Home ~ Technical Links ~ IH8MUD Forum ~ Photo Gallery ~ Product Reviews ~ Tech Trivia ~ IH8MUD Store ~ CruiserFAQ.com
IH8MUD.com Forum
Go Back   IH8MUD.com Forum > Toyota Tech Forums > FJ Cruiser
Old 03-22-08, 01:25 PM   #1
RACERX24 is on a distinguished road
Wiring roof rack light
I have a Gobi Stealth that I want to mount lights on..Can anyone tell me how they ran there wiring inot the cab or does anyone have any pictures of ho they did it..
Thank you
RACERX24 is offline   Reply With Quote
Old 03-22-08, 08:53 PM   #2
bernd122465's Avatar
bernd122465 is on a distinguished road
I have a Gobi pdf that shows how its done. PM me a email address and I can send it
bernd122465 is offline   Reply With Quote
Old 04-05-08, 08:49 PM   #3
kp66 is on a distinguished road
Did anyone of you have to drill a hole int he roof to get the wiring into the cab? i am puttin lights on the arb rack and was told at the dealership they drill a hole under the rack mount? and ideas ?
Current owner:07 FJ, 89 4 Runner
Past owner :81 Toy Sh.box,74 FJ40,91 Hilux Surf
kp66 is offline   Reply With Quote
Old 05-09-08, 08:14 AM   #4
willymack is on a distinguished road
Could you also send that PDF to me. I am installing an ARB next week. Thanks.
wmcabee@mbakercorp.com
willymack is offline   Reply With Quote
Old 05-12-08, 01:30 PM   #5
EyeCruzr is on a distinguished road
I really didn't want to drill a hole in the roof or run it down the exterior A pillar, so I ran the wiring backwards and down the rear. Wires entered the door jam conduit into the rear driver side cubby with the bottle jack.
I ran the power from my 2ndary batt through the firewall on the driver's side, along the door sill, then connected power to a Fuse block. several trigger wires were also installed at the same time.
Now I have all the relays and connections in the cubby and two switches to the left of the steering wheel controlling the rear fogs and the front drivers on my Gobi Stealth.
will look for picts and post.
T
EyeCruzr is offline   Reply With Quote
Old 05-13-08, 07:45 AM   #6
NoHandleBars is on a distinguished road
T
Possible for pics? If you get a chance that is. That seems SAFER, but not as clean as I'd want it to be...besides, when I add XM I'll have to drill a hole in the roof anyway, or run it down the front pillar....
NoHandleBars is online now   Reply With Quote
Old 05-13-08, 12:03 PM   #7
will look for them tonight and post.
as for XM, theres a good install build on fjforums for a no drill alternative.
As for Safer, clean, it's all relative. to me it's all good.
1. there's plenty of space for all the wiring and relays in back!
there's minimal room under the steering for everything.
2. no drilling needed and no risk of leaking in the roof
3. ability to add other things in back like extra 12V outlet, rear camera
4. already running wiring for CB antennae off the Bandi mount, so did everything at one time!
T
Old 05-13-08, 01:59 PM   #8
T
If you silcone the hole you drilled after you run the wires through and get them set, then you should be fine...can't see why it would leak unless someone did a poor job at silconeing or used a subpar sealer.
Old 05-13-08, 02:16 PM   #9
ok I just didn't want to drill.
T
Old 05-13-08, 02:20 PM   #10
Wiring Roof Lights from the back
ran power wire through driver side firewall
Ran wiring along door sill.
ended wire in driver side rear storage area (Jack/tools)
On the roof, ran all wires to the back.
removed rear gutter cover, cut access hole and ran wire under cover and through.
then ran down side in through door conduit
So far works well for me and reversable if need be.
Cheers!
T
vBulletin® v3.7.0 ©2000 - 2008, Jelsoft Enterprises Ltd.
©2000-2008 by IH8MUD.com LLC - ALL RIGHTS RESERVED
Free Engineering Ebooks | Discount Magazine | Myspace Layouts | eBay | Loans
