FJ Cruiser The newest model GSJ15 Toyota FJ Cruiser -- FJCruiserForum.com
Closed Thread
Old 06-21-06, 05:13 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
tlcwagons.org
FirstToy's Avatar
FJ Cruiser name history
For the FAQ- Info on the history of names and codes, member's name in bold and their post following
If anyone has info on the GSJ15 designation, PM me. Thanks!
1GR-FE is the code for
1 = First Generation of the block (2003)
GR = This is the engine family or GR-series aka Gas Research
F = Economy narrow-angle DOHC
E = Electronic Fuel injection
Toyota GR engine - Wikipedia, the free encyclopedia
cruiserdrew
B = in line 4 cylinder diesel
F = in line 6 cylinder gasoline
H = in line 6 cylinder diesel
U = v-8 gasoline
J = assembled by Araco(Arakawa)
Z = 4 valves per cylinder
Thus, FZJ80 is an 80 series Land Cruiser with an inline 6 gasoline motor with 4 valves per cylinder.
beowulf
I believe the FE designation is only on the newer engines to denote they are Fuel Injected.
F
2F
3FE
1FZ-FE
-B-
Darwood & Beowulf
Originally Posted by Darwood
I think just the E designation stands for fuel injection as in the 22R-E. The F I think is for overhead cam or something like that. This was all discussed in 80's tech before.
You are correct. The E designates fuel injection. The F is the "head design" according to this source.
The next digit (the first after the dash) designates the head design. "G" is the DOHC performance head, generally with a more aggressive valve angle for higher rpm/more power. "F" is the low-end torque and fuel-efficient DOHC head, with less aggressive valve angles. If there is neither an “F” or “G” in that digit, then the engine is a SOHC model (probably chain-driven). Toyota did make a few OHV engines, but they are much older and by now quite rare.
-B-
Rzeppa
In ancient Land Cruiser history, the very first prototype was the AK10, produced in January of 1951. It used a B type 3386cc 6 cylinder gasoline engine which was installed on the SB type 1-ton truck chassis. Toyota called its prototype the Toyota Jeep, and by combining a B-type engine with a Jeep model it was known as the BJ. Large scale production of the Toyota Jeep did not begin until August of 1953.
In June of 1954, responding to claims of trademark violations by the Willy's Corporation, Toyota renamed it the Land Cruiser.
The FJ25 made it's debut in August of 1955. Technically, this would be the first Land Cruiser with the "FJ" designation, and there were a number of differences in this model from the BJ.
The first B type 3.0 liter 4 cylinder diesel was introduced in 1974 in the BJ40. Interestingly, the H type 6 cylinder 3576cc diesel was introduced in 1967, apparently installed in a 40 series.
The above information is from "The Land Cruiser - Special Issue of the 50th Anniversary", published by 4x4Magazine Co., LTD of Tokyo in 2001. This book was available through SOR, but is now out of print. Their description is item number 403-100.
It's a fantastic book, loaded with history, trivia, specs, stories by some of the original designers in their own words, lots of great drawings and photos. It covers practically every model from the AK10 through the 100 series, including models I had never heard of before, such as the FJ35 wagon.
Happy cruisin'!
TEPUI
And in this tech sheet by www.cruiserheads.org too
http://www.cruiserheads.org/series/codigo/codigo.htm
(article written in Spanish, but easy to understand, since it is mainly composed of codes)
Here's a great example description. (translated below)
Translation:
Familia de motores= Engine Family
Codigo Nase= Base Code
Volante del lado izquierdo= left hand drive
Distancia ente ejes corta=short wheelbase
Techo Duro=Hard Top
Manual de 5 velocidades= 5 speed manual
Equipamiento LX=LX trim
Configuración Regional Europea=European Regioanl Configuration
History of the Land Cruiser Family Tree
Toyota Land Cruiser History
The 120 (Prado) is the 90 series replacement (70series--->90--->120)
while the LC's follow this line (50series-->60--->80--->100)
The FJC is based on the 120 platform They share common parts from the LC Prado & 4Runner.
70 series
The first requirement for the new series was that the new Land Cruiser should not sacrifice any of its toughness, so a strong ladder frame was outfitted with rigid leaf springs. The body plates were thickened by 1mm for added strength. While leaving something of the image of the 40-series, such as externally added fenders, it was also given modern features such as curved glass.\
However, the 1st generation Prado had inherited too strong a workhorse image and did not attract the interest Toyota had hoped.
With a full model change in May of 1996, the Prado embarked on a new and independent path. This 2nd generation design was aimed at creating a car that retained its 4WD character while looking at home on city streets. It reflected Mr. Yoshii's experience while doing development work on another Toyota vehicle, the Carib. Then a Land Cruiser was used as a support car during snow testing. The heavy Land Cruiser often got stuck, while the Carib was "light enough to run circles around it," as Mr. Yohii puts it. Although he had no idea that one day he would be put in cha rge of Land Cruiser development, that experience helped him create the lighter, more car-like characteristics that made the 70-series such a success.
90 series
In May of 1996, the 70-series underwent a makeover and emerged as the 90-series Prado, an independent series. The design was heavy-duty, like the 70-series Prado, but with a smaller engine and light classification
Aiming for supremacy in all classes, Toyota developed the 90-series Prado as its final weapon against its main competitor, the Mitsubishi Pajero.
120 series
Toyota's new Land Cruiser is aimed at the core of the Sports Utility Vehicle (SUV) market and replaces the current Land Cruiser 90 in Toyota’s comprehensive SUV range. Like all previous Land Cruiser models, the new Toyota Land Cruiser offers full off-road capability - but, in response to the growing leisure market, the latest model adds superb on-road driving pleasure with new standards of premium car quality and comfort.
120 series tree
2003- Land Cruiser Prado 5 door & 3 door introduced in Europe. This model offered w/ several engine options including the 4.0L V6 (all new design)
2003- 4Runner & GX470 introduced in America. Using the same frame, suspension & tech; the 4R is offered w/ the 4.0L V6 & 4.7L iForce V8 (V8 came w/ new 5spd fuzzy logic transmission)
-------GX470 uses much of the LC Prado body except different fascia, tailgate and trim. Interior is upgraded quite a bit over the Prado and exclusively uses the 4.7L V8.
-------Both the Prado and GX have air rear suspension instead of coils. This was an option on the 4Runner.
------ Tacoma uses a similar front suspension, same 4.0L engine. Basically from the A-pillar forward, it is nearly identical to the 4Runner/FJC/Prado mechanically. Rear uses leaf springs and frame is not fully boxed.
------ FJC is a modified Prado/4Runner frame (shorter wheelbase, but not as short as the 3 dr Prado). Identical suspension to the 4Runner. Auto Trans, front diff (8") and rear coil susp the same as the V8 4Runner. Same 4.0L V6 as the Prado/Tacoma/4Runner.
----- All models are a creative mix of the 120 platform parts bin. Take a bit from the Prado, take a bit from the 4Runner, etc.
----- The body of the FJ Cruiser is all-new and based on the showcar that debuted to overwhelming popularity, thus the decision to bring it into production.
----- The production FJ C is the first Toyota to actually say 'TOYOTA' on the front grille since 1994 (?) Even the concept car had the Toyota "sombrero" oval logo. I believe in more an effort to tie in w/ the original FJ40.
I love cachapas!
my wip
I drink your milkshake!
FirstToy is offline
Closed Thread
LinkBack to this Thread: http://forum.ih8mud.com/fj-cruiser/98390-fj-cruiser-name-history.html
Posted By For Type Date
pradopoint.com - Toyota Prado 4x4 Landcruiser Forum • View topic - Food ideas for GTG This thread Refback 07-05-09 04:33 AM
Land Cruiser initials key - Toyota 120 Platforms Forum This thread Refback 02-05-09 12:13 PM
