Go Back   IH8MUD Forums > Toyota Tech Forums > FJ Cruiser
Old 09-06-08, 08:45 PM   #1 (permalink)
joebob2586's Avatar
Fluids
Alright Stupid question, im going to do an oil change in a couple days, i have already changed fluid in my front and rear diffs, but i want to do my transmission and xfer case, do they share the same drain port or do they have seperate ones, and where do they fill from. Thanks for the help...
2007 Silver FJ, 75WXST Cobra Compact CB Radio, 3ft Firestick with Bandi Mount, Bushwacker flares, Aero Turbine Exhaust, and JBA Headers, Custom Tube Bumper with 9.0 epi Superwinch and two 7in HIDs, 285/70/17 Good Year MT/R.
joebob2586 is offline   Reply With Quote
Old 09-07-08, 10:30 AM   #2 (permalink)
knoll0351's Avatar
TLCA# 17675
Check with dealer or tech manual to be sure but I've been told, and my research supports this, that there is no drain plug for the transmission. The FJC comes with a "lifetime fluid" and is not designed to be changed. in order to replace the fluid it must be done with one of those high speed low drag machines that hook up via the lines and replaces a portion (I've heard approximately one third) of the fluid at temp and presure. As for the T-case...no splash, no idea over.
07 FJC Voodoo Blue - 3" Sway Away - 33" Toyo M/Ts - Custom Skids by Knoll - On Board Air - AllPro Front Bumper/Light Bar - ARB Full Length Roof Rack - Warn M8000/Wireless Remote
Wheel it or Park It!!
Jefferson State Cruisers
knoll0351 is offline   Reply With Quote
Old 09-07-08, 02:29 PM   #3 (permalink)
TLCA# 17635
Knoll is right. Curious... Why would you want to change the transimission oil?
TRD SE w/ Full BudBuilt Skids, All Pro Link & Shock Skids, Diff. Armor, 3" OMEs/ToyTec, Scuba Driver Breather mod., Maxxis MTs, Winch.
TLCA Member # 17635
FJ LE is offline   Reply With Quote
Old 09-07-08, 03:46 PM   #4 (permalink)
AT or MT?
They are separate plugs in either case.
The AT has a special filling procedure and requires special ATF.
DEWFPO
2007 Sun Fusion, FJ Cruiser, 5AT
DEWFPO is offline   Reply With Quote
Old 09-07-08, 03:58 PM   #5 (permalink)
____-__-______
raydouble's Avatar
mmmmmmmmmm...............shitty picture but that is definitely a drain and fill plug
Edit: looks like it might be under the pan, but is still a drain plug.
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 4x4 all stock
Web Wheeler Wizard-Level 21
raydouble is offline   Reply With Quote
Old 09-07-08, 04:18 PM   #6 (permalink)
knoll0351's Avatar
TLCA# 17675
Originally Posted by raydouble View Post
mmmmmmmmmm...............****ty picture but that is definitely a drain and fill plug
Wow, now I'd recomend calling the dealer or other authorized service center prior to trying to use that "plug"...
Old 09-07-08, 04:22 PM   #7 (permalink)
____-__-______
raydouble's Avatar
Just saying
So what's the low down? You can't use it to drain fluid?
Is this false advertising?
Old 09-07-08, 05:08 PM   #8 (permalink)
knoll0351's Avatar
TLCA# 17675
From what my local dealer said it is a "lifetime fluid" so shouldn't need changing. That being said they also told me that they can "service it" which is what they do now adays with these new fangled trany's (not the dress up kind but the mechanical kind). Just a fancy way of saying changing the fluid, well at least about thirty percent of it, that way they can charge a fortune to hook it up to a special machine and charge us a fortune. The kicker is that there isn't a dip stick any more so there is no way to check the fluid level or fill it...and it needs to be filled at tempurature to avoid blowing out any gaskets or causing other damage...
Old 09-07-08, 05:13 PM   #9 (permalink)
It's not a lifetime fluid, it's got a 100K change recommendation from Toyota, 50K would be more prudent if you go off roading or tow.
Pulling the plug will drain some of the fluid out but not all. Most all who have it changed have the dealer change it.
DEWFPO
Old 09-07-08, 05:13 PM   #10 (permalink)
____-__-______
raydouble's Avatar
"Lifetime fluid" my ass, kinda like the parts jackass at the dealership that told me the fuel filter never needs replacing on a 22RE
Anyone have the FSM? The ad makes it sound like you can drain and fill to the plug level, wait, that's exactly what it says, anyone have the FSM and what it says?
Old 09-07-08, 05:24 PM   #11 (permalink)
knoll0351's Avatar
TLCA# 17675
Look man I don't work for Toyota, nor do I claim to be a service tech. I just know what they have passed to me and am trying to answer a question to the best of my knowledge. I have warenty thru 100,000 miles and if anything i've been told by my dealer results in failure I'll be damn sure to get it fixed without cost to me. If the FSM says different great but if my service writer told me otherwise I'm going with his word since it's his buck not mine.
Old 09-07-08, 05:33 PM   #12 (permalink)
____-__-______
raydouble's Avatar
Whoa whoa, I wasn't attacking you or anything, I'm saying someone has got to have the book, therefore the answer Toyota wants to give "techs"
Old 09-07-08, 05:48 PM   #13 (permalink)
____-__-______
raydouble's Avatar
Here it is
A750E Pages 148-150
http://www.ncttora.com/fsm/FJ/RM/RM0...0Transaxle.pdf
A750F Pages 157-159
Save some money everyone
Old 09-07-08, 06:37 PM   #14 (permalink)
____-__-______
raydouble's Avatar
Here is the FJC FSM link should be able to find all the info you need.
2007 Toyota FJ FSM and Wiring Diagram
Old 09-07-08, 08:21 PM   #15 (permalink)
knoll0351's Avatar
TLCA# 17675
I think that's all just electrical, but if anyone does have the whole FSM that would be sweet!!!!!! I'd even pay for that, just not the five bills the dealer wants.
Old 09-07-08, 08:27 PM   #16 (permalink)
joebob2586's Avatar
thanks for the info ill look into it at our local toyota performance shop, I just thought it would be a quick job like the diffs were.
Old 09-07-08, 08:30 PM   #17 (permalink)
____-__-______
raydouble's Avatar
It's the full FSM + electrical
list of contents:
A750E Automatic Transaxle A750F Automatic Transaxle
Air Conditioning
Audio Visual
Axle
Brake Control
Brake
CAN Communication
Charging
Clutch
Cooling
Cruise Control
Differential
Door Lock
Drive Shaft
Emission Control
Engine Control
Engine Hood Door
Engine Mechanical
Exhaust
Exterior
Fuel
Horn
Ignition
Instrument Panel
Intake
Interior
Introduction
Lighting
Lubrication
Maintenance
Meter
Mirror
Multiplex Communication
Park Assist
Parking Brake
Power Steering
Preparation
Propeller Shaft
Power Steering
RA61 Manual Transaxle
Seat Belt
Seat
Service Specifications
Old 09-08-08, 11:55 AM   #18 (permalink)
mbisson's Avatar
ray,
Thank you very much for the link. I have it saved already.
'07 Titanium metalic
Expidition One BullBar front bumper
All Pro Sliders, Bud Built Skids
285x70x17 MT/R
Aisle 3.......G-4 Club
TLCA #16716
mbisson is offline   Reply With Quote
Old 09-15-08, 03:16 PM   #19 (permalink)
TLCA# 17556
I think you are all talking about the Auto.... What about the Manual? Isn't that a whole other story?
The manual I thought was supposed to be flushed every 30K for heavy use (like off-roading) or at least that's what I got from reading the service records booklet.
I once had a lifted '87 Toyota pickup 4x4 22R 5-speed, etc.
I latter had a '97 Tacoma X-cab V6 5-speed with all kinds of cool stuff on it.
I now have a '07 FJC TRD SE 6-speed completely stock, but still has some cool stuff on it.
Spaldam.com
spaldam is offline   Reply With Quote
Old 09-15-08, 05:36 PM   #20 (permalink)
joebob2586's Avatar
I did forget to mention I have a MT does this change anything?
Old 09-15-08, 05:42 PM   #21 (permalink)
knoll0351's Avatar
TLCA# 17675
Yup that kinda changes everything...
Old 09-15-08, 05:46 PM   #22 (permalink)
____-__-______
raydouble's Avatar
Makes it a lot easier to change oil
Old 09-15-08, 06:12 PM   #23 (permalink)
joebob2586's Avatar
ok so since it makes it a lot easier where is the drain plug and the fill spot, and does it fill and drain the xfer case as well or is it seperate?
Old 09-15-08, 06:57 PM   #24 (permalink)
____-__-______
raydouble's Avatar
Page 16 the two plugs with gaskets looks like drivers side.
The Transfer will have it's own drain and fill plug I'm sure, didn't find a picture. It should be easy once you get under there, it's no more complicated then the diffs.
Old 09-15-08, 10:24 PM   #25 (permalink)
joebob2586's Avatar
thanks for the info
Old 09-15-08, 10:27 PM   #26 (permalink)
____-__-______
raydouble's Avatar
thanks for the info
No problem, check the owners manual for the fluid type and amount I don't know off hand.
Old 11-05-08, 03:30 PM   #27 (permalink)
To drain your tranny all the way, it would take a machine (dealer). But you can drain most of it. I've done it once with the pages from the repair manual in front of me.
There is a typical drain plug (bolt)on the driver's side of the pan, and the other is a flat hex key design. This is the overflow.
Drain the tranny. I let mine drain overnight. Replace the plug and fill with fluid.The filler hole bolt is a 19mm on the passenger side about half way up. Start the vehicle and cycle through the gears slowly ( about 10 sec, each), then with vehicle running, remove the overflow plug. Fluid should just trickle out. If it doesn't, replace the overflow. Stop vehicle and add about 2 cups of fluid. Repeat as above until it trickles out. Check level after 500 miles.
Fun huh?
Cruzrman is offline   Reply With Quote
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
