12-26-08, 10:04 AM
#1 | | Forum Regular
| Cleaning your MAF Recently pulled apart my K&N CAI and reinstalled the stock cold air intake. While ripping and replacing I put together a write-up, video and pictures on how to clean your mass air flow (MAF) sensor.
Hope it helps.
__________________ lgrt
Mods: Check the Off Road Adventure Blog for my pictures, videos, and stories... and a few rants and raves. |
12-26-08, 10:16 AM
#2 | | Forum Regular
Join Date: May 2006 Location: Lethbridge, Alberta, Canada
| Very helpful information. Once the deep freeze of winter is over i'll be sure to get this done.
Cheers
__________________ TLCA member #18143
The Adventure Continues... 07 GSJ15 (FJC) 03 Echo |
12-26-08, 11:41 AM
#3 | | Forum Lifer
| Howdy! Good info. That MAF looks identical to the one in my daughter's 2000 Echo. It is p/n 22204-22010 or 22204-0d030. I cleaned hers, but it did not do any good. The car ran like crap until I got the MAF replaced. Considering that there are more than two wires going into the MAF, I figured there was more to it up inside the long snout. I am guessing it is either air temp or pressure. I was tempted to tear it apart, but it got tossed before I could break it open. John
__________________ 97 FZJ80, < 100M miles, rustfree S W native, white over gray leather, factory lockers, 315 MTRs with 4.88s, Slee/OME 5" lift, Slee sliders and rear bumper, ARB front with Warn M12000, dual batts, custom exhaust, Scangauge II, Sonoran SuperKooler System  (3FE fan & Blue Clutch w 24000 oil), Oh, and one of them Kazuma  Thingies on top
76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers,
85 Toyota mini truck: for chase/support! CSC #41 |
12-29-08, 10:10 AM
#4 | | Forum Regular
| Thanks for the info video.
__________________ TRD SE w/ Full BudBuilt Skids, All Pro Link & Shock Skids, Diff. Armor, 3" OMEs/ToyTec, Scuba Driver Breather mod., Maxxis MTs, Winch.
TLCA Member # 17635 |
01-13-09, 01:29 PM
#5 | | Forum Regular
Join Date: Sep 2007 Location: Just ahead of you handing you the strap
| I have a question... Isnt that electrical cleaner bad for rubber parts, and can the rubber "O" ring be removed before spraying?
Just a thought,
Bobby |
01-13-09, 08:00 PM
#6 | | Forum Regular
| Quote:
Originally Posted by HummerHater I have a question... Isnt that electrical cleaner bad for rubber parts, and can the rubber "O" ring be removed before spraying?
Just a thought,
Bobby | you may also want to put a thin layer of white grease on the O-ring to protect it and help it slide back into it's home.
| Thread Tools | | | | Display Modes | Linear Mode |
