04-25-06, 10:41 PM
puttin 33's on rub a bit
Put on some BFG mud terrain tires that were 285 70 17 and it rubs a bit on an extreme turn on the rubber that covers the frame.
04-25-06, 10:43 PM
with one of each tire. Attachment 69940
04-25-06, 10:45 PM
rubbing on rubber. Attachment 69944
04-25-06, 10:50 PM
cut that shit out! Attachment 69945
04-25-06, 10:51 PM
04-25-06, 11:41 PM
I think it's not due to the wheel size but the bigger thread that the BFG mud has. Because Fusion Cruiser has 285s and he has about 1/2 left, I tried out yokos muds 285s and MT/Rs and they both had 1/2 of free space.
04-26-06, 07:19 AM
is this when it is stuffed, or just while it is sitting there?
bk
bk
KJ4HFL
646 and repeat
04-26-06, 08:51 AM
All tires vary between brands.
My 37 inch MTR's measure 36.2 inches.
My 35 inch BFG's measured 33.4 inches. And I have had 33's that measured anywhere from 31.5 to almost 33.
You need a lift to run those tires anywhere but the road.
04-26-06, 12:04 PM
Hopefully I can ask this as a general question without sounding tooo stupid....
I have been looking at my wheel wells and tires (GY MTR 285/70/17 - with no rubbing) and have a question about the lift kit comments that abound...
My clearance 'issue' is not with the top of the fender but the front to back measurement of the opening. So if I put a sexy 3" lift, I'm raising the fender but the front to back measurement is still the same. So with the front to back being my problem and with my fancy new lift won't I be in the exact same 'tight situation' when I compress the suspension on one of the front corners?
This is a question that has been bugging me since I first heard about the size limits with and without a lift on the FJC.
Hopefully someone can enlighten me.
Thanks!
Shawn
-'07 SunFusion FJ Cruiser C Pak
-33" GY MTRs
-Regrets... None!
04-26-06, 12:05 PM
#10 (permalink)
Can you measure your tire from the ground to the very top to see how it compares to the GoodYear MTRs ?
I can measure mine when I get home.
Thanks,
Shawn
-33" GY MTRs
-Regrets... None!
04-26-06, 01:23 PM
#11 (permalink)
Thanks!
Shawn
You put on that sexy lift and your front and back measurements are now three inches higher...and, without getting into measurements of pi, a circle is the fattest across the diameter. If you're three inches above the diameter then you've got a bit more room front and back.
04-26-06, 01:28 PM
#12 (permalink)
Admin
make sure your tire presssures are exactly the same and that each vehicle is exactly loaded the same....otherwise that measurement won't mean much....
ideally, because of where the tires rub, you want a "corner to corner" measurement at the horizontal centerline (much like a car where the left rear bumper point measured to the right front bumper point is it's "worst case" length)
no surprise that two different tires measure differently, and that one may rub where another doesn't.
Brian 'woody' Swearingen
Owner, IH8MUD.com
Owner, ROCKCRAWLER.com
- 1974 FJ40 'The Raisin' - 39" Pitbull Maddogs, 17x9 TrailReadys, 30-spline Longfields, SOA - 1/4 ellip, Ultimate Air, MobiArc, Optima RedTop
- 1996 FZJ80 'Gretchen' - MetalTech sliders, MetalTech tube front, MileMarker V10 MiFi, OME lift, IPOR rear & skid, 4x4Labs swings, INTI rack, dual Optima RedTops, 285 TreadWright tires, Ultimate Air, Raingler Barrier
- 2009 buggy....designing... RockCrusher60's
- 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Hankook DynaPro ATM, KYB MonoMax, 4" exhaust
- 2008 32' ABU Gooseneck car hauler, 2000 Damon Hornet M-32F, 1997 14' car hauler
Forum Questions? Click Here! .. .. .. .. 2009 IH8MUD Wheelin Schedule!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
'Everyone wants to save the porpoises, but no one cares about the tuna'
04-26-06, 02:27 PM
#13 (permalink)
Sawzall time
Sam Shaya
96' FZJ80 convertable
4x4 Labs Rear end, Bengels Offroad front bumper, roll cage, etc.
other goodies, but you get the idea.
Call Sign KI6KNB
"Team Pull-OUT"
Phi Kappa Psi
04-26-06, 04:37 PM
#14 (permalink)
Are you suggesting that 'post lift' I will not be able to compress the front suspension? I have to say that is not my past experience. After a good lift I could still bury my wheel in the wheelwell with ease. That means I have the diameter of the tire still trying to fit between the same area of the wheelwell that is causing the problem. Unless we aren't expecting to be able to compress the fronts that far.
I'm still confused.
-33" GY MTRs
-Regrets... None!
04-26-06, 06:35 PM
#15 (permalink)
The wheel isn't going to move a lot front to back as its coil on the back an torsion bar in front. But it will be deflecting some. But it seems like 33 inch the limit for anything stock.
If you really need big tires then start cutting.
04-26-06, 06:47 PM
#16 (permalink)
ive got 33's and a 3' lift on my fj no rubbing no problems its great.
paul
07 voodoo blue fj
3" lift
expedition one front bumper
t-max winch synthetic line
gobi roof rack and ladder
ipf lights
33"hankook dynapro mtr's
mapleton, utah
fj rocks!
04-26-06, 06:55 PM
#17 (permalink)
I have GY MTR 33's and no lift (at this time) with no rubbing.
-33" GY MTRs
-Regrets... None!
04-27-06, 10:48 AM
#18 (permalink)
Do what a lot of Taco guys do (and I did) take off the mudflap, pound tte pinch weld down so it doesn't stick out as far. Yes a BFH is required. Re-install mudflap. No more rubbing. Sounds much worse than it actually is.
dmc
