Go Back   IH8MUD™ Forums > Toyota Tech Forums > FJ Cruiser
Old 02-17-08, 09:32 AM   #1
imzjustplayin is on a distinguished road
Optimal MPG for FJ Cruiser
I'm creating this thread in hope that people will post the things they've noticed or they've done in order to get the best MPG from their FJ Cruiser. I'd be interested in hearing what MPG people get with their FJ at a given cruising speed. I have a sneaking suspicion that if you could drive the FJ at a constant 35mph, you'd get better mileage than had you continuously been driving at 55mph.
First off I would like to ask a question of my own:
When is overdrive enabled on the FJ cruiser? 35mph or 45mph? What speed does torque converter lockup occur at? And also, does the FJ allow the utilization of overdrive AND bring the RPMs down to 1000? It just seems like that once overdrive is enabled, the FJ sits at 1500RPM and climbs from there (depending on speed). Has anyone DYNO'ed the FJ cruiser yet? Does it have graphs from idle all the way to the rev limiter? I believe I saw one DYNO sheet but it started at 1500rpm and even then it didn't seem to make much sense in the numbers it had. 25lbs of torque at 1500rpm? Seriously?
'07 FJC, '91 FJ80
imzjustplayin is offline   Reply With Quote
Old 02-17-08, 05:14 PM   #2
tddfj's Avatar
tddfj is on a distinguished road
dont know if the overdrive is set for a certain speed. i live i a subdivision all the way at the back and at 25 mph it will go to 5th gear. and rpm drop to below 1000 a lot of timesi will put it in 4th gear when i am on streets for a good distance that are 25 to 35 mph because trans likes to shift a lot from 4th to 5th because of the electronic throtle and trans being tied together to work better. just getson my nerves.
tddfj is offline   Reply With Quote
Old 02-17-08, 06:44 PM   #3
I don't think it shifts into 5th gear at 25mph because I've noticed that once it gets to 34mph it will shift one more time.
'07 FJC, '91 FJ80
Old 02-17-08, 06:57 PM   #4
tddfj's Avatar
no i know forsure its in 5th because ive counted the shifts before you need to hold a steady speed for it shift to 5th.
Old 02-17-08, 07:17 PM   #5
I lurk there for I am!
Niner's Avatar
TLCA# 13372
Niner is an unknown quantity at this point
I think 5th gear at 25 and lock the converter at 35
Chris Hannis, TLCA #13372
2008 FJ Cruiser, Bud Built 5, Warn Bull Bar, 9.5TI, OME Heavies all around.
1971 FJ 40, 400 SBC, th400, Dana 20 Tcase, F/R Dana 44's, Front 4 link, rear spring over
1993 4 Runner (the Girlfriends) Stock for sale.
A bunch of stuff thats for sale
Niner is offline   Reply With Quote
Old 02-19-08, 01:02 PM   #6
Shaken - not stirred
Blues Dawg's Avatar
TLCA# 16271
Blues Dawg is on a distinguished road
No T/C for me. I've got a manual tranny. Stuff impacting mileage that I've noticed:
The Good - I changed the exhaust to a magnaflo muffler and installed the TRD CAI and gained about 1 mpg in the city and and went from about 16.5 to 19+ on the highway (cruising in the 70-75 range).
The Bad - BFG AT KO's Suck (gas). Second truck with these tires and the cost me at least 1-2 mpg on both.
Take into account I also am running the OME lift and OEM roof rack - both will impact aerodynamics and reduce mileage.
Carl
Yellow FJ Cruiser - a work in progress -
Copper State Cruisers #68
IBL8 & Procrastin8
Blues Dawg is offline   Reply With Quote
Old 02-19-08, 03:06 PM   #7
TLCA# 17556
spaldam is on a distinguished road
I've got the 6MT with TRD package (i.e. BFG's). I get around 15-16 on average, mostly freeway at around 70 MPH. I also can't go much slower then 45 in 6th without lugging the engine and that's on a slight decline. 5th does fine above 40ish.
Keep in mind that your driving habits will have a big effect too, and just because your going slow in a high gear doesn't mean you're getting really good gas mileage. If you travel faster, using the same amount of gas in the same amount of time, your MPG improves because the distance you traveled in that amount of time also improved. If you have to push on the peddle too much, you'll do better if you down shifted.
I once had a lifted '87 Toyota pickup 4x4 22R 5-speed, etc.
I latter had a '97 Tacoma X-cab V6 5-speed with all kinds of cool stuff on it.
I now have a '07 FJC TRD SE 6-speed completely stock, but still has some cool stuff on it.
Spaldam.com
spaldam is offline   Reply With Quote
Old 02-19-08, 04:24 PM   #8
DominicG is on a distinguished road
i went from 12mpg (before and after lift and 33"s) average to around 18mpg average. keep it under 2k rpm all around and your mileage will jump. 21-2200 rpm is where the gas starts to disappear fast
DominicG is offline   Reply With Quote
Old 02-19-08, 04:37 PM   #9
nashvegas is on a distinguished road
Dominicg- Did Your Engine Light Every Come On After Installing The Cold Air Intake. I Just Installed A K&n Cai And Both The Engine And Vsc Lights Are On. Any Ideas?
nashvegas is offline   Reply With Quote
Old 02-21-08, 08:54 AM   #10
Blues Dawg's Avatar
TLCA# 16271
It came on when I developed an air leak, effectively bypassing the filter. Had to have it reset. Also, apparently this may alos happen if you do the install without disconnecting the battery. Inspect for leaks in the air supply connections and if none found, try disconnecting the negative side of your battery and reconnect after about a minute.
Carl
IBL8 & Procrastin8
Old 02-22-08, 01:02 AM   #11
Well the only way to know how much fuel is being used depending on the RPM would be to hook up to the OBD and check, which is what I'm planning on doing, also doing a dyno would help tremendously.
I was just driving on the highway today at 55mph and mind you I had just filled my tank half way and already it has lost about 1/4 of that half tank which really pissed me off since I had only driven 37miles total! How accurate is this fuel guage? Two things, either its accuracy seems to change wildly or I am getting worse mileage when driving on the highway then when I'm driving in the city at 35mph which brings the engine down to around 1000rpm opposed to 1500rpm at 55mph.
'07 FJC, '91 FJ80
Old 02-23-08, 12:29 PM   #12
TLCA# 17556
The thing I would wonder about is that you only filled it to a half tank, or so you think. I find that fuel gages aren't very accurate when you first start the vehicle. To truly gage you're gas mileage you have to fill the tank all the way and pay attention to how much fuel when it, and how many miles you want from the last complete fill up. Keeping a running total also helps average out the discrepancies
Spaldam.com
Old 02-24-08, 04:08 PM   #13
The tank is 19 gallons, if I put in 8.7 gallons and the guage says that it's half way filled, I think I should believe it considering how late I am to fill up. One time when I did a full tank I got 19.002 Gallons and it's a 19 gallon tank! I still have the reciept.
'07 FJC, '91 FJ80
Old 02-26-08, 07:05 PM   #14
TLCA# 18830
Woodeye is on a distinguished road
You're a lucky guy! Let's go to the track or the casino! How do you get the FJ to the gas station with a totally empty tank?
Dick
Woodeye is offline   Reply With Quote
Old 02-27-08, 07:34 AM   #15
Blues Dawg's Avatar
TLCA# 16271
I'd question the calibration on the pump
IBL8 & Procrastin8
Old 02-27-08, 09:56 AM   #16
Blues Dawg's Avatar
TLCA# 16271
Did I mention I got rid of the BFG's (285/70/17) and put on Nitto T-Grapplers (315/75/16)? Well my odometer mileage went up! I'm now getting slightly more clock mileage w/ the Nittos so, when calibrated for size, I'm getting definitely better mileage.
IBL8 & Procrastin8
Old 03-04-08, 03:16 PM   #17
TLCA# 17556
I've got the 6speed manual (basically stock), and tried to follow you recommendation. I got slightly worse gas mileage (15.2 MPG - normally closer to 16 MPG). The very next tank full I took a mostly freeway trip (about 2hour of driving), at 75 MPH most of the way, putting the RPMs between 2500 - 3000, and I got 17.5 MPG.
P.S. I use a very precise MPG calculator (and costs tracking) program on my Treo, so I'm sure the numbers are accurate.
Spaldam.com
Old 03-08-08, 02:02 PM   #18
SurfPonto's Avatar
SurfPonto is on a distinguished road
With my MT6 I notice if I am able to keep it below 70 mph my mpg jumps.
I got close to 20 mpg when I did this. When I drive it hard it drops to 16 mpg/
Bob
http://www.anzaborrego.net
http://www.dieseltoy.com
  • 1985 CDM BJ70 LX. 2.5 inch lift, Safari Snorkel, 33s
  • 1977 FJ40 "MuMu" Kauai transplant (very stock)
    Tribute to MuMu
  • 2007 FJ Cruiser 6MT Diff Lock, Dobinson's 3" lift, Dual batteries
SurfPonto is offline   Reply With Quote
Old 04-28-08, 10:13 AM   #19
ckline's Avatar
TLCA# 18688
ckline is on a distinguished road
either that or somehow you coasted in on fumes and filled up to the cap?!?
Over the last week I have tried to keep the rmp's below 2k, in the city and highway. I gained maybe a half mile to a gallon vs the way I usually drive it...harder and faster. To me a half mpg isn't all that big of a deal.
Some of the other threads on the CAI are not showing as much of an increase in gas milage (sometimes only an exra mile a gallon). HOW are you guys pulling of 20mpg (what octain are you running)? Do you drive on completely flat land? I WANT 20 MPG, i just don't understand the variance between all the drivers. I have a 6, so its easy to monitor RPM's. Is the CAI truly worth it?
2007 Black FJ. Donahoe Racing coilover suspension lift, TRD CAI, Mangaflow Catback, ARB Bull Bumper, ARB ROOF RACK, ARB MOUNTS AND ROOF TENT, WARN winch, ARB sliders, American Eagle Wheels and Goodyear MT/R's 305/70/17's
ckline is offline   Reply With Quote
Old 05-01-08, 02:58 PM   #20
IBFJC's Avatar
TLCA# ???
IBFJC is on a distinguished road
MPG
Questioning fill ups now after reading this thread...Just filled up gas light was on, receipt said 14.99G...Did I have five gallons left with the light on...???...I do a lot of city driving...I went 239 miles with 19 gallons, I get 12.57 MPG...with 15 gallons I get 15.9 MPG...91 octane just went over $4...will have to keep a close eye on it...also trying lower octane...more to follow...
07 FJC, Black Cherry, AT, 4X4, stock but loaded...
74 VW Thing, 1935cc, Dual Solex Carb, Freeway Flyer trans...
03 Lexus ES300
85 Winnebago Class A, 23'...
IBFJC is offline   Reply With Quote
Old 05-01-08, 05:14 PM   #21
TLCA# 18830
Hey guys,
The first long trip I made with my 07 MT6 was from Lexington, KY. to Williansport, Pa. through KY, WV, MD, PA, and back. Loaded with some tools and a few suitcases for me and my honey. Nothin' but mountains all the way. Every tank full on the interstate at 70 mph on c ruise control, I got 20 and 20.5,20.7, 20.1 mpg. Around town, I get about 16-17.5 depending on how I play with the Jeeps and other 4x4's next to me. I've been burning the mid grade since she was new and tried the 91 and 92 octane a few times. Can't see any difference except when towing my 3500 lb trailer. Let's not talk about that mpg. I've used the 87 octane when the mid range isn't available. still can't see much difference. Most of the time I drive like an old fart, but I like to stomp thing too, especially next to a Jeep or Hummer.
One thing I don't do is let her warm up more than a minute or two, even in "0" deg. weather. According to the manual, it says not to warm up the rig just drive steady. Goes against my religion but you get zero mpg while ideling.
Woodeye
Old 05-03-08, 01:34 PM   #22
ckline's Avatar
TLCA# 18688
Woodeye
FREAKIN LOVE IT!!! CAN I GET AN AMEN?
I sacked up and got the TRD CAI. Changed the fluids to sythetic, since I found out that the 07 didn't run synthetic. Changed the spark plugs and got close to 20 mpgs on my last tank...not driving it much different than I used to. I'm gonna try the Woodeye "old fart" driving style and re-test to see if I get better than that.
Old 05-03-08, 06:46 PM   #23
TLCA# 18721
Mountainclimber is on a distinguished road
Amen Brother!
I've been putting off buying one of those TRD CAI's but I may just have to do that this spring.
20 is a good thing. I bet with full synthetics, a non-aggressive driving style, and just generally easing around in the thing, you may get even better than that.
It is really difficult to keep my foot out of the throttle just because its just so much fun. But at a price.
Eric
KJ4ETF
TLCA 18721
07 FJC 6MT So far pretty standard.
Looks like this FJ is going to be a money pit.
Mountainclimber is offline   Reply With Quote
Old 05-03-08, 08:58 PM   #24
REKCUT's Avatar
TLCA# 13816
REKCUT is on a distinguished road
I just drove 298 miles on I44 interstate right at 80mph the whole way. The gas guage was just above e and the light had just turned on when i pulled into the gas station. Only took 14.7 gallons so I must be able to go below the empty mark. By may calculations thats 20.272 miles tothe gallon. Not very flat going into st louis either. I am running revo 285's
Thad Brown/ Rogersville Mo
84 FJ 60 / SROR sides and rear / beauty marks from RR, FN, & LSCR / Free bumper from GCC and Locker from LSCR/
07 FJ
08 Tundra Rocket ship
Green Country Cruisers
REKCUT is offline   Reply With Quote
Old 05-03-08, 09:00 PM   #25
REKCUT's Avatar
TLCA# 13816
Also running royal purple if that add to it.
07 FJ
Old 05-03-08, 09:07 PM   #26
