Old 10-12-09, 09:33 AM   #1 (permalink)
Rookie
Wider wheel base and top heavy theory
ok so everyone knows that a 6 in lift makes the fjc more top heavy... but here is my theory and let me know what you think. here is the situation, you have a 6" lift with your wheel base widened by 2 in each tire. should it not feel (weight ratio) as if you were only on a 4" lift instead of a 6" lift. it might sound confusing cause im not a mathmagician or anything but it makes sense in my head
brise27 is offline   Reply With Quote
Old 10-12-09, 09:59 AM   #2 (permalink)
jmylie's Avatar
The center of gravity would not change with the increase in width.
However, the wider wheelbase would improve stability and make it feel less tippy than the standard width.
I'm sure some engineer will post the calculations.
Joe
TLCA # 6363
Yankee Toys
Gotham City Land Cruisers
Connecticut Open Access Land Trust
Northeast Association 4 Wheel Drive Clubs
Tread Lightly - Tread Trainer
National Off-Highway Conservation Council
1977 FJ55 - for fun (x2)
1979 FJ40 - the wife's
1986 HJ60 - my dd
2007 FJC - my second dd?
jmylie is offline   Reply With Quote
Old 10-15-09, 07:18 AM   #3 (permalink)
ONSC TLCA Delegate
Mtbcoach's Avatar
TLCA# 17784
If you want a 6" lift, just put one on. Just know that it won't do anything more for you than appearance...
Jerry - Olde North State Cruisers TLCA Delegate
'07 GJS15 well enhanced
'97 FZJ80 40th OME J
'71 FJ40 stock
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline   Reply With Quote
Old 10-15-09, 07:56 PM   #4 (permalink)
HJ-45CrewCab's Avatar
TLCA# 10465
and make you more proficient in changing cv axles.
1980 HJ-45 Mining Conversion
1995 4Runner
2007 FJC
2005 BMW F650GS Dakar
1968 M105 trailer
HJ-45CrewCab is offline   Reply With Quote
Old 10-16-09, 08:46 PM   #5 (permalink)
joebob2586's Avatar
The 6in lift wont even offer more ground clearence because you still have the drop down bracket, they FJ is wide enough anyways pushing out the wheels and tires will only make it more difficult to squeeze it through trails.
2007 Silver FJ, 75WXST Cobra Compact CB Radio, 3ft Firestick with Bandi Mount, Bushwacker flares, Aero Turbine Exhaust, and JBA Headers, Custom Tube Bumper with 9.0 epi Superwinch and two 7in HIDs, 285/70/17 Good Year MT/R.
joebob2586 is offline   Reply With Quote
Old 10-23-09, 12:31 PM   #6 (permalink)
Brock's Avatar
TLCA# 18493
yep.....3" lift is optimal for the FJ Cruiser in my opinion no matter the terrain or obstacles with 33 or 35 tires...players choice.
Brock is online now   Reply With Quote
Old 10-23-09, 10:25 PM   #7 (permalink)
TLCA# 17121
The general rule is from what I remember is for every 1" up go .25" out.......
So in theory a 6" lift requires 1.5" wider stance.......
I have never put this to the test, but I do know my 3" lift and 35" tires with a 1.5" spacers at each corner seems to handle pretty well with no more of a roll rate then a stock truck.
One last note on this is that the theory is designed for OEM equipment to be installed...... once you add bumpers and other items all things change.
James
'07 Titanium FJ
#00001778
3" ToyTec OME H/D Lift
315/75R16 Mickey T's MTZ's
IPOR F/R Bumpers & Silde Protection
IPOR Custom Rear Lower Control Arms
BudBuilt Skids
Lots of Trail Markings!!!!!
07TEQ is offline   Reply With Quote
Old 10-27-09, 11:19 AM   #8 (permalink)
woooody's Avatar
TLCA# 7704
My feeling is that 3" lift seems to work best. If you want to run 35's, do a SAC (Solid Axle Conversion). the 6" lift seems to cause a lot of problems.
The 3" lifted FJCs have run Rubicon just fine, albeit with a bit of rock stacking.
Ross Woody
TLCA Secretary - Member #7704
72 FJ40 - ORION #342 ROTW 10/6/08
07 TRD FJC
woooody is offline   Reply With Quote
Old 11-05-09, 07:58 PM   #9 (permalink)
Krazyfj's Avatar
TLCA# 18300
You definitely absolutely positively have more clearance with the 6" lift under the body, Yes the drop bracket is the same clearance as the 3" lift (actually it's a bit more) in the front but past that there is much more clearance.
Now some people will argue this till they are blue in the face and maybe they are right, I have had both 3" and 6" on my rig, done the same trails with both and definitely clear more obstacles without scraping, banging or stopping because of clearance with the 6" lift. By properly placing the tires on the obstacle to keep the drop bracket from hitting you have a much better chance of clearing the obstacle under the body with the extra 3" under the body.
Personally I have found that I can go places that an FJC with a 3" cannot, Yes they can possibly change the line and make it but I have found that the 6" lift makes clearing rocks, ledges etc. easier on you and your rig.
However,
You will find yourself breaking more cv axles and bending more tierods, Now I do not know if this is because the 6" lift puts more stress on it's parts or that I am just trying harder lines, bigger rocks and taller ledges or that maybe I am nuts and just imagining it.
With 1.5" spacers and 6" lift I have buried the inclometer well past the line and the only issue was unclenching my butt,
Good luck
74 fj40 35's, detroits.
2007 FJ cruiser
6" RC lift, 35" Maxxis Trepadors
TLCA#18300
eastern4wheelers VP
Yankee Toys
northeast toyota crawlers
FJ northeasters
Krazyfj is offline   Reply With Quote
Old 11-08-09, 07:22 PM   #10 (permalink)
ONSC TLCA Delegate
Mtbcoach's Avatar
TLCA# 17784
I beg to differ.
The rigs I've seen with the drop diff brackets create less than 11" of unprotected (as in no skid plate) clearance where my rig has 14" at the front bend of the Budbuilt skid plates...
'71 FJ40 stock
