Go Back   IH8MUD.com > CruiserRegistry.com > FJ45 Owners Club
Old 06-03-08, 03:16 PM   #31 (permalink)
ColoCruiserJeff's Avatar
TLCA# Don't have one yet :)
You mean we have to wait till Weds to see the pics??????? That's just not good enough!
"Soon Ralph, Soon!"
MY TOYS:
72' FJ40, Sold on eBay,guy never heard of an FJ40! :(
81' FJ40, went the way of the destructor! (parted out)
66' FJ45LV, currently being fixed back up!
02' Tacoma Double Cab, TRD SuperCharged- My Daily Driver
99' Acura TL - Wife's
My Fix-up Thread:
http://forum.ih8mud.com/fj45-owners-club/113621-here-goes-66-lv-restore-thread.html
ColoCruiserJeff is offline   Reply With Quote
Old 06-03-08, 05:19 PM   #32 (permalink)
I took a little time of this last weekend for a ride. 480 miles on a dirt bike is a little much. Fun though. Pic is from the Hope BC landslide.
dr_claw is offline   Reply With Quote
Old 06-03-08, 05:25 PM   #33 (permalink)
I wanted to keep a little of the original style of the rear tub body mounts. I came up with this to replace the rusted crap. The last pic is it just sitting on the tub. More pics of the finished product welded on tomorrow. I am very happy with how it turned out.
Old 07-28-08, 07:27 PM   #34 (permalink)
I have not touched this thing since the end of the school year. I have got back at it and I am hoping that the cab will look like a cab by the end of the week.
Here are the new rockers I bought from real steel off ebay. I am happy with how fast they were shipped and the quality.
The ONLY reason that I bought these new instead of fixing/making my own is for the proper alignment of the rear cab section to the fire wall.
Old 07-28-08, 07:29 PM   #35 (permalink)
here are the old inners I will try to reuse.
Old 07-28-08, 07:32 PM   #36 (permalink)
Because I am running a tig'd alu. fuel tank under the bed, I blanked out the sender, but kept the factory shape. I was just going to smooth out all, but I wanted to keep it sort of stock.....
I also want a sub under the factory bench
Old 07-28-08, 07:35 PM   #37 (permalink)
I am using a different firewall, witht the original floor. I used the tunnel to mock up where everything should line up. Looks like it worked!
I am going to start welding tomorrow. Enought grinding and cutting for today.
Old 08-06-08, 11:17 AM   #38 (permalink)
I have got a lot done in the last week or so.
I needed a very important measurement because I built the rear of the cab w/o the step down. I figured it out with some help from mud, and this is what happened.....
http://forum.ih8mud.com/fj45-owners-...asurement.html
Old 08-06-08, 11:18 AM   #39 (permalink)
mockup etc pics
Old 08-06-08, 11:19 AM   #40 (permalink)
side view...
Old 08-06-08, 11:24 AM   #41 (permalink)
here is the rocker all finished! I used a flap disk to smooth it out. A small skim coat of bondo is all that will be needed to cover up the seam.
Old 08-06-08, 11:29 AM   #42 (permalink)
on her back, sides all welded up.
Old 08-06-08, 11:38 AM   #43 (permalink)
Ok, here is a body work lesson that I learned from a local guy named Ron Morris.
My dad is into vintage cars and hotrods so I picked up some skills from him and his club.
Anyway, I watched Ron turn a 1940 four door ford into a tudor by splicing the frame and roof section of the two cars.
Step one....
Cut out some cardboard stencils. ( I didn't take a pic of that )
Step 2
Cut out the sheetmetal the same shape as the cardboard. I am using 16 gauge HR.
Step 3
Tack the piece into the hole in two or three places. I realize that I am out by about 3/8" to 1/2" the whole way around.
Old 08-06-08, 11:41 AM   #44 (permalink)
Step 4:
Spray paint the rear of the panel with white or bright spray paint. Only on the seams
Old 08-06-08, 11:46 AM   #45 (permalink)
Step 5
Remove the panel and cut the remainder with a zip disk.
Step 6
tack back in
Step 7
Continue all other panels until all are done!
Old 08-06-08, 11:49 AM   #46 (permalink)
all tacked in!
Old 08-06-08, 11:52 AM   #47 (permalink)
Last pic for now,
I am using these neat sheet metal body clamps. Basically just a 1x1" piece of square tubing with a pin and a threaded rod. They worked well.
Old 08-06-08, 12:04 PM   #48 (permalink)
k,almost last pic. I just saw that buck used the same style clamps on his 45.
Old 08-11-08, 12:08 AM   #49 (permalink)
crawlin cruiser's Avatar
lookin good dude, word of advise, attach the doors and hard top so you are 100% sure things will close and line up when its all welded up
Dan
87HJ61
83BJ60
75FJ40
74FJ40x2
73FJ55
slowly buying every landcruiser in Kamloops
crawlin cruiser is offline   Reply With Quote
Old 08-18-08, 01:10 PM   #50 (permalink)
Dan you need to change your sig.
I have done a lot over the last while. Welding is all done on the tub.
Here is the plate that i fixed the rocker rear corner with. A little filler will be needed.
Old 08-18-08, 01:13 PM   #51 (permalink)
here are some more pics of stuff i have fixed, filled. There will be a deck in the glove box, maybe the amp in there too. The new plate on the dash will be for the sirius radio.
The spot beside the gauge cluster will now be for a autometer 3 5/8" tach.
Old 08-18-08, 01:23 PM   #52 (permalink)
something is missing
Old 08-18-08, 01:37 PM   #53 (permalink)
The inner rockers were half salvaged from the old tub. I just used the top inch or so.
I am not super concerned how the inner panels look because they will be under 3/16" of bedliner, sound deading material, and a factory floor mat. I wire wheeled the seams so slag and crap isn't going to screw anything up.
I am going to paint the floor, behind the dash ect with POR 15 before I get the bedliner sprayed.
Old 08-26-08, 11:33 PM   #54 (permalink)
The body work on the cab is almost done. I am starting to work on a trailer because I have no way to move this to the paint booth
Old 08-28-08, 09:56 PM   #55 (permalink)
Rhinoliner's Avatar
TLCA# 16914
So, I'm guessing you're a non-smoker.....haha
I couldn't tell how you ended up doing the holes in the short vertical panel behind the seats. I only saw where you marked out where they would be. What did you end up doing there?
Keep the pics coming.
Rhinoliner is offline   Reply With Quote
Old 08-29-08, 10:25 PM   #56 (permalink)
The Anti-Leafer
LC_Hamma's Avatar
TLCA# 3343
Superb job so far! I like the fact you're bringin a *questionable tub, in that shape, back to life. Good patience & quality skillz. Looks like you've done this before. You using .25 wire & some type of heat absorption mat'l. to keep it from warping?
LC_Hamma is offline   Reply With Quote
Old 09-23-08, 05:21 PM   #57 (permalink)
sounds like drive train work will start in about a week !
Old 09-24-08, 12:48 PM   #58 (permalink)
In the garage
John Smith's Avatar
TLCA# 9074
dr_claw, Sorry to hijack your excellent thread but I could not help noticing the supplied air respirator. What brand / model and are you happy with it? Great build!
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 09-24-08, 10:42 PM   #59 (permalink)
Thanks for the positive comments,
The respirator is made by North products and the air inlet tube is by the same company. I am still very happy with it.
http://www.uvex.us/products/products...=36rescription
safety glasses are made by Uvex. I am also very happy with them and I strongly recomend anyone with glasses to get a pair. Clip in inserts and removable lenses are great for welding and grinding!
Old 12-30-08, 07:39 PM   #60 (permalink)
UPDATE!
The body work on the tub and cab parts has been done for about 2 months now. I have been stalling to the "christmas break" to paint the tub.
My work is shut down for 2 weeks. With no one in the shop, and the dust level down. It has a paint booth but is only like 8' x 8'.
The plan is to paint the body at work in the shop, then take it back home to finish all interior stuff on saw horses.
I can paint the top, doors, and small body stuff in the booth whenever, but the tub has to be done, NOW!
Pics shortly.
