Old 08-06-09, 08:19 PM   #31 (permalink)
sturobertson40's Avatar
Tear down to body off
Ok. Gonna keep the tear down short b/c we've all seen plenty of pigs in pieces...just the way it goes. These pics were taken the night I pulled the body off the frame. Had everything loose, invited my buds over for a BBQ and con'd them into it. No pics of us in motion b/c it took all 7 of us.
Stu Robertson
1972 FJ55
Charleston, SC
sturobertson40 is offline   Reply With Quote
Old 08-06-09, 08:24 PM   #32 (permalink)
Body OFF
THE BODY'S OFF! Built some saw horses and set it right on them.
Frame and drivetrain were in good shape. But boy were they dirty. Spent an hour pushing water around. Helped a little bit.
This was all Summer '08. Wait until you see the powder-coated frame!
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 08:26 PM   #33 (permalink)
More Water Pushing!
More Pressure Washing!
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 08:30 PM   #34 (permalink)
Down to the Frame
Ok. Here are some great shots of the frame. Before and After Powdercoat. Amazing what that guy did for $400. Looks like I bought a brand new frame of the shelf.
He blasted it, cut off my bumpers, ground down some ugly factory welds, corrected a small bend, and powdercoated for that price. I think it was the best deal I've gotten on this thing so far.
Take a look:
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 08:32 PM   #35 (permalink)
More Frame
Couple more....
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 08:33 PM   #36 (permalink)
Ok gotta resize some more pics. Hang on....
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 09:18 PM   #37 (permalink)
On again / Off Again
More pics of the chassis before I took out the motor and broke it down to the frame. Just found these....
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 09:19 PM   #38 (permalink)
More....
More pics.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 09:23 PM   #39 (permalink)
Cleaning the engine
Degreased, sprayed off, degreased, scrubbed, sprayed...you get the picture. This was the second cleaning. Mostly just so I could put it in the garage without feeling too bad.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 09:28 PM   #40 (permalink)
Dirty Axle
It's amazing how bad road grime makes stuff look. This axle was hideous. Spent several hours with cleaners, wire wheels, and sandpaper and it started to look pretty good.
Didn't take a lot of pics in the process of this unfortunately. I think I was alone and too dirty to snap the camera.
Cleaned out both axles and primed and painted w/ rattle can Rust-O-Leum. Figured I'd go low dollar on these since they're just going to get dirty and nicked again.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 09:40 PM   #41 (permalink)
Mechanicals
I did get the whole rear end resealed and aligned. Took it apart to see how it worked and ended up taking the whole thing in pieces to a machine shop. Awesome! At least he fixed it right. The front didn't look too bad so I just cleaned up and went with it.
You'll see that I am doing the minimum on the mechanicals for now. Lots of cleaning, painting, and resealing things. Everything ran great when I took it apart so I didn't want to tear the whole engine down.
This build is about the body...which you will soon see. I am going to keep the truck forever so the engine swap will come someday. But the body could not wait.
The mechanicals will be clean, refirb'd, within spec, but stock.
Engine was resealed. New clutch. POR'd the block. New accessories (water pump, alternator, starter, etc.).
Painted springs and went back with the extended shackles/shocks that I put on in early 2008. Pretty good ride.
Had to paint the fan that awesome stock orange.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 09:51 PM   #42 (permalink)
Pics for that.
Oops...forgot pics.
Must also mention brakes.
Did a lot of research on this one. I finally concluded that the only way I would go discs is if I could go Landcruiser OEM. A pig just isn't meant to run w/ El Dorado calipers. I love Toyotas not Chevys. Spector has a "kit" of course but it costs an arm, leg, and a thigh by the time you get everything you need for front discs.
I just decided, it's a play car; I didn't ever mind the drums before; and new drums are going to be twenty times nicer than the rusted, rotting, mud-caked old ones.
I think the brakes were the first call I had to make on stock vs. upgrade. The more I went along, the more I continued to revert back to other stock items too. The finished product is not a show car, but it is very close to the way it drove off the Toyota line (save for the lift and tires).
Just thought I would note. And I'll continue to throw in interesting pics of earlier stages and specific parts as I go. The computer has stuff stored all over the place. Hard to find it all.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 10:12 PM   #43 (permalink)
1973Guppie's Avatar
looks great! keeps the pics coming!
NEED A CRUISER MECHANIC?:http://forum.ih8mud.com/ca-san-diego...rlsbad-ca.html
Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies
1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA
1970 FJ55 - Restoration project, 1996 FZJ80 - DD
FJ55 Restoration Thread: http://forum.ih8mud.com/fj55-iron-pig-preservation-society/102079-guppies-fj55-build-thread.html
FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40
1973Guppie is offline   Reply With Quote
Old 08-06-09, 10:16 PM   #44 (permalink)
Thanks Guppie! Did a lot of drooling on your build pages before I ever turned the first wrench. Finally got motivated and lost interest in web surfing. Now that I'm close to done, I feel like this is a piece of history that has to be shared. Love thePigs!
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-06-09, 10:35 PM   #45 (permalink)
flaa1a's Avatar
Dude that is so what i want to do. My two kids and lack of space is going to keep me from it though. Oh yeah....and lack of knowledge! Hats off Broseph!
FLA A1A
Aug 72 FJ 55- Land Shark
09 Tacoma Offroad TURD
flaa1a is offline   Reply With Quote
Old 08-07-09, 11:49 AM   #46 (permalink)
PabloCruise's Avatar
TLCA# 10713
Originally Posted by sturobertson40 View Post
Oops...forgot pics.
I forget what year your Pig is - do you have Toyota discs on the front at least?
That is easy and does not cost a thigh...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 08-07-09, 01:15 PM   #47 (permalink)
No went back to drums for now. I think SOR wanted like 800 bucks for the conversion parts, plus the knuckle rebuild pieces. And I messed up the rear end's rebuild so I didn't have the confidence to take apart the front. I think eventually I will buy a refirb'ed complete front axle assembly from cruiserparts.net.
Like I said for a project this size, I had to make some choices and keep moving. Went with drums. Just a fun car ya know.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:18 PM   #48 (permalink)
Ok, Back in Action
Well somehow I screwed up my jump drive on Friday so I could resize pics on the PC. Weird how it's easier on my cheapy Costco PC then the high dollar Mac. Went to WalMart, now back in action.
Not sure which pics I'm going post first. So I'll post then comment.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:23 PM   #49 (permalink)
Body on it's way to the shop
Hard to believe...but I got this body on the trailer almost 100% by myself with moving dollies and a hi-lift jack. Probably dangerous in hindsight.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:29 PM   #50 (permalink)
Rainy Day
It was a rainy day when I took the rolling chassis to the shop. My lovely wife operated the winch controls...awesome!
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:31 PM   #51 (permalink)
More...
More....
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:34 PM   #52 (permalink)
To the shop!
Got to love when you're wife takes pictures of the cruiser as it's driving away! I didn't have to ask her to snap these!
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:53 PM   #53 (permalink)
THE BODY
I knew this would be the interesting part of the thread, that's why I glossed over the rest so far.
The Pig's body was in pretty decent shape...for a pig.
Rear quarters were gone, along with the rear body mounts. Passenger front floor pan was eaten up down to the mount and into the front pillar.
But here's the cool part: The rockers were intact, totally solid, on the outside. So we just had to replace the inner skin and some of the mounts, which also gave us an excuse to wipe out the inside of the outer rockers of any rust.
I'll show a before and after of sandblasting.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 07:55 PM   #54 (permalink)
More Before Sandblasting
More Before Sandblasting:
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 08:03 PM   #55 (permalink)
Sandblasted
The next few were AFTER the sandblasting.
Let me note here that the roughness that you see on the otherwise clean metal is left over factory undercoating. We only blasted clean the areas that were in advanced stages of cancer. The areas that were solid got a good once over to clean them and break off any obvious rust.
I know, I know...you're supposed to blast down to bare metal or better yet, acid dip the whole thing! But since I live in the real world and pay for this stuff, I had to make some compromises. I decided to get the rotten metal out and take my chances with the rest. The shop still had about 250 HOURS in this thing by the time I took it home.
Anyway, take a look.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 08:08 PM   #56 (permalink)
More After Blasting
More After Blasting
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 08:14 PM   #57 (permalink)
Etching Primer
After blasting, the whole body got a coat of OSPHOS rust inhibitor. Then he want to etching primer.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 08:16 PM   #58 (permalink)
More....
More shots of the etch primer.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 08:20 PM   #59 (permalink)
Front Clip
The front clip was especially rusty. Started to look pretty good after the treatment and some paint.
Stu Robertson
1972 FJ55
Charleston, SC
Old 08-09-09, 08:24 PM   #60 (permalink)
Doors
Doors and tailgate were just about rust free...amazing that their lips were all intact. I forgot to get shots before he started the body work on them.
Stu Robertson
1972 FJ55
Charleston, SC
