Go Back   IH8MUD™ Forums > Toyota Tech Forums > FJ Cruiser
Old 06-06-06, 01:35 PM   #1
you can use reg. octane w/ the 1GR-FE, no problem.
Is this true? Would Toyota support a warranty if you did this? Why does Toyota recommend Premium Gas if this is the case? Is anyone else running regular? I am so confused now.
C5Drvr is offline   Reply With Quote
Old 06-06-06, 02:05 PM   #2
nickw's Avatar
I know Land Rovers do this too.
Roverheads have discussed it.
How it works in a Land Rover is:
The engine is high compression, so it requires a high octane fuel to run correctly. If someone does run a low octane fuel the engine's knock sensor detects it and retards the engine appropriately to stock the any possible knocking/pinging. The computer corrects for this well before we as humans could notice. So to us it appears to run well with no noticeable difference other then a slight loss of power (which we might not notice).
So the question then arose, would running regular not cause damage? And if does not cause damage (which most believe it doesn't), is it cheaper to do so?
What they found was, the engine consumed more fuel to run in the slightly retarded state required to properly burn regular fuel. They found they got better millage (and better savings) and power (noticed when under load) to run premium.
Not sure if this carries over to Toyota, but I think it would.
Hope this helps,
Nick
1988 BJ74 / Lots of goodies - Sold
1990 HDJ81 / Fully outfitted loaded beautiful truck - Rolled
1985 BJ60 / Beautiful Stock truck - Stolen
nickw is offline   Reply With Quote
Old 06-06-06, 02:13 PM   #3
bulldog-yota's Avatar
Same engine as on the V6 Tacoma and 4R. Both states regular with premium recommended. So far most have said they see no difference in economy or performance with regular on the V6. No problems either.
03 Pavement Princess
05 Mall Queen
06 Toaster
bulldog-yota is offline   Reply With Quote
Old 06-06-06, 03:27 PM   #4
tlcwagons.org
FirstToy's Avatar
You should use premium if it starts to ping- like high altitudes, towing, etc
the engine has ping sensors so you will not hurt the engine w/ low grade petrol.
I ran over 3 years on the 1GR-FE. 90% of the time on regular octane. I used premium occaisionally (crappy gas stations, was at costco, etc)
High alt, city gridlock, high heat, etc. never any problems or noticed any real difference between premium & regular.
also,my understanding is that regular gas has more "power" per gallon than premium. Premium has more octane which takes more energy to combust, thus it won't pre-detonate. (non-scientific description here, some fuel expert can clarify this)
TLCA#14645
BRC#41798
I love cachapas!
my wip
I drink your milkshake!
Old 06-06-06, 04:50 PM   #5
The only difference I have ever noticed is miles per tank and it was about 40 50 miles different
PASON21 is offline   Reply With Quote
Old 06-09-06, 11:20 AM   #6
RokCrawlinToy's Avatar
TLCA# 14120
The performance ratings are also based off of using premium gas. I know that there have been times when the West Coast Trail Team have only had access to 85 octane in our travels and have had no problems using that grade.
Toyota Trail Teams
L.A. County TrailCrew T.L.C.A website SoCal
4WheelDriveToyotaOwnersMagazine
Northridge Toyota Parts
92 Extracab SASd Flatbed 218:1-PreTaco on 42s
2007 Tundra Supercharged CrewMax 4x4
2008 Tundra CrewMax 4x4
2007 FJ
2008 TT FJ
2008 S/C Tacoma 4x4
RokCrawlinToy is offline   Reply With Quote
Old 06-09-06, 12:14 PM   #7
I actually get better gas milage on plus gas. There are a couple of threads on http://www.fjcruiserforums.com/ that are having the same results.
I am a new member to match my new 2007 Toyota FJ Cruiser MT6 VooDoo Blue (FE, CQ, GY, RB, UR, CF, C7, V5)
Please be gentle on us newbies, we don't always know better
terahex is offline   Reply With Quote
Old 06-14-06, 08:19 PM   #8
Shaken - not stirred
Blues Dawg's Avatar
TLCA# 16271
my experience has been as noted above that with the computer controlled ignition the biggist difference - except maybe under a heavy load and/or altitude - is in gas mileage. Cost wise it ran about the same as a result. Hope it can run on lower octane, otherwise I'll have to carry octane boost to mexico...
Yellow FJ Cruiser - a work in progress -
Copper State Cruisers #68
IBL8 & Procrastin8
Blues Dawg is offline   Reply With Quote
Old 06-19-06, 11:04 PM   #9
Commando's Avatar
i found premo for about 3.05 over here (other places were charging 2.99 for regular) so i figured, "Eh why not". 93 octane. i felt like the engine ran much more smoothly.
Commando is offline   Reply With Quote
Secured Loans | Mortgage Calculator | Car Finance | Loans | Advertising
