Old 05-13-09, 01:39 PM   #1 (permalink)
el_diabolico's Avatar
loss of power
Hey guys, hope you can help.
07 FJ. 4x4 M/T 34k miles
Recently (at around 28k miles)I began to notice a slight hesitation at 1st and 2nd gear, as well as decreased gas mileage (from 20+ to 18mpg), along with an apparent loss of power (sluggish feel). As I was close to 30k miles, I replaced the spark plugs (as well as changing all filters religiously).
This seemed to improve things, but now (34k miles) she's getting sluggish as hell, and I'm down to about 16mpg.
No codes are showing, so I'm a bit lost here. Any ideas?
Thank you.
10/71 FJ40,33s, HEI, 4WDB, PS
2000 UZJ100 Stock
2007 FJ Cruiser
__________________________
el_diabolico is offline   Reply With Quote
Old 05-13-09, 02:31 PM   #2 (permalink)
toy4xfun's Avatar
it is a shot in the dark but check your exahust system not only the cat but all your pipes too
toy4xfun is offline   Reply With Quote
Old 05-13-09, 11:13 PM   #3 (permalink)
Try cleaning your MAF sensor. I had about the same thing at 50k miles and now I clean it all the time. Use MAF cleaner and be careful not to damage the sensor.
-Brian-
2007 SC TRD - AKA "The Black Lemon"
Every Warranty Voiding Option Available - SE Model with Custom Fender Bulging and X-Large Cracking
amaintaylor is offline   Reply With Quote
Old 05-14-09, 05:11 AM   #4 (permalink)
TLCA# 19012
+1 on the MAF sensor suggestion.
Cthulhu: 08 FJC 5AT, OME 885/895 & N140s/N141's, All-Pro f. bumper, Smitty XRC8, Trailgear sliders, All-Pro skids, TRD CAI, aFe ex., Safari Snorkel, SCUBA mod, pizza cutter BFG KM2's, MPAC side rack, & more!
Member TLCA #19012 - GCLC - FJ Bruisers - FJ Northeasters
FJCthulhu is offline   Reply With Quote
Old 05-14-09, 07:06 PM   #5 (permalink)
Cleaned out the MAF today, tomorrow shall see if it made a difference. Thank you!
2000 UZJ100 Stock
2007 FJ Cruiser
Old 05-15-09, 04:18 AM   #6 (permalink)
There's two sensors on the MAP unit, the match looking device is the air temp sensor, the MAF is actually buried in there and is more difficult to see. It's the two wires inside that you have to clean. The only reason I mention it is because some folks clean the air temp sensor only thinking it is the MAF sensor.
DEWFPO
2007 Sun Fusion, FJ Cruiser, 5AT
DEWFPO is offline   Reply With Quote
Old 05-15-09, 07:10 AM   #7 (permalink)
Cool. I followed lgrt's write up. I'll post back after I test it today. Thank you.
2000 UZJ100 Stock
2007 FJ Cruiser
Old 05-15-09, 03:40 PM   #8 (permalink)
fmj308's Avatar
TLCA# 19278
The last time this happened to me ( but not on my FJC) it was because my injector nozzles were beginning to get clogged. The FJC is designed to perform best with high octane fuel. If you run regular all the time without an occasional hi-test fill up or the regular use of fuel injector cleaner, this could possibly be your problem also. Just my two cents worth.
Uh-oh, the pigs are flyin'...
fmj308 is offline   Reply With Quote
Old 05-17-09, 08:33 PM   #9 (permalink)
TLCA# 17671
I don't suppose you have recently added new steel bumpers, a lift, rear storage, winch, bigger tires and armor underneath. Added weight = sluggishness. Just figured I would toss that out there... Sometimes the simple answer is overlooked. Best of luck!
Silence is golden... duct tape is silver.
'07 FJC
ToyTec 3" from PhilC64
Firestone Dest. M/T's
Assorted other little stuff...
GoISU is offline   Reply With Quote
Old 05-18-09, 07:02 PM   #10 (permalink)
OK,
I cleaned out the injectors and this seemed to make a helluva difference, more so than cleaning the MAF. No recent add-ons etc. I'll keep an eye on it and post anything relevant. Thank you!
2000 UZJ100 Stock
2007 FJ Cruiser
Old 05-18-09, 11:10 PM   #11 (permalink)
fmj308's Avatar
TLCA# 19278
Glad I was of some help. I find that one can of injector cleaner per tankfull helps a lot.
