06-28-07, 02:03 PM
| | Site Addict
| How High is "Too High" to lift my FJ? My FJ is my daily driver as well as my off road toy. I wheel it almost every weekend and need to add some additional lift. I've never lifted a rig before and don't know how much lift will make it overly top heavy. I'd rather not role my FJ while side hilling and I'd also like to not have to replace my drive shafts or anything extra. |
06-28-07, 02:13 PM
| | 250+ Club
| right now pretty much everyone is offering 3" of lift if you're looking for an actual suspension lift. spacers can give you an additional inch but taht doesnt really give you any extra travel, infact just a little less. there is a 6" kit that is out (i think its tough country's) but its a drop bracket lift so you're ground clearance isint really all that improoved. personally i'd like 4.5" of pure suspension but i think that if you go over 3" it will require a drop bracket for the front susp. or at least different controll arms or axles. anyone correct me if i'm wrong here.
__________________ 2007 FJC "the short bus" friggin yellow!
AT/4x4
factory locker
A-TRAC mod TuT Pirate. the Amish do it with Hoes. |
06-28-07, 02:55 PM
| | Site Addict
| And i've read all 6" kit requires 18" wheels! |
06-28-07, 03:46 PM
| | Forum Lifer
| Quote:
Originally Posted by eleblanc And i've read all 6" kit requires 18" wheels! | Howdy! Our club has several lifted and very lifted FJ's, and I can't see any mechanical reason to to to bigger wheels. They are not changing the O.D. of the brakes, and that is what prescribes the wheel size. John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!!
85 Toyota mini truck  for chase/support!
CSC #41 |
06-28-07, 04:53 PM
| | 250+ Club
| What type of trails are you going on?
How much off camber stuff you do?
How big of a problem has ground clearance been?
What type of ground clearance problems have you had? approch&Brake over angles or just dragging the belly of the truck
my thougts are to keep the CG as low as you can while still giving you the clearance you require |
06-28-07, 05:37 PM
| | Site Addict
| Quote:
Originally Posted by inkpot Howdy! Our club has several lifted and very lifted FJ's, and I can't see any mechanical reason to to to bigger wheels. They are not changing the O.D. of the brakes, and that is what prescribes the wheel size. John | When you start messing with struts through, does that change the game? |
06-28-07, 07:09 PM
| | Site Addict
| Quote:
my thougts are to keep the CG as low as you can while still giving you the clearance you require | Most of the runs I've been on have been Rock crawlin' and such. I have run the back half of Mc Grew a couple of times and trails of the like. So far I've replaced my tail pipe three times as it hangs too low, but that could be corrected in other ways. Mainly my muffler has been banged up pretty badly and I'm pretty concerned about my fuel tank as it hangs fairly low, so I take most of the abuse on my passanger side under carriage. I do side hill quite a bit as well so I'm trying to find the best of both worlds...that's why I chose an FJ because it is as close to perfec stock as you can get. |
06-29-07, 07:19 AM
| | Site Addict
| Quote:
Originally Posted by inkpot Howdy! Our club has several lifted and very lifted FJ's, and I can't see any mechanical reason to to to bigger wheels. They are not changing the O.D. of the brakes, and that is what prescribes the wheel size. John | From what i've read on fjcruiserforum all the 5-6" kit available have long knuckle / tie-rod direction and requires larger diameter rims. Maybe a good spacer or a large offset wheel solves it. any how i have no experience, just what i have read. Because i was looking/evaluating cost to raise a FJ up to 6", and the 18" wheel requirement is not really pratical for serious offroading. If there is a way around this i'd like to know. |
06-29-07, 07:50 AM
| | 250+ Club
| Quote:
Originally Posted by knoll0351 Most of the runs I've been on have been Rock crawlin' and such. I have run the back half of Mc Grew a couple of times and trails of the like. So far I've replaced my tail pipe three times as it hangs too low, but that could be corrected in other ways. Mainly my muffler has been banged up pretty badly and I'm pretty concerned about my fuel tank as it hangs fairly low, so I take most of the abuse on my passanger side under carriage. I do side hill quite a bit as well so I'm trying to find the best of both worlds...that's why I chose an FJ because it is as close to perfec stock as you can get. | I went with more armor, high clearance tail pipe, and a 3" lift, as I travel on a little of everything and have been happy with it so far...
hope this helps |
06-29-07, 09:01 AM
#10 (permalink)
| | Site Addict
| Quote:
Originally Posted by BC_FJC I went with more armor, high clearance tail pipe, and a 3" lift, as I travel on a little of everything and have been happy with it so far...
hope this helps | That's what I was thinking, thank you for the first hand information. :-) I was looking OME, which kit did you use and did you just go springs and shocks or did you purchase new struts as well? |
06-29-07, 10:01 AM
#11 (permalink)
| | 250+ Club
| Quote:
Originally Posted by BC_FJC my thougts are to keep the CG as low as you can while still giving you the clearance you require | I agree. That's why you should only do as much lift as is needed for the size of tire you want, because bigger tires are what truly improve ground clearance. Having more lift then you need might look cool, but from a functionality point of view it only makes you top heavy. I've always thought that doing a little bit of trimming was better then an extra inch or two of lift. I'm planning on 285/75/16's (33") with no lift on my FJC once my stock tires ware out (or if someone what’s to trade). If I do lift it'll be no more then 3", and I'll expect to be able to put 315/75/16's (35") on it at that point (with a wheel spacer, and a little trimming). If you do go with a 6" lift that requires 18" wheels, than I'd expect you'd want to put on some massive tires like 335/75/18 (38"). You'd still have a good amount of sidewall with that, but you'd also need some massive off-sets on your wheels. Here's a calculator to help out with the measurements: http://www.miata.net/garage/tirecalc.html |
06-29-07, 10:55 AM
#12 (permalink)
| | 250+ Club
| Quote:
Originally Posted by knoll0351 That's what I was thinking, thank you for the first hand information. :-) I was looking OME, which kit did you use and did you just go springs and shocks or did you purchase new struts as well? | I went with the All-Pro, http://www.allprooffroad.com/index.p...sk=view&id=131, but the OME is a good kit to. |
06-29-07, 07:07 PM
#13 (permalink)
| | Forum Regular
| Quote:
Originally Posted by FJTex right now pretty much everyone is offering 3" of lift if you're looking for an actual suspension lift. spacers can give you an additional inch but taht doesnt really give you any extra travel, infact just a little less. there is a 6" kit that is out (i think its tough country's) but its a drop bracket lift so you're ground clearance isint really all that improoved. personally i'd like 4.5" of pure suspension but i think that if you go over 3" it will require a drop bracket for the front susp. or at least different controll arms or axles. anyone correct me if i'm wrong here. | There is a Rough Country 6" lift, but it's not for sale to the public yet. |
06-29-07, 07:16 PM
#14 (permalink)
| | Benevolent Dictator
| In my opinion....
3-4" lift is perfect for anything your pocketbook is willing to accept for body damage....
spend money on sliders....FULL skid plates.....front bumper/winch.....rear bumper....control arm bracket skids....aftermarket rear lower control arms....spare front CV.... The Team's run products from RevTek, ARB, Warn, Toyota, BudBuilt, AllPro...mmm....I think that's it....lol
then, some research regarding fitting 295-305-315 size tires and the options available....
"more lift" does nothing...proper protection will get you a long ways....the Trail Team proves this continually...Gustaf and I took a pair of Team FJ's thru Lower2 in Tellico and thoroughly tested our sliders and skids...a more aggressive tire than the BFG-AT would have been nice, but more lift would have made minimal difference.
__________________ Brian 'woody' Swearingen - IH8MUD.com - ROCKCRAWLER.com - 1974 FJ40 'The Raisin' - 39" Pitbull Maddogs, 17x9 TrailReadys, 30-spline Longfields, SOA - 1/4 ellip, Ultimate Air, MobiArc, Optima RedTop
- 1996 FZJ80 'Gretchen' - MetalTech sliders, MetalTech tube front, MileMarker V10 MiFi, OME lift, IPOR rear & skid, 4x4Labs swings, INTI rack, dual Optima RedTops, 285 Guard Dog MT's w/ Kedge, Ultimate Air, Raingler Barrier
- 2009 buggy....designing... RockCrusher60's
- 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Hankook DynaPro ATM, KYB MonoMax, 4" exhaust
- 2008 32' ABU Gooseneck car hauler, 2000 Damon Hornet M-32F, 1997 Shadow Cruiser, 1997 14' car hauler
"There is a very fine line between hobby and mental illness." |
06-29-07, 07:18 PM
#15 (permalink)
| | Forum Regular
| Quote:
Originally Posted by eleblanc And i've read all 6" kit requires 18" wheels! | Quote:
Originally Posted by eleblanc From what i've read on fjcruiserforum all the 5-6" kit available have long knuckle / tie-rod direction and requires larger diameter rims. Maybe a good spacer or a large offset wheel solves it. any how i have no experience, just what i have read. Because i was looking/evaluating cost to raise a FJ up to 6", and the 18" wheel requirement is not really pratical for serious offroading. If there is a way around this i'd like to know. | The Rough Country 6" does not require 18" wheels. I have 17" American Racing Victor's with 33 x 12.50 Mickey Thompson BAJA MTZ's. |
06-29-07, 08:07 PM
#16 (permalink)
| | 250+ Club
| Quote:
Originally Posted by spaldam I agree. That's why you should only do as much lift as is needed for the size of tire you want, because bigger tires are what truly improve ground clearance. Having more lift then you need might look cool, but from a functionality point of view it only makes you top heavy. I've always thought that doing a little bit of trimming was better then an extra inch or two of lift. I'm planning on 285/75/16's (33") with no lift on my FJC once my stock tires ware out (or if someone what’s to trade). If I do lift it'll be no more then 3", and I'll expect to be able to put 315/75/16's (35") on it at that point (with a wheel spacer, and a little trimming). If you do go with a 6" lift that requires 18" wheels, than I'd expect you'd want to put on some massive tires like 335/75/18 (38"). You'd still have a good amount of sidewall with that, but you'd also need some massive off-sets on your wheels. Here's a calculator to help out with the measurements: http://www.miata.net/garage/tirecalc.html |
Runner Ryan runs 37" krawlers with 3" of lift on his FJ (or at least he DID) if you do a search you can find a thread detailing where and how much he trimmed for it. FWIW.
AT/4x4
factory locker
