south with the ’82 BJ60. We were able to cross back into Canada without the obligatory 3 business day wait since we only brought in “parts”. The carcass had no frame and thus was considered parts.
Now we had the main ingredients to construct an FJ55 with a possibility of success. We began stripping the ’76 of any and all parts necessary to “create” the new truck with. The body was unbolted from the frame and raised high enough so that the chassis could be removed.
The ’74 was scrubbed and cleaned underneath and any rust was removed by cutting out the affected metal and welding in new. The chassis was also cleaned and then both chassis and the underside of the ’74 body were painted with two coats of POR15 to help make the resulting truck a little less rust prone.
www.wirrell.com
Old 08-31-07, 10:07 PM   #3 (permalink)
TLCA# 16387
Since I had a 3B which was in need of a rebuild, we decided to part out the existing 2F which was not operational anyways, rebuild the 3B with a turbo and use that. The 3B was completely stripped down and all bearings, pistons and sleeves replaced as well as checking clearances for everything, essentially a new engine. I was fortunate to find an AXT header with a Volvo Garrett turbo to use as well. An H42 tranny housing with bosses for the belly cross member, ala B/FJ60 was found as well as a “B” series input shaft and the guts of the existing H42 was swapped to the new housing along with the “B” series input shaft. I did not want to use the cross member that mounts to the rear of the transfer case, it just doesn’t look very secure to me and it relies on bolts in the aluminum transfer case as well. A new transfer case needed to be found as well and an older 3 speed transfer case from a ’71 FJ40 was used for the lower low range. We did not go with the split case due to cost as well as the need to either swap the rear axle (to gain an e-brake) or add an e-brake to the split case, adding even more costs.
While the engine rebuild was underway we also worked at removing the rest of the rust on the body. The ’74 body had significant rust along the perimeter of the roof and since the roof on the ’76 was good it was decided to swap the roofs. This was done by drilling out the factory spot welds on both roofs and keeping the windshield frame and “B” pillars of the ’76 and the “C” and “D” pillars of the ’74. The replacement roof was welded on with cinch straps holding the roof securely in position for the best possible welded joint. Since we had the rusty roof we removed the supports from the rusty roof and added those as additional supports to the new roof. All rust perforation in the doors and tailgate were removed and new metal welded in. All welds we done with a continuous series of short welds until the entire seam was welded. Doing it this way avoids warping the panels. The welding beads were ground down and bondo was used to fair in the patches.
www.wirrell.com
Old 08-31-07, 10:10 PM   #4 (permalink)
TLCA# 16387
At this time the entire truck was sprayed with high build primer to cover any scratches or blemishes. This was followed by single stage paint in the factory white/green color scheme that the ’76 came with from the factory. Paint was matched based on the color code on the firewall VIN tag. The grille, headlight doors and other parts that were pewter from the factory were also painted in the factory pewter color.
Once all the paint was done the engine and body hardware was installed. Wiring was also done at this time and is an amalgamation of the wiring from an ’81 BJ60 and the ’76 FJ55. Anything in the FJ55 harness relating to the 2F engine was stripped out and anything in the BJ60 harness relating to the truck was stripped out and the two merged to one. This enabled us to retain the low oil pressure shutoff found on the BJ60 as well as EDIC motor operation. A momentary push button switch is incorporated for glow plug operation. Amazingly, the only error in wiring was a short in the glow plug warming circuit!
A pyrometer is drilled and tapped into the exhaust manifold to give and exhaust temperature as near as possible to the pistons. This avoids guessing whether the pistons are getting too hot or not. A boost gauge is tapped into the turbo crossover pipe. Both gauges are mounted below the dash in a two gauge pod.
www.wirrell.com
Old 08-31-07, 10:13 PM   #5 (permalink)
TLCA# 16387
This is basically how the truck looked when my daughter had it. However she now wanted something "faster" so the FJ55 no longer fit her "image".
www.wirrell.com
Old 09-01-07, 07:07 AM   #6 (permalink)
TLCA# 16387
As we work in Guatemala and with my wife working out in the "boonies" we decided to take the piggy down south, WAY down south!! Here's some piggy shots as we're heading south through the states on the way to Phoenix and the lift install.
You can see that we were in the snow on our departure, we had great weather along the California coast and then ran into a sand storm crossing over from California to Arizona.
www.wirrell.com
Old 09-01-07, 07:28 AM   #7 (permalink)
TLCA# 16387
In Arizona we traded help and garage space to do the lift with the piggy springs, a much sought after item in the FJ40 circles! I'm sure not many folks lift their truck half way through a trip!
www.wirrell.com
Old 09-01-07, 07:32 AM   #8 (permalink)
TLCA# 16387
More lift pictures. There springs were the 2 1/2" lift springs from Spector along with greaseable pins and oversize shackles and poly bushings. During the install I messed up on the shim install for the castor correction and the truck was wandering all through Mexico.
www.wirrell.com
Old 09-01-07, 07:45 AM   #9 (permalink)
TLCA# 16387
Here we are heading through Mexico with the new lift and the backwards castor shims.
The last picture is crossing over into Guatemala. Quite a journey for a 30 year old vehicle from winter in Canada to the jungles of Central America.
www.wirrell.com
Old 09-01-07, 08:15 AM   #10 (permalink)
RIDDLER's Avatar
brave
Charles- that is one nice FJ55. I cannot believe how brave you guys are for driving that far in a Piggy. I wouldn't do that drive in our 80 series let alone a Pig.
Nice build that is a keeper.
1997 Toyota land Cruiser FJZ80 40th Anniversary
1975 Mercedes Unimog 416 Troopy
1967 Toyota Landcruiser FJ45 LPB
RIDDLER is offline   Reply With Quote
Old 09-01-07, 11:08 AM   #11 (permalink)
TLCA# 16387
The weatherstripping for the windshield and lower tailgate has been replaced with parts available from www.slocruisers.com, the cargo area windows and tailgate glass weatherstripping have been replaced with parts available from PV Cruisers. We are still using the old rear door quarter window weatherstripping and hopefully those will be available soon (there are rumors of someone making them up in time for the fall).
www.wirrell.com
Old 09-01-07, 11:13 AM   #12 (permalink)
TLCA# 16387
Here's a shot of the completed engine bay. As you can see the 3B is turbo-charged! I used a BJ60 air cleaner housing and directed the intake as near the front as possible for the coolest air possible. There is a Racor water separator off to one side as well to ensure clean water free diesel. You can just see the A/C lines on the bottom left. I hope to have that hooked up in the next little while.
I had two batteries in it for the cold Canadian winters but right now we are running on just one battery (the cheap batteries in my BJ60 quit, that's why!).
Here's a poser shot before we put the 33" Mud-Terrains on it.
www.wirrell.com
Old 09-01-07, 11:30 AM   #13 (permalink)
TLCA# 16387
After the deafening drive from Canada to Guatemala we installed the Damplifier sound deadening product from www.secondskin.com
In addition to the Damplifier layer which was installed directly on the beadlined floor and as high up the fire wall as I could reach and over the wheel wells too, we also replaced the original rubber mat and put in a carpet kit from Spector. It has made a significant difference to the in-truck sound level to the point where one can hold a conversation without having to talk over the engine and road noise. The noise level is now comparable to the BJ60, not a Cadillac but not too bad either.
www.wirrell.com
Old 09-01-07, 11:38 AM   #14 (permalink)
TLCA# 16387
Here's some shots of the lower tailgate to body weatherstrip installation. The top edge of the tailgate is held in with small plastic clips while the sides are simply glued down with automotive weatherstrip adhesive (contact cement). The last shot shows the Damplifier underneath the Spector carpet set.
Do any piggy owners know of a source for the weatherstrip that seals the lower edge of the tailgate? I know I can simply use closed cell foam but the real piece would be nice.
www.wirrell.com
Old 09-01-07, 11:50 AM   #15 (permalink)
TLCA# 16387
Here's a poser shot of the piggy as it stands now on 33x9.5x15 BFG Mud-Terrains. We got these tires to help ensure that the truck stays on the road here during rainy season when my wife heads out to the medical clinic in the villages. Some of the roads can get pretty slick with mud.
The truck is much taller now with the lift and the 33" tires.
The next mod is installing the PTO and winch head. I need a few FJ55 specific parts though to complete that install. Here is a picture of the front bearing of the PTO driveline. I need the plate that bolts to the frame to carry this bearing as well as the yoke that goes between this and the winch head itself. I also require the shims to mount the winch head to the frame (they fit between the rear angle support and the sloping frame rails). I'll need other PTO parts for the install on the FJ45LV when I get to that point in a year or two so if you have miscelleaneous PTO parts send me a PM!
www.wirrell.com
Old 09-01-07, 02:13 PM   #16 (permalink)
Currently Cruiser-less...
ChuckB's Avatar
Location: Honolulu, HI (Soon to be San Diego via VA and RI)
TLCA# member
cruiser_guy,
That is simply awesome!! Nice work!
I think you have inspired me to hold out for a 3B and a turbo.
PRESENT:
'01 Saab 9-5 SE Wagon 102k mi. (wife)
'93 Volvo 940 312k mi. (my DD)
still looking for another Cruiser...
PAST:
'72
'00 LX-UZJ100
'86 FJ60
ChuckB is offline   Reply With Quote
Old 09-01-07, 02:39 PM   #17 (permalink)
North Florida Cruiserhead
mel lowe's Avatar
TLCA# 19409
Oink!
Whoa!!
Oink Oink!
82 Fj60 - 2F, 37"s, Toybox, Daily Driver, 62 Frame, Lights, Grill and Roof
http://nfcruiserheads.org/forum
mel lowe is offline   Reply With Quote
Old 09-01-07, 04:18 PM   #18 (permalink)
PabloCruise's Avatar
TLCA# 10713
Beautiful!!!
It is nice to see folks honoring the Pig heritage vs. junking them...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 09-01-07, 05:14 PM   #19 (permalink)
Charles.......awesome!
Lou
n2666s is offline   Reply With Quote
Old 09-01-07, 05:25 PM   #20 (permalink)
usmcruiser's Avatar
TLCA# 15913
That's a fantastic pig!!!
It's a shame you daughter desired something "faster". If you are looking to adopt a son I am available.
Nick
'78 FJ40 (scattered all over garage)
'76 FJ55
"If you can read this thank a teacher.
If you can read it in English thank a U.S. Marine."
usmcruiser is offline   Reply With Quote
Old 09-01-07, 06:04 PM   #21 (permalink)
Lucy_FJ55's Avatar
TLCA# 10314
Wow! I have been waiting to see this POTM for awhile. I remember seeing you post this on Pirate (I think...) years ago and had wanted to see/read about the process again. I am stoked to see you are using it daily also. Great build, thanks for sharing. OINK! ONIK!
1970 FJ55 Lucy-Trail Pig
http://forum.ih8mud.com/fj55-iron-pi...ml#post3162540
1977 FJ55 Lily-Princess Pig
http://forum.ih8mud.com/fj55-iron-pi...e-old-pig.html
Lucy_FJ55 is offline   Reply With Quote
Old 09-01-07, 06:09 PM   #22 (permalink)
TLCA# 16387
That was OK with me. She'll pay for it with speeding tickets! She already started after only two months! Lack of speeding tickets is a fringe benefit of driving a Land Cruiser!
I don't need more sons, I've got two teenagers still at home and I can hardly keep them fed!
www.wirrell.com
Old 09-01-07, 06:09 PM   #23 (permalink)
IH8MUD Cruiser
oldfj40's Avatar
TLCA# 17100
I've seen this Pig up close and personal and these pics do not do it justice.Charles-and family-did an excellent job in restoring this rig!Putting in the diesel was a definite upgrade too in my opinion.
The upgrades you did on your trip south look great Charles.That's a nice looking lift on a 55.
Steve
Lots of cruisers in the yard.
It's better to be over the hill than to be buried under it.
oldfj40 is offline   Reply With Quote
Old 09-01-07, 11:01 PM   #24 (permalink)
GreasedPiggy's Avatar
I love this!!! Built really nice and used in places a LandCruiser should
Very inspiring work. I am putting a turbo diesel together for my pig.
How is the diesel quality as you make your way down the continent?
icongratulations!
1975 FJ 55, Cummins 4BT, 4L80E, NP208, SOA, 14 bolt rear, Dana 60 front, ARB Lockers, Scout II PS, Discs, Cross-over, TSL Q78-16
1995 T-100, 4" susp lift, 33 Goodyear MT/R, bought it new, my DD
1961 ford Falcon, 5.0L EFI, T-5, 9-inch
GreasedPiggy is offline   Reply With Quote
Old 09-02-07, 06:42 AM   #25 (permalink)
TLCA# 16387
Diesel is fine as you make your way south. It's even fairly priced down here (we're gouged in Canada and the USA when diesel is equal or more than regular) being a consistent 75% or so of the price of regular gas!
www.wirrell.com
Old 09-02-07, 06:43 PM   #26 (permalink)
RHINO's Avatar
brilliant !!!! not only a super clean build but driven! wow, nice nice nice.
Clay
75 BDJ55- biopig
Old 09-02-07, 09:29 PM   #27 (permalink)
Big Boyz Motor Toyz
Farr off road's Avatar
TLCA# 3130
Great Job! Love everything you've done to the oinker!!! But I don't see any PTO winch.
Farr off road is offline   Reply With Quote
Old 09-02-07, 10:47 PM   #28 (permalink)
TLCA# 16387
Stay tuned!! I hope to get the winch head mounted this month but I'm still looking for a few FJ55 specific PTO parts to complete this. If you know of a source for the front driveshaft bearing mount (I have the bearing section just on the plate that it mounts to) and the flange that takes the shear pin I'd be grateful.
Without all the parts it's not a high priority.
www.wirrell.com
Old 09-03-07, 03:49 PM   #29 (permalink)
Big Boyz Motor Toyz
TLCA# 3130
I understand....if I here of any parts I will let you know.
Old 09-03-07, 11:11 PM   #30 (permalink)
Charles
When you mentioned this Pig, my mind had pictures of what it would look like. However, now that I have, kinda, seen it for myself, I am truly amazed.
This is the pig I will model my future pig after. Now all I need to do is buy one...
Great job. Beautiful Pig!
1994 fzj80
1970 fj40
www.bellaadventures.net
Robb
blupaddler is online now   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/fj55-iron-pig-preservation-society/174972-september-potm-cruiser-guy-guatemala.html
Posted By For Type Date
1978 FJ55 with a 3B diesel.... - Pirate4x4.Com Bulletin Board This thread Refback 08-28-09 09:11 PM
Sound Deadening Options? - Page 5 - Expedition Portal Forum This thread Refback 04-21-09 10:19 PM
Your Free Find of the Day..... - Expedition Portal Forum This thread Refback 04-20-09 09:10 PM
Sound Deadening Options? - Page 5 - Expedition Portal Forum This thread Refback 02-23-09 10:41 AM
september cruiser | VIRGILIO Ricerca | Web This thread Refback 11-28-08 02:24 PM
Fj55 - Pirate4x4.Com Bulletin Board This thread Refback 11-11-08 04:50 PM
Sound Deadening Options? - Page 5 - Expedition Portal Forums This thread Refback 12-16-07 08:21 PM
