Go Back   IH8MUD.com > CruiserRegistry.com > FJ25 Owners Group
Old 11-06-09, 04:00 PM   #811 (permalink)
a.greenspan's Avatar
Originally Posted by My wife said no FJ! View Post
Well...at least you know you have time to do the jack
In early days of automobile history ( before 1920) cars were painted by brush (for example the legendary Ford T )
Think Destin have enough time to paint his jack in this technique
Cheers
Peter
BJ43/1980 Softop ~ FJ45 LPB/1973.... old school
~ endangered species ~
~ res tantum valet quantum vendi potest ~
http://www.federalreserve.gov/
a.greenspan is offline   Reply With Quote
Old 11-06-09, 04:06 PM   #812 (permalink)
vroo000Ooommm
destin's Avatar
Cheers
Peter
hehehe
indeed!
Cool photo btw!
64FST FJ40
destin is offline   Reply With Quote
Old 11-06-09, 05:50 PM   #813 (permalink)
450,000+ mile club
TLCA# 2231
thats me in the blue suit BTW .....peter's hacking in my computer again
hijack over
JohnnyC is offline   Reply With Quote
Old 11-06-09, 06:19 PM   #814 (permalink)
Bill McC's Avatar
Originally Posted by Corrugated Toy View Post
Tailgate wiring 1963: wire comes up and into tub behind the jamb area of the drivers side rear door. Then it takes a bend in the open around the door frame where a steel clip holds the wire to the door. From there it goes to the center of the door and through the door to the lamp. If you would like a picture I would be pleased to furnish it.
Mine is the same as Bill described.
Apologies for a dirty rig.[/QUOTE]
Yep, mine is just like that except the wire clips on mine are attached by a screw.
Bill McC is offline   Reply With Quote
Old 11-07-09, 07:07 PM   #815 (permalink)
vroo000Ooommm
destin's Avatar
Stripped the front bits apart with the intention of looking at the timing gears...
but i could not figure out how to get the lower pully off...
No nuts that i could see...
( yeah the shop is a mess i know )
So how do i get this off?
I just need to buy gasket and new timing gear yeah?
Where is a reliable place to get these?
Thanks guys
64FST FJ40
Old 11-07-09, 11:10 PM   #816 (permalink)
vroo000Ooommm
destin's Avatar
hmmm was the generator on these 40's green like the starter?
May as well do it if it was
Let me know guys!
64FST FJ40
Old 11-08-09, 10:43 AM   #817 (permalink)
That 25 Guy.
Cruiser_Nerd's Avatar
TLCA# 12092
You can and should get the gears from Toyota. Get both, gasket and seal should be available too. The seal will crumble when you take it out. Numbers should be in the part # thread. You need a puller to get the pully off, there should be two tapped holes in the face of the pulley that you'll thread into. My cheapo harbor freight one actually came with the correct bolts. The pulley "Presses" on with a BFH when you reassemble. Generator was the same color as the starter.
Jim
FJ25.com
"The FJ25 is almost humorous in its simplicity, but therein lies its beauty." Nina Padgett - Autoweek
Cruiser_Nerd is offline   Reply With Quote
Old 11-08-09, 10:52 AM   #818 (permalink)
vroo000Ooommm
destin's Avatar
Nice!
Thanks man
BFH haha nice
( gets hammer ready )
Thanks again man, many thanks.
64FST FJ40
Old 11-08-09, 11:00 AM   #819 (permalink)
vroo000Ooommm
destin's Avatar
so I think these are all the bits i need aside from the pully "puller"
Timing Cover Gasket 11328-61010
Timing Cover Seal 90311-45069 034-29A Beck-Arnley 052-2144
Crank Timing Gear 13521-60010
Camshaft Gear 13523-60030 (Steel replacement for fiber gear)
Anything else?
Want to have all the parts and do it in one swoop!
64FST FJ40
Old 11-08-09, 07:30 PM   #820 (permalink)
vroo000Ooommm
destin's Avatar
ok pulled the generator and cleaned it up, preped and put 2 coats of hunter green on it, looks great.
Will install it tomorrow after it sets up completely
Waiting on pulling the pully and timing gears until i make my order and recieve parts.
Just so i am clear.
When i pull the pully and remove the timing cover...
Do i just pull the cam and timing gears, and replace them with steel ones and put the new gasket and timing cover back on?
Or do i need to remove the timing plate as well, and put the rear timing gasket on, timing plate, cam and timing gears, timing cover gasket, then install timing cover and hammer on the pully?
Also, does that pully just stay on by hammering it back on? no clip? lock washer?
Thanks guys, some crappy flash photos:
64FST FJ40
Old 11-08-09, 07:46 PM   #821 (permalink)
dkroth's Avatar
Destin, what are your plans for that *nasty* thermostat housing?
Your build is looking great...
dkroth is offline   Reply With Quote
Old 11-08-09, 07:51 PM   #822 (permalink)
vroo000Ooommm
destin's Avatar
Thanks man
What about the thermostat housing?
hehe, you mean am i gonna clean it up?
I just received the new radiator hoses and heater hoses
64FST FJ40
Old 11-08-09, 08:12 PM   #823 (permalink)
dkroth's Avatar
Yes. Not being critical. But everything else looks new!
I had to clean mine up (82 BJ42) earlier this year. I used JB Weld to fill some of the corrosion dimples. Worked great!
Old 11-08-09, 08:15 PM   #824 (permalink)
vroo000Ooommm
destin's Avatar
Sweet thanks man!
Yeah it is pretty corroded hehe, but i think it will clean up ok
Alot of little things to do while i wait on the body stuff hehe :/
The more i stare at it the more things i notice i need to do
If you guys see anything wonkey chime in
64FST FJ40
Old 11-08-09, 08:49 PM   #825 (permalink)
wesintl's Avatar
TLCA# 4180
that and it's not original
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 11-08-09, 08:53 PM   #826 (permalink)
vroo000Ooommm
destin's Avatar
What is not original?
What is it supposed to look like?
64FST FJ40
Old 11-08-09, 10:26 PM   #827 (permalink)
vroo000Ooommm
destin's Avatar
hmmm...
which is correct?
( found this in the 25 section thread )
64FST FJ40
Old 11-08-09, 10:30 PM   #828 (permalink)
vroo000Ooommm
destin's Avatar
or this?
64FST FJ40
Old 11-08-09, 10:48 PM   #829 (permalink)
vroo000Ooommm
destin's Avatar
looks like Dobster's is the same way.
One of you cats gonna hook me up with a spare thermostat housing ?
64FST FJ40
Old 11-09-09, 01:49 AM   #830 (permalink)
fwed's Avatar
Hi Destin I don't like butting in but the timing gears are not just going to fall off. The best way is to remove cam and press off. Otherwise on the fibre one you may have to drill or cut the hub off cam, then drill and tap cam to put it back on. Do not lever too much on gear to pull it off or you will break cam retaining plate. I hope I have not scared you too much,don't forget to time the gears, so have fun. Cheers Fred.
fwed is offline   Reply With Quote
Old 11-09-09, 10:36 AM   #831 (permalink)
vroo000Ooommm
destin's Avatar
Hehe thanks for the warning man.
Drilling and cutting them off sounds a bit of putting to be honest...
Maybe this is a bit out of my reach :(
64FST FJ40
Old 11-09-09, 01:01 PM   #832 (permalink)
vroo000Ooommm
destin's Avatar
generator painted
64FST FJ40
Old 11-09-09, 02:30 PM   #833 (permalink)
IH8MUD Wannabe
Dobster's Avatar
Wow..... My truck has been referenced in Destin's build thread. I'm gunna tell all my friends.
FJ25 1960 Tray
FJ40 1965 Soft Top
"Space - the final frontier" or .... the bain of every car collector.
Dobster is offline   Reply With Quote
Old 11-09-09, 02:37 PM   #834 (permalink)
vroo000Ooommm
destin's Avatar
haha
64FST FJ40
Old 11-09-09, 03:28 PM   #835 (permalink)
Bill McC's Avatar
Destin,
What are those angle iron chunks on the front center of the frame for?
Old 11-09-09, 04:22 PM   #836 (permalink)
vroo000Ooommm
destin's Avatar
Originally Posted by Bill McC View Post
Destin,
For the winch
64FST FJ40
Old 11-09-09, 05:58 PM   #837 (permalink)
450,000+ mile club
TLCA# 2231
every time you put another part on all i can say is....ooooooo ahhhhhhh
hows the gear going?
Old 11-09-09, 06:10 PM   #838 (permalink)
dkroth's Avatar
The green really sets it off. Very nice.
Destin, any chance you can clean the lens on your camera? Many of your recent photos are coming through a little soft. I think your lens is smudged.
Don't forget about the wrenches on the right front frame rail!
Old 11-09-09, 06:13 PM   #839 (permalink)
vroo000Ooommm
destin's Avatar
Thanks man
the timing gear?
Fwed was saying something about drilling and cutting to get the gears free, so I am kinda questioning wether or not it is within my grasps
At the very least i will pull the main pully off and look to see what the gears look like.
Still need to get Shane's 411 on the jack painting, where are ya man?
64FST FJ40
Old 11-09-09, 06:17 PM   #840 (permalink)
vroo000Ooommm
destin's Avatar
Thanks man
I will clean the lens, probably has a mix of salt/sand and dog from the last trip to the beach
i need to be more careful with my tools though hehe, just noticed that when you mentioned it Fortunately it is a smooth ride from in and outta the shop bay
Looked on SOR for the proper thermostat housing, nada to be found :(
Taking the fan, pully, and some other bits to the powder coater soon
Cleaned up some electrical stuff today a bit too, will post more photos once i get this project for work deployed.
64FST FJ40
