05-28-08, 12:32 PM
#151 (permalink)
UC Webmaster
the springs and starter are back. The total on the springs came to just under $200, and they look pretty good. We'll see how they hold up once i get them under the truck. I am waiting on new poly bushings and greasable pins and shackles from SOR. Here are the before and after shots.
I also had the starter rebuilt to 12V for $165.
05-28-08, 08:05 PM
#152 (permalink)
What a difference in the springs. I hope they sit where you want.
Are going SOA? Or would that be too much lift?
-Josh
94' FZJ80, Locked X3, OME 850J/N73L, OME 863J/N74L, Marlinks, 37x13.50x17 Nitto Mud Grapplers, Herculined Everything!
04' Ford F-350 6.0 Turbo Diesel King Ranch Fx4, 12.5" Icon, 47x15.50x20 Michelin XML's!!!
The Mid Atlantic Toyota Land Cruiser Association at www.matlca.com
05-28-08, 10:03 PM
#153 (permalink)
-Josh
huh? why would he go SOA? he is having to put these springs in temporary until he has more time to set up the coils.
'93 FZJ 39K miles - 850/860, Bilies, LED tails, & 285 MTRs Lightforce 240s waiting on a bumper.
'89 FJ62 - 4" Alcan, 33" BFG MT's, 4.88's, Lockright (rear), 4runner calipers. FOR SALE
'97 4Runner SR5 - 4x4, leather, Toyo AT, TJM T15, LF 240s.
'83 FJ60 4parts - DooDoo Brown in and out FOR SALE!
'63 Biscayne Wgn - Kandy Green & Tweed. Family Wagon 3rd row in the garage.
Erskine College Upstate Cruisers
05-29-08, 06:36 AM
#154 (permalink)
Looks good Gehn
If you need any help this weekend just give me a shout.
John
05-29-08, 07:59 AM
#155 (permalink)
UC Webmaster
-Josh
SOA would be way too much lift. For expedition use, I don't want to run anything bigger than 33"s.
Originally Posted by jleeFJ62
Looks good Gehn
John
Thanks man, I am out of town until saturday, but I'll let you know.
05-29-08, 09:38 PM
#156 (permalink)
I wasn't sure how much lift that gives a 62 ... I though I'd ask ...
05-30-08, 06:23 AM
#157 (permalink)
UC Webmaster
SOA on a 60/62 is usually 5-6" minimum, enough to clear 37"s.
05-30-08, 01:59 PM
#158 (permalink)
I love the color, I love the 1hz conversion. I am glad to see that you are keeping it Toyota, I cant wait to see the coil set-up.
Keep up the awesome work. Thanks for the thread
Aaron
2.5 OME Heavy coils, ARB rear locker PRADO STOLEN
 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low 33" Yokohama MTpluses 60" HI-LIFT
with MAGELLAN 1500 TRITON with JUNGLE GHOST maps. OH YA I'M ALSO A JUNIOR MEMBER OF COASTAL CRUISERS!
06-03-08, 08:08 PM
#159 (permalink)
UC Webmaster
06-03-08, 08:40 PM
#160 (permalink)
did you do any paint prep before applying rust bullet?
94 FZJ80 - 200k+ miles, Sleed 6", 325/85/16 XMLs the moveable yard ornament.
LQ9, NV4500, 4speed Atlas, 1 TONs, 40s, in near future
Be informed about ButylFuel
"my AAD (Advanced Automotive Disorder) has grown worse"
-IPOR-
06-04-08, 06:22 AM
#161 (permalink)
UC Webmaster
As far a using other products, no. I just made sure the surfaces were as clean as possible and scuffed up the smooth spots a little. It seemed to adhere pretty well, and it dries really hard.
06-04-08, 05:14 PM
#162 (permalink)
Wow, just saw this thread. I'm so jealous. What mpg do you get with your 1hz?
89 FJ62- w/ an H42 and other stuff
06-04-08, 06:51 PM
#163 (permalink)
UC Webmaster
Before I parked it about a year ago, I averaged about 21mpg mixed driving. The best I ever got was 25, the worst 18.
06-04-08, 07:37 PM
#164 (permalink)
UC Webmaster
I had two sets of the long fluid lines (one brake line, two fuel lines) that run front to rear along the frame, one set from a 62 I parted out a few years ago, and the ones from the FJ60. I used the 60 brake line, but chose the fuel lines from the 62 because they are the same size as the one on the HJ (the FJ lines were smaller) and they install a little cleaner running parallel the whole way down the frame. In order to make it work, I had to add a couple bends around the new tranny x-member brackets..
My suspension components arrived as well, so I installed the front springs.
It's hard to say how much lift I ended up with until I get the rear springs installed, but here's what I am using...
Front:
- Re-arched springs (6 leaves)
- Greaseable pins
- SOR 1.5" over "Performance" shackles with greaseable bolts
- 2.5 deg, caster shims
- Poly bushings
Rear:
- Re-arched springs (7 leaves)
- Greaseable pins
- SOR 2.5" over "Performance" shackles with greaseable bolts
- Poly bushings
06-04-08, 10:42 PM
#165 (permalink)
lookin really good bud
'these are my awards, mother, from army. the seal is for marksmanship and the gorilla is for sand racing.'
...build-up here (stalled)...
06-05-08, 06:39 PM
#166 (permalink)
er should have phrased question differently did you use any mechanical means sandin, wire brush. ect...
-IPOR-
06-05-08, 07:39 PM
#167 (permalink)
UC Webmaster
no, there was no rust and the surface was rough enough for the rust bullet to adhere to. All I did was clean it up and brush on the black shell.
06-05-08, 08:13 PM
#168 (permalink)
UC Webmaster
I installed the fuel tank and small push pump. The pump is made by Carter and was on the FJ when I bought it, but summit carries them. It comes with a pre-strainer.
I mounted it just in front of the fuel tank along the right hand frame rail, right where the tank outlet and return hoses are located.
The fuel line I am using is Dayco Gen-2 fuel injection hose which is rated for biodiesel and can be found at Pepboys. Just make sure it's the Gen-2 fuel injection stuff.
I also ended up buying a new fuel filter. The old one is a Racor 445MAM which is a marine filter. I bought it off ebay a few years ago and it has worked well, but wasn't quite what I was expecting. Here's the old one...
The new one is a Racor 245R. It is similar to the 445 with a primer pump and 45gph flow capacity, but has a few additional features.
This one came with a 2 micron element (10 and 30 mic elements are available for this model as well), and a 12V heater in a transparent bowl.
It has an easier drain mechanism too which you can open with your fingers so you don't have to fuss with getting a wrench on it. There is also a port for a water sensor you can buy separately. Overall, it's not much smaller than the 445MAM. If anything, it may be a bit longer, but narrower and the top assy less bulky.
The best price I found was through B-Line Filter. I bought the 245R122 which comes with the 12V heater and 2 mic filter for $142.67. Replacement elements appear to cost about $20.
06-08-08, 07:34 PM
#169 (permalink)
UC Webmaster
Here are a couple shots of the suspension. The fuel tank is empty and there's no interior, but there's clearly plenty of room for them to settle...
Next to the now roughly stock-height HJ...
The rear....
the front...
06-11-08, 08:59 PM
#170 (permalink)
UC Webmaster
I've been working on a bunch of small stuff recently while I wait for parts to come in, mostly cleaning. I started reassembling the under dash, and found some pretty good stuff to replace the deteriorated foam duct gaskets. It's foam duct wrap I got at home depot and cost about $6.
Here's a shot of it installed. What's left ofl the original stuff is still on the left for comparison.
I also put the front end back together. It's Starting to look like a cruiser again...
06-13-08, 08:29 AM
#171 (permalink)
UC Webmaster
06-13-08, 09:13 AM
#172 (permalink)
only if i had the time to do that to my 80
-IPOR-
06-13-08, 05:46 PM
#173 (permalink)
Rookie
Schpedoinkle!
06-16-08, 06:15 AM
#174 (permalink)
UC Webmaster
The fuel system in finished. I installed the new filter and bent up some hard line to wrap behind the engine along the firewall.
the larger one with insulation is the feed, and the small one is the return.
a shot of the driver side...
I also swapped over the lower dash, and hooked up the battery to start the wiring process.
06-16-08, 07:33 AM
#175 (permalink)
UC Webmaster
FYI, I edited the first post adding a tech outline and some direct links.
06-16-08, 11:48 PM
#176 (permalink)
Looking REALLY nice. Be proud of it... Can't wait to see some more updates!
no cruiser right now :(
1995 Volvo 850 Turbo
defender of the good, mo-fessional drunk, total art-fag, and all around nice guy...
06-20-08, 07:25 AM
#177 (permalink)
UC Webmaster
Sorry, I have been elbow deep in the wiring harness for the last few days. I'll have an update soon...
06-20-08, 03:18 PM
#178 (permalink)
Awesome work, this is going to be a beauty!
And thanks for the diligent sharing
'01 LC - Champagne Pearl
'96 328is - Alpine White
Dearly departed - '88 FJ-62
06-20-08, 11:35 PM
#179 (permalink)
Not sure if this stuff is cheap or not, but my father owns an Armacell plant. Let me know if you need anymore armaflex, or armaflex tape for whatever it costs to ship it. I have it everywhere around here it feels..
Ryan
Ryan
96 FZJ80... Firestone Destination MT 285/75, Linexed.. Thats it, for now
69 FJ55... 8 inches custom lift.  Project Crawler
ONSC
06-21-08, 06:51 AM
#180 (permalink)
UC Webmaster
Ryan
it's not expensive. That roll cost a little over $6 and I still have some left over. It's good stuff to keep around. Thanks though!
