Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > FJ Cruiser
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
FJ Cruiser The newest model GSJ15 Toyota FJ Cruiser -- FJCruiserForum.com
Closed Thread
Old 05-27-06, 10:04 PM   #1
tlcwagons.org
FirstToy's Avatar
Fj Cruiser Faq**freq Asked Questions**
Work in progress, many links are not active yet but we're working on it!
The Frequently Asked Questions (FAQ) for the FJ Cruiser tech section continues to be a work in progress. The goal is to have links in the below to other threads and tech articles. By having these linked, instead of pasting the text, the threads will remain live. The live threads can continue to be updated and/or modified for things such as part numbers, adding on additional insight or after a period of time, some follow up information.
These FAQs will be put together by FORUM members. We want this to become a great resource for FJ Cruiser owners, so make the best of it!
Again, these will continue to be updated and we will continue to add new ones as we move forward.
If you have an idea for a new faq, or would like to take ownership of pulling one together, then don't be shy about it, you'll be helping everyone
Acronyms and Definitions - Wondering what those Acronyms mean, look here. PM a mod if you see one missing.
General Info- The General Links include model info and if you are thinking of buying or getting ready to look at an FJ Cruiser, look here for helpful links.
Modifications - Need to start modifying your rig? Look here for what other forum members have done from roof racks, tires, lifts, ATRAC hacks, to . . . . If you have an idea, let us know and we can add it! Some modifications are also included in the Accessories link below
Maintenance/Trail Fix items- If you need to perform some maintenance from CV's to ABS sensors, Fluid Changes, Filters, Injector Cleaning to wiper blade changes, look here! In addition, our local Oil experts provide their recommendations.
Bling- Need to add a little Bling, add leather, make the paint shine, look here!
Repairs - Snapped a ABS line during a lift? Broke a tie-rod on the trail?
Forum Member Mods - - Links to threads showing, bumpers, sliders, lifts, tires, OnBoard Air Systems, etc. as they look installed on your fellow members rides. Also a Link to Storage ideas can be found here
Where can I get those Accessories - Links to Vendor sites for lots of those great accessories.
SC'd, Water intercool'd, HQ'd, Slee'd, Norcal80'd
my wip
I drink your milkshake!
FirstToy is offline
Old 05-27-06, 10:22 PM   #2
tlcwagons.org
FirstToy's Avatar
Please PM me for additions/corrections. Thanks!
Common Forum Lingo:
AFAIK - As far as I know
BTW - By the way
FWIW - For What it's worth
FYI - For your information
IIRC- If I recall correctly
IMHO - In my humble opinion
IMO - In my opinion
LMAO - Laughing my @$$ off
LOL - Laugh out loud
OTOH - On the other hand
ROTFLOL - Rolling on the floor laughing out loud
ROTFLMAO - Rolling on the floor laughing my ass off
RTFM - Read the F-ing Manual
YMMV - Your methods/mileage may vary
Technical Acronyms:
1GR-FE= 4.0 Liter V6 used in the FJ Cruiser
ABS - Acronym for Anti-lock Braking System. This system uses a computer to control your brakes on your car by applying and releasing your brakes quickly to prevent skidding or sliding from occuring.
ATRAC; also A-TRAC - Automatic Traction Control. Uses the ABS system as a traction aid by activating the brakes to "lockup" the wheels momentarily to create traction.
VSC - Vehicle Skid Control. This applies the brakes to modulate high speed manuvers (e.g. a slippery, ice-strewn road) to keep the FJ Cruiser from loosing traction due to excessive speed or sudden loss of traction.
DAC- Downhill Assist Control. This applies the ABS system to 'crawl' down steep, loose terrain with a minimum of sliding or loss of control. Activated by a dash switch while in 4Lo
CDL Switch- Center Differential Lock Switch- Switch installed to allow the Center Differential to be locked when the transfer case is in High. The actual Center Differential Lock is in the Transfer Case.
A-TRAC Switch- Activates the traction control for slow speed, offroad use.
Rear Locker Switch; RR Locker Switch - This locks the rear differential so both rear wheels rotate at the same speed no matter what.
Reference on operation of Center Differential. Diffs and Difflocks for Dummies (George Couyant from www.lcool.org) - Can Purchase CDL from Cdan (Toyota) or Sleeoffroad.com
ALT - Alternator: power generator for automobiles
ARB - australian 4x4 accessories manufacturer
AT - Automatic Transmission
MT - Manual Transmission. Also referred to as MT6 (6 speed manual)
AT - (tires) All Terrain
M&S - (tires) Mud and Snow
MT - (tires) Mud Terrain
ATF - Automatic Transmission fluid
CV- Constant Velocity Joints: Found in the front axles of our rigs; they are constant velocity joints that transmit power through variable angles, at constant velocities. There are two most commonly used types of CV joints: ball-type and tripod-type. Different variations of ball-type CV joints are commonly used on the outer side of the drive shaft, while tripod-type CV joints mostly used on the inner side. Most common problem with the CV joints is when the protective boot gets damaged. Once this happens, the grease comes out and the moisture and dirt come in, eventually causing the CV joint to fail due to lack of lubrication and corrosion.
Coilover - The shock and coilspring are combined into one unit. The FJ Cruiser uses 'coilovers' in the front suspension
UCA - Upper Control Arm. This is the upper A-arm in the front suspension, commonly reffered to when thinking of upgrading the suspension.
Uniball UCA - A Upper Control Arm with a spherical ball joint that allows for greater range of motion than the stock ball joint, which is limited in it's range of movement.
LT; Long Travel - A 'kit' that has longer UCA's, CV's, Tie Rods. This basically widens the front track to gain wheeltravel. LT suspensions are used for high speed desert running.
TRE - Tie Rod Ends.
CEL - check engine light, sometimes refers tocode that cuased light that can be read by a code reader
DS- Driver's side
DS: Drive Shaft=shafts that carry power and torque from the engine/tranny/xfer case to the axles.
DC DS=Double Cardan Drive Shaft=a pair of joints in a drive shaft that allows the tube to move in various directions and angularities.
Diffs - Differentials: found in the front and rear axles that consists of gears that transmit equal power and torque even if they rotate at different speeds.
EGR = Exhaust Gas Recirculation valve
EWD or WD - Electrical Wiring Diagram, (part of FSM set)
FSM - Factory Service Manual. The "bible" as published by the manufacturer. Used to guide in repairs
FAQ - Frequently Asked Questions
Land Cruiser Prado - A 120 series Toyota SUV which the FJ Cruiser shares many mechanical parts and structure.
GSJ-15 - A 4WD FJ Cruiser powered by the 1GR-FE engine.
GSJ-11 - A 2WD FJ Cruiser powered by the 1GR-FE engine.
HG - Head Gasket
JDM- Japan Domestic Market- Refers to items particular to vehicles manufactured and sold in the Japanese market.
Items include but are not limited to:
Power retracting mirrors
Dual air conditioning
Adjustible shocks
Winches
and various cool and some gawdy accessories.
LB/FT - pound feet of torque
LB/IN - pound inches of torque
LHD (Left-Hand Drive): steering wheel on the left side, driving on the right side of the road
MAF - Mass air flow sensor
MIL - Malfunction Indicator Light (same as a CEL)
NA - Naturally Aspirated - An engine that is not turbocharged nor supercharged
OBDII - On Board Diagnostics Port available on ALL cars sold in the US 199 and later. Allows a common intercface tool to be connected to read and reset engine fault codes (CEL). Many Autpart stores will read your code for free vs. paying the dealer.
OEM - Original Equipment Manufacturer. (Toyota in this case)
OME - Old Man Emu. An Australian four wheel drive specialty manufacturer that makes all kinds of cool stuff that causes us to empty our billfolds.
PCV Valve - The Positive Crankcase Ventilation valve is an emissions control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned.
PM - preventive mantenance
PM - private message
PO - Previous owner
POS - Piece of S#1T
PS- Passenger side
PSI - Pounds per square inch - A measure,emt of pressure.
RHD (Right-Hand Drive): steering wheel on the right side, driving on the left side of the road.
RPM - Rotations Per Minute
SOA - Sprong Over Axle - A suspension lift for a leaf (Vs 120 series coil) spring suspension. It places the leaf springs on top of the axle vs the bottom.
SC or S/C = Supercharger/Supercharged
SSM - Special Service Materials
SST - Special Service Tools
SUA = Spring under axle. Stock configuration for a Leaf (80's use Coil)Spring Vehicle (vs. SOA previously mentioned).
TB - Throttle Body: controls air flow into engine system in response to gas pedal depression.
TC or T/C = Turbocharger/Turbocharged
TLCA - Toyota Land Cruiser Association (tlca.org) - The Toyota Land Cruiser Association (TLCA) is a 4 wheel drive organization open to all Toyota 4 wheel drive vehicles (except sedan types). This includes all models of Land Cruisers, 4Runners, and 4x4 trucks.
USDS- US driver's side or the left-hand side of the vehicle.
USPS - US passenger side or the right-hand side of the vehicle.
xfer=Transfer case: sits behind transmission, has front and rear drive shafts coming out of it, and distributes power from the transmission to the front and rear differentials/axles.
Part-time 4wd; part-time t-case - This allows the disconnect of power to the front wheels, making it a RWD (rear wheel drive) vehicle. The activation of a switch or lever to 'lock' the front driveshaft makes full-time 4wd.
Fulltime 4wd - The vehicle is always in 4wd with power to all 4 wheels at all times.
my wip
FirstToy is offline
Sponsor 05-29-06, 09:57 AM
Sponsored Link
advertisement
Old 05-29-06, 10:17 AM   #4
tlcwagons.org
FirstToy's Avatar
Forum Member Front Bumpers
Forum Member Rear Bumpers
Forum Member RockSliders
Forum Member Suspension Lifts
Forum Member Tire Choices
Forum Member Cargo Storage Boxes
--LandcruiserSteve's full-length cargo box
Forum Member Storage Solutions
Forum Member Audio/Nav/electrical Modifications
my wip
FirstToy is offline
Old 05-29-06, 05:28 PM   #5
tlcwagons.org
FirstToy's Avatar
Please Support our Vendors!
other vendors
my wip
FirstToy is offline
Old 12-29-10, 09:59 AM
Sponsored Link
advertisement
Old 12-29-10, 09:59 AM   #7
ONSC TLCA Delegate
Mtbcoach's Avatar
Garage
Squeaky clutch bearing TSB document attached...
Jerry - Olde North State Cruisers Triangle VP
'07 GJS15 well enhanced SOLD
'97 FZJ80 40th OME J
'77 FJ45
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Interior Tire Mount for your 91-97 FJ/FZJ80
Mtbcoach is offline
Closed Thread
Trackbacks are Off
Pingbacks are Off
LinkBack to this Thread: http://forum.ih8mud.com/fj-cruiser/94998-fj-cruiser-faq-freq-asked-questions.html
Posted By For Type Date
jasontrotter's bookmarks on del.icio.us Post #0 Refback 05-21-08 05:02 PM
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
