Go Back   IH8MUD Forums > Toyota Tech Forums > FJ Cruiser
Old 05-30-06, 03:12 PM   #1
Scooterpilot's Avatar
Day Time Running Lights
Hi
I'd like to disable the daytime running lights on my FJ. I know someone addressed this in "some forum" but I can't remeber which formum?
Can anyone help me out so I can disable my DRL?
Chuck
Scooterpilot
2008 Sandstorm, 4x4, MT, convenience package, off road package, towing package, skid plate, rock rails, TRD shifter, rear door storage,
2008 Corvette, Red Z51, 3LT M/T 6 speed, Nav
Scooterpilot is offline   Reply With Quote
Old 05-30-06, 03:25 PM   #2
SurfPonto's Avatar
Originally Posted by Scooterpilot
Hi
I'm like to disable the daytime running lights on my FJ. I know someone addressed this in "some forum" but I can't remeber which formum?
Chuck
DRL Resistor module behind drivers headlight, Gray plug looks like a heatsink. Simply unplug it! (from FJ Cruiser Forums)
Curious as to why you want to disable the DRLs?
Bob
SurfPonto is offline   Reply With Quote
Old 05-30-06, 11:48 PM   #3
SurfPronto,
A firend of mine just bought an FJ and wanted to know how to disable the light.
Regards
Scooterpilot
Old 05-31-06, 08:45 AM   #4
Previous posts were at http://forum.ih8mud.com/fj-cruiser/90750-daytime-running-lights-any-options.html and detail at least one good reason for occasionally disabling DRL. BTW you can also disable H3 DRL by following a specific start-up sequence using the light control switch in the cabin.
Go4aRyd is offline   Reply With Quote
Old 05-31-06, 10:59 AM   #5
Go4aRyd,
Thanks for the information
Scooterpilot
Old 06-01-06, 09:20 PM   #6
SATXChelus's Avatar
FYI, some insurance companies give you a small discount if the vehicle has DRL. I know Geico and USAA do, sure some others do as well. just something else do think about.
SATXChelus is offline   Reply With Quote
Old 06-01-06, 11:06 PM   #7
I have two options that are tricks but both leave
the PARK BRAKE lamp on.
1. Pull up the park brake one notch. (besure the
brake does not begin to set) This has to be done before
starting and cannot be set down after starting or the lights
come on.
2. Pull up the center consloe and install a switch in the
Park Brake wire.
Both of these work and leave the PARK BRAKE lamp on.
This may be good as to remind you that the DRL are off.
torpedo is offline   Reply With Quote
Old 06-03-06, 11:52 AM   #8
If anyone tries to add a switch to the headlight resister (instead of hard disconnect), let me know. I'm thinking that might be the best route - but am unsure if it is feasible. In the older days, you could put a switch on anything, but with ECUs and control units, adding a switch can be much more complicated.
Buy PSP | Cheap Loan | Electricity Suppliers | Personal Finance | PSD to HTML
