Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > FJ Cruiser
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
FJ Cruiser The newest model GSJ15 Toyota FJ Cruiser -- FJCruiserForum.com
Old 11-18-11, 10:12 PM   #21
Pehea 'oe?
monniepoo's Avatar
I wonder if this is something I could tackle on my own? Hmmm
I'm experiencing life at a rate of several wtf's a minute!
monniepoo is offline   Reply With Quote
Old 11-18-11, 11:16 PM   #22
Originally Posted by Mtbcoach View Post
There is the "no cut" and the "cut" ATRAC hack. I did the cut version on mine, the thread I linked also has a link to the no cut version...
Rear Locker + ATRAC - Write up - TTORA Forum
Sorry for the thread Jack.
Jerry, I have a 2007 and am not sure if I can run atrac and the rear locker at the same time. If I'm looking at the picture in the link you posted correctly, if I put it in 4lo (automatic) then activate the locker, and then hit the atrack button, if I'm able to run both at the same time, I should have "A-Trac" and the red rear locker light come on at the same time on my gauge cluster. Does this sound correct? If I am not able to do it, if I go 4lo, locker, and then try the atrac, the atrac light wont light up. Sound reasonable?
Capt Sensible is offline   Reply With Quote
Sponsor 11-19-11, 05:14 AM
Sponsored Link
advertisement
Old 11-19-11, 05:14 AM   #23
ONSC TLCA Delegate
Mtbcoach's Avatar
Garage
If I recall, the build date for the change was 10/07.
Before that, you could not activate ATRAC with the rear locker locked. That is when the "ATRAC Hack" was developed. Then, both could not be used at the same time. If rear locker was locked, ATRAC was disabled (light goes out on the dash).
After, Toyota changed the ECU so that they could both be active at the same time and shows with the lights on the dash.
Yes, your dash should tell the story. Lock the rear, get the red light, push ATRAC button and if doesn't appear, you might consider doing one of the two hacks. If the lights are on, you are good to go, no need for the hack.
Make sense?...
Jerry - Olde North State Cruisers Triangle VP
'07 GJS15 well enhanced SOLD
'97 FZJ80 40th OME J
'77 FJ45
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Interior Tire Mount for your 91-97 FJ/FZJ80
Mtbcoach is offline   Reply With Quote
Old 11-19-11, 03:30 PM   #24
holmanm's Avatar
If I recall, the build date for the change was 10/07. ...
Just double checked to make sure and mine was built in 07/07 and the A-Trac comes on with the Rear Locker engaged, no hack needed.
Mike H
2007 Black Cherry Auto 4WD FJC
1982 Husqvarna 430XC
holmanm is offline   Reply With Quote
Old 11-19-11, 05:23 PM   #25
***** chupacabra
1911's Avatar
Garage
It's easy, as long as you don't mind cutting your stock wiring harness. Follow the instructions very carefully (making absolutely positive you are cutting the right wire) and you will be fine.
'80 FJ40, '86 FJ60, '07 FJC
N5MUD
4x4ham.com
High Desert Cruisers
"What is life? It is the flash of a firefly in the night. It is the breath of a buffalo in the wintertime. It is the little shadow which runs across the grass and loses itself in the sunset."
- Crowfoot, Blackfoot warrior and orator
1911 is offline   Reply With Quote
Old 11-19-11, 07:42 PM   #26
Pehea 'oe?
monniepoo's Avatar
Mine was made in 06 I got it in August of 06.
Old 11-20-11, 05:57 AM   #27
***** chupacabra
1911's Avatar
Garage
You will need to do the hack for sure.
N5MUD
4x4ham.com
Old 02-02-12, 05:33 PM   #28
LCCRUISER's Avatar
I love my A-Trac. It's better then a posi. I leave it on all the time and then only engage the rear locker when needed.
Trucks with front lockers experience a higher incidence of CV failure. That also holds true if you move up to 35's w/o a front locker.
'08 FJ Cruiser Sun Fusion w/Locker, A-Trac, MetalTech Tube Winch Bumper, Full Ricochet SkidPlating, All-Pro OffRoad Rock Rails, BFG 10.5X16X33 KM2's, Front Downey 3" Coilovers, Rear OME Medium Coils & Bilstein Shocks. T-Max 12.5K Winch.
Tan '78 FJ40 w/Black Diamond 3" Lift, Mini Truck PS, T-Max Winch & Super Swamper 34X10.50 LTB's, LockRite locker and more to come.
Smurf Blue '78 FJ40 (The Swiss Miss due to rust holes).'94 FJ80 Runs Great - $2250. Parting out a '72 FJ40. Built '87 YJ.
LCCRUISER is offline   Reply With Quote
Old 02-02-12, 06:01 PM   #29
***** chupacabra
1911's Avatar
Garage
Particularly if you're too happy with the skinny pedal.
But if you're careful, and don't try to replace good wheeling technique with the locker and skinny pedal usage, you're not any more likely to break the CV's. I'm still running the factory original CV's on mine, with an ARB locker, 34" tires and 130,000 miles on it (and a heavy dose of wheeling too).
N5MUD
4x4ham.com
Old 02-04-12, 04:53 PM   #30
LCCRUISER's Avatar
You sound like you share my wheeling philosophy, so maybe I should make the mods after all.
I was discouraged from doing it because one of our local club members went to 35's, 4.88's, lockers and the "unbreakable" CV's that he still broke regularly. He had the 6" RC lift and the All-Pro UCA's. His nickname on Mud is KrazyFJ, so maybe that is why? I remember following him with my 40 one day and backing away after watching him hammer it up over a steep and abrupt ledge.
Another club guy went to 35's after wheeling his first model year FJC safely for years and blew a CV within a few weeks. He also just had to replace the wheel bearing on that same side 6 months later.
Both guys mentioned above have 6 speeds with the full time case. The FT case undoubtedly adds more wear to the front end over time. The more direct coupling of a manual tranny will also add more abrupt torque peaks to the drivetrain than an auto.
Is yours automatic?
Old 02-04-12, 05:30 PM   #31
ONSC TLCA Delegate
Mtbcoach's Avatar
Garage
I'll add to Lee's idea...I never broke a CV, ran 35's, 4.88's and an ARB front locker. I watched people do it with 285's and no locker just because they had their front tire "pinched" and hammered the gas.
I got an email from the current owner of my old FJC, pics included a blown RCV CV and toasted Inchworm that I had upgraded with Marlin CroMo, oversized input & output shafts. Just proving that anything can be broken if one tries hard enough...
'77 FJ45
Old 02-05-12, 06:16 AM   #32
***** chupacabra
1911's Avatar
Garage
Yep, that is pretty much the guaranteed way to break rear diffs, never mind front cv joints.
Is yours automatic?
Yes. I also have an Inchworm Lefty 4.7:1 transfer case which allows much more control and less abrupt surges in power.
Absolutely! Sounds like we all know off-road FJC drivers like that. I don't get it, but some guys think it's macho to break stuff and proves what a great wheeler they are.
N5MUD
4x4ham.com
Old 02-06-12, 08:33 AM   #33
As they said if you are careful with the application things can hold up well. To much throttle while on an incline caused me to bust the 4lo gear set in my lefty, CVs were fine, but not so much with the lefty.
Going from a situation where binded to momentarily having the drivetran break free (with enough throttle) to it immediatley binding again a second later cause enough of a load to shear off a few teeth.
My mistake not the transfercases.
FJNewb is offline   Reply With Quote
Old 02-08-12, 12:29 AM   #34
Layonnn's Avatar
I think the change was a few months earlier than that.
I had an June2007 built 2007 model year and A-trac and the rear locker worked together without having to do any hacks.
Make sense?...
2001 UZJ100
1997 FZJ-80
- sold
2007 SC'ed FJ Cruiser - sold
-Layton
TLCA# 20623
Layonnn is offline   Reply With Quote
Old 02-08-12, 03:14 PM   #35
LCCRUISER's Avatar
That 4.7 also multiplies the torque substantially, so you definitely are what I call a "smooth wheeler".
Old 02-08-12, 04:54 PM
Sponsored Link
advertisement
Old 02-08-12, 04:54 PM   #36
***** chupacabra
1911's Avatar
Garage
I'm pretty old, and got my fill of "fast" and "hurry" on motorcycles when I was a much younger man, so I'm all about smooth and slow now. I'm usually the tail gunner in any trail group I'm in because no one else wants to go as slow as I do.
N5MUD
4x4ham.com
Trackbacks are Off
Pingbacks are Off
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
