Old 02-19-09, 10:57 PM   #1 (permalink)
Why I think the ARB Roof Rack Sucks
I'm usually not one to complain, but I'm just irritated at my ARB roof rack.
1. The nice plate steel side rails with sexy roof line contour and FJ Cruiser knockouts also keep ice and snow from sliding out from under the rack. Nor can you use a broom handle to shove said ice out either side. The eventual abacus-like ice chunks that form around the lateral rails slide back and forth endlessly scratching the formerly perfect cygnus white roof and pissing the hell out of you.
2. At 40 MPH the front two lateral rails hum like a massive tuning fork rattling your patience AND drowning out Metallica at all but the highest settings, which begs the question: How would I ever hear it anyway?
3. The damn bolt holes leak soaking my A-Pillar lining and making the cab reek like a musty fart after any rain, or while the bowling ball size ice chunks slowly grinding grooves in the roof discharge melted cygnus spooge into the leaking orofices. But I blame Toyota for that. For heaven's sake, open bolt holes?
4. My wife refuses to believe the soggy headliner is causing the stench. #@#$%&* ARB.
pirateslair is offline   Reply With Quote
Old 02-21-09, 11:09 AM   #2 (permalink)
knoll0351's Avatar
TLCA# 17675
Mine came with a factory rack and when my ARB started leaking down the A pillar I took it to the dealer and they fixed it under warenty
My wife doesn't believe me either, but she was in it when I got high centered in water over the rear tail lights on Rubicon....guess mine may be more than just the roof rack.
I was pretty frustrated with ARB when doing the install, I had to use a make shift breaker bar to tighten the allen heads that came with the kit. Really shouldn't have been that tight! And I would agrea that it is a bit noisier than the stock rack...but I haven't noticed it that much....maybe try putting some sort of vibration dappener in between the roof and the mounting rails....
Good luck! I will say though that it is the sturdiest rack I've ever seen, and it does make a good level sleeping spot when wheelin'
Originally Posted by Brian in Oregon
"As an American I am not so shocked that Obama was given the Nobel Peace Prize without any accomplishments to his name, but that America gave him the White House based on the same credentials." - - Newt Gingrich
07 FJC Voodoo Blue - 3" Sway Away - 33" Toyo M/Ts - Custom Skids by Knoll - On Board Air - AllPro Front Bumper/Light Bar - ARB Full Length Roof Rack - Warn M8000/Wireless Remote
Wheel it or Park It!!
Jefferson State Cruisers
knoll0351 is offline   Reply With Quote
Old 02-23-09, 09:50 AM   #3 (permalink)
adso's Avatar
TLCA# 16713
No problem with mine.
Noisy, but you can't have all that metal stuck up in the air and expect it to be quiet.
If it's vibrating or humming, it's loose. That might explain the leak, too.
Lot's of people have had trouble with aftermarket racks, in general. Make sure everything is tight and use the crap out of silicone sealer.
"Dad, Napoleon called. He wants his complex back."
2007 FJ Cruiser "Napoleon" ARB bullbar/sliders/rack, Tabor winch, OME heavies front and mediums rear, BFG M/T 33s on ProComps
adso is offline   Reply With Quote
Old 02-25-09, 04:45 PM   #4 (permalink)
I just installed mine last night, I LOVE it and think it's built like a rock. I honestly don't notice any more wind noise than stock but I do notice a *little* more wind drag (although I did expect it).
I *will* say that the install was a bitch though. It wasn't hard to figure out, it was just frickin DIFFICULT to get the screws through the mounting system into the roof of the car. My silver allen wrench that came with the kit has blood on it from my thumbs, and I'm saying that with 100% honestly. I ended up using a wrench+allen wrench to get the tough ones in. I proceded to bury the whole mess in blue RTD silicone sealant.
...on a side note, did anyone have issues fitting the washers under the screws in the front bolt of each mounting arm? (the bolt on each side nearest the front of the car.) There wasn't anywhere near enough room.
UFCSam is offline   Reply With Quote
Old 02-25-09, 05:36 PM   #5 (permalink)
knoll0351's Avatar
TLCA# 17675
I have one of those interchangable screw driver things. That's what I used as a leaver, I just inserted the long end of the alen into the reciever end of the screwdriver. I thought I was going to break the allen wrench!
Old 02-26-09, 11:31 AM   #6 (permalink)
Lemony's Avatar
TLCA# 17958
A definate pain to install, got mine used and looking at the pile o parts I thought this will be done in 15... but the installing the bolts through the mesh was a pain and took lots of time ~ 2 hrs total. Makes lots of noise, I havent had to deal with the snow and ice. Its makes a good place to stand for parades and such but I need a ladder to make it easier for others to climb up and down.
2007 Fj Cruiser
TLCA 17958
CA4WDC 11103
Pacific Mountain Cruisers
Lemony is offline   Reply With Quote
Old 02-26-09, 05:23 PM   #7 (permalink)
knoll0351's Avatar
TLCA# 17675
I use the bumper, then the license plate cover then the spare tire.... Well actually I usually just use the rocker, but the other way is much easier.
Yeah, gotta say I don't think the new rack is much louder than stock...if any.
Old 02-26-09, 06:47 PM   #8 (permalink)
Installing the brackets/bolts through the mesh wasn't as bad as I thought it'd be. I had the worst time with the mounting rails to the roof connection. It *was* tricky through the mesh, but I think I was just extra determined because I wanted to be done (and my thumbs were raw from the Allen Wrenches.) I have heard a lot of people complaining about the wind noise; I don't notice much difference all. It's infinitely more useful than the stock rack, so it's worth it anyway.
Old 03-07-09, 11:37 PM   #9 (permalink)
bigjer's Avatar
As for the install it was a sob. the nuts on the underside of the roof fell off and I had to remove the head liner and I had to use lots of silicone. As for the wind noise, ARB makes an air-dam for the front of the rack andit seems to cut down the wind noise quite a bit- sells for about $90 to $100- and if you stretch a bungie lenth wise over and under the cross bars it cuts down on the hum of the bars. You would think that ARB would come up with better mounting brackets and if you park in a garage you dont have the ice problem
bigjer is offline   Reply With Quote
Old 04-28-09, 06:32 PM   #10 (permalink)
Rookie
I have removed two OEM roof racks and put on two ARB fit kits so far - I recommend starting with the middle holes - just get the bolts started and then move to the front and back. Use the rubber gaskets and add some silicone around the holes - specially between the nuts coming up from underneath and the roof of the FJ. I would expect leaks could come from those, if not sealed. As far as the ARB bolts being a sob to screw in - remove all the blue locktite and replace with new - or at least remove most of it, so you only have a couple of threads with locktite on. ARB put on a ton of locktite and that is what is causing the bolts to be too tight to get in with just a allan wrench. Once most of this is removed, the bolts go in easy. Then add some silicone around the top of the bolt.
When removing bolts from the roof rack - be sure not to press down on the bolts, once you get them started. Use a 30 torx screw driver and once the bolts turn, be careful to just rest the screw driver on the bolts - pressure at this point can push out the nuts underneath. So far I have removed and reattached FJ racks, and ARB fit kits about six or seven times without any problems.
Hope this help.
Bjorn
bjorno is offline   Reply With Quote
