LinkBack (26) Thread Tools Display Modes
Old 04-02-09, 04:27 PM   #31 (permalink)
holmanm's Avatar
I'm de-moth balling an old thread. I did this mod this weekend but with a twist. I took the front mount brackets and switched the left and right so that they would point forward, then attached some 4" lights to them. The lights are still lower than the back half of the rack.
I did have one issue though. I ordered the fog-light switch and relay from Sparks Toyota. I used the attached instructions as a guide. I plugged the switch into the white connector behind the switch console. I put the relay and 15 amp fuse in the Off-Road LP spots in the engine compartment fuse box. The lamp symbol of the switch lights up when the headlights are turned on but the rectangular light on the switch never lights up even with the switch depressed and none of the wires in the a-pillar connector is hot with the switch depressed.
I tried the blue connector behind the switch console and the Aux LP relay and fuse slots under the hood and all combinations possible of the three but I never get power to the a-pillar.
The connector in the a-pillar has from top left:
1 - Constant 12 volts. Red.
2 - Ignition On 12 volts. Orange.
3 - Empty.
4 - ? White/Black stripe.
5 - ? White/Black stripe.
6 - ? Green.
I assume this is a mirror image of the connector shown in the attached instructions Fig 2-26 since it says looking at their connector and I am looking at the a-pillar connector so one has to be flipped to plug into the other one.
So I was expecting pin 5 or 6 to be hot, but none were except of course for 1 and 2 which were unaffected by the switch.
So what I did was use pin 1 to connect the relay, hid in the a-pillar, and a rocker switch above the grab handle. It works fine and I like the fact I can turn the roof lights on without the key on.
Another strange thing, none of the 4 bolts used to attach the front 2 rack supports attach to ground. I had to run a ground wire from one of the middle roof rack support bracket bolts to get ground for the lights and not have to run another wire down the outside of the a-pillar.
But it still bothers me why I'm not getting power to the a-pillar from the dash switch.
The fuse is good, the relay is good, the switch is good. I would appreciate any suggestions to the problem, obvious or not.
Mike H
2007 Black Cherry Auto 4WD FJC
1982 Husqvarna 430XC
holmanm is offline   Reply With Quote
Old 04-05-09, 08:01 PM   #32 (permalink)
adso's Avatar
TLCA# 16713
I don't know how to fix your problem, but the lights look cool!
"Dad, Napoleon called. He wants his complex back."
2007 FJ Cruiser "Napoleon" ARB bullbar/sliders/rack, Tabor winch, OME heavies front and mediums rear, BFG M/T 33s on ProComps
adso is offline   Reply With Quote
Old 04-05-09, 11:03 PM   #33 (permalink)
Rookie
Great Mod here Fusion... I'll have to keep this one in mind when it comes time for the 6" lift.
Thanks for the write-up and pics!
ZroBug is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/fj-cruiser/90182-all-new-roof-rack-diet-mine-bit-too-big.html
Posted By For Type Date
Finally got the FJ stuck... grrrr **Warning high pic count ** - Page 4 - Toyota FJ Cruiser Forum This thread Refback 09-23-09 07:52 PM
Blockeados 4X4 • Ver Tema - Parrilla para Fj Cruiser This thread Refback 08-30-09 01:36 PM
Toyota FJ Cruiser Forum - View Single Post - Mini Roof Rack This thread Refback 05-18-09 06:23 PM
Taking off roof rack, need help. - Toyota FJ Cruiser Forum This thread Refback 11-09-08 10:50 AM
OEM This thread Refback 10-28-08 05:36 PM
Need help lowering roof rack. - Toyota FJ Cruiser Forum This thread Pingback 09-19-08 12:19 PM
WTS/WTT 17 This thread Refback 09-15-08 10:19 PM
My kayak hauling solution - Toyota FJ Cruiser Forum This thread Refback 08-19-08 04:12 PM
Mini Roof Rack - Toyota FJ Cruiser Forum This thread Pingback 08-08-08 01:23 AM
WTS/WTT 17 This thread Pingback 08-08-08 01:19 AM
OEM This thread Refback 05-31-08 10:31 PM
Factory Rack Mod---Pipe Dreams - Toyota FJ Cruiser Forum This thread Pingback 05-28-08 10:27 AM
Suspension advice for my build. Now and down the road mod. - Toyota FJ Cruiser Forum This thread Refback 05-28-08 08:00 AM
SHorter roof rack? - Toyota FJ Cruiser Forum This thread Refback 05-21-08 10:19 PM
Fj - This thread Refback 04-01-08 02:27 PM
mini me rack mod - Toyota FJ Cruiser Forum This thread Refback 03-23-08 11:24 PM
New FJ :-) - Toyota FJ Cruiser Forum This thread Refback 03-10-08 01:07 PM
arb roof rack :: BoardReader This thread Refback 03-03-08 04:08 PM
Picking up my new FJ tomorrow - Toyota FJ Cruiser Forum This thread Pingback 01-27-08 11:07 PM
Roof Rack - Remove top bar - Toyota FJ Cruiser Forum This thread Refback 01-16-08 04:47 PM
Another mini-me OEM roof rack mod - Toyota FJ Cruiser Forum This thread Refback 01-02-08 03:08 PM
Stock roof rack removal - Toyota FJ Cruiser Forum This thread Refback 01-01-08 07:28 PM
FJC forums faq - Toyota FJ Cruiser Forum This thread Refback 12-30-07 11:26 AM
ROOF RACKS: Comparisons / buyers guide - Toyota FJ Cruiser Forum This thread Refback 12-22-07 04:15 PM
Streamlining the roof rack - Toyota FJ Cruiser Forum This thread Pingback 12-21-07 08:52 AM
Complete Roof Rack Comparison - Toyota FJ Cruiser Forum This thread Refback 12-17-07 08:40 PM
