LinkBack (10) | Thread Tools | Display Modes |
kill the alarms?
Any way to kill the seatbelt and door open alarms? I don't wear the seat belt on the trails around my house and sometimes I like to leave the doors open to listen to music.
__________________ 66FJ45, The Newt 76 fj40 two Aussies, Orion, SOA, shackel reversal, one set Hyper Flex, 35" Boggers, Metaltech, DUI, Webber and some new seats. 78 JF40 all original 07 FJC with mods |
I tried this "simple" trick and it worked...
Courtesy of RoverGGM (in the FJ Cruiser Forum):
Seat belt chime 1. Turn the ignition switch on (without starting car) 2. Press the ODO/TRIP switch until the odometer displays "ODO" 3. Turn the ignition switch off 4. Turn the ignition switch on 5. Press ODO/TRIP switch immediately (within 6 seconds after turning the power switch ON) and hold it down for 10 seconds or more. 6. Continue holding the ODO/TRIP switch and fasten the front passenger's seat belt. 7. Check that the odometer displays either "b-on" or "b-off" (it will be "b-on") 8. Press the ODO/TRIP button to change the display to "b-off". 9. Turn the ignition switch off. 10. Turn the ignition switch on while depressing the brake pedal. 11. Check that no buzzer sounds when setting on the front passenger seat. |
We had a guy that didn't wear his seatbelt on trails near his house, he got ejected when he got too close to the edge of a drop off, when his 4wd rolled, his head was crushed between the vehicle body and a large rock. He is dead.
But hey, I know what you mean about listening to music with doors open while parked. Not familiar with the FJC but if it's like other vehicles, I think you could wire in a manual switch in line or in place of the door switch, to connect/disconnect the circuit, thereby fooling the vehicle into thinking the door is closed. __________________ Ben Silva IH8MUD Site Supporter since July 2004 1996 Lexus LX 450, 130k, locked, Cooper STT 285s, OME 850/863, CDL/Pin 7, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter 1998 Lexus LX 470, 139k Sold 1993 FZJ80 198k miles Sold |
#4 | |
__________________ All things being equal, fat people use more soap. |
Does this keep the dome light from turning on when you open the door?
#6 | |
__________________ '80 FJ40, '84 Hilux 4WD, '07 FJC KE5VTE "You may find me one day dead in a ditch somewhere. But by God, you'll find me in a pile of brass." - Tpr. M. Padgett |
It actually tells you how to do it in your manual. You have to hold the odo button down for about 10 seconds after you turn the key on. It does work, you just have to follow all instructions exactly. As for the door open beeper...I hate those along with the key in the ign. beeper. I usally pull the wires out as soon as I get a diffrent car, but this one is a little diffrent. I just put a clamp on the button on the door.
__________________ 07 FJ Cruiser 3" OME lift, 37" BFG Krawlers, E-Locker, Free A-Trac. Allpro winch bumper, sliders, and CB Bandi mount. 89 4Runner 38.5" Swampers, SAS, Injected 5L V-8. SOON TO HAVE DANA 60/14 BOLT WITH 42" IROKS.
1911, you wrote "Tried this many times, meticulously following the instructions and even a few variations but no joy - nothing I can do will change the odo display to show anything but "ODO" or trip A or trip." I don't think the hole is closed, because the instructions are in your owners manual. It's been a while but as I remember, I wasn't having any luck trying this on mine until I tried it while sitting in the seat. It's possible that you're doing the same thing. Just follow the manual exactly and it should work (if you're sitting in the seat while doing it.
FJ Tribe of the Carolinas proud member of the FJ Nation |
#9 | |
#10 | |
#11 |
For the door, I took out the Driver's side button (its on the inside of the suicide door), disconnected, then carefully pulled apart the switch assembly so I could get to the metal mounting plate. I then used some mastic paper to insulate the button from the bracket - put it all back together and re-installed. Then the old "back it out 1/2 turn" trick worked just fine after tightening it back on in place. I didn't want to lose the electrical inside the door in case I needed it back on someday.
__________________ Go4aRyd - '07 FJ Cruiser, Voodoo Blue, AT, TRD wheels, BFG A/T KO. white bezel, Demello sliders, Gobi Stealth |
#12 | |
#13 |
I did this. Got the "b-off" and both door and seat belt alarms still sound. Where is the audio comming from? Can we just disconnect it?
TIA __________________ Stock 71/FJ40 FJC |
#14 |
The 11 step proceedure is only for the second and third alarms. The initial alarm is not affected.
#15 |
thanks!!! my wife nagging me is enough of an alarm.
#16 |
I just may add if you happen to stumble upon this and you don't own an FJC it works on all toyota vehicles, recently new I guess as it's the same steps I used on my 'rolla XRS
__________________ 07 FJC 33" STTs, OME lift |
#17 |
Can anyone tell me how to modify the remote keyless entry to one click does it all?
#18 |
Last I heard you have to take it to the dealer. Posed to be pretty simple.
__________________ Stock 71/FJ40 FJC Last edited by steven4mc; 04-22-08 at 01:36 PM. |
#19 |
[quote=firetruck41;1174323]We had a guy that didn't wear his seatbelt on trails near his house, he got ejected when he got too close to the edge of a drop off, when his 4wd rolled, his head was crushed between the vehicle body and a large rock. He is dead.
On the road and on trails that pose a threat for possible roll (or really any risk), I couldn't agree more with intent of the statement above. Seatbelts are there for a reason, USE THEM. On another note, when you are driving flat offroad, say on a hunting lease, and keeping speeds down.....getting in an out often depending on what you want to shoot, what fence you want to fix and so on...This is the coolest fix I have seen yet. That alarm was enough to give you a headache. The directions work perfect. Thanks for the post. Haven't had a passenger in the car since I just turned the alarm off. Does this overrule the passager alarm as well? __________________ 2007 Black FJ. Donahoe Racing coilover suspension lift, TRD CAI, Mangaflow Catback, ARB Bull Bumper, ARB ROOF RACK, ARB MOUNTS AND ROOF TENT, WARN winch, ARB sliders, American Eagle Wheels and Goodyear MT/R's 305/70/17's |
#20 |
Also never really thought of the door alarm. With the windows down, back up to the campsite....the stock FJammer is plenty loud enough for me. Try that instead of jamming a stick in your door!
#21 |
In my taco, I just turn the ignition to the "on" position and the dinging stops after 5 dings. I'm pretty sure this is the same for the FJ.
Company Reports | Personal Loans | Secured Loans | Credit Cards | Computer Support |
