Go Back   IH8MUD™ Forums > Toyota Tech Forums > FJ Cruiser
Old 03-24-08, 05:06 PM   #1
Oil change on FJ
Should I change the oil filter every oil change or every two oil changes?
Where is a good place to get cheap car related things online? I know I could go to a store but if buying online is cheaper, then I'm going to do just that. I'm thinking of replacing the differential fluid on the FJ as well. How do I check the differential fluid with out changing it?
Though I was wondering, for changing the oil filter, I noticed that the oil filter is upright and there is a groove with a hole in it surrounding the oil filter. How am I suppose to approach this with out getting the area all covered in gunk?
I can't remember, do I need a gasket for the Oil filter or does it come with one? I haven't done an oil change in about a year and it was on a different car.
'07 FJC, '91 FJ80
imzjustplayin is offline   Reply With Quote
Old 03-24-08, 06:18 PM   #2
joebob2586's Avatar
i personally change the oil filter every time i do the oil, and as for price i normally just go to kragen or auto zone, oil filters are cheap, it has a gasket on it, you dont buy them seperately. As for the diff fluid how many miles are on your FJ? Since the filter is upright when the car is off there should be no oil in it, so there really wont be any mess. Hope this helps.
2007 Silver FJ, Stallion Customs Tail Light Guards, 75WXST Cobra Compact CB Radio, 3ft Firestick with Bandi Mount.
joebob2586 is offline   Reply With Quote
Old 03-24-08, 06:18 PM   #3
Brock's Avatar
TLCA# 18493
you may want to take it to get done the first time and watch them as it sounds as if you dont have much experience servicing your own fluids....
but to answer most your questions: I recommend changing filter every time you change oil...after all that is where the dirt and metal shavings are collected. Some may change filter and not change oil every two times....but I am not a proponent of that.
depends on what you mean by cheap...price wise or quality. I would not go too cheap as not all filters are created equally.....personally i spend a little more on oil and filters and other fluids as they are life blood of your vehicle...to each his own though. Mine will be running amsoil fluids and filters after first year and my free changes are over at dealer.
As for FJ oil filter change....with engine off and letting it sit a bit I am guessing the oil drains down mostly from filter.....if you unscrew it and then flip it over quickly it should not spill much as anything that wanted to come out would have gone down drain hole by then....easy clean up and caught mostly in catch tray around filter.
Oil filters cme with rubber gaskets...take clean oil and fill filter most of way up....take finger and stick in clean oil...wipe finger on rubber gasket...install filter. Now that is for regular setup...I have not changed my FJ yet so would read manual or ask your toyota or a member that has done it to see if filling oil filter is required with it at that angle.....
I would take it to shop the first time or two if you and watch them and ask questions......costly mistake to put wrong filter or to do something wrong when it affects your engine so permanently.
I have a high art, I hurt with cruelty those who would damage me. - Archilochus, 650 B.C.
08 FJ Cruiser aka "Brick House", Nitto TG 295x70x17, BudBuilt Rock Sliders
84 FJ60, Blue, BFG, 2.5inch; lift, Warn hubs, etc
Lowcountry AMSOIL Products
Brock is offline   Reply With Quote
Old 03-24-08, 06:25 PM   #4
Niner's Avatar
TLCA# 13372
Get a mountain dew 20 oz. Drink it.
remove cap on bottom of drain hole.
place bottle over drain nipple.
remove oil filter.
wipe a small amount of oil on provided rubber gasket on new oil filter.
clean up oil in filter mount area with clean towel.
install oil filter, hand tight.
remove oil plug with drain pan under the area.
Drain oil in pan.
replace oil plug.
fill with 5.5 quarts of oil.
recycle oil.
I always use a genuine toyota filter. due to a problem years ago with GM products and a rattle when starting that doesn't happen with a factory AC delco filter. I know it isn't a GM but I don't want to chance it for a few pennies.
Chris Hannis, TLCA #13372
2008 FJ Cruiser, Bud Built 5, Warn Bull Bar, 9.5TI, OME Heavies all around.
1971 FJ 40, 400 SBC, th400, Dana 20 Tcase, F/R Dana 44's, Front 4 link, rear spring over
1993 4 Runner (the Girlfriends) Stock for sale.
A bunch of stuff thats for sale
Niner is offline   Reply With Quote
Old 03-24-08, 06:29 PM   #5
Brock's Avatar
TLCA# 18493
there you go...someone that has done it on the FJ...mine has less than 500 miles still so not got there. LOL Cant be anything like changing fuel filter and removing water from my Cummins Turbo Diesel though...LOL
Old 03-24-08, 07:18 PM   #6
TLCA# 18830
Hey Man, don't bet on there not being oil in that filter! The hole is a drain hole - you can get a piece of plastic hose at the hardware store that will fit on the small tube below the hole. (remove the rubber cap) and let the oil from the filter drain into the oil change pan you used to drain the crankcase. I screwed two 3/8" nuts on the bottom of my hose to weight it down so the wind won't blow it around. Works like a charm.
Woodeye
Woodeye is offline   Reply With Quote
Old 03-24-08, 07:55 PM   #7
Is the TRD oil filter worth the cost for daily driving and light off roading?
Blake
Gizmos_fj is offline   Reply With Quote
Old 03-24-08, 08:34 PM   #8
Niner's Avatar
TLCA# 13372
Blake
That YRD is a air filter not an oil filter.
And I don't feel a reusable filter does a good enough job cleaning the air.
Old 03-24-08, 08:38 PM   #9
FJ40 MNTCRZR's Avatar
TLCA# 16256
Buy a TOYOTA oil filter, from what i understand they are the only filters that have a bleed back value on them, meaning the oil does'nt drain out of them when the motor is turned off.
Yes change the filter EVERY time you change the oil.
Ihave changed my oil, and they info about the drain tube is right on the mark ...
Good luck ...
" IF I HAD TO EXPLAIN,YOU WOULDN'T UNDERSTAND "
2008 Sandstorm FJC
FJ40
LEXUS
HARLEY
THE GOOD LIFE !
FJ40 MNTCRZR is offline   Reply With Quote
Old 03-24-08, 11:48 PM   #10
Woodeye
Yeah I wasn't sure how to get the rubber cap off nor did I know what it'd look like after I removed the cap. Do I unscrew it or do I have to peel it off? I tried to remove it but it was a no go.
'07 FJC, '91 FJ80
Old 03-25-08, 12:36 AM   #11
gon2srf's Avatar
TLCA# 16768
Pull harder. It is not threaded and it will come off by hand.
Scott/Gon2srf
gon2srf is offline   Reply With Quote
Old 03-25-08, 05:43 AM   #12
Brock's Avatar
TLCA# 18493
sometimes you just gotta go with it.....and learn as you proceed. dont park in driveway though in case you spill a lot of it.....LOL
Old 03-25-08, 10:37 AM   #13
TRD oil filters are available for the FJ. The size of the filter is actually quit a bit larger than the stock OE filter.
When changing the oil, BE SURE that you remove the Oval plastic cover that HIDES the oil pan drain bolt. DO NOT accidentally drain the ATF as some have done. The ATF pan is the black pan with the 2 silver plugs sticking out of the bottom. The engine oil pan is ABOVE the skid plate and the plastic Oval cover needs to be removed to access the oil pan drain plug.
Be sure to re-install or replace the drain plug gasket, don't double up on it.
DEWFPO
2007 Sun Fusion, FJ Cruiser, 5AT
DEWFPO is offline   Reply With Quote
Old 03-25-08, 06:35 PM   #14
TLCA# 18830
Brock,
Do yourself another favor! when you re start the engine the first time after an oil change, the filter is empty. So, when you turn the key to start her up, just crank the motor a few turns but don't actually start the engine. Let off the key and do it again 3 or 4 times more. This will fill the oil filter and everything else needed and will save the few seconds on dry start on your engine.
Hate that bearing and valve lifter rattle. Have fun!
Woodeye
Old 03-25-08, 06:39 PM   #15
Brock's Avatar
TLCA# 18493
thanks buddy.....I was going to see how much I could get into filter and then install without it all draining all over LOL
Old 03-25-08, 11:32 PM   #16
You'll be able to get a fair amount of oil in the filter before installing it. Just put a few ounces at a time in since the filter media will need to soak it up, but don't get overzealous otherwise you'll have a mess on your hands. I always pre-soak/pre-fill my filters before installing them.
DEWFPO
Old 03-28-08, 08:28 AM   #17
NYCTRD's Avatar
DEWFPO
You mean some people STILL have the oval cover?
Mine fell off in the dealers parking lot as I tore out and over the median strip!!
07 TRD-All options.
Dest. MT on Pro Comp Rockcrawler steelies
Sirius-Scaguage-lot's o gear
Heavy duty brush/bumperguard-PIAA offroad lights
NYCTRD is offline   Reply With Quote
Old 03-28-08, 02:29 PM   #18
TLCA# 17556
On my second oil change I was looking for it, and then realized it was missing. I guess it just doesn't stay on very well after you take it off the first time.
I once had a lifted '87 Toyota pickup 4x4 22R 5-speed, etc.
I latter had a '97 Tacoma X-cab V6 5-speed with all kinds of cool stuff on it.
I now have a '07 FJC TRD SE 6-speed completely stock, but still has some cool stuff on it.
Spaldam.com
spaldam is offline   Reply With Quote
Old 04-02-08, 01:24 PM   #19
Noaccount Webwheeler
Degnol's Avatar
TLCA# 14529
The dealer was adamant about NOT changing oil the first time until 5,000 miles to seat the rings. At 5K, i switched to Mobil 1 and go 6K between changes but I change the filter every 3K. Very easy to do with it's location.
Good tip on the drain tube
Ed
There is nothing so depraved as a man in the depths of an ether binge
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Degnol is offline   Reply With Quote
Old 04-02-08, 11:11 PM   #20
Oil Change on FJ
My oval cover disappeared after the first oil change, likely buried in my entry road somewhere. I use the K&N oil filters, pricey but I like the wrench end. I also made the mistake of not putting a container under the oil filter drain hole the first time, Doh!
What oil treatment (Slick 50, etc.) are people using if any?
Scott
2007 TRD SE, Warn F/R bumpers w/powerplant HP, 3" OME Heavy Front/Medium Rear
Aphonopelma is offline   Reply With Quote
Old 04-09-08, 09:00 AM   #21
TLCA# 17556
I'm on using any trements. A good sythetic is really the best way to go.
I've used Slick 50 and Prolong in the past with no noticable differance. Slick 50 caused foam to form in the oil, so I figured it probably wasn't the best thing to use.
Spaldam.com
Old 04-14-08, 12:34 PM   #22
Niner's Avatar
TLCA# 13372
Slick 50 is a once every 50,000 mile treatment not every oil change. I don't think the foaming was an issue on the vehicles I've treated.
