04-23-06, 03:15 PM
All new Roof Rack Diet... Mine was a bit too big :(
Here's the story...
I bought the FJC but after measuring the total height, it became obvious that the underground parking at my work wouldn't accomodate the truck. The truck seemed to be measuring about 6'10 to 6'11" (depending on gas load I'm guessing) and the parking lot is limited to 6'5". When I found that out, I drove downtown to see if there were any lots with higher clearance but none to be found except outdoor ones and those all have signs up saying 'no monthly spots available' so here is the compromise I had to go with....
A Roof Rack Diet.
Rack removed from truck.
One of the pillar torx bolts removed. Pillars are plastic and appear to be all the same.
Bottom view of one of the mounting 'feet'
Rear ODD pillar. This is the only pillar that needs to be 'dealt' with. This is an H shaped plastic pillar that is needed to keep the 2 sides of the rack together but if you want to keep the option of going back to a full rack later, you won't want to cut this to make it nice as it won't allow for the two level rack unless the shape is maintained.
There is a little hole (square) that allows access to a torx screw without having to remove the foot.
Here is the one spot that I had to make a 'permanent' alteration to the bottom rack section. I had to drill two holes on the top so that I could mount the H Piller horizontal (not pretty but make the Pillar reusable later).
Back view showing the H Pillar (connector) with it's new mounting orientation.
Top view showing the H Pillar (connector) with it's new mounting orientation.
Side view showing profile of completed roof rack reduction.
If you want to do it and have questions, msg me and I'll help where I can.
Thanks,
Shawn
-'07 SunFusion FJ Cruiser C Pak
-33" GY MTRs
-Regrets... None!
04-23-06, 04:45 PM
Wow! It looks so ... svelt!
Can it be put back to ... err ... "normal" later?
04-23-06, 05:21 PM
Yup, that's why I didn't alter the H pillar
I plan to put it back together if I find a better parking spot at work but for now, this will have to do.
-33" GY MTRs
-Regrets... None!
04-23-06, 06:01 PM
You were smart enough to focus on the overall height. I took mine to the mall today and hit (lightly) a low hanging clearance sign (it was setting lower than the others) on my way into the parking garage. The FJ actually did fit in the garage, as I rolled down the window and peeked up as I crawled the car in slowly, but it only had about an inch or so of clearance.
THe pictures and in fact the in person view doesn't quite get you focused on where the top of that rack is. I need to go look at the specs, but it might be higher than the landcruiser with factory rack.
EDIT: Just did that and indeed the FJ is a LOT HIGHER than the 100 series cruiser with rack. I would estimate about 4-5 inches higher. I think both of them measure about 72 inches without the racks, but the FJ rack adds probably 7+ inches of height. I don't think it will fit in my existing garage.
______________________________
'06 UZJ-100 Stock 33K
'07 GSJ15 FJ Cruiser Voodoo Blue 6K
Si fractum non sit, noli id reficere
04-23-06, 08:43 PM
what are you doing to fill the holes left in the roof for the front mounting locations
2007 Voodoo Blue FJ Cruiser
Flat black stock 17's, 285/70/17 Goodyear Wrangler Mtr's, All-Pro lift
Plans- All-Pro front bumper, rock sliders
04-23-06, 08:48 PM
Getting a set of the trim tabs that are on the rain channels before the roof racks get fitted in port. The dealership is looking into part numbers etc but it may take a bit as they can't figure out how to order them.
-33" GY MTRs
-Regrets... None!
04-23-06, 08:59 PM
It's a little baggie of parts, they're called "Accessory Covers." If your guy can't find 'em, call www.TRDsource.com and talk to Matt (actually, you can talk to any of the guys there; they ALL know about the FJC!). They can drop ship to you pretty quick.
04-23-06, 09:14 PM
Cool, I'll give them a call b/c my Toy Parts guy has no idea what to order.
Thanks!
Shawn
-33" GY MTRs
-Regrets... None!
04-24-06, 09:42 AM
Not a good idea - the clearance signs mark the lowest clearance in the garage, not the overall clearance. If you hit the marker ... back up.
Tucker
04-24-06, 07:03 PM
#10 (permalink)
Fair enough. IF I ihadn't been familiar with the garage from my 80 with extra Thule cross bars, and the 100 with factory rack, I probably would have, but I just couldnt believe it wouldnt fit. Of course, I thought it was shorter than the 100, which was not correct.
In any case, the sign I drove under was hanging lower than the others,...I didn't see it before I swung it.
04-25-06, 10:03 AM
#11 (permalink)
Rookie
So... i got a chuckle reading this yesterday.
Last night, I picked up my fjc..... this morning, I notice the garage clearance at work is 6'4
Looks like my rack may be on a diet!!
AS
04-25-06, 12:29 PM
#12 (permalink)
Lots of celery and watermelon.
I'm kind of getting used to the skinny rack. It grows on you.
-33" GY MTRs
-Regrets... None!
04-25-06, 01:53 PM
#13 (permalink)
As I posted in the other thread, I measured the height with roof rack at 78 inches. You just don't get that impression that it would be that high,
Given how strong the rack feels , I sure wouldn't want to see what was "going to give" if you ran under somthing pretty solid. On a lot of cars, ti would be the rack, but on this one you'd worry that the rack might be strong enough to allow some structural damage to the roof frame before it came loose. Of course, Toyota engineers have often considered issued like that and are a step ahead.
I'll bet though, that it becomes the most frequent "first repair" item.
04-26-06, 07:29 PM
#14 (permalink)
Nice Mod! I hope I never need to do it...
04-26-06, 07:43 PM
#15 (permalink)
Rookie
Thanks for the tip - exactly the issue I have wiht my FJ and I think I am going to have to remove rack to get it in the garage.
04-26-06, 07:51 PM
#16 (permalink)
IH8MUD Lifer - No Appeal
Shawn,
Thanks for posting this. A very inventive solution. We are having trouble helping customers to mount tents on their FJs - the rack is a little higher than necessary for many applications.
On a related note, Thule's new fitment guide refers to the FJC as a "2007 FJ40". WTF? They list the 450 CrossRoads as fitting the rack with minimum 50" Load Bars. Tall and taller.
Mike
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
09-22-06, 08:47 PM
#17 (permalink)
I FIT in my garage, but I will be doing this mod. I think the stock rack is butt ugly. This allows the Demello baby shovel or other accessories to mount up there sideways if needed.
I might just remove it completely, but this is far better than that ugly crap factory 'bullhorns' looking sob.
09-22-06, 09:10 PM
#18 (permalink)
I think it looks great and was a inovative mod of stock while using most of what was provided. I'd be intrested in how/if it affects mileage too.
Yellow FJ Cruiser - a work in progress -
Copper State Cruisers #68
IBL8 & Procrastin8
09-24-06, 02:06 PM
#19 (permalink)
Fourty Wonderful!
Well I was thinking of having one installed and I think that the parking issue might me the deal breaker for me... I like the way they look. Is there any other rack that could be put on the fj that isnt as tall?
02-02-07, 06:16 AM
#20 (permalink)
Rookie
What's the Rack Tube Diameter?
Do you know what the tube outer and inner diameter is?
02-02-07, 06:39 AM
#21 (permalink)
The FJs outer diameter for the roof rack tubing is 1.75".
04-21-07, 02:58 PM
#22 (permalink)
Is it possible for someone to post the part number, versus everyone calling Matt each time they are missing these pieces from a port-installed OEM roofrack?
06-15-07, 03:47 PM
#23 (permalink)
I drove my FJC under a "6'5" clearance" sign the other day, with the stock roof rack fully intact. I was probably way close to hitting it, and didn't realize it until after I had already gone under it.
Now that I'm starting to install some antennas, I think I need to start being a lot more careful about that.
07-14-07, 12:25 AM
#24 (permalink)
You can get the Drip Rail Covers at TRD Source.com I believe they are like 10 dollars or so I do not remember exactly
RR... well before the tree wanted my Hi-Lift, UPG-1, OME H_Frt/M_Rear, ProComp 1069's, ProComp Xtrm AT305/65/17's, TRD Exhaust, AFE Cold Air Intake, Demello Sliders, BUD BUILT SKIDS
more to Follow...
12-08-07, 03:44 PM
#25 (permalink)
Rookie
Roof Rack Diet
For those who've pulled the factory rack off. What do you do with the holes left from the rack?
12-08-07, 05:15 PM
#26 (permalink)
After removing the factory rack ...
You can always fill in the holes with the mounting bracket and screws from the ARB roof rack!
2007 FJ, Black, 3" OME, 285 70R17 (33") Micky Thompson ATZs
12-08-07, 05:52 PM
#27 (permalink)
Rookie
Roof Rack Diet
12-09-07, 02:43 PM
#28 (permalink)
Snap the OE rain gutter covers back on that came with the vehicle prior to roof rack installation at port/dealership.
12-09-07, 03:39 PM
#29 (permalink)
Rookie
Baldman,
That sounds good but i have a couple of questions. Since I picked my FJ up from the dealer with the rack already on.
1) Where does one find these rain gutter covers?
2) will that seal up the holes or just cover them?
12-09-07, 04:53 PM
#30 (permalink)
You can order them from the Toyota parts dept. or ask the service manger at your local dealership(s) if they have any spares hanging around. I had to contact my regional distributor to get a set, since that is where they installed my roof rack.
2) Will that seal up the holes or just cover them?
The covers are just that - covers. You can either pickup some shorter screws from the hardware store or just add a dab of silicone to fill the mounting holes before installing the covers.
Let me know how you fair on locating the covers. I can offer you my set if you don't have any luck, as I am about to trade my FJ in on a Tundra - need the bed for hauling...and the additional tow capacity. Feel free to email me from here on out.
--Michael
