View Poll Results: Have you had Issues Lossing Beads with FJC Steel Wheels?
Nope, Never lost one
2 |
66.67% |
I have Seen others, or lost a bead myself
1 |
33.33% |
Yes, They Loose Beads all the time.
0 |
0% |
05-14-09, 04:16 PM
Supporting Vendor
FJC Stock Steel Wheel - Bead Loss Issue
Just Curious How you guys have been doing with loosing beads on stock 17" FJC Steelies.
I have now lost a bead on Each Corner of my truck with mine, and im wondering if its an issue with the wheel in general, or just me
Please dont vote unless you have personal experience with this, or post links to relevant links on the net.
This is Only For those who Air Down (Under 15PSI or so). Please List Tire Size and PSI of your Issues..
05-14-09, 05:18 PM
IH8MUD Chupacabra
I have never lost a bead on mine. I've got dents in the rims, but never lost a bead. Currently I'm on my third set of tires, Toyo Open Country MT in 285/75/17. I air down to 11-12 psi on the trail.
'80 FJ40, '07 FJC
N5MUD
High Desert Cruisers
"What is life? It is the flash of a firefly in the night. It is the breath of a buffalo in the wintertime. It is the little shadow which runs across the grass and loses itself in the sunset."
- Crowfoot, Blackfoot warrior and orator
05-14-09, 06:14 PM
Admin
2 years on the Trail Teams, never once lost a bead....also stayed in the 18psi range tho....also, alum rims tho...
never had an issue with any of the rigs we wheeled with tho....and that's a bunch
Brian 'woody' Swearingen
Owner, IH8MUD.com
Owner, ROCKCRAWLER.com
- 1974 FJ40 'The Raisin' - 39" Pitbull Maddogs, 17x9 TrailReadys, 30-spline Longfields, SOA - 1/4 ellip, Ultimate Air, MobiArc, Optima RedTop
- 1996 FZJ80 'Gretchen' - MetalTech sliders, MetalTech tube front, MileMarker V10 MiFi, OME lift, IPOR rear & skid, 4x4Labs swings, INTI rack, dual Optima RedTops, 285 TreadWright tires, Ultimate Air, Raingler Barrier
- 2009 buggy....designing... RockCrusher60's
- 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Hankook DynaPro ATM, KYB MonoMax, 4" exhaust
- 2008 32' ABU Gooseneck car hauler, 2000 Damon Hornet M-32F, 1997 14' car hauler
Forum Questions? Click Here! .. .. .. .. 2009 IH8MUD Wheelin Schedule!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
'Everyone wants to save the porpoises, but no one cares about the tuna'
05-14-09, 07:05 PM
Is this what you are experiencing?
Recall ID # 06V235000 - TIRES:BEAD - Hide Details
Recall Date: JUN 26, 2006
Component: TIRES:BEAD
Model Affected: FJ CRUISER
Potential Units Affected: 9434
Recall Date:
JUN 26, 2006
Model Affected:
2007 TOYOTA FJ CRUISER
Summary:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH EITHER BRIDGESTONE DUELER OR DUNLOP GRANDTREK TIRES, THERE IS A POSSIBILITY THAT THE INNER BEAD OF THE TIRE MAY HAVE BEEN DAMAGED. IF THE BEAD IS DAMAGED, A BULGE MAY DEVELOP ON THE SIDEWALL OF THE TIRE AND AIR MAY LEAK FROM THE AREA OF THE DAMAGED BEAD.
Consequence:
IF THE TIRE LOSES AIR PRESSURE IT MAY LEAD TO A LOSS OF VEHICLE CONTROL AND INCREASE THE POSSIBILITY OF A CRASH.
Remedy:
DEALERS WILL INSPECT ALL FIVE TIRES, INCLUDING THE SPARE TIRE, TO DETERMINE IF THEY ARE WITHIN THE AFFECTED TIRE-TO-WHEEL ASSEMBLY RANGE AND REPLACE ALL INVOLVED TIRES WITH NEW TIRES FREE OF CHARGE. THE RECALL BEGAN ON JULY 5, 2006. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331. NOTE: DUE TO AN ERROR IN THE DOT SERIAL NUMBER SECTION OF THE TECHNICAL INSTRUCTIONS, A NUMBER OF VEHICLES WERE NOT INSPECTED CORRECTLY. TOYOTA RELAUNCHED THIS CAMPAIGN IN MID-AUGUST 2006.
9434
Notes:
TOYOTA MOTOR NORTH AMERICA, INC. 6AD
10/71 FJ40,33s, HEI, 4WDB, PS
2000 UZJ100 Stock
2007 FJ Cruiser
__________________________
05-14-09, 09:32 PM
Supporting Vendor
No..
Im Running 37's and Airing down to about 8-10 PSI. I have read one other instance where a guy was having issues losing beads on his FJC Steelies with some 34" Swampers.. so im just gathering a little data. and making a decision to either Add Beadlocks to these wheels, or Ditch them for a different set. id hate to add beadlocks to the outer lip, just to have issues losing the inner bead..
one other thing i noticed is that the paint Toyota used sucks, after a year of sitting outside the wheels are faded pretty bad
i guess its going to be hard to find others who are running big meats on these wheels, but let me know if you are running any larger Bias Ply Tires and having issues..
05-15-09, 09:40 PM
I have never lost a bead on mine (1 year running the Steel Wheels).
'07 FJ Cruiser, 6MT, Voodoo Blue, Sway-A-Way Coil-over lift, aFe CAI Pro Guard-7, KC Daylighters, All-Pro Mods: Front Bumper, Sliders, complete skid package.
05-16-09, 09:52 PM
If you're running 37's....you ain't running an FJ.......
Other then that....8lbs is pushing the limit of the bead regardless of what you're running.....
I run at 14 lbs rock crawlin' in Az. and only lost a bead once.....under water/on rocks/spinnin' a wheel.....a quick ratchet strap and the power tank and I was on my way....
Sorry but I don't think the rims are the issue unless you have a set off a very early build FJ....and those were recalled as per previous post....
05-19-09, 04:46 PM
Supporting Vendor
thx for the info
