LinkBack (3) Thread Tools Display Modes
Old 04-19-06, 06:53 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
TLCA# 1272
Smile FJ Old Man Emu Install LIVE...NOW...Watch...Tire Install Update...pictures
We are installing an OME Full Suspension on the FJ TODAY...NOW. I will be updating this thread as we go. We have started at 8:30am ECT. Should be fun, here are the first pictures..... Enjoy
Tedd
Gilead is offline   Reply With Quote
Old 04-19-06, 07:27 AM   #2 (permalink)
TLCA# 1272
Here is the first picture. It seems that we are limited on the space(amount) of pictures that we allowed to post. We will try to work with smaller attachments.
Old 04-19-06, 07:34 AM   #3 (permalink)
TLCA# 1272
Compare stock on the left and OME on the right. Yeah, there is a fairly significant weight difference between the two....say 10-15 pounds...
Old 04-19-06, 07:43 AM   #4 (permalink)
TLCA# 1272
Here are prodcuts being used....OME 893 front coils...light duty, N139S Strut, OME 895 rear coils....light duty(listed as medium), N141 shocks. We do have the OME95PF5's for trim packers if needed. This is the Prado 120 suspension we are testing. We have two OME suspension that we will be installing/testing and reporting on. The first here being the light duty....the next, in a week or so, the medium duty one.
Old 04-19-06, 07:48 AM   #5 (permalink)
IH8MUD Thread Killer
Koffer's Avatar
Originally Posted by Gilead
Here is the first picture. We seems that we are limited on the space(amount) of pictures that we allowed to post. We will try to work with smaller attachments.
That looks like a 2 post Rotary lift, not a OME no matter what stickers you put on it
Todd
64' FJ40, 86' BJ70, 96' FZJ80 , 66'M416 and a 92' M101CND
Koffer is offline   Reply With Quote
Old 04-19-06, 07:53 AM   #6 (permalink)
TLCA# 1272
Front coil and strut installed. As a point of information. The stock coil measured 14" and the OME 13 15/16". We did use the trim spacer beacuse the coils were a bit loose without it....
Old 04-19-06, 08:05 AM   #7 (permalink)
TLCA# 1272
Talking
The front Struts, N139S were shipped via air frieght from Australia last week.
Old 04-19-06, 08:10 AM   #8 (permalink)
TLCA# 1272
Angry
Just so that we had a point of reference, we took the FJ for a trail ride last weekend. Yeah, the tires sucked in the mud.
Old 04-19-06, 08:24 AM   #9 (permalink)
TLCA# 1272
Talking
THe front LH coil and strut have been installed. The RH is coming off as I type here. The front sway bar seems to be giving us a run for the $. We will be able to post bigger pictures now...thanks Woody. Here is the RH side...
Old 04-19-06, 08:33 AM   #10 (permalink)
TLCA# 1272
Here are some stats on the stock height. Front RH- 28 3/4",LH- 29", Rear RH- 30 7/8", LH- 30 3/4".
Old 04-19-06, 08:38 AM   #11 (permalink)
TLCA# 1272
The RH coil ands strut are in the Branick 7200 strut machine. The amount of tension to compress this coil verses the stock one is much greater!
Old 04-19-06, 08:57 AM   #12 (permalink)
TLCA# 1272
We now move onto the rear suspension. Here it is stock..
Old 04-19-06, 09:06 AM   #13 (permalink)
TLCA# 1272
The stock rear coil information is as follows...Stock RH-14 13/16" LH- 14 13/16"...the same. The OME's are 15 3/8" each. The stocker is on the left, the OME is on the right...cleaner too....
Old 04-19-06, 09:14 AM   #14 (permalink)
TLCA# 1272
Install of the rear coil, LH side....
Old 04-19-06, 09:25 AM   #15 (permalink)
TLCA# 1272
Picture of the stock rear shock and OME shock.
Old 04-19-06, 09:29 AM   #16 (permalink)
Rookie
Notice that the OME shock is a thicker body?? It also has a bell housing around the shaft to keep mud dirt and grime from staying inside as a shock boot would. It also keeps the rod from getting pitted. That's another thing you can't see, but the rod is a thicker shaft!!
This is great to watch Tedd!! Very impressive!!
smc4wd is offline   Reply With Quote
Old 04-19-06, 09:30 AM   #17 (permalink)
TLCA# 1272
Angry
The shock goes in. Yeah, the installer got in the way...
Scott Cohen at ARB is also coaching us on the phone...sort of. Thanks Scott for all your help and insight.
Old 04-19-06, 09:36 AM   #18 (permalink)
TLCA# 1272
Just about done....in the rear
Old 04-19-06, 09:39 AM   #19 (permalink)
TLCA# 1272
To install the rear "stuff" we had to unbolt the rear sway bar and track bar.
Old 04-19-06, 09:40 AM   #20 (permalink)
Admin
woody's Avatar
TLCA# 1548
Garage
blow by blow tech rocks
Brian 'woody' Swearingen
Owner, IH8MUD.com
Owner, ROCKCRAWLER.com
Forum Questions? Click Here! .. .. .. .. 2009 IH8MUD Wheelin Schedule!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
'Everyone wants to save the porpoises, but no one cares about the tuna'
Old 04-19-06, 09:44 AM   #21 (permalink)
TLCA# 1272
We are getting there.
Old 04-19-06, 09:45 AM   #22 (permalink)
TLCA# 1272
Here we go...now the picture is here...
Old 04-19-06, 09:58 AM   #23 (permalink)
TLCA# 1272
Here is the back of the wheel. Yeah, the wheel is 17 x 7.5, but the back spacing was not know....at least by me at this point. So after measuring I would say it is 5 inches.
Old 04-19-06, 10:01 AM   #24 (permalink)
TLCA# 1272
Tires are going back on...
Old 04-19-06, 10:03 AM   #25 (permalink)
TLCA# 1272
Tires and in the air...
Old 04-19-06, 10:05 AM   #26 (permalink)
Rookie
Almost three hours, by a trained professional...
Old 04-19-06, 10:17 AM   #27 (permalink)
FusionCruiser's Avatar
TLCA# 16070
VERY Cool!!
Now where can I buy that kit?
Thanks for the Uber Install Post.
Now that it's finished I guess I should get back to work.
Shawn
-'07 SunFusion FJ Cruiser C Pak
-33" GY MTRs
-Regrets... None!
FusionCruiser is offline   Reply With Quote
Old 04-19-06, 10:32 AM   #28 (permalink)
TLCA# 1272
Okay, it is now on the ground. Here is the deal at this point. As you can see the front is "diving" Big Time. This is because we have the OME 893 and this is a non-USA coil that is specifically designed for low height Prado's. We are now putting the Cruiser back in the air and swapping out the coils for a set of OME 895's. We have been on the line with Tim the Tech guy at ARB who knows his stuff inside-and-out about installs. Watch as we continue with the process....
Old 04-19-06, 10:35 AM   #29 (permalink)
TLCA# 1272
The rear suspension is looking good. Here at the numbers there.
RH- 33", LH- 32 3/4". Now we have not driven it yet...obviously, but this should come down just a fraction when we hit the road.
Old 04-19-06, 10:37 AM   #30 (permalink)
Rookie
Tedd, let's hope you meant OME884's on the front...
The OME895's should have been correct for the rear.
LinkBack to this Thread: http://forum.ih8mud.com/fj-cruiser/89560-fj-old-man-emu-install-live-now-watch.html
Posted By For Type Date
KDJoteros.com - Toyota Landcruiser KDJ This thread Refback 03-11-08 06:00 AM
KDJoteros.com - Toyota Landcruiser KDJ This thread Refback 02-20-08 05:55 AM
Ome - Toyota FJ Cruiser Forum This thread Refback 12-25-07 03:55 PM
