That's "Greyt" "Andy"
Toyota Front Skidplate
Just curious, what is the point of Toyota's accessory front skid plate? Does this imply that the skidplate already there is inadequate, or is it because the aluminum plate "looks good"? Does the front end take more abuse? Thanks.
I wonder that same thing. I also wonder how thick it is. There other skid is very thin and almost pointless, so I wonder if this other one actually has some beef to it...
I put on the Skidplate myself and it appears to be a very heavy duty piece. Its definitely vulnerable underneath of there until you put a plate on. It was, what, $200? I've already scraped it running up rocks. I wouldn't have wanted to tear up that part of the truck without it...
The plate is probably 6061 T-6 Alluminum, and if that is the case, it will be VERY strong. That's a good question for Toyota to see what kind of Alluminum they are using for the plate.
__________________ 2007 6-Speed Toyota FJ Cruiser 2002 Land Rover Discovery II 1978 Toyota FJ-40 Cruiser I UNDERSTAND THE JEEP THING, THAT'S WHY I DON'T OWN ONE. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#5 | |
I do have to say that the skidplate seems to be mounted low. I would like to see it tight up against the underbelly of the beast instead of on brackets and 1-2 inches lower. And as long as I blabbing about it, I'd like to see a third tube on the sliders to protect the outer most part of the door. __________________ Heather '07 FJ Cruiser and 1973 FJ55 Upstate Cruisers - Land Use Officer SFWDA - Director of Land Management Georgia Cruisers TreadLightly! Master Tread Trainer DONATE TO SAVE TELLICO |
#6 | |
tlcwagons.org
I took a good look at the accessory skidplate. It is 3/16" aluminum stamping with cursory mounting brackets and is a light duty item. Toyota has a fine tradition of this type of accessory skid with the Tacoma and older Sport Edition 4Runner. I think it's a fun item to dress up the FJC but your expectations on it's performance should be on par with what it is. If you look under the FJC's the FJC Trail Team uses, they fabricated proper steel skidplates to replace the factory ones if you plan on hitting 3+ trails. |
Either I find time to break out the torch and welder to fab my own up, or I wait til some nice aftermarket plates come out. Either way, it's going to cost us all more money. Toyota should have done it right so we didn't have to spend more money.
#8 | |
tlcwagons.org
Weedo,
TexasB is just enthusiastic about the FJC and so are you, with differing perspectives. There is nothing wrong w/ the stock toyota skids, they do a fine job for most owners. If you are going on harder trails, you would need new skids on any rig. No OEM makes true, HD steel skids. The add-on front skidplate pictures (which is not the OEM skidplates, but an accessory option) (also found as an accessory for the Tacoma-see toyota.com) ![]()
#10 |
Unleash the Beast
OEM skid plates not heavy duty one...
The point Toyota have the front skid plates to provide safety and protection against unforeseen road hazards (rock, chips..etc) and also to prevent unwanted damage to your lower radiator.
#11 | |
Still, I've got the torch ready!
#12 |
Admin
I run a piece of 3/8" 6061 alum for my skid plate on my offroad rig....I use it VERY hard, and have supported much of the rig on it before....supported only by the frame rails.
I know quite a few other hardcore wheelers who run 1/4" alum skids with no problems either, but they frequently support on 4 sides where mine is only attached to the frame rails. For front protection for 95% of owners, the 3/16" will be perfect in front....the 5% of us who will push the rig well past it's expected limits will likely spring for a true aftermarket option, like what AllPro does with their bumper. My next rig will be running 6061 1/4" skids and 7075-T6 alum links too
__________________ Brian 'woody' Swearingen 1974 FJ40 'The Raisin' - Pitbull Rockers, 30-spline Longfields, SOA - 1/4 ellip 1996 FZJ80 'Gretchen' - MetalTech, ARB, OME, IPOR, 4x4Labs 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Nitto Terra Grapplers, 4" exhaust Forum Questions? Click Here! 'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln |
#13 | |
tlcwagons.org
It mounts below the actual factory skids (steel stampings) by way of simple drop brackets. It cannot support much weight at all, and much of the aluminum skid is unsupported. I consider it a light-duty add-on item for this reason. However, for the right buyer, that might fit the bill perfectly. Not everyone needs a full belly HD skidplate array. Incidentally, there are several 4R owners who replaced the stock skids w/ HDPE (like the TrailLex) and seem to be going well with it in the rocks. I am curious about this, according to the TrailLex guys, it came from competition rockcrawlers. On a suv, i can see + and - with it. Time will tell, I guess. |
#14 | |
What am I planning on using? UHMW polycarbonate. White plastic cutting board material, .5" thick. It has good impact strength (dump trucks, coal and rock hoppers are lined with it), and it's slick enough to slide off of most everything. There are quite a few rigs running this material, most famously the Four Wheeler Magazine Lexus "Trailex."
#15 |
That is pretty cool. I have burnt that stuff cooking before, how well will it hold up to engine heat?
__________________ Dan Kunz 1996 FZJ-80 "AV0CAD0" 2000 UZJ-100 "T0WCAD0" Member: TLCA, GA Cruisers, Upstate Cruisers Donate to SAVE TELLICO! _____________________________ Originally Posted by eventhough: "apparently I just need to play with it until it feels right... " |
#16 |
My friend's '02 taco had a skid plate until it got ripped off on a trail out here in vegas. he found an aftermarket one that worked for him. good to have one - protects valuable stuff.
#17 |
Does the AL Skidplate Fit with the ARB Bar
Has anyone tryed to keep the Aluminum plate after the ARB install?
Cheap Books | PrePaid Credit Cards | Discount Computer Speakers | Refinance | Mortgages |
